    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    802.7k
    • A
      anzg512
      ping 正常 虚拟机也设置桥街模式 IP设置也正确 为什么还是连接不上呢?!
        小鱼 技术大佬 @anzg512
        @anzg512 参考这个视频看一下, FishBot常见问题汇总:
        链接:https://pan.baidu.com/s/14NKr0QLTnlWwcbUg97IFBQ?pwd=fish
        • 23520949922
          小皮
          博主您好,我可以ping通我的雷达,但是在第一步启动驱动的时候一直停留在 prepare to accept connect。这是为啥呢,好奇怪?烦请大佬指点一二!3a2ce694aad37bf97994af4e960e468.jpg
            小鱼 技术大佬 @2352094992
            @2352094992 检查雷达连接,跳线帽,工作模式
              flyingPig
              最后由 2216096692 编辑
              雷达已上路由
              PING 192.168.1.103
              (192.168.1.103) 56(84) bytes of data.
              64 bytes from 192.168.1.103: icmp_seq=1 ttl=255 time=5.76 ms
              64 bytes from 192.168.1.103: icmp_seq=2 ttl=255 tinme=23.9 ms
              64 bytes from 192.168.1.103: icmp_seq=3 ttl=255 time=4.62 ms
              64 bytes from 192.168.1.103: icmp_seq=4 ttl=255 timie=8.08
              64 bytes from 192.168.1.103: icmp_seq=5 ttl=255 time=9.46 ms
              64 bytes from 192.168.1.103: icmp_seq=6 ttl=255 time=13.2 ms
              64 bytes from 192.168.1.103: icmp_seq=7 ttl=255 time=5.02 ms
              ms
              Now YDLIDAR is scanning
              等5 -10 分钟左右,出 timout count
              欢迎鱼香ROS使用雷达驱动系统,注意当前版本为ROS2版本驱动功哦
              1)驱动雷达
              2)建图测试
              3)退出
              #? 1
              Prepare to Accept connect!
              3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketK
              , proto=0, laddr=('172.17.0.3', 8888), raddr=(
              PTY: Opened /dev/pts/7 for 0.0.0.0:8888
              192.168.1.103', 49
              [YDLIDAR] :SDK Version: 1.4.5
              [YDLIDAR]:Lidar running correctly ! The health statuus: good
              [YDLIDAR] Connection established in [/tmp/fishbot_laser][[115200] :
              Firmware version: 1.5
              Hardware version: 1
              Model: S4
              Serial: 2021042500000085
              [YDLIDAR]:Fixed Size: 410
              [YDLIDAR]:Sample Rate: 3K
              [YDLIDAR INFO]
              [ERROR] [1711427477.710755044] [ydlidar_node]: Failed to getscan
              timout count: 1
              但是,选 2 测试,又能扫出东西来,虽然有报错
              [rviz2-5] [ERROR] [1711427701.753874806] [rviz2]: Lobookup would require extrapolation into the future.Requ
              Tested time 1711427701.869087 but the latest datais at time 1711427701.869087, when looking up transform fin
              om frame [laser_frame] to frame [map]
              list 有 scan 的会话,但是无效的
              fp-macpro@fpmacpro-MacBookPro:~$ ros2 topic list
              /parameter_events
              /rosout
              /scan
              fp-macpro@fpmacpro-MacBookPro:~$ ros2 topic hz /scan
              请问啥问题?和 帖子里说的 timout count: 1 的原因好像不一样啊?
              26932262522 小鱼小 2 条回复 最后回复 回复 引用 0
              • 26932262522
                命里有我 @2216096692
                @2216096692 我和你有一样的问题呜呜呜
                  小鱼 技术大佬 @2216096692
                  @2216096692 偶尔出一个timeout没事,能建图就说明数据没啥问题,另外驱动过后,需要开新的终端测试,看你的图好像退出后再用hz查看,但驱动已经退出了,肯定没有数据
                  M 1 条回复 最后回复 回复 引用 0
                  • 5152617255
                    空无之时
                    保存地图出错
                    使用小鱼在B站分享的fishros2的fishbotU盘系统,而且我用一键安装指令重装了ROS2依旧报错。
                      小鱼 技术大佬 @515261725
                      @515261725 你有安装nav2吗,上下文操作有哪些?
