    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    48.1k
    • 8477189568
      H.
      问题:进行到2.3重新编译工程后,删除libmicroros文件夹后出现编译错误
      错误日志
      Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
      Verbose mode can be enabled via `-v, --verbose` option
      CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
      PLATFORM: Espressif 32 (5.2.0) > Adafruit ESP32 Feather
      HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
      DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
      PACKAGES:
       - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
       - tool-esptoolpy @ 1.40201.0 (4.2.1)
       - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
      LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
      LDF Modes: Finder ~ chain, Compatibility ~ soft
      Installing pyyaml with pip at PlatformIO environment
      /home/xhy/.platformio/penv/bin/python -m pip install pyyaml
      Requirement already satisfied: pyyaml in /home/xhy/.platformio/penv/lib/python3.10/site-packages (6.0)
      Installing markupsafe==2.0.1 with pip at PlatformIO environment
      /home/xhy/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
      Requirement already satisfied: markupsafe==2.0.1 in /home/xhy/.platformio/penv/lib/python3.10/site-packages (2.0.1)
      Configuring featheresp32 with transport serial
      Building micro-ROS dev dependencies
      Checking extra packages
               - Adding interfaces
               - Adding install
               - Adding build
               - Adding log
      Building micro-ROS library
      Build mcu micro-ROS environment failed:
      --- stderr: rosidl_typesupport_interface
      CMake Warning:
        Manually-specified variables were not used by the project:
          CMAKE_POSITION_INDEPENDENT_CODE
          THIRDPARTY
      --- stderr: rosidl_cli
      /home/xhy/.platformio/penv/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
        warnings.warn(
      --- stderr: rmw_implementation_cmake
      CMake Warning:
          BUILD_SHARED_LIBS
          THIRDPARTY
      --- stderr: rosidl_adapter
      CMake Warning:
          BUILD_SHARED_LIBS
          THIRDPARTY
      --- stderr: microcdr
      CMake Warning:
          BUILD_TESTING
          THIRDPARTY
      --- stderr: tracetools
      CMake Warning:
          THIRDPARTY
      --- stderr: rcutils
      CMake Warning:
          ENABLE_TESTING
          THIRDPARTY
      In function 'rcutils_char_array_strncat',
          inlined from 'rcutils_char_array_strcat' at /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10:
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:224:3: warning: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
         strncat(char_array->buffer, src, n);
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c: In function 'rcutils_char_array_strcat':
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10: note: length computed here
         return rcutils_char_array_strncat(char_array, src, strlen(src));
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c: In function 'rcutils_get_error_string':
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: warning: initializer-string for array of chars is too long
           return (rcutils_error_string_t) {"error not set"};  // NOLINT(readability/braces)
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: note: (near initialization for '(anonymous).str')
      In file included from /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:35:
      At top level:
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:109:1: warning: '__rcutils_convert_uint64_t_into_c_str' defined but not used [-Wunused-function]
       __rcutils_convert_uint64_t_into_c_str(uint64_t number, char * buffer, size_t buffer_size)
      /home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:91:1: warning: '__rcutils_reverse_str' defined but not used [-Wunused-function]
       __rcutils_reverse_str(char * string_in, size_t string_len)
      --- stderr: rosidl_parser
      CMake Warning:
          BUILD_SHARED_LIBS
          THIRDPARTY
      CMake Error at cmake_install.cmake:119 (file):
        file INSTALL cannot find
        "/home/xhy/Documents/PlatformIO/interface_Oled_demo/custom_interface_Oled/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rosidl/rosidl_parser/bin/idl2png":
        No such file or directory.
