    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    92.7k
    • R
      ros2_fresh @小鱼
      @小鱼 小鱼老师,我检查了驱动,显示的有帧率,也有视频图像,但就是看不到检测结果,请问是怎么回事?
        小鱼 技术大佬 @ros2_fresh
        @ros2_fresh 看看是否有报错的地方,node graph 连接是否正常
        R 1 条回复 最后回复 回复 引用 0
        • R
          ros2_fresh @小鱼
          @小鱼 换了个文件夹,重新编译就好了。可能是编译的问题,
            2280322272 @小鱼
            @小鱼 header:
            stamp:
            sec: 1740455780
            nanosec: 215156274
            frame_id: camera
            detections:
            • header:
              stamp:
              sec: 0
              nanosec: 0
              frame_id: ''
              results:
              • hypothesis:
                class_id: chair
                score: 0.5549157857894897
                pose:
                pose:
                position:
                x: -0.15733063741351616
                y: -0.26011998719034674
                z: 0.0
                orientation:
                x: 0.0
                y: 0.0
                z: 0.0
                w: 1.0
                covariance:
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                • 0.0
                  bbox:
                  center:
                  x: 325.5
                  y: 276.5
                  theta: 0.0
                  size_x: 95.0
                  size_y: 53.0
            这是我运行得到的结果,我希望可以通过话题中‘position’引导机器人运动,可否解释下这个坐标的具体计算方式?
              2075605318 年度VIP
              lwb@Lwb:~$ cd ~/fishbot_ws/
              source install/setup.bash
              Starting >>> yolov5_ros2
              /home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
              warnings.warn(msg)
              [0.351s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
              --- stderr: yolov5_ros2
              warnings.warn(msg)
              File "/home/lwb/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module>
              setup(
              return run_commands(dist)
              dist.run_commands()
              self.run_command(cmd)
              super().run_command(command)
              cmd_obj.run()
              self.find_sources()
              mm.run()
              self.prune_file_list()
              super().prune_file_list()
              Failed <<< yolov5_ros2 [0.84s, exited with code 1]
              Summary: 0 packages finished [0.96s]
              1 package failed: yolov5_ros2
              1 package had stderr output: yolov5_ros2
              lwb@Lwb:~/fishbot_ws$ ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
              Package 'yolov5_ros2' not found
              编译时报错,yolov5已安装,前面的步骤没有问题
                2075605318 年度VIP
                @小鱼 在 [FishBotCamera]3.结合YOLO实现检测 中说:
                pub_result_img:=True
                这个代码默认是物体检测,我想用这个yolo5来实现色块识别并控制fishbot跟踪要怎样实现
                  mmexport1742526264787.png mmexport1742526267321.png 大佬,执行以上步骤的时候出现下图问题怎么办?
                    小鱼 技术大佬 @2652794104
                    @2652794104 把右边终端的所有日志复制粘贴出来看看
                      2652794104 @小鱼
                      @小鱼 mmexport1742557560588.png mmexport1742557572037.png mmexport1742557564295.png mmexport1742557570033.png mmexport1742557567641.png
                        小鱼 技术大佬 @2652794104
                        @2652794104 感觉你电脑yolo没安装好
                          2652794104 @小鱼
                          @小鱼 但卸载后重新安装了还是不行,我在Ubuntu终端的情况如下VirtualBox:~/fishbot_ws/src$ cd ~/fishbot_ws/ colcon build source install/setup.bash Starting >>> fishbot_camera Starting >>> yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) [0.584s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future) --- stderr: yolov5_ros2 /home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:289: UserWarning: Unknown distribution option: 'tests_require' warnings.warn(msg) Traceback (most recent call last): File "/home/huan/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module> setup( File "/home/huan/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup return distutils.core.setup(**attrs) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 186, in setup return run_commands(dist) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 202, in run_commands dist.run_commands() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1002, in run_commands self.run_command(cmd) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/dist.py", line 1104, in run_command super().run_command(command) File "/home/huan/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 1021, in run_command cmd_obj.run() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run self.find_sources() File "/home/huan/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources mm.run
                            mmexport1743428498958.png mmexport1743428500801.png 在执行colcon build的这一步时候出现以下报错该如何处理
                              小鱼 技术大佬 @2652794104
                              @2652794104 是不是 setup 的版本有问题
                                小鱼 技术大佬 @2652794104
                                @2652794104 编译其他功能包会这样子吗
                                  2652794104 @小鱼
                                  @小鱼 编译其他功能包好像没出现类似的
                                  小鱼小 2 条回复 最后回复 回复 引用 1
                                    小鱼 技术大佬 @2652794104
                                    @2652794104 日志看起来很奇怪,换台电脑试试可以不可以编译
                                      小鱼 技术大佬 @2652794104
                                      @2652794104 https://blog.csdn.net/qq_38196449/article/details/143998597
                                      看下这个
                                        2652794104 @小鱼
                                        @小鱼 谢谢大佬,解决了
                                          萌新
                                          小鱼,这个用CPU会有点卡,可以用GPU吗,启动时代码改成gpu好像显示只能用cpu或者跳过
                                            小鱼 技术大佬 @2431039560
                                            @2431039560 这个要看yolo那边的了
