    [FishBotCamera]3.结合YOLO实现检测
    fishbotcamera yolo 检测
    19
    67
    80.3k
    • 10044615811
      班超 @2431039560
      @2431039560是udpserver_ip吗,改了这个还是不行哎
      小鱼小 2 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @1004461581
        @1004461581 发一下网络结构看看
        10044615811 1 条回复 最后回复 回复 引用 0
        • 10044615811
          班超 @小鱼
          @小鱼 感谢已经解决
            小鱼 技术大佬 @1004461581
            @1004461581 👍
            • P
              pengzhju
              sudo apt update
              sudo apt install python3-pip ros-$ROS_DISTRO-vision-msgs
              pip3 install -i https://pypi.tuna.tsinghua.edu.cn/simple yolov5
              为什么运行上面指令之后,我所有曾经成功编译过的代码现在colcon build 之后都会出错了,以前面FishBotCamera为例,我可以成功运行了,但是按照 “3.结合YOLO实现检测”内容操作之后,再运行前面的FishBotCamera,就会出现colcon build 错误,错误指示如下:
              tarting >>> fishbot_camera
              /home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py:261: UserWarning: Unknown distribution option: 'tests_require'
              warnings.warn(msg)
              --- stderr: fishbot_camera
              warnings.warn(msg)
              File "/home/hance/fishbot_ws/src/fishbot_camera/setup.py", line 5, in <module>
              setup(
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/init.py", line 117, in setup
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 183, in setup
              return run_commands(dist)
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/core.py", line 199, in run_commands
              dist.run_commands()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
              self.run_command(cmd)
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/dist.py", line 999, in run_command
              super().run_command(command)
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
              cmd_obj.run()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 312, in run
              self.find_sources()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 320, in find_sources
              mm.run()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/egg_info.py", line 546, in run
              self.prune_file_list()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/command/sdist.py", line 162, in prune_file_list
              super().prune_file_list()
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_distutils/command/sdist.py", line 380, in prune_file_list
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 267, in get_fullname
              File "/home/hance/.local/lib/python3.10/site-packages/setuptools/_core_metadata.py", line 285, in _distribution_fullname
              Failed <<< fishbot_camera [4.58s, exited with code 1]
              Summary: 0 packages finished [5.19s]
              1 package failed: fishbot_camera
              1 package had stderr output: fishbot_camera
              小鱼小 1 2 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @pengzhju
                @pengzhju 在 [FishBotCamera]3.结合YOLO实现检测 中说:
                setuptools
                什么系统版本,是不是操作后不小心更新了 setuptools 版本
                P 2 条回复 最后回复 回复 引用 0
                • P
                  pengzhju @小鱼
                  @小鱼 对的小鱼,应该问题出在了setuptools上,这个需要怎么解决呀?
                    小鱼 技术大佬 @pengzhju
                    @pengzhju 搜搜默认版本和怎么回退,我帮你看下我的
                    fishros$ pip list| grep setuptools
                    setuptools                           59.6.0
                    • P
                      pengzhju @小鱼
                      @小鱼 我的是Ubuntu22.04 humble,是按照图片这个步骤来的,可能我哪里出错了。好的小鱼,我先试一下,谢谢呀
                        2290305520 @1004461581
                        @1004461581 请问一下是怎么解决的
                          @小鱼 请问我运行这段命令后就这样不动了是什么原因?
                          ros2 run yolov5_ros2 yolo_detect_2d --ros-args -p device:=cpu -p image_topic:=/fishbot_camera_raw
                          /usr/lib/python3/dist-packages/requests/init.py:87: RequestsDependencyWarning: urllib3 (2.2.3) or chardet (4.0.0) doesn't match a supported version!
                          warnings.warn("urllib3 ({}) or chardet ({}) doesn't match a supported "
                          [INFO] [1732460432.020769982] [yolov5_ros2]: Current ROS 2 distribution: humble
                          [INFO] [1732460432.127483045] [yolov5_ros2]: default_camera_info: [476.7030836014194, 0.0, 400.5, 0.0, 476.7030836014194, 400.5, 0.0, 0.0, 1.0]
                          [0.0, 0.0, 0.0, 0.0, 0.0]
                            小鱼 技术大佬 @2290305520
                            @2290305520 是不是没有图像数据
                              2290305520 @小鱼
                              @小鱼 是的,没有图像数据
                                小鱼 技术大佬 @2290305520
                                @2290305520 没有数据检查下驱动
                                R 1 条回复 最后回复 回复 引用 0
                                  154253494 @小鱼
                                    154253494 @pengzhju
                                    • R
                                      ros2_fresh @小鱼
                                      @小鱼 小鱼老师,我检查了驱动,显示的有帧率,也有视频图像,但就是看不到检测结果,请问是怎么回事?
                                        小鱼 技术大佬 @ros2_fresh
                                        @ros2_fresh 看看是否有报错的地方,node graph 连接是否正常
                                        • R
                                          ros2_fresh @小鱼
                                          @小鱼 换了个文件夹,重新编译就好了。可能是编译的问题,
                                            2280322272 @小鱼
                                            @小鱼 header:
                                            stamp:
                                            sec: 1740455780
                                            nanosec: 215156274
                                            frame_id: camera
                                            detections:
                                            • header:
                                              stamp:
                                              sec: 0
                                              nanosec: 0
                                              frame_id: ''
                                              results:
                                              • hypothesis:
                                                class_id: chair
                                                score: 0.5549157857894897
                                                pose:
                                                pose:
                                                position:
                                                x: -0.15733063741351616
                                                y: -0.26011998719034674
                                                z: 0.0
                                                orientation:
                                                x: 0.0
                                                y: 0.0
                                                z: 0.0
                                                w: 1.0
                                                covariance:
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                • 0.0
                                                  bbox:
                                                  center:
                                                  x: 325.5
                                                  y: 276.5
                                                  theta: 0.0
                                                  size_x: 95.0
                                                  size_y: 53.0
                                            这是我运行得到的结果,我希望可以通过话题中‘position’引导机器人运动,可否解释下这个坐标的具体计算方式?