      Failed   <<< rosidl_parser [7.57s, exited with code 1]
      ======================================================================== [FAILED] Took 117.00 seconds ========================================================================
       *  终端进程“platformio 'run'”已终止,退出代码: 1。
       *  终端将被任务重用,按任意键关闭。
      小鱼小 8421452488 铁 3 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @847718956
        @847718956 你的系统环境是20,还是22.04
        8477189568 1 条回复 最后回复 回复 引用 0
        • 8477189568
          H. @小鱼
          最后由 847718956 编辑
          @小鱼 22.04 ros_humble
            小鱼 技术大佬 @847718956
            @847718956 搞定了,更新了代码,已有工程解决方案如下:
            打开工程,删除目录.pio/libdeps/featheresp32/micro_ros_platformio
            接着重新点击编译即可。
            PACKAGES:
            /home/fishros/.platformio/penv/bin/python -m pip install pyyaml
            Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
            Requirement already satisfied: pyyaml in /home/fishros/.platformio/penv/lib/python3.10/site-packages (6.0)
            [notice] A new release of pip available: 22.3.1 -> 23.0
            [notice] To update, run: pip install --upgrade pip
            /home/fishros/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
            Requirement already satisfied: markupsafe==2.0.1 in /home/fishros/.platformio/penv/lib/python3.10/site-packages (2.0.1)
            Configuring featheresp32 with transport custom
            Downloading micro-ROS dev dependencies
                     - Downloaded ament_cmake
                     - Downloaded ament_lint
                     - Downloaded ament_package
                     - Downloaded googletest
                     - Downloaded ament_cmake_ros
                     - Downloaded ament_index
            Downloading micro-ROS library
                     - Downloaded microcdr
                     - Downloaded microxrcedds_client
                     - Downloaded rcl
                     - Downloaded rcl_action
                     - Downloaded rcl_lifecycle
                     - Downloaded rcl_yaml_param_parser (ignored)
                     - Downloaded rclc_parameter
                     - Downloaded rclc_examples (ignored)
                     - Downloaded rclc
                     - Downloaded rclc_lifecycle
                     - Downloaded micro_ros_utilities
                     - Downloaded rcutils
                     - Downloaded micro_ros_msgs
                     - Downloaded rmw_microxrcedds
                     - Downloaded rosidl_typesupport_cpp (ignored)
                     - Downloaded rosidl_typesupport_microxrcedds_c
                     - Downloaded rosidl_typesupport_microxrcedds_test_msg
                     - Downloaded rosidl_typesupport_microxrcedds_cpp_tests
                     - Downloaded rosidl_typesupport_microxrcedds_c_tests
                     - Downloaded rosidl_typesupport_microxrcedds_cpp (ignored)
                     - Downloaded rosidl_generator_c
                     - Downloaded rosidl_runtime_cpp (ignored)
                     - Downloaded rosidl_typesupport_introspection_cpp (ignored)
                     - Downloaded rosidl_generator_cpp (ignored)
                     - Downloaded rosidl_typesupport_introspection_tests
                     - Downloaded rosidl_parser
                     - Downloaded rosidl_cmake
                     - Downloaded rosidl_adapter
                     - Downloaded rosidl_typesupport_interface
                     - Downloaded rosidl_cli
                     - Downloaded rmw_implementation_cmake
                     - Downloaded rmw
                     - Downloaded composition_interfaces
                     - Downloaded test_msgs
                     - Downloaded rosgraph_msgs
                     - Downloaded rcl_interfaces
                     - Downloaded action_msgs
                     - Downloaded lifecycle_msgs
                     - Downloaded builtin_interfaces
                     - Downloaded statistics_msgs
                     - Downloaded rosidl_default_generators
                     - Downloaded rosidl_default_runtime
                     - Downloaded unique_identifier_msgs
                     - Downloaded actionlib_msgs
                     - Downloaded visualization_msgs
                     - Downloaded trajectory_msgs
                     - Downloaded sensor_msgs_py
                     - Downloaded stereo_msgs
                     - Downloaded common_interfaces
                     - Downloaded shape_msgs
                     - Downloaded geometry_msgs
                     - Downloaded std_srvs
                     - Downloaded diagnostic_msgs
                     - Downloaded std_msgs
                     - Downloaded nav_msgs
                     - Downloaded test_interface_files
                     - Downloaded test_rmw_implementation
                     - Downloaded rcl_logging_interface
                     - Downloaded rcl_logging_spdlog (ignored)
                     - Downloaded rcl_logging_noop
                     - Downloaded test_tracetools
                     - Downloaded ros2trace
                     - Downloaded tracetools_launch
                     - Downloaded test_tracetools_launch
                     - Downloaded tracetools_trace
                     - Downloaded tracetools_read
                     - Downloaded tracetools_test
                     - Downloaded example_interfaces
                     - Adding fishbot_interfaces
            Found 46 compatible libraries
            Scanning dependencies...
