    fishbot 导航
    67
    239
    903.4k
      小鱼 技术大佬 @2462331351
      @2462331351 图太乱了,没有空间给小车走
      • H
        yaoyao ROS2开发者 @小鱼
        @小鱼 感谢小鱼,问题已解决
        • R
          ros_freshman 年度VIP @921203724
          @921203724 你这个问题解决了吗,我出现了同样的问题。@小鱼
          • R
            ros_freshman 年度VIP
            出现这个错误了,该怎么解决呢?rosdep已经用一键安装配置好了。
              小鱼 技术大佬 @ros_freshman
              @ros_freshman 可以跳过
              • R
                rex.chen80
                我使用的fishros镜像系统。
                但是colcon编译一直报错。有没有整合好的代码可以运行?
                ~ » git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                正克隆到 'fishbot'...
                接收对象中: 100% (84/84), 332.98 KiB | 1.81 MiB/s, 完成.
                处理 delta 中: 100% (21/21), 完成.
                ~ » cd fishbot
                fishbot (v1.0.0 o) » rosdep install --from-paths src --ignore-src -y -r # 安 装依赖
                fishbot (v1.0.0 o) » colcon build
                Starting >>> fishbot_bringup
                Finished <<< fishbot_description [0.60s]
                Finished <<< fishbot_cartographer [0.71s]
                Finished <<< fishbot_navigation2 [0.84s]
                execute_process(/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/l/j/h/bin/python3
                -m rosidl_adapter --package-name fishbot_interfaces --arguments-file
                /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter__arguments__fishbot_interfaces.json
                --output-dir
                /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces
                --output-file
                /home/fishros/fishbot/build/fishbot_interfaces/rosidl_adapter/fishbot_interfaces.idls)
                returned error code 1:
                AttributeError processing template 'srv.idl.em'
                File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/resource/__init__.py", line 48, in evaluate_template
                  _interpreter = em.Interpreter(
                AttributeError: module 'em' has no attribute 'Interpreter'
                File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 196, in _run_module_as_main
                File "/home/fishros/.x-cmd.root/local/data/pkg/sphere/X/tree.linux.x64.0/miniconda/v3.10.0+23.9.0-0/lib/python3.10/runpy.py", line 86, in _run_code
                  exec(code, run_globals)
                  sys.exit(main())
                File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/__init__.py", line 24, in convert_to_idl
                  return convert_srv_to_idl(
                File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_adapter/srv/__init__.py", line 39, in convert_srv_to_idl
                  expand_template('srv.idl.em', data, output_file, encoding='iso-8859-1')
                  _interpreter.shutdown()
                Failed <<< fishbot_interfaces [0.89s, exited with code 1]
                Aborted <<< fishbot_bringup [1.08s]
                Summary: 3 packages finished [1.24s]
                1 package aborted: fishbot_bringup
                  小鱼 技术大佬 @rex.chen80
                  @rex-chen80 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                  fishbot_interfaces
                  删除下这个功能包试试
                    鱼哥,我在执行这段代码:ros2 launch fishbot_navigation2 navigation2.launch.py
                    发生报错:
                    launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/jws/fishbot/fishbot/install/fishbot_navigation2', '/home/jws/fishbot/fishbot/install/fishbot_interfaces', '/home/jws/fishbot/fishbot/install/fishbot_description', '/home/jws/fishbot/fishbot/install/fishbot_cartographer', '/home/jws/fishbot/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
                    好像是缺少一个功能包:nav2_bringup
                    后来我搜了GPT,执行了:sudo apt install ros-foxy-nav2-bt-navigator(运行成功了)
                    后来再回来执行:ros2 launch fishbot_navigation2 navigation2.launch.py
                    还是原来的找不到“nav2_bringup”包这个错误。
                    该怎么解决啊😭
                      小鱼 技术大佬 @18296522393
                      @18296522393 建议用humble版本,另外需要单独装一下nav2_bringup,你可以看最新的视频或书,7.2章节有介绍命令。
                      • 16347699901
                        西林街 @1683127550
                        @1683127550 请问解决了吗?