                      • M
                        mixllred @小鱼
                        @小鱼 鱼哥,我也有这个问题,每次都扫描开始一会就会timeout,然后就ERROR了,地图扫描不完整
                        终端如下:
                        [INFO] [launch]: All log files can be found below /root/.ros/log/2024-04-16-12-06-30-681768-ec555413ec15-47
                        [INFO] [laser_x2-1]: process started with pid [48]
                        [INFO] [static_transform_publisher-2]: process started with pid [50]
                        [INFO] [cartographer_node-3]: process started with pid [52]
                        [INFO] [cartographer_occupancy_grid_node-4]: process started with pid [54]
                        [INFO] [rviz2-5]: process started with pid [56]
                        [static_transform_publisher-2] [WARN] [1713269191.318786549] []: Old-style arguments are deprecated; see --help for new-style arguments
                        [static_transform_publisher-2] [INFO] [1713269191.583721233] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                        [static_transform_publisher-2] translation: ('0.000000', '0.000000', '0.000000')
                        [cartographer_node-3] [INFO] [1713269191.671332461] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/workspace/install/fishbot_laser_driver/share/fishbot_laser_driver/config/fishbot_laser_2d.lua' for 'fishbot_laser_2d.lua'.
                        [cartographer_node-3] [INFO] [1713269191.675178836] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                        [cartographer_node-3] [INFO] [1713269191.677415568] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                        [cartographer_node-3] [INFO] [1713269191.681007798] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                        [cartographer_node-3] [INFO] [1713269191.682020949] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                        [cartographer_node-3] [INFO] [1713269191.683193823] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                        [cartographer_node-3] [INFO] [1713269191.684767187] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                        [cartographer_node-3] [INFO] [1713269191.685998156] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                        [cartographer_node-3] [INFO] [1713269191.686030258] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                        [cartographer_node-3] [INFO] [1713269191.687939363] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                        [cartographer_node-3] [INFO] [1713269191.687977251] [cartographer logger]: I0416 12:06:31.000000 52 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                        [cartographer_node-3] [INFO] [1713269191.761594023] [cartographer logger]: I0416 12:06:31.000000 52 map_builder_bridge.cpp:136] Added trajectory with ID '0'.
                        [rviz2-5] QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
                        [rviz2-5] [INFO] [1713269194.620629614] [rviz2]: Stereo is NOT SUPPORTED
                        [rviz2-5] [INFO] [1713269194.621912638] [rviz2]: OpenGl version: 4.1 (GLSL 4.1)
                        [rviz2-5] [INFO] [1713269194.754669959] [rviz2]: Stereo is NOT SUPPORTED
                        [cartographer_node-3] [INFO] [1713269205.685849593] [cartographer logger]: I0416 12:06:45.000000 52 ordered_multi_queue.cc:172] All sensor data for trajectory 0 is available starting at '638488660056556545'.
                        [cartographer_node-3] [INFO] [1713269205.686133853] [cartographer logger]: I0416 12:06:45.000000 52 local_trajectory_builder_2d.cc:135] Extrapolator is still initializing.
                        [cartographer_node-3] [INFO] [1713269205.786017544] [cartographer logger]: I0416 12:06:45.000000 52 pose_graph_2d.cc:148] Inserted submap (0, 0).
                        [rviz2-5] [INFO] [1713269206.710351584] [rviz2]: Trying to create a map of size 157 x 75 using 1 swatches
                        [rviz2-5] [ERROR] [1713269206.742586494] [rviz2]: Vertex Program:rviz/glsl120/indexed_8bit_image.vert Fragment Program:rviz/glsl120/indexed_8bit_image.frag GLSL link result :
                        [cartographer_node-3] [INFO] [1713269207.336078908] [cartographer logger]: I0416 12:06:47.000000 52 collated_trajectory_builder.cc:81] scan rate: 1.20 Hz 8.36e-01 s +/- 9.58e-01 s (pulsed at 101.84% real time)
                        [rviz2-5] [ERROR] [1713269207.352292656] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269207.326929 but the latest data is at time 1713269207.325720, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.109143317] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.211466 but the latest data is at time 1713269209.211132, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.334953712] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.469465 but the latest data is at time 1713269209.340465, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.461521477] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.598465 but the latest data is at time 1713269209.598465, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.590836696] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.727465 but the latest data is at time 1713269209.680132, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.749655316] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.835842 but the latest data is at time 1713269209.835508, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269209.877724903] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269209.965175 but the latest data is at time 1713269209.965175, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [INFO] [1713269210.711138962] [rviz2]: Trying to create a map of size 158 x 76 using 1 swatches
                        [rviz2-5] [ERROR] [1713269211.638195663] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269211.651583 but the latest data is at time 1713269211.651250, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269211.768248920] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269211.879476 but the latest data is at time 1713269211.879142, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269212.953693786] [rviz2]: Lookup would require extrapolation into the past. Requested time 1079831768.051021 but the earliest data is at time 1713269205.814118, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269213.045640846] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269213.160907 but the latest data is at time 1713269213.160573, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269213.173373009] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269213.289907 but the latest data is at time 1713269213.289907, when looking up transform from frame [laser_frame] to frame [map]
                        [cartographer_node-3] [WARN] [1713269213.282777994] [cartographer logger]: W0416 12:06:53.000000 52 range_data_collator.cc:82] Dropped 1 earlier points.
