    fishbot 导航
    67
    239
    985.9k
      小鱼 技术大佬 @154453683
      @154453683 nav2支持通过代码进行这些操作,可以到Nav2官方文档进行学习
      • 17405804851
        1740580485
          小鱼 技术大佬 @1740580485
          @1740580485 你的网络不行,可以试试 github代理,github.fishros.org,另外终端内容最好赋值粘贴,我好给你修改
            执行ros2 launch fishbot_bringup fishbot_bringup.launch.py
            报错
            [INFO] [launch]: All log files can be found below /home/a/.ros/log/2023-10-30-02-11-31-404730-a-10225
            future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=PackageNotFoundError("package 'joint_state_publisher' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']")>
                raise LookupError(
                return self.execute(context)
                result = self.find(package)
                raise PackageNotFoundError(
            ament_index_python.packages.PackageNotFoundError: "package 'joint_state_publisher' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
              小鱼 技术大佬 @13768252287
              @13768252287 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
              报错
                  raise LookupError(
              sudo apt install ros-$ROS_DISTRO-joint-state-publisher
                切换自己的slam地图报错
                执行```
                [INFO] [launch]: All log files can be found below /home/a/.ros/log/2023-11-02-22-09-38-820997-a-9591
                future: <Task finished name='Task-2' coro=<LaunchService._process_one_event() done, defined at /opt/ros/foxy/lib/python3.8/site-packages/launch/launch_service.py:226> exception=InvalidLaunchFileError('py')>
                raise LookupError(
                LookupError: Could not find the resource 'nav2_bringup' of type 'packages'
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_file_utilities.py", line 53, in get_launch_description_from_any_launch_file
                return loader(launch_file_path)
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/python_launch_file_utilities.py", line 68, in get_launch_description_from_python_launch_file
                return getattr(launch_file_module, 'generate_launch_description')()
                File "/home/a/fishbot/install/fishbot_navigation2/share/fishbot_navigation2/launch/navigation2.launch.py", line 21, in generate_launch_description
                File "/opt/ros/foxy/lib/python3.8/site-packages/ament_index_python/packages.py", line 70, in get_package_share_directory
                return os.path.join(get_package_prefix(package_name), 'share', package_name)
                ament_index_python.packages.PackageNotFoundError: "package 'nav2_bringup' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
                The above exception was the direct cause of the following exception:
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/actions/include_launch_description.py", line 130, in execute
                launch_description = self.__launch_description_source.get_launch_description(context)
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_source.py", line 84, in get_launch_description
                self._get_launch_description(self.__expanded_location)
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_description_source.py", line 53, in _get_launch_description
                return get_launch_description_from_any_launch_file(location)
                File "/opt/ros/foxy/lib/python3.8/site-packages/launch/launch_description_sources/any_launch_file_utilities.py", line 56, in get_launch_description_from_any_launch_file
                launch.invalid_launch_file_error.InvalidLaunchFileError: Caught exception when trying to load file of format [py]: "package 'nav2_bringup' not found, searching: ['/home/a/fishbot/install/fishbot_navigation2', '/home/a/fishbot/install/fishbot_interfaces', '/home/a/fishbot/install/fishbot_description', '/home/a/fishbot/install/fishbot_cartographer', '/home/a/fishbot/install/fishbot_bringup', '/opt/ros/foxy']"
                  foxy
                  换humble版本就好
                  • 10416326111
                    燦.
                    您好,第一步的克隆仓库出错了,包括代理也无法克隆,请问有其他链接么?
                    emily3@emily3-virtual-machine:~$ git clone https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                    正克隆到 'fishbot'...
                    fatal: 无法访问 'https://github.com/fishros/fishbot.git/':Failed to connect to github.com port 443 after 130728 ms: 连接超时
                      小鱼 技术大佬 @1041632611
                      @1041632611 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                      git clone http://github.fishros.org/https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                      • 北北
                        北
                        ubuntu22在问题出现后重装过ros2humble,rosdepc
                        rosdep install {ERROR}报错,如何重新安装依赖或者是否有其他的解决方案?
