    fishbot 导航
    67
    239
    900.8k
    • 10320637471
      大道至简 @小鱼
      @小鱼 鱼哥这一步跑一键安装,输入命令后安装第几项?
      • 10320637471
        大道至简 @小鱼
        @小鱼 截图 2024-02-20 20-03-27.png 截图 2024-02-20 20-13-53.png鱼哥,卡在“fishbot_bringup”这里了,没找到如何解决的方法呢,帮我看看怎么个问题,多谢😊
        • 5634119395
          那年那兔
          我下载的NAV2的代码为什么编译阶段会报错
          rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
          /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:35:3:   required from here
          /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:49:15: error: cannot convert ‘rclcpp::SystemDefaultsQoS’ to ‘const rmw_qos_profile_t&’ {aka ‘const rmw_qos_profile_s&’}
             49 |       rclcpp::SystemDefaultsQoS(),
          In file included from /opt/ros/humble/include/rclcpp/rclcpp/node.hpp:1321,
                           from /opt/ros/humble/include/rclcpp/rclcpp/executors/single_threaded_executor.hpp:28,
                           from /opt/ros/humble/include/rclcpp/rclcpp/executors.hpp:22,
                           from /opt/ros/humble/include/rclcpp/rclcpp/rclcpp.hpp:155,
                           from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp:20,
                           from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
                           from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:15:
          /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::ChangeState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::ChangeState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
            127 |   const rmw_qos_profile_t & qos_profile,
          In file included from /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/lifecycle_service_client.hpp:24,
          /home/tq/workspace/nav2/src/navigation2-main/nav2_util/include/nav2_util/service_client.hpp: In instantiation of ‘nav2_util::ServiceClient<ServiceT, NodeT>::ServiceClient(const string&, const NodeT&) [with ServiceT = lifecycle_msgs::srv::GetState; NodeT = std::shared_ptr<rclcpp::Node>; std::string = std::__cxx11::basic_string<char>]’:
          /home/tq/workspace/nav2/src/navigation2-main/nav2_util/src/lifecycle_service_client.cpp:36:3:   required from here
          /opt/ros/humble/include/rclcpp/rclcpp/node_impl.hpp:127:29: note:   initializing argument 2 of ‘typename rclcpp::Client<ServiceT>::SharedPtr rclcpp::Node::create_client(const string&, const rmw_qos_profile_t&, rclcpp::CallbackGroup::SharedPtr) [with ServiceT = lifecycle_msgs::srv::GetState; typename rclcpp::Client<ServiceT>::SharedPtr = std::shared_ptr<rclcpp::Client<lifecycle_msgs::srv::GetState> >; std::string = std::__cxx11::basic_string<char>; rmw_qos_profile_t = rmw_qos_profile_s; rclcpp::CallbackGroup::SharedPtr = std::shared_ptr<rclcpp::CallbackGroup>]’
            小鱼 技术大佬 @1032063747
            @1032063747 第二个命令应该在第一个后面输入,注意终端目录
            • 19238250151
              Woah damn @小鱼
              • 19238250151
                Woah damn @1923825015
                @1923825015 https://fishros.org.cn/forum/topic/923/fishbot配套资料教程汇总?lang=zh-CN
                • 19238250151
                  Woah damn @小鱼
                  source install/setup.bash
                  哥,我前面都弄好了,最后一步点击Rviz2工具栏——2D Pose Estimate没有反应是什么原因?4157af28-15b1-4766-9385-eaf865be402c-1709551263769.png ,是Ubuntu22.04,humble版本,前面的都没问题,知道一下呗,很急!!!重试了很多次都是没反应。
                    小鱼 技术大佬 @1923825015
                    @1923825015 你提供的信息不足,连个日志都没有
                    • 19238250151
                      Woah damn @小鱼
                      平台:Ubuntu22.04 ROS:humble
                      具体操作步骤和执行状态如下:
                      1、启动micro-ros命令:
                      状态正常,可以接收到话题
                      2、启动雷达驱动:
                      在新开的RVIZ中可以看到雷达正常工作。
                      4、运行程序,加载地图如下3913b6df-269e-48d1-bb6e-fbc8af74dcd2-1709557682799.png cd0cfc78-dcd9-4bfe-9b00-c4a878c3ec51-1709557670585.png fd271237-1e0a-405e-bfc4-851700638cb1-1709557660299.png 190802ed-f1ae-41ea-a0b0-3da74e614b44-1709557650488.png
                        小鱼 技术大佬 @1923825015
                        @1923825015 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                        这里选的几?