                        [rviz2-5] [ERROR] [1713269213.302591756] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269213.418573 but the latest data is at time 1713269213.418240, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269213.493703933] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269213.547573 but the latest data is at time 1713269213.547573, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269215.221313290] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269215.256422 but the latest data is at time 1713269215.256088, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [ERROR] [1713269215.414464657] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269215.465421 but the latest data is at time 1713269215.465421, when looking up transform from frame [laser_frame] to frame [map]
                        [rviz2-5] [INFO] [1713269215.533682452] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1713269205.526 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
                        [rviz2-5] [ERROR] [1713269215.542120629] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713269215.594754 but the latest data is at time 1713269215.550088, when looking up transform from frame [laser_frame] to frame [map]
                          小鱼 技术大佬 @mixllred
                          @mixllred 检查下网络结构
                          M 2 条回复 最后回复 回复 引用 0
                          • M
                            mixllred @小鱼
                            @小鱼 鱼哥,我是用电脑开的热点,虚拟机用的是桥接模式
                            • M
                              mixllred @小鱼
                              #? 1
                              3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.2', 8888), raddr=('192.168.43.165', 62715)> 4
                              PTY: Opened /dev/pts/2 for 0.0.0.0:8888
                              [YDLIDAR]:SDK Version: 1.4.5
                              Hardware version: 1
                              Model: S4
                              Serial: 2020101300002268
                              [YDLIDAR]:Fixed Size: 390
                              [YDLIDAR]:Sample Rate: 4K
                              [YDLIDAR INFO] Current Sampling Rate : 4K
                              timout count: 1
                              [ERROR] [1713320114.687064868] [ydlidar_node]: Failed to get scan
                              timout count: 2
                              [ERROR] [1713320116.687741811] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320118.689269687] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320120.691270177] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320122.691578106] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320124.692916798] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320126.693436285] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320128.694099668] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320130.695395445] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320132.695617436] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320134.696474381] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320136.697445108] [ydlidar_node]: Failed to get scan
                              [ERROR] [1713320138.698319895] [ydlidar_node]: Failed to get scan
                              ^C[INFO] [1713320140.087169237] [rclcpp]: signal_handler(signum=2)
                              File "/workspace/install/fishbot_laser_driver/lib/fishbot_laser_driver/laser_x2", line 33, in <module>
                              sys.exit(load_entry_point('fishbot-laser-driver==0.0.0', 'console_scripts', 'laser_x2')())
                              File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 83, in main
                              SocketServer()
                              File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 35, in init
                              self.main()
                              File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 61, in main
                              fdlist = mypoll.poll(256)
                              KeyboardInterrupt
                              [ros2run]: Interrupt
                              • M
                                mixllred @mixllred
                                @mixllred
                                建图前雷达连接正常,开始建图后雷达转接板指示灯一闪一闪,出现以上报错,出现基本地图图像后建图停止,一个坐标轴开始偏离起始点(雷达没有移动)
                                • M
                                  mixllred @mixllred
                                  @mixllred 在 [FishBot教程] 6. 雷达驱动及建图测试 中说:
                                  @mixllred
                                  M 2 2 条回复 最后回复 回复 引用 1
                                  • M
                                    mixllred @mixllred
                                    @mixllred
                                    1. 驱动雷达
                                    2. 建图测试
                                    3. 退出
                                      #? 2
                                      [INFO] [launch]: All log files can be found below /root/.ros/log/2024-04-17-03-09-33-024637-0e0b6e597728-48
                                      [INFO] [laser_x2-1]: process started with pid [49]
                                      [INFO] [static_transform_publisher-2]: process started with pid [51]
                                      [INFO] [cartographer_node-3]: process started with pid [53]
                                      [INFO] [cartographer_occupancy_grid_node-4]: process started with pid [55]
                                      [INFO] [rviz2-5]: process started with pid [57]
                                      [static_transform_publisher-2] [WARN] [1713323373.381805889] []: Old-style arguments are deprecated; see --help for new-style arguments
                                      [static_transform_publisher-2] [INFO] [1713323373.453802981] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                      [cartographer_node-3] [INFO] [1713323373.468241251] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/workspace/install/fishbot_laser_driver/share/fishbot_laser_driver/config/fishbot_laser_2d.lua' for 'fishbot_laser_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.470254898] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.471063510] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.472037645] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.472087576] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.472576546] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.472652258] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.473540021] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.473565354] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.475454388] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.475525833] [cartographer logger]: I0417 03:09:33.000000 53 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                                      [cartographer_node-3] [INFO] [1713323373.513228297] [cartographer logger]: I0417 03:09:33.000000 53 map_builder_bridge.cpp:136] Added trajectory with ID '0'.