                        北北 1 条回复 最后回复 回复 引用 0
                        • 北北
                          北 @北
                          dragon@dragon-virtual-machine:~/Documents/custom/fishbot$ rosdep install --from-paths src --ignore-src -y  -r
                          to system dependencies:
                          @北 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                          • 5655178305
                            我姓徐 💋
                            克隆代码完成后,安装依赖一直提示:
                            编译也报错
                              小鱼 技术大佬 @565517830
                              @565517830 这个没关系,编译错误提出来,建议单独发帖
                              • 5655178305
                                我姓徐 💋
                                下载代码后colcon build报错,如图片所示
                                14492629671 1 条回复 最后回复 回复 引用 1
                                • 5655178305
                                  我姓徐 💋 @1954923637
                                  @1954923637 代码路径有中文,换个没有中文的路径
                                  • 14492629671
                                    秩 @565517830
                                    @565517830 同问,我也是这个报错!!bfdff8a2-5425-4099-8558-0a1d2f254248-截图 2023-12-27 18-58-56.png file:///home/fishros/%E5%9B%BE%E7%89%87/%E6%88%AA%E5%9B%BE/%E6%88%AA%E5%9B%BE%202023-12-27%2018-58-56.png
                                    • 4290162674
                                      h1
                                      无法下载cartographer和navigation源码,自己手动下载后,又无法编译cartographer源码
                                      使用git clone --recursive https://github.com/fishros/fishbot.git -b v1.0.0 --depth=1
                                      cd fishbot
                                      colcon build下载源码,无法下载cartographer和navigation源码,(我得环境是vm虚拟机+ubuntu22.04+ros2 humble版本)
                                      报错 重定向:http://ww3.91chi.fun/?sub1=90563160-ae8f-11ee-b3d1-c2900044a4dd
                                      fatal: 无法克隆 'https://github.91chi.fun/https://github.com/ros2/cartographer.git' 到子模组路径 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'
                                      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer_ros'...
                                      warning: 您似乎克隆了一个空仓库。
                                      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/navigation'...
                                      正克隆到 '/home/zlkj/Desktop/gong_xiang/yuan_ma1/fishbot/src/cartographer_code/cartographer'...
                                      error: inflate: data stream error (incorrect header check)
                                      error: File 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 (https://github.91chi.fun/https://github.com/ros2/cartographer.git/objects/2c/e33a65bd4e41e3bf5af92c9275354ce7921c70) corrupt
                                      error: Unable to find 2ce33a65bd4e41e3bf5af92c9275354ce7921c70 under https://github.91chi.fun/https://github.com/ros2/cartographer.git
                                      Cannot obtain needed object 2ce33a65bd4e41e3bf5af92c9275354ce7921c70
                                      error: 获取失败。
                                      fatal: 获取了子模组路径 'src/cartographer_code/cartographer',但是它没有包含 2ce33a65bd4e41e3bf5af92c9275354ce7921c70。直接获取该提交失败。
                                      fatal:
                                      2:后续自己手动下载这里两部分源码,在编译cartographer时候,报错:home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool,h:73:63: error:"mutexhas not been declaredvoid NotifyDependenciesCompleted(Task* task) LOCKS EXCLUDED(mutex ) ov73erride;
                                      home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread pool.h:73:48: error: ISO C++ forbids declaration ofLOCKS EXCLUDED’ with no type [-fpermissive]73void NotifyDependenciesCompleted(Task* task) LOCKS_EXCLUDED(mutex ) override;
                                      home/zlkj/Desktop/gong xiang/yuan ma/fishbot/src/cartographer_code/cartographercartographer/common/thread poolh:73:48: error: int cartographer::common::thredPool::LOCKS EXCLUDED(int)’ cannot be overloaded with "int cartographer::common::Threadpool::LOCKS EXCLUDED(int)1704870970161.jpg
                                        小鱼 技术大佬 @429016267
                                        @429016267 源码版本有些老了,直接二进制安装吧
                                        4290162674 1 条回复 最后回复 回复 引用 0
                                        • 4290162674
                                          h1 @小鱼
                                          @小鱼 好吧,目前我就是源码编不过,其他都可以,有没有什么方案能解决下这个问题呢,大佬
                                            小鱼 技术大佬 @429016267
                                            @429016267 看d2lros2教程前面的仿真部分,根据提示重新从原来的仓库克隆