                        Y 1 条回复 最后回复 回复 引用 0
                          yongyong @1683127550
                          @1683127550 你这个解决了吗
                            yongyong
                              小鱼 技术大佬 @yongyong
                              @yongyong 把终端日志拿出来看看
                                2075605318 年度VIP
                                lwb@Lwb:~/fishbot_nav$ colcon build
                                Finished <<< fishbot_cartographer [0.09s]
                                Finished <<< fishbot_navigation2 [0.09s]
                                Finished <<< fishbot_description [0.11s]
                                Finished <<< fishbot_bringup [0.13s]
                                File "/home/lwb/fishbot_nav/build/fishbot_interfaces/ament_cmake_python/fishbot_interfaces/setup.py", line 4, in <module>
                                setup(
                                return run_commands(dist)
                                dist.run_commands()
                                self.run_command(cmd)
                                super().run_command(command)
                                cmd_obj.run()
                                self.find_sources()
                                mm.run()
                                self.prune_file_list()
                                super().prune_file_list()
                                gmake[2]: *** [CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/build.make:70:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg] 错误 1
                                gmake[1]: *** [CMakeFiles/Makefile2:447:CMakeFiles/ament_cmake_python_build_fishbot_interfaces_egg.dir/all] 错误 2
                                gmake[1]: *** 正在等待未完成的任务....
                                Failed <<< fishbot_interfaces [0.39s, exited with code 2]
                                Summary: 4 packages finished [0.52s]
                                按照步骤来的这个interface一直编译不过是不是源代码有语法错误
                                • A atjason 在 中 引用了 这个主题
                                  yongyong
                                  832e5f7a-31e8-4e32-b361-fd8e7f1c17db-image.png file:///home/lyy/%E5%9B%BE%E7%89%87/%E6%88%AA%E5%9B%BE/%E6%88%AA%E5%9B%BE%202025-03-29%2014-32-11.png
                                  这个出了什么问题啊
                                    yongyong @1634769990
                                    @1634769990 你解决了吗
                                      可以实现导航功能,但不准确。而且雷达会报error ,不知道有哪位大神可以指点如何解决。
                                      [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x59BC != 0x8FAA
                                      [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x0199 != 0x4A68
                                      [ydlidar_node-2] [2025-04-05 01:04:07][error] Check Sum 0x45A6 != 0x493D
                                      [ydlidar_node-2] [2025-04-05 01:04:55][error] Check Sum 0x73D6 != 0x5C76
                                      [ydlidar_node-2] [2025-04-05 01:05:30][error] Check Sum 0x0077 != 0x3023
                                      [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6D00 != 0x7940
                                      [ydlidar_node-2] [2025-04-05 01:05:51][error] Check Sum 0x6874 != 0x64AF
                                      [ydlidar_node-2] [2025-04-05 01:05:59][error] Check Sum 0x75C8 != 0x6DCC
                                      [ydlidar_node-2] [2025-04-05 01:06:03][error] Check Sum 0x69BA != 0x6FB2
                                      [ydlidar_node-2] [2025-04-05 01:06:34][error] Check Sum 0x1C86 != 0x0D49
                                      [ydlidar_node-2] [2025-04-05 01:06:39][error] Check Sum 0x60F6 != 0x4492
                                      [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x01A6 != 0x2E11
                                      [ydlidar_node-2] [2025-04-05 01:06:56][error] Check Sum 0x6C28 != 0x0F78
                                      [ydlidar_node-2] [2025-04-05 01:07:02][error] Check Sum 0x6450 != 0x6A17
                                      [ydlidar_node-2] [2025-04-05 01:07:03][error] Check Sum 0x7495 != 0x4DBD
                                      [ydlidar_node-2] [2025-04-05 01:07:13][error] Check Sum 0x7516 != 0x71E2
                                      [ydlidar_node-2] [2025-04-05 01:07:22][error] Check Sum 0x1D3E != 0x5AEA
                                        小鱼 技术大佬 @165437424
                                        @165437424 最近会更新下雷达驱动,这个偶尔出现一次没问题
                                          2768003759 @1250372262
                                            2768003759 @2768003759