            Dependency Graph
            |-- micro_ros_platformio @ 0.0.1+sha.a2f9de7
            |-- Esp32McpwmMotor @ 0.1.0+sha.48fcf81
            |-- Esp32PcntEncoder @ 0.1.0+sha.43dbbb7
            |-- Adafruit SSD1306 @ 2.5.7
            |   |-- Adafruit GFX Library @ 1.11.3
            |   |   |-- Adafruit BusIO @ 1.14.1
            |   |   |   |-- Wire @ 2.0.0
            |   |   |   |-- SPI @ 2.0.0
            |   |   |-- Wire @ 2.0.0
            |   |   |-- SPI @ 2.0.0
            |   |   |-- Wire @ 2.0.0
            |   |   |-- SPI @ 2.0.0
            |   |-- Wire @ 2.0.0
            |   |-- SPI @ 2.0.0
            |-- OneButton @ 2.0.3
            |-- Time @ 1.6.1
            |-- Displays
            |   |   |   |-- Wire @ 2.0.0
            |   |   |   |-- SPI @ 2.0.0
            |   |   |-- Wire @ 2.0.0
            |   |   |-- SPI @ 2.0.0
            |   |   |   |   |-- Wire @ 2.0.0
            |   |   |   |   |-- SPI @ 2.0.0
            |   |   |   |-- Wire @ 2.0.0
            |   |   |   |-- SPI @ 2.0.0
            |   |   |   |-- Wire @ 2.0.0
            |   |   |   |-- SPI @ 2.0.0
            |   |   |-- Wire @ 2.0.0
            |   |   |-- SPI @ 2.0.0
            |   |-- Time @ 1.6.1
            |   |-- Wire @ 2.0.0
            |-- FishbotUtils
            |-- MicroRosRwm
            |   |-- WiFi @ 2.0.0
            |-- BluetoothSerial @ 2.0.0
            |-- Kinematics
            |-- PidController
            |-- WiFi @ 2.0.0
            |-- Preferences @ 2.0.0
            Building in release mode
            Compiling .pio/build/featheresp32/src/fishbot.cpp.o
            Compiling .pio/build/featheresp32/src/fishbot_config.cpp.o
            Compiling .pio/build/featheresp32/src/main.cpp.o
            Building .pio/build/featheresp32/bootloader.bin
            Generating partitions .pio/build/featheresp32/partitions.bin
            esptool.py v4.2.1
            Creating esp32 image...
            Merged 1 ELF section
            Successfully created esp32 image.
            Compiling .pio/build/featheresp32/lib233/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
            Compiling .pio/build/featheresp32/lib72b/Esp32McpwmMotor/Esp32McpwmMotor.cpp.o
            Compiling .pio/build/featheresp32/libdd7/Esp32PcntEncoder/Esp32PcntEncoder.cpp.o
            Compiling .pio/build/featheresp32/libc6b/Wire/Wire.cpp.o
            Compiling .pio/build/featheresp32/libe29/SPI/SPI.cpp.o
            Compiling .pio/build/featheresp32/libe08/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
            Compiling .pio/build/featheresp32/libe08/Adafruit BusIO/Adafruit_I2CDevice.cpp.o
            Compiling .pio/build/featheresp32/libe08/Adafruit BusIO/Adafruit_SPIDevice.cpp.o
            Compiling .pio/build/featheresp32/lib609/Adafruit GFX Library/Adafruit_GFX.cpp.o
            Compiling .pio/build/featheresp32/lib609/Adafruit GFX Library/Adafruit_GrayOLED.cpp.o
            Compiling .pio/build/featheresp32/lib609/Adafruit GFX Library/Adafruit_SPITFT.cpp.o
            Compiling .pio/build/featheresp32/lib609/Adafruit GFX Library/glcdfont.c.o
            Compiling .pio/build/featheresp32/lib1ec/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
            Compiling .pio/build/featheresp32/libe07/OneButton/OneButton.cpp.o
            Compiling .pio/build/featheresp32/lib928/Time/DateStrings.cpp.o
            Archiving .pio/build/featheresp32/libe08/libAdafruit BusIO.a
            Archiving .pio/build/featheresp32/libc6b/libWire.a
            Archiving .pio/build/featheresp32/libe29/libSPI.a
            Archiving .pio/build/featheresp32/libdd7/libEsp32PcntEncoder.a
            Indexing .pio/build/featheresp32/libe08/libAdafruit BusIO.a
            Archiving .pio/build/featheresp32/lib72b/libEsp32McpwmMotor.a
            Archiving .pio/build/featheresp32/lib233/libmicro_ros_platformio.a
            Indexing .pio/build/featheresp32/libc6b/libWire.a
            Indexing .pio/build/featheresp32/libe29/libSPI.a
            Indexing .pio/build/featheresp32/libdd7/libEsp32PcntEncoder.a
            Indexing .pio/build/featheresp32/lib72b/libEsp32McpwmMotor.a
            Indexing .pio/build/featheresp32/lib233/libmicro_ros_platformio.a
            Compiling .pio/build/featheresp32/lib928/Time/Time.cpp.o
            Compiling .pio/build/featheresp32/lib726/Displays/fishbot_display.cpp.o
