    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    41.4k
      小鱼 技术大佬 @842145248
      @842145248
      $ source install/setup.bash && ros2 service call /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
      这句在哪一个目录下执行的
      8421452488 1 条回复 最后回复 回复 引用 0
      • 8421452488
        likesingjumprap @小鱼
        @小鱼 example14_custom_interfaces/extra_packages 目录下
          小鱼 技术大佬 @842145248
          @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
          • 8421452488
            likesingjumprap @小鱼
            @小鱼 删除重新编译后还不行
            CMakelists.txt
            project(fishbot_interfaces)
            endif()
            # find dependencies
            if(BUILD_TESTING)
              # uncomment the line when a copyright and license is not present in all source files
              #set(ament_cmake_copyright_FOUND TRUE)
              # uncomment the line when this package is not in a git repo
              #set(ament_cmake_cpplint_FOUND TRUE)
            endif()
              "srv/OledControl.srv"
            ament_package()
            OledControl.srv
            int32 px
            int32 py
            string data
            int32 result
              小鱼 技术大佬 @842145248
              @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
              • 8421452488
                likesingjumprap @小鱼
                @小鱼 示例也不行
                 *  Executing task: platformio run
                Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                git version 2.34.1
                Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                remote: Enumerating objects: 5773, done.
                remote: Counting objects: 100% (5773/5773), done.
                remote: Compressing objects: 100% (2618/2618), done.
                remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                Resolving deltas: 100% (2905/2905), done.
                Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                Unpacking  [####################################]  100%
                Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                Library Manager: Resolving dependencies...
                Library Manager: Installing Adafruit GFX Library
                Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                Library Manager: Installing Adafruit BusIO
                Library Manager: Adafruit BusIO@1.14.4 has been installed!
                Verbose mode can be enabled via `-v, --verbose` option
                CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
                PLATFORM: Espressif 32 (5.2.0) > Adafruit ESP32 Feather
                HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
                DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
                PACKAGES:
                 - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                 - tool-esptoolpy @ 1.40201.0 (4.2.1)
                 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
                LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
                LDF Modes: Finder ~ chain, Compatibility ~ soft
                Installing pyyaml with pip at PlatformIO environment
                /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                Looking in indexes: https://pypi.tuna.tsinghua.edu.cn/simple
                Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                [notice] A new release of pip available: 22.3.1 -> 23.2.1
                [notice] To update, run: pip install --upgrade pip
                Installing markupsafe==2.0.1 with pip at PlatformIO environment
                /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                Configuring featheresp32 with transport serial
                micro-ROS already built
                Found 36 compatible libraries
                Scanning dependencies...
                Dependency Graph
                |-- micro_ros_platformio @ 0.0.1+sha.085c5dd
                |-- Adafruit SSD1306 @ 2.5.7
                |-- Wire @ 2.0.0
                |-- Adafruit GFX Library @ 1.11.8
                Building in release mode
                Compiling .pio/build/featheresp32/src/main.cpp.o
                Building .pio/build/featheresp32/bootloader.bin
                Generating partitions .pio/build/featheresp32/partitions.bin
                esptool.py v4.2.1
                Creating esp32 image...
                Merged 1 ELF section
                Successfully created esp32 image.
                src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                 #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                compilation terminated.
                Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                 *  The terminal process "platformio 'run'" terminated with exit code: 1.
                 *  Terminal will be reused by tasks, press any key to close it.
                  小鱼 技术大佬 @842145248
                  @842145248 需要重新构建microros库,按照你之前的流程,或者把extra_pkgs 替换下
                  • 8421452488
                    likesingjumprap @小鱼
                    最后由 842145248 编辑
                    @小鱼 鱼哥,还是不行😭 ,libmicroros 删除了,重新编译,终端打印编译过程没报错,也通过了,但是中间报这种影响吗?
                    看 libmicroros 目录下也有那个fishbot_interfaces了
                    执行ros2 service call /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}" 报错还是之前这个:
                      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 46, in import_type_support
                        return importlib.import_module(module_name, package=pkg_name)
                      File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
                      File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
                      File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
                      File "<frozen importlib._bootstrap>", line 1004, in _find_and_load_unlocked
                    ModuleNotFoundError: No module named 'fishbot_interfaces.fishbot_interfaces_s__rosidl_typesupport_c'
                      File "/opt/ros/humble/bin/ros2", line 33, in <module>
                        sys.exit(load_entry_point('ros2cli==0.18.7', 'console_scripts', 'ros2')())
                      File "/opt/ros/humble/lib/python3.10/site-packages/ros2cli/cli.py", line 89, in main
                        rc = extension.main(parser=parser, args=args)
                      File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/command/service.py", line 41, in main
                        return extension.main(args=args)
                      File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/verb/call.py", line 58, in main
                        return requester(
                      File "/opt/ros/humble/lib/python3.10/site-packages/ros2service/verb/call.py", line 86, in requester
