    fishbot 导航
    67
    239
    901.1k
      切换自己的slam地图报错
      执行```
      [INFO] [launch]: All log files can be found below /home/a/.ros/log/2023-11-02-22-09-38-820997-a-9591
      future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=InvalidLaunchFileError('py')>
      raise LookupError(
      LookupError: Could not find the resource 'nav2_bringup' of type 'packages'
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_file_utilities.py", line 53, in get_launch_description_from_any_launch_file
      return loader(launch_file_path)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/python_launch_file_utilities.py", line 68, in get_launch_description_from_python_launch_file
      return getattr(launch_file_module, 'generate_launch_description')()
      File "/home/a/fishbot/install/fishbot_navigation2/share/fishbot_navigation2/launch/navigation2.launch.py", line 21, in generate_launch_description
      File "/opt/ros/foxy/lib/python3.8/site-packages/ament_index_python/packages.py", line 70, in get_package_share_directory
      return os.path.join(get_package_prefix(package_name), 'share', package_name)
      raise PackageNotFoundError(
      ament_index_python.packages.PackageNotFoundError: "package 'nav2_bringup' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
      The above exception was the direct cause of the following exception:
      return self.execute(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/include_launch_description.py", line 130, in execute
      launch_description = self.__launch_description_source.get_launch_description(context)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_source.py", line 84, in get_launch_description
      self._get_launch_description(self.__expanded_location)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_description_source.py", line 53, in _get_launch_description
      return get_launch_description_from_any_launch_file(location)
      File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_file_utilities.py", line 56, in get_launch_description_from_any_launch_file
      launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
        小鱼 技术大佬 @13768252287
        @13768252287 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
        foxy
        换humble版本就好
        • 10416326111
          燦.
          您好,第一步的克隆仓库出错了,包括代理也无法克隆,请问有其他链接么?
          emily3@emily3-virtual-machine:~$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
          正克隆到 'fishbot'...
          fatal: 无法访问 'https://github.com/fishros/fishbot.git/':Failed to connect to github.com port 443 after 130728 ms: 连接超时
            小鱼 技术大佬 @1041632611
            @1041632611 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
            git clone http://github.fishros.org/https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
            • 北北
              北
              ubuntu22在问题出现后重装过ros2humble,rosdepc
              rosdep install {ERROR}报错,如何重新安装依赖或者是否有其他的解决方案?
              北北 1 条回复 最后回复 回复 引用 0
              • 北北
                北 @北
                dragon@dragon-virtual-machine:~/Documents/custom/fishbot$ rosdep install --from-paths src --ignore-src -y  -r
                to system dependencies:
                @北 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                • 5655178305
                  我姓徐 💋
                  克隆代码完成后,安装依赖一直提示:
                  编译也报错
                    小鱼 技术大佬 @565517830
                    @565517830 这个没关系,编译错误提出来,建议单独发帖
                    • 5655178305
                      我姓徐 💋
                      下载代码后colcon build报错,如图片所示
                      14492629671 1 条回复 最后回复 回复 引用 1
                      • 5655178305
                        我姓徐 💋 @1954923637
                        @1954923637 代码路径有中文,换个没有中文的路径
                        • 14492629671
                          秩 @565517830
                          @565517830 同问,我也是这个报错!!bfdff8a2-5425-4099-8558-0a1d2f254248-截图 2023-12-27 18-58-56.png file:///home/fishros/%E5%9B%BE%E7%89%87/%E6%88%AA%E5%9B%BE/%E6%88%AA%E5%9B%BE%202023-12-27%2018-58-56.png
                          • 4290162674
                            h1
                            无法下载cartographer和navigation源码,自己手动下载后,又无法编译cartographer源码
                            使用git clone --recursive https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                            cd fishbot
                            colcon build下载源码,无法下载cartographer和navigation源码,(我得环境是vm虚拟机+ubuntu22.04+ros2 humble版本)
                            报错 重定向:http://ww3.91chi.fun/?sub1=90563160-ae8f-11ee-b3d1-c2900044a4dd
                            fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'
                            正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer_ros'...
                            warning: 您似乎克隆了一个空仓库。
                            正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/navigation'...
                            正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'...
