    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    92.7k
      2075605318 年度VIP
      lwb@Lwb:~$ cd ~/fishbot_ws/
      source install/setup.bash
      Starting >>> yolov5_ros2
      /home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
      warnings.warn(msg)
      [0.351s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
      --- stderr: yolov5_ros2
      warnings.warn(msg)
      File "/home/lwb/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module>
      setup(
      return run_commands(dist)
      dist.run_commands()
      self.run_command(cmd)
      super().run_command(command)
      cmd_obj.run()
      self.find_sources()
      mm.run()
      self.prune_file_list()
      super().prune_file_list()
      Failed <<< yolov5_ros2 [0.84s, exited with code 1]
      Summary: 0 packages finished [0.96s]
      1 package failed: yolov5_ros2
      1 package had stderr output: yolov5_ros2
      lwb@Lwb:~/fishbot_ws$ ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
      Package 'yolov5_ros2' not found
      编译时报错,yolov5已安装,前面的步骤没有问题
        2075605318 年度VIP
        @小鱼 在 [FishBotCamera]3.结合YOLO实现检测 中说:
        pub_result_img:=True
        这个代码默认是物体检测,我想用这个yolo5来实现色块识别并控制fishbot跟踪要怎样实现
          mmexport1742526264787.png mmexport1742526267321.png 大佬,执行以上步骤的时候出现下图问题怎么办?
            小鱼 技术大佬 @2652794104
            @2652794104 把右边终端的所有日志复制粘贴出来看看
              2652794104 @小鱼
              @小鱼 mmexport1742557560588.png mmexport1742557572037.png mmexport1742557564295.png mmexport1742557570033.png mmexport1742557567641.png
                小鱼 技术大佬 @2652794104
                @2652794104 感觉你电脑yolo没安装好
                  2652794104 @小鱼
                  @小鱼 但卸载后重新安装了还是不行,我在Ubuntu终端的情况如下VirtualBox:~/fishbot_ws/src$ cd ~/fishbot_ws/ colcon build source install/setup.bash Starting >>> fishbot_camera Starting >>> yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) [0.584s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future) --- stderr: yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) Traceback (most recent call last): File "/home/huan/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module> setup( File "/home/huan/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup return distutils.core.setup(**attrs) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup return run_commands(dist) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands dist.run_commands() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_commands self.run_command(cmd) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/dist.py", line 1104, in run_command super().run_command(command) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1021, in run_command cmd_obj.run() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run self.find_sources() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources mm.run
                    mmexport1743428498958.png mmexport1743428500801.png 在执行colcon build的这一步时候出现以下报错该如何处理
                      小鱼 技术大佬 @2652794104
                      @2652794104 是不是 setup 的版本有问题
                        小鱼 技术大佬 @2652794104
                        @2652794104 编译其他功能包会这样子吗
                          2652794104 @小鱼
                          @小鱼 编译其他功能包好像没出现类似的
                          小鱼小 2 条回复 最后回复 回复 引用 1
                            小鱼 技术大佬 @2652794104
                            @2652794104 日志看起来很奇怪,换台电脑试试可以不可以编译
                              小鱼 技术大佬 @2652794104
                              @2652794104 https://blog.csdn.net/qq_38196449/article/details/143998597
                              看下这个
                                2652794104 @小鱼
                                @小鱼 谢谢大佬,解决了
                                  萌新
                                  小鱼,这个用CPU会有点卡,可以用GPU吗,启动时代码改成gpu好像显示只能用cpu或者跳过
                                    小鱼 技术大佬 @2431039560
                                    @2431039560 这个要看yolo那边的了
                                    • J
                                      jkr
                                      ImportError: cannot import name 'Detect' from 'models.yolo' (/home/jkr/.local/lib/python3.10/site-packages/ultralytics/models/yolo/init.py)
                                      在输入这段代码后会显示这个错误
                                      J 小鱼小 2 条回复 最后回复 回复 引用 0
                                      • J
                                        jkr @jkr
                                          小鱼 技术大佬 @jkr
                                          @jkr yolo安装问题吧,重装试试
                                          J 2 条回复 最后回复 回复 引用 0
                                          • J
                                            jkr @小鱼
                                            @小鱼 重装了一边不太行