                                      [rviz2-5] [INFO] [1713323375.276606532] [rviz2]: Stereo is NOT SUPPORTED
                                      [rviz2-5] [INFO] [1713323375.276847655] [rviz2]: OpenGl version: 4.1 (GLSL 4.1)
                                      [rviz2-5] [INFO] [1713323375.377706087] [rviz2]: Stereo is NOT SUPPORTED
                                      [INFO] [rviz2-5]: process has finished cleanly [pid 57]
                                      [static_transform_publisher-2] [INFO] [1713323445.889626697] [rclcpp]: signal_handler(signum=2)
                                      [cartographer_occupancy_grid_node-4] [INFO] [1713323445.889629396] [rclcpp]: signal_handler(signum=2)
                                      [laser_x2-1] Traceback (most recent call last):
                                      [laser_x2-1] File "/workspace/install/fishbot_laser_driver/lib/fishbot_laser_driver/laser_x2", line 33, in <module>
                                      [laser_x2-1] sys.exit(load_entry_point('fishbot-laser-driver==0.0.0', 'console_scripts', 'laser_x2')())
                                      [laser_x2-1] File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 83, in main
                                      [cartographer_node-3] [INFO] [1713323445.890779139] [rclcpp]: signal_handler(signum=2)
                                      [cartographer_node-3] [INFO] [1713323445.892393929] [cartographer logger]: I0417 03:10:45.000000 53 node.cpp:569] Shutdown the subscriber of [scan]
                                      [cartographer_node-3] [INFO] [1713323445.892404802] [cartographer logger]: I0417 03:10:45.000000 53 map_builder_bridge.cpp:152] Finishing trajectory with ID '0'...
                                      [cartographer_node-3] [INFO] [1713323445.892462594] [cartographer logger]: I0417 03:10:45.000000 53 map_builder_bridge.cpp:161] Running final trajectory optimization...
                                      [cartographer_node-3] [INFO] [1713323445.892541842] [cartographer logger]: I0417 03:10:45.000000 90 pose_graph_2d.cc:538] Remaining work items in queue: 2
                                      [cartographer_node-3] [INFO] [1713323445.892582549] [cartographer logger]: I0417 03:10:45.000000 90 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                      [cartographer_node-3] [INFO] [1713323445.892593095] [cartographer logger]: I0417 03:10:45.000000 90 constraint_builder_2d.cc:292] Score histogram:
                                      [cartographer_node-3] Count: 0
                                      [cartographer_node-3] [INFO] [1713323445.892601242] [cartographer logger]: I0417 03:10:45.000000 90 pose_graph_2d.cc:538] Remaining work items in queue: 1
                                      [cartographer_node-3] [INFO] [1713323445.892608468] [cartographer logger]: I0417 03:10:45.000000 90 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                      [cartographer_node-3] [INFO] [1713323445.892612679] [cartographer logger]: I0417 03:10:45.000000 90 constraint_builder_2d.cc:292] Score histogram:
                                      [laser_x2-1] SocketServer()
                                      [laser_x2-1] File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 35, in init
                                      [laser_x2-1] self.main()
                                      [laser_x2-1] File "/workspace/install/fishbot_laser_driver/lib/python3.10/site-packages/fishbot_laser_driver/fishbot_laser_x2.py", line 52, in main
                                      [laser_x2-1] client, client_address = s.accept()
                                      [laser_x2-1] File "/usr/lib/python3.10/socket.py", line 293, in accept
                                      [cartographer_node-3] [INFO] [1713323445.897581908] [cartographer logger]: I0417 03:10:45.000000 93 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                      [cartographer_node-3] [INFO] [1713323445.897597265] [cartographer logger]: I0417 03:10:45.000000 93 constraint_builder_2d.cc:292] Score histogram:
                                      [laser_x2-1] fd, addr = self._accept()
                                      [laser_x2-1] KeyboardInterrupt
                                      Optimizing: Done.
