    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    103.6k
    • P
      pengzhju
      sudo apt update
      sudo apt install python3-pip ros-$ROS_DISTRO-vision-msgs
      pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple yolov5
      为什么运行上面指令之后,我所有曾经成功编译过的代码现在colcon build 之后都会出错了,以前面FishBotCamera为例,我可以成功运行了,但是按照 “3.结合YOLO实现检测”内容操作之后,再运行前面的FishBotCamera,就会出现colcon build 错误,错误指示如下:
      tarting >>> fishbot_camera
      /home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:261: UserWarning: Unknown distribution option: 'tests_require'
      warnings.warn(msg)
      --- stderr: fishbot_camera
      warnings.warn(msg)
      File "/home/hance/fishbot_ws/src/fishbot_camera/setup.py", line 5, in <module>
      setup(
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 183, in setup
      return run_commands(dist)
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 199, in run_commands
      dist.run_commands()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
      self.run_command(cmd)
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
      super().run_command(command)
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
      cmd_obj.run()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
      self.find_sources()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
      mm.run()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 546, in run
      self.prune_file_list()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
      super().prune_file_list()
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 267, in get_fullname
      File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 285, in _distribution_fullname
      Failed <<< fishbot_camera [4.58s, exited with code 1]
      Summary: 0 packages finished [5.19s]
      1 package failed: fishbot_camera
      1 package had stderr output: fishbot_camera
      小鱼小 1 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @pengzhju
        @pengzhju 在 [FishBotCamera]3.结合YOLO实现检测 中说:
        setuptools
        什么系统版本,是不是操作后不小心更新了 setuptools 版本
        P 2 条回复 最后回复 回复 引用 0
        • P
          pengzhju @小鱼
          @小鱼 对的小鱼,应该问题出在了setuptools上,这个需要怎么解决呀?
            小鱼 技术大佬 @pengzhju
            @pengzhju 搜搜默认版本和怎么回退,我帮你看下我的
            fishros$ pip list| grep setuptools
            setuptools                           59.6.0
            • P
              pengzhju @小鱼
              @小鱼 我的是Ubuntu22.04 humble,是按照图片这个步骤来的,可能我哪里出错了。好的小鱼,我先试一下,谢谢呀
                2290305520 @1004461581
                @1004461581 请问一下是怎么解决的
                  @小鱼 请问我运行这段命令后就这样不动了是什么原因?
                  ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                  /usr/lib/python3/dist-packages/requests/init.py:87: RequestsDependencyWarning: urllib3 (2.2.3) or chardet (4.0.0) doesn't match a supported version!
                  warnings.warn("urllib3 ({}) or chardet ({}) doesn't match a supported "
                  [INFO] [1732460432.020769982] [yolov5_ros2]: Current ROS 2 distribution: humble
                  [INFO] [1732460432.127483045] [yolov5_ros2]: default_camera_info: [476.7030836014194, 0.0, 400.5, 0.0, 476.7030836014194, 400.5, 0.0, 0.0, 1.0]
                  [0.0, 0.0, 0.0, 0.0, 0.0]
                    小鱼 技术大佬 @2290305520
                    @2290305520 是不是没有图像数据
                      2290305520 @小鱼
                      @小鱼 是的,没有图像数据
                        小鱼 技术大佬 @2290305520
                        @2290305520 没有数据检查下驱动
                        R 1 条回复 最后回复 回复 引用 0
                          154253494 @小鱼
                            154253494 @pengzhju
                            • R
                              ros2_fresh @小鱼
                              @小鱼 小鱼老师,我检查了驱动,显示的有帧率,也有视频图像,但就是看不到检测结果,请问是怎么回事?
                                小鱼 技术大佬 @ros2_fresh
                                @ros2_fresh 看看是否有报错的地方,node graph 连接是否正常
                                • R
                                  ros2_fresh @小鱼
                                  @小鱼 换了个文件夹,重新编译就好了。可能是编译的问题,
                                    2280322272 @小鱼
                                    @小鱼 header:
                                    stamp:
                                    sec: 1740455780
                                    nanosec: 215156274
                                    frame_id: camera
                                    detections:
                                    • header:
                                      stamp:
                                      sec: 0
                                      nanosec: 0
                                      frame_id: ''
                                      results:
                                      • hypothesis:
                                        class_id: chair
                                        score: 0.5549157857894897
                                        pose:
                                        pose:
                                        position:
                                        x: -0.15733063741351616
                                        y: -0.26011998719034674
                                        z: 0.0
                                        orientation:
                                        x: 0.0
                                        y: 0.0
                                        z: 0.0
                                        w: 1.0
                                        covariance:
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                        • 0.0
                                          bbox:
                                          center:
                                          x: 325.5
                                          y: 276.5
                                          theta: 0.0
                                          size_x: 95.0
                                          size_y: 53.0
                                    这是我运行得到的结果,我希望可以通过话题中‘position’引导机器人运动,可否解释下这个坐标的具体计算方式?
                                      2075605318 年度VIP
                                      lwb@Lwb:~$ cd ~/fishbot_ws/
                                      source install/setup.bash
                                      Starting >>> yolov5_ros2
                                      /home/lwb/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:270: UserWarning: Unknown distribution option: 'tests_require'
                                      warnings.warn(msg)
                                      [0.351s] WARNING:colcon.colcon_ros.task.ament_python.build:Package 'yolov5_ros2' doesn't explicitly install a marker in the package index (colcon-ros currently does it implicitly but that fallback will be removed in the future)
                                      --- stderr: yolov5_ros2
                                      warnings.warn(msg)
                                      File "/home/lwb/fishbot_ws/src/yolov5_ros2/setup.py", line 7, in <module>
                                      setup(
                                      dist.run_commands()
                                      cmd_obj.run()
                                      self.find_sources()
                                      mm.run()
                                      Failed <<< yolov5_ros2 [0.84s, exited with code 1]
                                      Summary: 0 packages finished [0.96s]
                                      1 package failed: yolov5_ros2
                                      1 package had stderr output: yolov5_ros2
                                      lwb@Lwb:~/fishbot_ws$ ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                                      Package 'yolov5_ros2' not found
                                      编译时报错,yolov5已安装,前面的步骤没有问题
                                        2075605318 年度VIP
                                        @小鱼 在 [FishBotCamera]3.结合YOLO实现检测 中说:
                                        pub_result_img:=True
                                        这个代码默认是物体检测,我想用这个yolo5来实现色块识别并控制fishbot跟踪要怎样实现
                                          mmexport1742526264787.png mmexport1742526267321.png 大佬,执行以上步骤的时候出现下图问题怎么办?
                                            小鱼 技术大佬 @2652794104
                                            @2652794104 把右边终端的所有日志复制粘贴出来看看
