    一键安装使用指南及常见问题解决方案
    66
    149.6k
      月翘上枝头 @1597854501
      @1597854501 我现在已经尝试过pip3 distro,修改系统变量将3.11的site-package路径加到pythonpath,再次运行一键安装时读取状态信息也可以识别到distro,但到了“已保存/tmp/fishinstall/tools/base.py"后运行还是会报错No module named distro,请问这是怎么回事呢
        月翘上枝头 @1597854501
        @1597854501 更改etc/environment,添加pythonpath后,报错最终追溯到lsb_release,这是不是因为我修改系统默认python3.8到3.11导致的呢
          月翘上枝头 @1597854501
          @1597854501 破案了,我找到报错文件,将开头的python3改成python3.8即可,推测原因为系统自带的这些功能默认用python3去软链接系统自带的python3.8,但我升级后将python3软连接给了python3.11,python3.11并不支持系统的ls_release等功能,故须像上述一样主动修改python3为python11,希望大家对我的教训引以为戒吧
          • 7347352937
            734735293
            我在树莓派ubuntu mate 16.04 上安装ros1-Kinetic无法定位软件包9da69809-8171-4ddf-b87f-1f1e5453049f-c711e019ce12cd103a476cd601eb4e7.jpg
            • 叮
              叮又叮不懂鞋又鞋不会 @2090127048
              @2090127048 sudo pip install distro 或者 sudo pip3 install distro
                [1]:bouncy(ROS2)
                [2]:crystal(ROS2)
                [3]:dashing(ROS2)
                [4]:eloquent(ROS2)
                [5]:melodic(ROS1)
                请输入[]内的数字以选择:2
                请选择安装的具体版本(如果不知道怎么选,请选1桌面版):
                [1]:crystal(ROS2)桌面版
                [2]:crystal(ROS2)基础版(小)
                请输入[]内的数字以选择:2
                [-][1.67s] Simple tool to mail about pending package updates - systemd versio[][1.67s] brain teaser game and trainer to have fun and to keep your brain t[-][1.67s] CMD Result:success es)
                [-][0.00s] CMD Result:code:100
                Run CMD Task:[sudo apt install ros-crystal-ros-base -y]
                E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
                E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
                Run CMD Task:[ls /opt/ros/crystal/setup.bash]
                [/][0.00s] ls: cannot access '/opt/ros/crystal/setup.bash': No such file or dir[-][0.00s] CMD Result:code:2
                请问这个改怎么解决
                • ganyuanzhenG
                  Elysia 技术大佬 @2960110040
                  @2960110040 等一下吧,系统里有其他的程序在占用dpkg。一般是系统的自动更新
                    一键安装会安装moveit吗
                      ygx
                      HELP:
                      问题:roscore报错:
                      ... logging to /home/nuc/.ros/log/d5a6d328-d4ad-11ef-8b12-d1928152a029/roslaunch-nuc-BQM5-36720.log
                      Press Ctrl-C to interrupt
                      RLException: Unable to contact my own server at [http://192.168.31.213:44895/].
                      This usually means that the network is not configured properly.
                      A common cause is that the machine cannot connect to itself. Please check
                      for errors by running:
                      ping 192.168.31.213
                      For more tips, please see
                      http://wiki.ros.org/ROS/NetworkSetup
                      The traceback for the exception was written to the log file
                      描述:本来有一个foxy版本ROS,后来又一键安装了一个noetic的版本,然后在网上搜索后把foxy版本的删除了,现在又通过一键安装下载回来了现在每次打开终端之后,会先有这个询问:ros:foxy(1) noetic(2) ?
                      我输入 2 换行后,输入roscore,出现上述问题。
                        这是怎么回事,请问
                        • F
                          fxdzz
                          大佬,这是什么情况
                            1556319011 @小鱼
                            @小鱼 请问运行ros2 doctor后输出
                            /opt/ros/humble/lib/python3.10/site-packages/ros2doctor/api/init.py: 118: UserWarning: Fail to call PackageCheck class functions.
                            All 4 checks passed
                            这是怎么回事,运行ros2 run demo_nodes_cpp talker
                            ros2 run demo_nodes_cpp listener
                            后可以收到消息
                            • N
                              nnnnnnnnnn
                              416c970d-9b4d-4052-8479-619730e625a6-image.png 能问下图中的ModuleNotFoundError: No module named 'robot_vision_msgs'是什么问题
                              • 8
                                872069305
                                924396dbab7730422c3890650a15b8bb.png 提示安装成功,但是在新命令行输入ros2时,显示未找到
                                8 1 条回复 最后回复 回复 引用 0
                                • 8
                                  872069305 @872069305
                                  @872069305 a483b7a6-4b00-49e5-9944-03591c03aad9-561ac935-7808-430b-8e91-bb7d70411826.png