                                      [cartographer_node-3] [INFO] [1713323445.908903661] [cartographer logger]: I0417 03:10:45.000000 92 constraint_builder_2d.cc:290] 0 computations resulted in 0 additional constraints.
                                      [cartographer_node-3] [INFO] [1713323445.908924915] [cartographer logger]: I0417 03:10:45.000000 92 constraint_builder_2d.cc:292] Score histogram:
                                      Optimizing: Done.
                                      [ERROR] [laser_x2-1]: process has died [pid 49, exit code -2, cmd '/workspace/install/fishbot_laser_driver/lib/fishbot_laser_driver/laser_x2 --ros-args -r __node:=laser_x2'].
                                      [INFO] [static_transform_publisher-2]: process has finished cleanly [pid 51]
                                      [INFO] [cartographer_occupancy_grid_node-4]: process has finished cleanly [pid 55]
                                      [INFO] [cartographer_node-3]: process has finished cleanly [pid 53]
                                      #? 2
                                      [INFO] [launch]: All log files can be found below /root/.ros/log/2024-04-17-03-10-59-823487-0e0b6e597728-119
                                      [INFO] [laser_x2-1]: process started with pid [120]
                                      [INFO] [static_transform_publisher-2]: process started with pid [122]
                                      [INFO] [cartographer_node-3]: process started with pid [124]
                                      [INFO] [cartographer_occupancy_grid_node-4]: process started with pid [136]
                                      [INFO] [rviz2-5]: process started with pid [138]
                                      [static_transform_publisher-2] [WARN] [1713323459.910656240] []: Old-style arguments are deprecated; see --help for new-style arguments
                                      [static_transform_publisher-2] [INFO] [1713323459.922487664] [static_tf_pub_laser]: Spinning until stopped - publishing transform
                                      [cartographer_node-3] [INFO] [1713323459.989363279] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/workspace/install/fishbot_laser_driver/share/fishbot_laser_driver/config/fishbot_laser_2d.lua' for 'fishbot_laser_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.992598529] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.993731283] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/map_builder.lua' for 'map_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.994592105] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.995089465] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/pose_graph.lua' for 'pose_graph.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.995736823] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.996473406] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder.lua' for 'trajectory_builder.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.997757398] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.998694898] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_2d.lua' for 'trajectory_builder_2d.lua'.
                                      [cartographer_node-3] [INFO] [1713323459.999343172] [cartographer logger]: I0417 03:10:59.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                                      [cartographer_node-3] [INFO] [1713323460.000050997] [cartographer logger]: I0417 03:11:00.000000 124 configuration_file_resolver.cc:41] Found '/opt/ros/humble/share/cartographer/configuration_files/trajectory_builder_3d.lua' for 'trajectory_builder_3d.lua'.
                                      [cartographer_node-3] [INFO] [1713323460.013546805] [cartographer logger]: I0417 03:11:00.000000 124 map_builder_bridge.cpp:136] Added trajectory with ID '0'.
                                      [rviz2-5] [INFO] [1713323461.468663953] [rviz2]: Stereo is NOT SUPPORTED
                                      [rviz2-5] [INFO] [1713323461.470127987] [rviz2]: OpenGl version: 4.1 (GLSL 4.1)
                                      [rviz2-5] [INFO] [1713323461.502845070] [rviz2]: Stereo is NOT SUPPORTED
                                      [laser_x2-1] timout count: 1
                                      [cartographer_node-3] [INFO] [1713323481.123088627] [cartographer logger]: I0417 03:11:21.000000 124 ordered_multi_queue.cc:172] All sensor data for trajectory 0 is available starting at '638489202810840850'.
                                      [cartographer_node-3] [INFO] [1713323481.123138202] [cartographer logger]: I0417 03:11:21.000000 124 collated_trajectory_builder.cc:81] scan rate: unknown
                                      [cartographer_node-3] [INFO] [1713323481.123171552] [cartographer logger]: I0417 03:11:21.000000 124 local_trajectory_builder_2d.cc:135] Extrapolator is still initializing.