                        这一步你怎么跳过了?
                        三、启动bringup
                        bringup节点目前主要将odom话题转成tf并,并发布机器本体的tf广播
                        19238250151 1 条回复 最后回复 回复 引用 1
                        • 19238250151
                          Woah damn @小鱼
                          @小鱼 好的,已经解决了,再问一下,这小车可以定点巡航嘛?就比如自动走圆形,或者其他图案。
                            小鱼 技术大佬 @1923825015
                            @1923825015 这个要自己去开发了,属于应用层的东西了
                            • 19238250151
                              Woah damn @小鱼
                              此时你可以使用rviz2的工具栏中的Nav2 Goal发送一个目标点,然后观察机器人运动即可。 这一步经常无法实现,有什么解决的方法嘛?每次发送目标时,小车就原地转圈。
                                小鱼 技术大佬 @1923825015
                                @1923825015 可能你的图有问题,也可能你的线松了,需要进一步排查
                                • 19238250151
                                  Woah damn @小鱼
                                  @小鱼 哥,具体的排查方法有吗?图我已经建了不低于三个了,然后系统我也重装了两次了,至于接线的话,我平装好之后就没动过线,反正到现在导航就是不行,每次导航,小车就在原地转圈,只有把小车电源关闭了,才能停下来。能帮我解决一下嘛 求求了。
                                  小鱼小 1 2 条回复 最后回复 回复 引用 0
                                    小鱼 技术大佬 @1923825015
                                    @1923825015 手动遥控是否正常,代价地图是否正常
                                    • 19238250151
                                      Woah damn @小鱼
                                      @小鱼 键盘控制正常的,代价地图我不清楚怎样才算正常,反正点击Rviz2工具栏——2D Pose Estimate,然后在地图上点个目标点并选择方向后,全局代价地图以及被地代价地图以及激光在地图上都标记出来了,这样算算正常嘛?
                                      • G
                                        guoxiaoqing2350
                                        1. Configuration : Ubuntu 22.04 humble + ros2
                                        1. issues 情景 + 尝试解决方案:
                                          (1) 初始问题 (retry_test_1):
                                        • 操作:按原教程使用
                                        cd fishbot
                                        rosdepc install --from-paths src --ignore-src -y  -r # 安装依赖
                                        • 结果:all packages 全部编译失败
                                          (2) retry_test_2:
                                        • 操作:手动 download “ https://github.com/fishros/fishbot ” 的 humble 源码,后添加依赖,后 colcon build
                                        • 结果:只有 “fishbot_description” package 编译成功,其它失败
                                          (3) retry_test_3:
                                          每个pkg 单独编译,结果 同(2)
                                          (4) retry_test_4:
                                          (5) 思考:
                                        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ ls
                                        fishbot  fishbot-1.0.0.zip  map
                                        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws$ cd fishbot/
                                        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ ls
                                        doc  README.md  src
                                        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ rosdepc install --from-paths src --ignore-src -y  -r
                                        欢迎使用国内版rosdep之rosdepc,我是作者小鱼!
                                        小鱼rosdepc正式为您服务
                                        (base) ros2@ros2-virtual-machine:~/Desktop/d2lros2/chapt2/Julie_ws/fishbot$ colcon build
                                        Starting >>> fishbot_bringup
                                        Finished <<< fishbot_description [3.93s]
                                          execute_process(/home/ros2/miniconda3/bin/python3
                                          /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/src/fishbot_navigation2/package.xml
                                          /home/ros2/Desktop/d2lros2/chapt2/Julie_ws/fishbot/build/fishbot_navigation2/ament_cmake_core/package.cmake)
                                          returned error code 1
                                          CMakeLists.txt:34 (ament_lint_auto_find_test_dependencies)
                                        Failed   <<< fishbot_navigation2 [4.18s, exited with code 1]
                                        Aborted  <<< fishbot_cartographer [8.20s]
                                        Aborted  <<< fishbot_interfaces [7.96s]
                                        Aborted  <<< fishbot_bringup [13.3s]
                                        Summary: 1 package finished [15.9s]
                                          3 packages aborted: fishbot_bringup fishbot_cartographer fishbot_interfaces
                                          小鱼 技术大佬 @guoxiaoqing2350
                                          @guoxiaoqing2350 在 [FishBot教程]7. FishBot-Nav2导航测试 中说:
                                          (base)
                                          请退出conda!!!!
                                          G 1 条回复 最后回复 回复 引用 0
                                          • G
                                            guoxiaoqing2350 @小鱼
                                            @小鱼 谢谢小鱼,已经解决了
