    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    60.5k
    • 8421452488
      likesingjumprap
      该贴中的方法都试过了还是不行,有兄弟们解决了的吗,
      platformio.ini,因为报错,根据提示也加了很多依赖,还是不行
      lib_deps =
      	https://gitee.com/ohhuo/micro_ros_platformio.git
      	adafruit/Adafruit SSD1306@^2.5.7
      	; adafruit/Adafruit GFX Library@^1.11.8
      	; adafruit/Adafruit BusIO@^1.14.4
      	; ; fabiobatsilva/ArduinoFake@^0.4.0
        小鱼 技术大佬 @842145248
        @842145248 你的报错是什么
        8421452488 1 条回复 最后回复 回复 引用 0
        • 8421452488
          likesingjumprap @小鱼
          @小鱼 刚刚重新编译了下,好慢,麻烦大佬帮我看看
          Building micro-ROS library
          Found 36 compatible libraries
          Scanning dependencies...
          Dependency Graph
          |-- Adafruit SSD1306 @ 2.5.7
          Building in release mode
          Compiling .pio/build/featheresp32/src/main.cpp.o
          Building .pio/build/featheresp32/bootloader.bin
          Generating partitions .pio/build/featheresp32/partitions.bin
          esptool.py v4.2.1
          Creating esp32 image...
          Merged 1 ELF section
          Successfully created esp32 image.
          Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
          Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
          Compiling .pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
          In file included from .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.cpp:53:
          .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.h:42:10: fatal error: Adafruit_GFX.h: No such file or directory
          * Looking for Adafruit_GFX.h dependency? Check our library registry!
          * CLI  > platformio lib search "header:Adafruit_GFX.h"
          * Web  > https://registry.platformio.org/search?q=header:Adafruit_GFX.h
           #include <Adafruit_GFX.h>
          compilation terminated.
          Compiling .pio/build/featheresp32/FrameworkArduino/Esp.cpp.o
          Compiling .pio/build/featheresp32/FrameworkArduino/FirmwareMSC.cpp.o
          *** [.pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o] Error 1
          ======================================== [FAILED] Took 658.83 seconds ========================================
           *  The terminal process "platformio 'run'" terminated with exit code: 1.
           *  Terminal will be reused by tasks, press any key to close it.
            小鱼 技术大佬 @842145248
            @842145248 再贴一下完整的代码
            • 8421452488
              likesingjumprap @小鱼
              platformio.ini
              [env:featheresp32]
              platform = espressif32
              board = featheresp32
              framework = arduino
              lib_deps =
              CMakeLists.txt
              project(fishbot_interfaces)
              endif()
              # find dependencies
              if(BUILD_TESTING)
              endif()
                "srv/OledControl.srv"
              ament_package()
              package.xml
              <?xml version="1.0"?>
              <package format="3">
                <name>fishbot_interfaces</name>
                <version>0.0.0</version>
                <maintainer email="root@todo.todo">root</maintainer>
                <build_depend>rosidl_default_generators</build_depend>
                <exec_depend>rosidl_default_runtime</exec_depend>
                <export>
                </export>
              </package>
              extra_package包
              extra_packages/fishbot_interfaces/
              ├── CMakeLists.txt
              ├── include
              │   └── fishbot_interfaces
              ├── package.xml
              ├── src
              └── srv
                  └── OledControl.srv
                小鱼 技术大佬 @842145248
                @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
                • 8421452488
                  likesingjumprap @847718956
                  @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
                  但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
                  $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
                      return requester(
                  main.cpp
                  #include <Arduino.h>
                  #include <rcl/rcl.h>
                  #include <rclc/rclc.h>
                  #include <rclc/executor.h>
                  #include "Wire.h"
                  #include <Adafruit_SSD1306.h>
                  #include <fishbot_interfaces/srv/oled_control.h>
                  rclc_executor_t executor;
                  rclc_support_t support;
                  rcl_allocator_t allocator;
                  rcl_node_t node;
                  rcl_service_t service;
                  fishbot_interfaces__srv__OledControl_Request req;
                  fishbot_interfaces__srv__OledControl_Response res;
                  Adafruit_SSD1306 display;
                  void service_cb(const void *req, void *res)
                    fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
                    fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
                    display.clearDisplay();
                    display.setCursor(req_in->px, req_in->py);
                    display.println(req_in->data.data);
                    display.display();
                    res_in->result = 0;
                  void setup()
                    // put your setup code here, to run once:
                    Serial.begin(115200);
                    delay(2000);
                    rclc_node_init_default(&node, "example14_interfaces", "", &support);
                    rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
                    rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
                    req.data = micro_ros_string_utilities_init_with_size(100);
                    Wire.begin(18, 19);
                    display = Adafruit_SSD1306(128, 64, &Wire);
                    display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
                    display.setTextSize(1);
                    display.setCursor(0, 0);
                    display.setTextColor(SSD1306_WHITE);
                    display.println("hello world!");
                    display.display();
                  void loop()
                    // put your main code here, to run repeatedly:
                    delay(100);
                    小鱼 技术大佬 @842145248
                    @842145248
                    这句在哪一个目录下执行的
                    • 8421452488
                      likesingjumprap @小鱼
                      @小鱼 example14_custom_interfaces/extra_packages 目录下
                        小鱼 技术大佬 @842145248
                        @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
                        • 8421452488
                          likesingjumprap @小鱼
                          @小鱼 删除重新编译后还不行
                          CMakelists.txt
                          endif()
                          # find dependencies
                          if(BUILD_TESTING)
                          endif()
                          ament_package()
                          OledControl.srv
                          int32 px
                          int32 py
                          string data
                          int32 result
                            小鱼 技术大佬 @842145248
                            @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
                            • 8421452488
                              likesingjumprap @小鱼
                              @小鱼 示例也不行
                               *  Executing task: platformio run
                              Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                              Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                              git version 2.34.1
                              Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                              remote: Enumerating objects: 5773, done.
                              remote: Counting objects: 100% (5773/5773), done.
                              remote: Compressing objects: 100% (2618/2618), done.
                              remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                              Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                              Resolving deltas: 100% (2905/2905), done.
                              Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                              Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                              Unpacking  [####################################]  100%
                              Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                              Library Manager: Resolving dependencies...
                              Library Manager: Installing Adafruit GFX Library
                              Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                              Library Manager: Installing Adafruit BusIO
                              Library Manager: Adafruit BusIO@1.14.4 has been installed!
                              Verbose mode can be enabled via `-v, --verbose` option
                              PACKAGES:
                               - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                              /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                              Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                              [notice] A new release of pip available: 22.3.1 -> 23.2.1
                              [notice] To update, run: pip install --upgrade pip
                              /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                              Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                              Configuring featheresp32 with transport serial
                              micro-ROS already built
                              Dependency Graph
                              |-- Wire @ 2.0.0
                              |-- Adafruit GFX Library @ 1.11.8
                              esptool.py v4.2.1
                              src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                               #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                              Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                              Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                              Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                              Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                              Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                              *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                              =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                                小鱼 技术大佬 @842145248
                                • 8421452488
                                  likesingjumprap @小鱼
                                  最后由 842145248 编辑
                                      return requester(
                                    小鱼 技术大佬 @842145248
                                    rm -rf build install log
                                    ros2 serivice list
                                    • 8421452488
                                      likesingjumprap @小鱼
                                      /oled_control
                                          return requester(
                                        小鱼 技术大佬 @842145248
                                        不要加这个
                                        • 8421452488
                                          likesingjumprap @小鱼
                                          • 8421452488
                                            likesingjumprap @842145248