                                      [cartographer_node-3] [INFO] [1713323481.150925466] [cartographer logger]: I0417 03:11:21.000000 124 pose_graph_2d.cc:148] Inserted submap (0, 0).
                                      [rviz2-5] [INFO] [1713323482.028109586] [rviz2]: Trying to create a map of size 156 x 72 using 1 swatches
                                      [rviz2-5] [ERROR] [1713323482.054869295] [rviz2]: Vertex Program:rviz/glsl120/indexed_8bit_image.vert Fragment Program:rviz/glsl120/indexed_8bit_image.frag GLSL link result :
                                      [rviz2-5] [ERROR] [1713323483.856608731] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323483.861673 but the latest data is at time 1713323483.861673, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [ERROR] [1713323485.386181754] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323485.397941 but the latest data is at time 1713323485.397691, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [INFO] [1713323488.007710668] [rviz2]: Trying to create a map of size 158 x 73 using 1 swatches
                                      [rviz2-5] [ERROR] [1713323488.456158042] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323488.462029 but the latest data is at time 1713323488.461279, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [INFO] [1713323489.001771792] [rviz2]: Trying to create a map of size 160 x 74 using 1 swatches
                                      [rviz2-5] [ERROR] [1713323489.863286941] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323489.861070 but the latest data is at time 1713323489.860945, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [INFO] [1713323491.042040818] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1713323481.033 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
                                      [rviz2-5] [INFO] [1713323491.125363673] [rviz2]: Message Filter dropping message: frame 'laser_frame' at time 1713323481.123 for reason 'the timestamp on the message is earlier than all the data in the transform cache'
                                      [rviz2-5] [ERROR] [1713323491.432702030] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323491.444609 but the latest data is at time 1713323491.429419, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [ERROR] [1713323492.969022591] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323492.968907 but the latest data is at time 1713323492.968782, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [INFO] [1713323493.992594985] [rviz2]: Trying to create a map of size 160 x 155 using 1 swatches
                                      [rviz2-5] [ERROR] [1713323494.664151929] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323494.659646 but the latest data is at time 1713323494.659021, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [ERROR] [1713323494.892792809] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323494.936818 but the latest data is at time 1713323494.936818, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [ERROR] [1713323495.015974891] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323495.061806 but the latest data is at time 1713323495.061556, when looking up transform from frame [laser_frame] to frame [map]
                                      [rviz2-5] [ERROR] [1713323495.176454398] [rviz2]: Lookup would require extrapolation into the future. Requested time 1713323495.186660 but the latest data is at time 1713323495.186035, when looking up transform from frame [laser_frame] to frame [map]
                                      [cartographer_node-3] [INFO] [1713323496.388982766] [cartographer logger]: I0417 03:11:36.000000 124 collated_trajectory_builder.cc:81] scan rate: 1.63 Hz 6.12e-01 s +/- 6.30e-01 s (pulsed at 99.92% real time)
                                      [rviz2-5]
                                    • M
                                      mixllred @mixllred
                                      @mixllred
                                      ) 驱动雷达
                                      2) 建图测试
                                      3) 退出
                                      #? 1
                                      3 <socket.socket fd=6, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=0, laddr=('172.17.0.2', 8888), raddr=('192.168.43.165', 62416)> 4
                                      PTY: Opened /dev/pts/1 for 0.0.0.0:8888
                                      Hardware version: 1
                                      Model: S4
                                      [YDLIDAR]:Fixed Size: 360
                                      timout count: 1
                                      [ERROR] [1713344387.186853131] [ydlidar_node]: Failed to get scan
                                      timout count: 2
                                      [ERROR] [1713344389.187233959] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344391.188039318] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344393.188949412] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344395.189370541] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344397.190185397] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344399.191660545] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344401.191919681] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344403.192957289] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344405.193506477] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344407.194619107] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344409.195089088] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344411.195370974] [ydlidar_node]: Failed to get scan
                                      [ERROR] [1713344413.196157579] [ydlidar_node]: Failed to get scan
                                        小鱼 技术大佬 @mixllred
                                        @mixllred 请按照要求,单独发帖提问
                                        • M
                                          mixllred @小鱼
                                          @小鱼 https://fishros.org.cn/forum/topic/2465/fishbot雷达建图中断
                                          • 13173076181
                                            苏格拉没有底
                                            雷达建图不是很清晰,感觉很模糊,是啥问题,如何解决
