    fishbot 导航
    67
    239
    986.5k
      小鱼 技术大佬 @rex.chen80
      @rex-chen80 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
      fishbot_interfaces
      删除下这个功能包试试
        鱼哥,我在执行这段代码:ros2 launch fishbot_navigation2 navigation2.launch.py
        发生报错:
        launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/jws/fishbot/fishbot/install/fishbot_navigation2', '/home/jws/fishbot/fishbot/install/fishbot_interfaces', '/home/jws/fishbot/fishbot/install/fishbot_description', '/home/jws/fishbot/fishbot/install/fishbot_cartographer', '/home/jws/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
        好像是缺少一个功能包:nav2_bringup
        后来我搜了GPT,执行了:sudo apt install ros-foxy-nav2-bt-navigator(运行成功了)
        后来再回来执行:ros2 launch fishbot_navigation2 navigation2.launch.py
        还是原来的找不到“nav2_bringup”包这个错误。
        该怎么解决啊😭
          小鱼 技术大佬 @18296522393
          @18296522393 建议用humble版本,另外需要单独装一下nav2_bringup,你可以看最新的视频或书,7.2章节有介绍命令。
          • 16347699901
            西林街 @1683127550
            @1683127550 请问解决了吗?
            Y 1 条回复 最后回复 回复 引用 0
              yongyong @1683127550
              @1683127550 你这个解决了吗
                yongyong
                  小鱼 技术大佬 @yongyong
                  @yongyong 把终端日志拿出来看看
                    2075605318 年度VIP
                    lwb@Lwb:~/fishbot_nav$ colcon build
                    Starting >>> fishbot_bringup
                    Finished <<< fishbot_cartographer [0.09s]
                    Finished <<< fishbot_navigation2 [0.09s]
                    Finished <<< fishbot_description [0.11s]
                    Finished <<< fishbot_bringup [0.13s]
                    File "/home/lwb/fishbot_nav/build/fishbot_interfaces/ament_cmake_python/fishbot_interfaces/setup.py", line 4, in <module>
                    setup(
                    return run_commands(dist)
                    dist.run_commands()
                    self.run_command(cmd)
                    super().run_command(command)
                    cmd_obj.run()
                    self.find_sources()
                    mm.run()
                    self.prune_file_list()
                    super().prune_file_list()
                    gmake[2]: *** [CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/build.make:70:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg] 错误 1
                    gmake[1]: *** [CMakeFiles/Makefile2:447:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/all] 错误 2
                    gmake[1]: *** 正在等待未完成的任务....
                    Failed <<< fishbot_interfaces [0.39s, exited with code 2]
                    Summary: 4 packages finished [0.52s]
                    按照步骤来的这个interface一直编译不过是不是源代码有语法错误
                    • A atjason 在 中 引用了 这个主题
                      yongyong
                      832e5f7a-31e8-4e32-b361-fd8e7f1c17db-image.png file:///home/lyy/%E5%9B%BE%E7%89%87/%E6%88%AA%E5%9B%BE/%E6%88%AA%E5%9B%BE%202025-03-29%2014-32-11.png
                      这个出了什么问题啊
                        yongyong @1634769990
                        @1634769990 你解决了吗
                          可以实现导航功能,但不准确。而且雷达会报error ,不知道有哪位大神可以指点如何解决。
                          [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x59BC != 0x8FAA
                          [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x0199 != 0x4A68
                          [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x45A6 != 0x493D
                          [ydlidar_node-2] [2025-04-05 01:04:55][error] Check Sum 0x73D6 != 0x5C76
                          [ydlidar_node-2] [2025-04-05 01:05:30][error] Check Sum 0x0077 != 0x3023
                          [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6D00 != 0x7940
                          [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6874 != 0x64AF
                          [ydlidar_node-2] [2025-04-05 01:05:59][error] Check Sum 0x75C8 != 0x6DCC
                          [ydlidar_node-2] [2025-04-05 01:06:03][error] Check Sum 0x69BA != 0x6FB2
                          [ydlidar_node-2] [2025-04-05 01:06:34][error] Check Sum 0x1C86 != 0x0D49
                          [ydlidar_node-2] [2025-04-05 01:06:39][error] Check Sum 0x60F6 != 0x4492
                          [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x01A6 != 0x2E11
                          [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x6C28 != 0x0F78
                          [ydlidar_node-2] [2025-04-05 01:07:02][error] Check Sum 0x6450 != 0x6A17
                          [ydlidar_node-2] [2025-04-05 01:07:03][error] Check Sum 0x7495 != 0x4DBD
                          [ydlidar_node-2] [2025-04-05 01:07:13][error] Check Sum 0x7516 != 0x71E2
                          [ydlidar_node-2] [2025-04-05 01:07:22][error] Check Sum 0x1D3E != 0x5AEA
                            小鱼 技术大佬 @165437424
                            @165437424 最近会更新下雷达驱动,这个偶尔出现一次没问题
                              2768003759 @1250372262
                                2768003759 @2768003759
                                  @1250372262 在 [FishBot教程]9.0.7. FishBot-Nav2导航测试 中说:
                                  建图都是没有问题的了 然后我按照导航测试那块 启动了fishbot_bringup 然后把地图换了,启动导航的时候地图能加载出来,但是点击2D Pose Estimate的时候,界面没有反应,不像之前那样了,并且也不能导航
                                  也是这个问题
                                    小鱼 技术大佬 @2768003759
                                    @2768003759 导航的时候雷达驱动,底盘驱动之类的都不能关闭,先检查各个话题数据是否正常,然后检查tf是否正常
                                    • 法
                                      法大
                                      @小鱼 鱼哥启动microros错误什么原因
                                      d13f47f6-fd4c-4493-bb50-66cbb34dc8b6-image.png 之前都能成功
                                        小鱼 技术大佬 @法大
                                        @法大 右上角搜 bind error ,你不复制粘贴,我就不帮你搜了
                                          yongyong
                                          ff5e16e4-842d-4b04-901a-6303eea07fba-df21491475416b2d93cb8204bf4524a8.png 请问出现了什么问题
                                            b447920d-3d05-47b0-a349-ffe630a8b3a4-image.png 使用ros2 launch fishbot_navigation2 navigation2.launch.py use_sim_time:=False指令终端出现这个问题,用的是git下来的例程。在rviz2中使用2D POSE ESTIMATE也无法看见雷达信息和代价地图。
                                            单独launch bringup_quick.launch.py文件5c046968-b3f9-4e3d-b6b6-a86551bd7d93-image.png
                                            话题中没有robot_description话题,ros2 topic echo /odom没有返回消息,请问这是什么原因?
                                            1 小鱼小 3 条回复 最后回复 回复 引用 0