            Compiling .pio/build/featheresp32/libed7/FishbotUtils/fishbot_utils.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFi.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiAP.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiClient.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiGeneric.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiMulti.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiSTA.cpp.o
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiScan.cpp.o
            Archiving .pio/build/featheresp32/lib928/libTime.a
            Archiving .pio/build/featheresp32/lib609/libAdafruit GFX Library.a
            Indexing .pio/build/featheresp32/lib928/libTime.a
            Archiving .pio/build/featheresp32/lib1ec/libAdafruit SSD1306.a
            Indexing .pio/build/featheresp32/lib609/libAdafruit GFX Library.a
            Archiving .pio/build/featheresp32/libe07/libOneButton.a
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiServer.cpp.o
            Indexing .pio/build/featheresp32/lib1ec/libAdafruit SSD1306.a
            Compiling .pio/build/featheresp32/lib146/WiFi/WiFiUdp.cpp.o
            Indexing .pio/build/featheresp32/libe07/libOneButton.a
            Compiling .pio/build/featheresp32/liba1b/MicroRosRwm/micro_ros_transport_serial.cpp.o
            Compiling .pio/build/featheresp32/liba1b/MicroRosRwm/micro_ros_transport_wifi_udp.cpp.o
            Compiling .pio/build/featheresp32/liba10/BluetoothSerial/BTAddress.cpp.o
            Compiling .pio/build/featheresp32/liba10/BluetoothSerial/BTAdvertisedDeviceSet.cpp.o
            Compiling .pio/build/featheresp32/liba10/BluetoothSerial/BTScanResultsSet.cpp.o
            Archiving .pio/build/featheresp32/libed7/libFishbotUtils.a
            Archiving .pio/build/featheresp32/lib726/libDisplays.a
            Indexing .pio/build/featheresp32/libed7/libFishbotUtils.a
            Indexing .pio/build/featheresp32/lib726/libDisplays.a
            Compiling .pio/build/featheresp32/liba10/BluetoothSerial/BluetoothSerial.cpp.o
            Compiling .pio/build/featheresp32/lib92b/Kinematics/Kinematics.cpp.o
            Compiling .pio/build/featheresp32/lib47c/PidController/PidController.cpp.o
            Compiling .pio/build/featheresp32/lib10d/Preferences/Preferences.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/Esp.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/FirmwareMSC.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/FunctionalInterrupt.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/HWCDC.cpp.o
            Archiving .pio/build/featheresp32/lib92b/libKinematics.a
            Archiving .pio/build/featheresp32/lib47c/libPidController.a
            Archiving .pio/build/featheresp32/lib146/libWiFi.a
            Indexing .pio/build/featheresp32/lib92b/libKinematics.a
            Archiving .pio/build/featheresp32/liba1b/libMicroRosRwm.a
            Indexing .pio/build/featheresp32/lib47c/libPidController.a
            Indexing .pio/build/featheresp32/lib146/libWiFi.a
            Indexing .pio/build/featheresp32/liba1b/libMicroRosRwm.a
            Compiling .pio/build/featheresp32/FrameworkArduino/HardwareSerial.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/IPAddress.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/IPv6Address.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/MD5Builder.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/Print.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/Stream.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/StreamString.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/Tone.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/USB.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/USBCDC.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/USBMSC.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/WMath.cpp.o
            Archiving .pio/build/featheresp32/lib10d/libPreferences.a
            Indexing .pio/build/featheresp32/lib10d/libPreferences.a
            Compiling .pio/build/featheresp32/FrameworkArduino/WString.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/base64.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/cbuf.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-adc.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-bt.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-cpu.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-dac.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-gpio.c.o
            Archiving .pio/build/featheresp32/liba10/libBluetoothSerial.a
            Indexing .pio/build/featheresp32/liba10/libBluetoothSerial.a