                            error: inflate: data stream error (incorrect header check)
                            error: File 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 (https://github.91chi.fun/https://github.com/ros2/cartographer.git/objects/2c/e33a65bd4e41e3bf5af92c9275354ce7921c70) corrupt
                            error: Unable to find 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 under https://github.91chi.fun/https://github.com/ros2/cartographer.git
                            Cannot obtain needed object 2ce33a65bd4e41e3bf5af92c9275354ce7921c70
                            error: 获取失败。
                            fatal: 获取了子模组路径 'src/cartographer_code/cartographer',但是它没有包含 2ce33a65bd4e41e3bf5af92c9275354ce7921c70。直接获取该提交失败。
                            fatal:
                            2:后续自己手动下载这里两部分源码,在编译cartographer时候,报错:home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool,h:73:63: error:"mutexhas not been declaredvoid NotifyDependenciesCompleted(Task* task) LOCKS EXCLUDED(mutex ) ov73erride;
                            home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool.h:73:48: error: ISO C++ forbids declaration ofLOCKS EXCLUDED’ with no type [-fpermissive]73void NotifyDependenciesCompleted(Task* task) LOCKS_EXCLUDED(mutex ) override;
                            home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread poolh:73:48: error: int cartographer::common::thredPool::LOCKS EXCLUDED(int)’ cannot be overloaded with "int cartographer::common::Threadpool::LOCKS EXCLUDED(int)1704870970161.jpg
                              小鱼 技术大佬 @429016267
                              @429016267 源码版本有些老了,直接二进制安装吧
                              4290162674 1 条回复 最后回复 回复 引用 0
                              • 4290162674
                                h1 @小鱼
                                @小鱼 好吧,目前我就是源码编不过,其他都可以,有没有什么方案能解决下这个问题呢,大佬
                                  小鱼 技术大佬 @429016267
                                  @429016267 看d2lros2教程前面的仿真部分,根据提示重新从原来的仓库克隆
                                  • 19238250151
                                    Woah damn @小鱼
                                    在安装依赖时报错,a0bb8f2d-b751-440d-b0b8-f47b8b876181-1704976690257.png 用的ubuntu22.04 humble版本 然后图上的网址打不开。
                                      小鱼 技术大佬 @1923825015
                                      @1923825015 https://zhuanlan.zhihu.com/p/398754989
                                      • 1922248011
                                        早点睡觉.
                                        10320637471 1 条回复 最后回复 回复 引用 1
                                          safereinforcementlab
                                          鱼哥,这是什么问题
                                          autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ rosdep install --from-paths src --ignore-src -y -r # 安装依赖
                                          autoliu@autoliu-LEGION-REN7000K-26IRB:~/fishbot$ colcon build
                                          Starting >>> fishbot_bringup
                                          --- stderr: fishbot_cartographer
                                          CMake Error at /usr/share/cmake-3.22/Modules/CMakeTestCCompiler.cmake:69 (message):
                                          The C compiler
                                          "/usr/bin/cc"
                                          is not able to compile a simple test program.
                                          It fails with the following output:
                                          Change Dir: /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp
                                          Run Build Command(s):/usr/bin/gmake -f Makefile cmTC_0c79a/fast && /usr/bin/gmake  -f CMakeFiles/cmTC_0c79a.dir/build.make CMakeFiles/cmTC_0c79a.dir/build
                                          gmake[1]: 进入目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
                                          Building C object CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o
                                          /usr/bin/cc    -o CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o -c /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c
                                          /home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp/testCCompiler.c:11:1: fatal error: error closing /tmp/cc76K2IV.s: 设备上没有空间
                                             11 | { (void)argv; return argc-1;}
                                          compilation terminated.
                                          gmake[1]: *** [CMakeFiles/cmTC_0c79a.dir/build.make:78:CMakeFiles/cmTC_0c79a.dir/testCCompiler.c.o] 错误 1
                                          gmake[1]: 离开目录“/home/autoliu/fishbot/build/fishbot_cartographer/CMakeFiles/CMakeTmp”
                                          gmake: *** [Makefile:127:cmTC_0c79a/fast] 错误 2
                                          CMake will not be able to correctly generate this project.
                                          CMakeLists.txt:2 (project)
                                          Failed <<< fishbot_cartographer [0.39s, exited with code 1]
                                          Aborted <<< fishbot_description [0.38s]
                                          Aborted <<< fishbot_bringup [0.41s]
                                          Aborted <<< fishbot_interfaces [0.49s]
                                          Aborted <<< fishbot_navigation2 [0.48s]
                                          Summary: 0 packages finished [0.91s]
                                          1 package failed: fishbot_cartographer
                                          4 packages aborted: fishbot_bringup fishbot_description fishbot_interfaces fishbot_navigation2
                                          S 1 条回复 最后回复 回复 引用 0
                                            鱼哥,如果我要自己写控制算法,应该在哪里改,没找到源码的控制算法在那里