                        cli = node.create_client(srv_module, service_name)
                      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/node.py", line 1413, in create_client
                        check_is_valid_srv_type(srv_type)
                      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 51, in check_is_valid_srv_type
                        check_for_type_support(srv_type)
                      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rclpy/type_support.py", line 29, in check_for_type_support
                        msg_or_srv_type.__class__.__import_type_support__()
                      File "/home/nzb/vscode_project/cplus_demo/ros2_demo/chat13/example14_custom_interfaces/extra_packages/install/fishbot_interfaces/local/lib/python3.10/dist-packages/fishbot_interfaces/srv/_oled_control.py", line 303, in __import_type_support__
                        module = import_type_support('fishbot_interfaces')
                      File "/opt/ros/humble/local/lib/python3.10/dist-packages/rosidl_generator_py/import_type_support_impl.py", line 48, in import_type_support
                        raise UnsupportedTypeSupport(pkg_name)
                    rosidl_generator_py.import_type_support_impl.UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'fishbot_interfaces'
                      小鱼 技术大佬 @842145248
                      @842145248 在 动手学ros2第5章进阶篇-控制OLED-自定义消息接口 中说:
                      真是奇怪了,你在extra_pkgs下依次运行下面的指令,把结果反馈出来看看
                      rm -rf build install log
                      colcon build
                      ros2 serivice list
                      ros2 interface list | grep fishbot
                      • 8421452488
                        likesingjumprap @小鱼
                        rm -rf build install log && colcon build --packages-up-to fishbot_interfaces && source install/setup.bash
                        [0.467s] WARNING:colcon.colcon_ros.prefix_path.ament:The path '/home/nzb/vscode_project/cplus_demo/ros2_demo/chat13/example14_custom_interfaces/extra_packages/install/fishbot_interfaces' in the environment variable AMENT_PREFIX_PATH doesn't exist
                        [0.468s] WARNING:colcon.colcon_ros.prefix_path.catkin:The path '/home/nzb/vscode_project/cplus_demo/ros2_demo/chat13/example14_custom_interfaces/extra_packages/install/fishbot_interfaces' in the environment variable CMAKE_PREFIX_PATH doesn't exist
                        Starting >>> fishbot_interfaces
                        Finished <<< fishbot_interfaces [5.13s]
                        Summary: 1 package finished [5.37s]
                        ros2 service list && ros2 interface list | grep fish
                        /oled_control
                            return requester(
                          小鱼 技术大佬 @842145248
                          不要加这个
                          • 8421452488
                            likesingjumprap @小鱼
                            @小鱼 一样的报错,那个是我测试加上的,刚刚我删了重新编译了下,还是上面报错😭 ,人都要麻了
                            • 8421452488
                              likesingjumprap @842145248
                              @842145248 我环境跟教程一样的22.04,humble
                                小鱼 技术大佬 @842145248
                                @842145248 我在我这里测试了一下,没有问题:
                                测试指令:
                                cd ~
                                git clone git@github.com:fishros/example_micoros_board.git
                                cd example_micoros_board/example14_custom_interface/extra_packages/
                                colcon build
                                ros2 serivice list
                                8421452488 2 条回复 最后回复 回复 引用 0
                                • 8421452488
                                  likesingjumprap @小鱼
                                  • 8421452488
                                    @842145248 这demo也没啥什么环境变量影响啊,咋就不行了呢😢
                                      小鱼 技术大佬 @842145248
                                      @842145248 代码一样你的系统是多少的,不幸就换个系统试试
                                      • 8421452488
                                        likesingjumprap @小鱼
                                        嗯嗯,我再找找看,非常感谢大佬的支持
                                        No LSB modules are available.
                                        Distributor ID:	Ubuntu
                                        Description:	Ubuntu 22.04.3 LTS
                                        Release:	22.04
                                        Codename:	jammy
                                        Linux lenovo 5.15.0-82-generic #91-Ubuntu SMP Mon Aug 14 14:14:14 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
                                        • 8421452488
                                          likesingjumprap @小鱼
                                          大佬,你电脑编完后的这个目录下的文件能截个图给我吗
                                            小鱼 技术大佬 @842145248
                                            @842145248
                                            fishros@fishros-linux:~/example_micoros_board/example14_custom_interface/extra_packages/install/fishbot_interfaces/local/lib/python3.10/dist-packages/fishbot_interfaces$ ll
                                            总计 136
                                            drwxr-xr-x 4 fishros fishros  4096 10月 14 16:44 ./
                                            drwxrwxr-x 4 fishros fishros  4096 10月 14 16:44 ../
                                            -rw-r--r-- 1 fishros fishros 11776 10月 14 16:44 _fishbot_interfaces_s.ep.rosidl_typesupport_c.c
                                            -rw-r--r-- 1 fishros fishros 11785 10月 14 16:44 _fishbot_interfaces_s.ep.rosidl_typesupport_fastrtps_c.c
                                            -rw-r--r-- 1 fishros fishros 11790 10月 14 16:44 _fishbot_interfaces_s.ep.rosidl_typesupport_introspection_c.c
                                            -rw-r--r-- 1 fishros fishros 17632 10月 14 16:44 fishbot_interfaces_s__rosidl_typesupport_c.cpython-310-x86_64-linux-gnu.so
                                            -rw-r--r-- 1 fishros fishros 17648 10月 14 16:44 fishbot_interfaces_s__rosidl_typesupport_fastrtps_c.cpython-310-x86_64-linux-gnu.so
                                            -rw-r--r-- 1 fishros fishros 17664 10月 14 16:44 fishbot_interfaces_s__rosidl_typesupport_introspection_c.cpython-310-x86_64-linux-gnu.so
                                            -rw-r--r-- 1 fishros fishros     0 10月 14 16:44 __init__.py
                                            -rw-r--r-- 1 fishros fishros 21392 10月 14 16:44 libfishbot_interfaces__rosidl_generator_py.so
                                            drwxrwxr-x 2 fishros fishros  4096 10月 14 16:44 __pycache__/
                                            drwxr-xr-x 3 fishros fishros  4096 10月 14 16:44 srv/