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-i2c-slave.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-i2c.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-ledc.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-matrix.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-misc.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-psram.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-rgb-led.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-rmt.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-sigmadelta.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-spi.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-time.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-timer.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-tinyusb.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-touch.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/esp32-hal-uart.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/firmware_msc_fat.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/libb64/cdecode.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/libb64/cencode.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/main.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/stdlib_noniso.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/wiring_pulse.c.o
            Compiling .pio/build/featheresp32/FrameworkArduino/wiring_shift.c.o
            Archiving .pio/build/featheresp32/libFrameworkArduino.a
            Indexing .pio/build/featheresp32/libFrameworkArduino.a
            Linking .pio/build/featheresp32/firmware.elf
            Retrieving maximum program size .pio/build/featheresp32/firmware.elf
            Checking size .pio/build/featheresp32/firmware.elf
            Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
            RAM:   [===       ]  27.7% (used 90760 bytes from 327680 bytes)
            Flash: [=====     ]  50.1% (used 1577545 bytes from 3145728 bytes)
            Building .pio/build/featheresp32/firmware.bin
            esptool.py v4.2.1
            Merged 25 ELF sections
            ======================================================================================================================================================================= [SUCCESS] Took 362.75 seconds =======================================================================================================================================================================
             *  终端将被任务重用,按任意键关闭。
            今天吃几顿今 8477189568 4439640734 3 条回复 最后回复 回复 引用 0
            • 小鱼小 小鱼 将这个主题标记为已解决,在
            • 今天吃几顿今
              今天吃几顿 @小鱼
              @小鱼 我删除那个文件后,他又自动下载了一个,然后报错Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
              Verbose mode can be enabled via -v, --verbose option
              PACKAGES:
              • framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
              • tool-esptoolpy @ 1.40201.0 (4.2.1)
              • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
                /home/liyanshen/.platformio/penv/bin/python -m pip install pyyaml
                Requirement already satisfied: pyyaml in /home/liyanshen/.platformio/penv/lib/python3.10/site-packages (6.0)
                /home/liyanshen/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                Requirement already satisfied: markupsafe==2.0.1 in /home/liyanshen/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                micro-ROS already built
                Found 36 compatible libraries
                Dependency Graph
                |-- micro_ros_platformio @ 0.0.1+sha.085c5dd
                Compiling .pio/build/featheresp32/libfab/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
                In file included from .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.cpp:53:
                .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.h:42:10: fatal error: Adafruit_GFX.h: No such file or directory
              • Looking for Adafruit_GFX.h dependency? Check our library registry!
              • CLI > platformio lib
                从你的报错信息来看,应该是你没有安装 Adafruit_GFX.h 的依赖。你可以使用 platformio lib 命令来查找并安装这个依赖,然后重新编译你的代码,就可以解决问题了。
                今天吃几顿今 1 条回复 最后回复 回复 引用 0
                • 今天吃几顿今
                  今天吃几顿 @小伊
                  @小伊 报错#include <Adafruit_I2CDevice.h>
                  compilation terminated.
                  In file included from .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.h:42,
                  .pio/libdeps/featheresp32/Adafruit GFX Library/Adafruit_GFX.h:12:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
                  • Looking for Adafruit_I2CDevice.h dependency? Check our library registry!
