    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    60.5k
      小鱼 技术大佬 @842145248
      @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
      8421452488 1 条回复 最后回复 回复 引用 0
      • 8421452488
        likesingjumprap @小鱼
        @小鱼 删除重新编译后还不行
        CMakelists.txt
        project(fishbot_interfaces)
        endif()
        # find dependencies
        if(BUILD_TESTING)
        endif()
          "srv/OledControl.srv"
        ament_package()
        OledControl.srv
        int32 px
        int32 py
        string data
        int32 result
          小鱼 技术大佬 @842145248
          @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
          • 8421452488
            likesingjumprap @小鱼
            @小鱼 示例也不行
             *  Executing task: platformio run
            Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
            Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
            git version 2.34.1
            Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
            remote: Enumerating objects: 5773, done.
            remote: Counting objects: 100% (5773/5773), done.
            remote: Compressing objects: 100% (2618/2618), done.
            remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
            Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
            Resolving deltas: 100% (2905/2905), done.
            Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
            Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
            Unpacking  [####################################]  100%
            Library Manager: Adafruit SSD1306@2.5.7 has been installed!
            Library Manager: Resolving dependencies...
            Library Manager: Installing Adafruit GFX Library
            Library Manager: Adafruit GFX Library@1.11.8 has been installed!
            Library Manager: Installing Adafruit BusIO
            Library Manager: Adafruit BusIO@1.14.4 has been installed!
            Verbose mode can be enabled via `-v, --verbose` option
            PACKAGES:
             - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
            /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
            Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
            [notice] A new release of pip available: 22.3.1 -> 23.2.1
            [notice] To update, run: pip install --upgrade pip
            /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
            Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
            Configuring featheresp32 with transport serial
            micro-ROS already built
            Found 36 compatible libraries
            Scanning dependencies...
            Dependency Graph
            |-- Adafruit SSD1306 @ 2.5.7
            |-- Wire @ 2.0.0
            |-- Adafruit GFX Library @ 1.11.8
            Building in release mode
            Compiling .pio/build/featheresp32/src/main.cpp.o
            Building .pio/build/featheresp32/bootloader.bin
            Generating partitions .pio/build/featheresp32/partitions.bin
            esptool.py v4.2.1
            Creating esp32 image...
            Merged 1 ELF section
            Successfully created esp32 image.
            src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
             #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
            compilation terminated.
            Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
            Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
            Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
            Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
            Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
            *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
            =========================================================== [FAILED] Took 16.30 seconds ===========================================================
             *  The terminal process "platformio 'run'" terminated with exit code: 1.
             *  Terminal will be reused by tasks, press any key to close it.
              小鱼 技术大佬 @842145248
              • 8421452488
                likesingjumprap @小鱼
                最后由 842145248 编辑
                    return requester(
                  小鱼 技术大佬 @842145248
                  rm -rf build install log
                  source install/setup.bash
                  ros2 serivice list
                  • 8421452488
                    likesingjumprap @小鱼
                    /oled_control
                        return requester(
                      小鱼 技术大佬 @842145248
                      不要加这个
                      • 8421452488
                        likesingjumprap @小鱼
                        • 8421452488
                          likesingjumprap @842145248
                            小鱼 技术大佬 @842145248
                            @842145248 我在我这里测试了一下,没有问题:
                            测试指令:
                            cd ~
                            ros2 serivice list
                            8421452488 2 条回复 最后回复 回复 引用 0
                            • 8421452488
                              likesingjumprap @小鱼
                              • 8421452488
                                  小鱼 技术大佬 @842145248
                                  • 8421452488
                                    likesingjumprap @小鱼
                                    嗯嗯,我再找找看,非常感谢大佬的支持
                                    No LSB modules are available.
                                    Distributor ID:	Ubuntu
                                    Release:	22.04
                                    Codename:	jammy
                                    • 8421452488
                                      likesingjumprap @小鱼
                                      大佬,你电脑编完后的这个目录下的文件能截个图给我吗
                                        小鱼 技术大佬 @842145248
                                        @842145248
                                        总计 136
                                        • 8421452488
                                          likesingjumprap @小鱼
                                          total 136
                                            小鱼 技术大佬 @842145248
                                            python3 --version
