    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    44.9k
      小鱼 技术大佬 @842145248
      @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
      • 8421452488
        likesingjumprap @847718956
        @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
        但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
        $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
            return requester(
        main.cpp
        #include <Arduino.h>
        #include <rcl/rcl.h>
        #include <rclc/rclc.h>
        #include <rclc/executor.h>
        #include "Wire.h"
        #include <Adafruit_GFX.h>
        #include <Adafruit_SSD1306.h>
        #include <fishbot_interfaces/srv/oled_control.h>
        rclc_executor_t executor;
        rclc_support_t support;
        rcl_allocator_t allocator;
        rcl_node_t node;
        rcl_service_t service;
        fishbot_interfaces__srv__OledControl_Request req;
        fishbot_interfaces__srv__OledControl_Response res;
        Adafruit_SSD1306 display;
        void service_cb(const void *req, void *res)
          fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
          fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
          display.clearDisplay();
          display.setCursor(req_in->px, req_in->py);
          display.println(req_in->data.data);
          display.display();
          res_in->result = 0;
        void setup()
          // put your setup code here, to run once:
          Serial.begin(115200);
          delay(2000);
          rclc_node_init_default(&node, "example14_interfaces", "", &support);
          rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
          rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
          req.data = micro_ros_string_utilities_init_with_size(100);
          Wire.begin(18, 19);
          display = Adafruit_SSD1306(128, 64, &Wire);
          display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
          display.setTextSize(1);
          display.setCursor(0, 0);
          display.setTextColor(SSD1306_WHITE);
          display.println("hello world!");
          display.display();
        void loop()
          // put your main code here, to run repeatedly:
          delay(100);
          小鱼 技术大佬 @842145248
          @842145248
          这句在哪一个目录下执行的
          8421452488 1 条回复 最后回复 回复 引用 0
          • 8421452488
            likesingjumprap @小鱼
            @小鱼 example14_custom_interfaces/extra_packages 目录下
              小鱼 技术大佬 @842145248
              @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
              • 8421452488
                likesingjumprap @小鱼
                @小鱼 删除重新编译后还不行
                CMakelists.txt
                project(fishbot_interfaces)
                endif()
                # find dependencies
                if(BUILD_TESTING)
                endif()
                  "srv/OledControl.srv"
                ament_package()
                OledControl.srv
                int32 px
                int32 py
                string data
                int32 result
                  小鱼 技术大佬 @842145248
                  @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
                  • 8421452488
                    likesingjumprap @小鱼
                    @小鱼 示例也不行
                     *  Executing task: platformio run
                    Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                    Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                    git version 2.34.1
                    Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                    remote: Enumerating objects: 5773, done.
                    remote: Counting objects: 100% (5773/5773), done.
                    remote: Compressing objects: 100% (2618/2618), done.
                    remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                    Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                    Resolving deltas: 100% (2905/2905), done.
                    Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                    Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                    Unpacking  [####################################]  100%
                    Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                    Library Manager: Resolving dependencies...
                    Library Manager: Installing Adafruit GFX Library
                    Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                    Library Manager: Installing Adafruit BusIO
                    Library Manager: Adafruit BusIO@1.14.4 has been installed!
                    Verbose mode can be enabled via `-v, --verbose` option
                    PACKAGES:
                     - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                    /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                    Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                    [notice] A new release of pip available: 22.3.1 -> 23.2.1
                    [notice] To update, run: pip install --upgrade pip
                    /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                    Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                    Configuring featheresp32 with transport serial
                    micro-ROS already built
                    Found 36 compatible libraries
                    Scanning dependencies...
                    Dependency Graph
                    |-- Adafruit SSD1306 @ 2.5.7
                    |-- Wire @ 2.0.0
                    |-- Adafruit GFX Library @ 1.11.8
                    Building in release mode
                    Compiling .pio/build/featheresp32/src/main.cpp.o
                    Building .pio/build/featheresp32/bootloader.bin
                    Generating partitions .pio/build/featheresp32/partitions.bin
                    esptool.py v4.2.1
                    Creating esp32 image...
                    Merged 1 ELF section
                    Successfully created esp32 image.
                    src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                     #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                    compilation terminated.
                    Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                    Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                    Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                    Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                    Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                    *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                    =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                     *  The terminal process "platformio 'run'" terminated with exit code: 1.
                     *  Terminal will be reused by tasks, press any key to close it.
                      小鱼 技术大佬 @842145248
                      • 8421452488
                        likesingjumprap @小鱼
                        最后由 842145248 编辑
                            return requester(
                          小鱼 技术大佬 @842145248
                          rm -rf build install log
                          ros2 serivice list
                          • 8421452488
                            likesingjumprap @小鱼
                            /oled_control
                                return requester(
                              小鱼 技术大佬 @842145248
                              不要加这个
                              • 8421452488
                                likesingjumprap @小鱼
                                • 8421452488
                                  likesingjumprap @842145248
                                    小鱼 技术大佬 @842145248
                                    @842145248 我在我这里测试了一下,没有问题:
                                    测试指令:
                                    cd ~
                                    ros2 serivice list
                                    8421452488 2 条回复 最后回复 回复 引用 0
                                    • 8421452488
                                      likesingjumprap @小鱼
                                      • 8421452488
                                          小鱼 技术大佬 @842145248
                                          • 8421452488
                                            likesingjumprap @小鱼
                                            嗯嗯,我再找找看,非常感谢大佬的支持
                                            No LSB modules are available.
                                            Distributor ID:	Ubuntu
                                            Release:	22.04
                                            Codename:	jammy