                  • CLI > platformio lib search "header:Adafruit_I2CDevice.h"
                  • Web > https://registry.platformio.org/search?q=header:Adafruit_I2CDevice.h
                  Compiling .pio/build/featheresp32/libf0a/GFX Library for Arduino/Arduino_DataBus.cpp.o
                  Compiling .pio/build/featheresp32/libf0a/GFX Library for Arduino/Arduino_G.cpp.o
                  *** [.pio/build/featheresp32/liba41/Adafruit GFX Library/Adafruit_GFX.cpp.o] Error 1
                  *** [.pio/build/featheresp32/liba41/Adafruit GFX Library/Adafruit_GrayOLED.cpp.o] Error 1
                  *** [.pio/build/featheresp32/liba41/Adafruit GFX Library/Adafruit_SPITFT.cpp.o] Error 1
                  *** [.pio/build/featheresp32/libfab/Adafruit SSD1306/Adafruit_SSD1306.cpp.o] Error 1
                  =============== [FAILED] Took 6.50 seconds ===============
                  • 终端进程“platformio 'run'”已终止,退出代码: 1。
                  • 终端将被任务重用,按任意键关闭。
                    从上面的报错信息可以看出,缺少Adafruit_I2CDevice.h文件,可以在PlatformIO库中搜索,然后下载安装对应的库文件,或者在Github上找到对应的文件,然后添加到项目中即可。
                    • 8477189568
                      H. @小鱼
                      最后由 847718956 编辑
                      @小鱼 我根据这篇CSDN的步骤添加Adafruit BusIO依赖库
                      lib_deps =
                      	https://gitee.com/ohhuo/micro_ros_platformio.git
                      	adafruit/Adafruit SSD1306@^2.5.7
                      	adafruit/Adafruit BusIO@^1.14.1```
                      删除.pio/libdeps/featheresp32/micro_ros_platformio/libmicroros文件夹
                      不是pio/libdeps/featheresp32/micro_ros_platformio文件夹,这样文件会在重新编译后重新生成该文件
                      重新编译出现下面问题
                      PACKAGES:
                      [notice] A new release of pip is available: 23.0 -> 23.0.1
                               - Downloaded rcl
                               - Downloaded rclc
                               - Downloaded rmw
                      CMake Warning:
                          THIRDPARTY
                        warnings.warn(
                      CMake Warning:
                          BUILD_SHARED_LIBS
                          THIRDPARTY
                      CMake Warning:
                          BUILD_TESTING
                          THIRDPARTY
                      CMake Warning:
                          BUILD_SHARED_LIBS
                          THIRDPARTY
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: rcutils
                      CMake Warning:
                          ENABLE_TESTING
                          THIRDPARTY
                          inlined from 'rcutils_char_array_strcat' at /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10:
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:224:3: warning: 'strncat' output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c: In function 'rcutils_char_array_strcat':
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/char_array.c:239:10: note: length computed here
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c: In function 'rcutils_get_error_string':
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: warning: initializer-string for array of chars is too long
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:240:38: note: (near initialization for '(anonymous).str')
                      In file included from /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/error_handling.c:35:
                      At top level:
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:109:1: warning: '__rcutils_convert_uint64_t_into_c_str' defined but not used [-Wunused-function]
                      /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/src/rcutils/src/./error_handling_helpers.h:91:1: warning: '__rcutils_reverse_str' defined but not used [-Wunused-function]
                      CMake Warning:
                          BUILD_SHARED_LIBS
                          THIRDPARTY
                      --- stderr: tracetools_trace
                        warnings.warn(
                      --- stderr: rosidl_cmake
                      CMake Warning:
                          BUILD_SHARED_LIBS
                          THIRDPARTY
                      --- stderr: rosidl_runtime_c
                      CMake Warning at /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/ament_cmake_export_libraries-extras.cmake:116 (message):
                        Package 'rcutils' exports library 'dl' which couldn't be found
                        /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcutils/cmake/rcutilsConfig.cmake:41 (include)
                        CMakeLists.txt:15 (find_package)
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: rcl_logging_interface
                        CMakeLists.txt:19 (find_package)
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: microxrcedds_client
                      CMake Warning:
                          BUILD_TESTING
                          THIRDPARTY
                      --- stderr: test_interface_files
                      CMake Warning:
                          BUILD_SHARED_LIBS
                          THIRDPARTY
                      --- stderr: rcl_logging_noop
                        /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/ament_cmake_export_dependencies-extras.cmake:21 (find_package)
                        /home/xhy/Documents/PlatformIO/Projects/oled_interface/.pio/libdeps/featheresp32/micro_ros_platformio/build/mcu/install/share/rcl_logging_interface/cmake/rcl_logging_interfaceConfig.cmake:41 (include)
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: rosidl_typesupport_introspection_c
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: rosidl_generator_c
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: rmw
                        CMakeLists.txt:21 (find_package)
                      CMake Warning:
                          THIRDPARTY
                      --- stderr: tracetools_launch
                        warnings.warn(
                      --- stderr: tracetools_read
                        warnings.warn(
                      --- stderr: fishbot_interfaces
                      CMake Error at CMakeLists.txt:26 (find_package):
                        By not providing "Findrosidl_default_generators.cmake" in CMAKE_MODULE_PATH
                        this project has asked CMake to find a package configuration file provided
                        by "rosidl_default_generators", but CMake did not find one.
                        "rosidl_default_generators" with any of the following names:
                          rosidl_default_generatorsConfig.cmake
                          rosidl_default_generators-config.cmake
                        Add the installation prefix of "rosidl_default_generators" to
                        CMAKE_PREFIX_PATH or set "rosidl_default_generators_DIR" to a directory
                        containing one of the above files.  If "rosidl_default_generators" provides
                        a separate development package or SDK, be sure it has been installed.
                      Failed   <<< fishbot_interfaces [3.79s, exited with code 1]
                      =========================================================================== [FAILED] Took 271.51 seconds ===========================================================================
                       *  终端将被任务重用,按任意键关闭。
                      • 8477189568 847718956 将这个主题标记为未解决,在
                        小鱼 技术大佬 @847718956
                        @847718956 这个错误好解决了
                        @847718956 在 动手学ros2第5章进阶篇-控制OLED-自定义消息接口 中说:
                        确认下CMakeList.txt
                        project(fishbot_interfaces)
                        endif()
                        # find dependencies
                        if(BUILD_TESTING)
                          # uncomment the line when a copyright and license is not present in all source files
                          #set(ament_cmake_copyright_FOUND TRUE)
                          # uncomment the line when this package is not in a git repo
                          #set(ament_cmake_cpplint_FOUND TRUE)
                        endif()
                          "srv/OledControl.srv"
                        ament_package()
                        packages.xml
                        <?xml version="1.0"?>
                        <package format="3">
                          <name>fishbot_interfaces</name>
                          <version>0.0.0</version>
                          <maintainer email="root@todo.todo">root</maintainer>
                          <license>TODO: License declaration</license>
                          <build_depend>rosidl_default_generators</build_depend>
                          <exec_depend>rosidl_default_runtime</exec_depend>
                          <export>
                          </export>
                        </package>
                        • 小鱼小 小鱼 在 中 引用了 这个主题
                        • 4439640734
                          房间里的大象 @小鱼
                          @小鱼 这里下载太慢了。挂梯子也一样
                          • 19916236831
                            1991623683
                            有一个问题,用git 克隆代码,编译出现错误:15795905-ed0a-427c-8303-868a76c3aa1b-图片.png ,请问是什么问题
                              小鱼 技术大佬 @1991623683
                              @1991623683 有重新编译过吗,删掉libmicroros
                              • 8421452488
                                likesingjumprap
                                该贴中的方法都试过了还是不行,有兄弟们解决了的吗,
                                platformio.ini,因为报错,根据提示也加了很多依赖,还是不行
                                lib_deps =
                                	; adafruit/Adafruit GFX Library@^1.11.8
                                	; adafruit/Adafruit BusIO@^1.14.4
                                	; ; fabiobatsilva/ArduinoFake@^0.4.0
                                  小鱼 技术大佬 @842145248
                                  @842145248 你的报错是什么
                                  8421452488 1 条回复 最后回复 回复 引用 0
                                  • 8421452488
                                    likesingjumprap @小鱼
                                    @小鱼 刚刚重新编译了下,好慢,麻烦大佬帮我看看
                                    Dependency Graph
                                    esptool.py v4.2.1
                                    Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                                    Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                                    Compiling .pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
                                    * Looking for Adafruit_GFX.h dependency? Check our library registry!
                                    * CLI  > platformio lib search "header:Adafruit_GFX.h"
                                    * Web  > https://registry.platformio.org/search?q=header:Adafruit_GFX.h
                                     #include <Adafruit_GFX.h>
                                    *** [.pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o] Error 1
                                    ======================================== [FAILED] Took 658.83 seconds ========================================
                                     *  The terminal process "platformio 'run'" terminated with exit code: 1.
                                     *  Terminal will be reused by tasks, press any key to close it.
                                      小鱼 技术大佬 @842145248
                                      @842145248 再贴一下完整的代码
                                      • 8421452488
                                        likesingjumprap @小鱼
                                        platformio.ini
                                        [env:featheresp32]
                                        platform = espressif32
                                        board = featheresp32
                                        framework = arduino
                                        lib_deps =
                                        CMakeLists.txt
                                        endif()
                                        # find dependencies
                                        if(BUILD_TESTING)
                                        endif()
                                        ament_package()
                                        package.xml
                                          <export>
                                          </export>
                                        </package>
                                        extra_package包
                                        extra_packages/fishbot_interfaces/
                                        ├── CMakeLists.txt
                                        ├── include
                                        │   └── fishbot_interfaces
                                        ├── package.xml
                                        ├── src
                                        └── srv
                                            └── OledControl.srv
                                          小鱼 技术大佬 @842145248
                                          @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
                                          • 8421452488
                                            likesingjumprap @847718956
                                            @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
                                            但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
                                            $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
                                              File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
                                                return importlib.import_module(module_name, package=pkg_name)
                                              File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
                                              File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
                                              File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
                                              File "<frozen importlib._bootstrap>", line 1004, in _find_and_load_unlocked
                                            ModuleNotFoundError: No module named 'fishbot_interfaces.fishbot_interfaces_s__rosidl_typesupport_c'
                                              File "/opt/ros/humble/bin/ros2", line 33, in <module>
                                                sys.exit(load_entry_point('ros2cli==0.18.7', 'console_scripts', 'ros2')())
                                              File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 89, in main
                                                rc = extension.main(parser=parser, args=args)
                                              File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/command/service.py", line 41, in main
                                                return extension.main(args=args)
                                              File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/verb/call.py", line 58, in main
                                                return requester(
                                              File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/verb/call.py", line 86, in requester
                                                cli = node.create_client(srv_module, service_name)
                                              File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/node.py", line 1413, in create_client
                                                check_is_valid_srv_type(srv_type)
                                              File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 51, in check_is_valid_srv_type
                                                check_for_type_support(srv_type)
                                              File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 29, in check_for_type_support
                                                msg_or_srv_type.__class__.__import_type_support__()
                                              File "/home/nzb/vscode_project/cplus_demo/ros2_demo/chat13/example14_custom_interfaces/extra_packages/install/fishbot_interfaces/local/lib/python3.10/dist-packages/fishbot_interfaces/srv/_oled_control.py", line 303, in __import_type_support__
                                                module = import_type_support('fishbot_interfaces')
                                              File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
                                                raise UnsupportedTypeSupport(pkg_name)
                                            rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'fishbot_interfaces'
                                            main.cpp
                                            #include <Arduino.h>
                                            #include <rcl/rcl.h>
                                            #include <rclc/rclc.h>
                                            #include <rclc/executor.h>
                                            #include <micro_ros_utilities/string_utilities.h>
                                            #include "Wire.h"
                                            #include <Adafruit_SSD1306.h>
                                            #include <fishbot_interfaces/srv/oled_control.h>
                                            rclc_executor_t executor;
                                            rclc_support_t support;
                                            rcl_allocator_t allocator;
                                            rcl_node_t node;
                                            rcl_service_t service;
                                            fishbot_interfaces__srv__OledControl_Request req;
                                            fishbot_interfaces__srv__OledControl_Response res;
                                            Adafruit_SSD1306 display;
                                            void service_cb(const void *req, void *res)
                                              fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
                                              fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
                                              display.clearDisplay();
                                              display.setCursor(req_in->px, req_in->py);
                                              display.println(req_in->data.data);
                                              display.display();
                                              res_in->result = 0;
                                            void setup()
                                              // put your setup code here, to run once:
                                              Serial.begin(115200);
                                              set_microros_serial_transports(Serial);
                                              delay(2000);
                                              rclc_node_init_default(&node, "example14_interfaces", "", &support);
                                              rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
                                              rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
                                              req.data = micro_ros_string_utilities_init_with_size(100);
                                              Wire.begin(18, 19);
                                              display = Adafruit_SSD1306(128, 64, &Wire);
                                              display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
                                              display.setTextSize(1);
                                              display.setCursor(0, 0);
                                              display.setTextColor(SSD1306_WHITE);
                                              display.println("hello world!");
                                              display.display();
                                            void loop()
                                              // put your main code here, to run repeatedly:
                                              delay(100);
