    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    44.9k
    • 8421452488
      likesingjumprap @小鱼
      platformio.ini
      [env:featheresp32]
      platform = espressif32
      board = featheresp32
      framework = arduino
      lib_deps =
      	https://gitee.com/ohhuo/micro_ros_platformio.git
      	adafruit/Adafruit SSD1306@^2.5.7
      CMakeLists.txt
      project(fishbot_interfaces)
      endif()
      # find dependencies
      if(BUILD_TESTING)
      endif()
        "srv/OledControl.srv"
      ament_package()
      package.xml
      <?xml version="1.0"?>
      <package format="3">
        <name>fishbot_interfaces</name>
        <version>0.0.0</version>
        <maintainer email="root@todo.todo">root</maintainer>
        <build_depend>rosidl_default_generators</build_depend>
        <exec_depend>rosidl_default_runtime</exec_depend>
        <export>
        </export>
      </package>
      extra_package包
      extra_packages/fishbot_interfaces/
      ├── CMakeLists.txt
      ├── include
      │   └── fishbot_interfaces
      ├── package.xml
      ├── src
      └── srv
          └── OledControl.srv
        小鱼 技术大佬 @842145248
        @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
        • 8421452488
          likesingjumprap @847718956
          @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
          但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
          $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
              return requester(
          main.cpp
          #include <Arduino.h>
          #include <rcl/rcl.h>
          #include <rclc/rclc.h>
          #include <rclc/executor.h>
          #include "Wire.h"
          #include <Adafruit_GFX.h>
          #include <Adafruit_SSD1306.h>
          #include <fishbot_interfaces/srv/oled_control.h>
          rclc_executor_t executor;
          rclc_support_t support;
          rcl_allocator_t allocator;
          rcl_node_t node;
          rcl_service_t service;
          fishbot_interfaces__srv__OledControl_Request req;
          fishbot_interfaces__srv__OledControl_Response res;
          Adafruit_SSD1306 display;
          void service_cb(const void *req, void *res)
            fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
            fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
            display.clearDisplay();
            display.setCursor(req_in->px, req_in->py);
            display.println(req_in->data.data);
            display.display();
            res_in->result = 0;
          void setup()
            // put your setup code here, to run once:
            Serial.begin(115200);
            delay(2000);
            rclc_node_init_default(&node, "example14_interfaces", "", &support);
            rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
            rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
            req.data = micro_ros_string_utilities_init_with_size(100);
            Wire.begin(18, 19);
            display = Adafruit_SSD1306(128, 64, &Wire);
            display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
            display.setTextSize(1);
            display.setCursor(0, 0);
            display.setTextColor(SSD1306_WHITE);
            display.println("hello world!");
            display.display();
          void loop()
            // put your main code here, to run repeatedly:
            delay(100);
            小鱼 技术大佬 @842145248
            @842145248
            这句在哪一个目录下执行的
            8421452488 1 条回复 最后回复 回复 引用 0
            • 8421452488
              likesingjumprap @小鱼
              @小鱼 example14_custom_interfaces/extra_packages 目录下
                小鱼 技术大佬 @842145248
                @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
                • 8421452488
                  likesingjumprap @小鱼
                  @小鱼 删除重新编译后还不行
                  CMakelists.txt
                  endif()
                  # find dependencies
                  if(BUILD_TESTING)
                  endif()
                  ament_package()
                  OledControl.srv
                  int32 px
                  int32 py
                  string data
                  int32 result
                    小鱼 技术大佬 @842145248
                    @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
                    • 8421452488
                      likesingjumprap @小鱼
                      @小鱼 示例也不行
                       *  Executing task: platformio run
                      Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                      Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                      git version 2.34.1
                      Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                      remote: Enumerating objects: 5773, done.
                      remote: Counting objects: 100% (5773/5773), done.
                      remote: Compressing objects: 100% (2618/2618), done.
                      remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                      Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                      Resolving deltas: 100% (2905/2905), done.
                      Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                      Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                      Unpacking  [####################################]  100%
                      Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                      Library Manager: Resolving dependencies...
                      Library Manager: Installing Adafruit GFX Library
                      Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                      Library Manager: Installing Adafruit BusIO
                      Library Manager: Adafruit BusIO@1.14.4 has been installed!
                      Verbose mode can be enabled via `-v, --verbose` option
                      PACKAGES:
                       - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                      /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                      Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                      [notice] A new release of pip available: 22.3.1 -> 23.2.1
                      [notice] To update, run: pip install --upgrade pip
                      /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                      Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                      Configuring featheresp32 with transport serial
                      micro-ROS already built
                      Found 36 compatible libraries
                      Scanning dependencies...
                      Dependency Graph
                      |-- Adafruit SSD1306 @ 2.5.7
                      |-- Wire @ 2.0.0
                      |-- Adafruit GFX Library @ 1.11.8
                      Building in release mode
                      Compiling .pio/build/featheresp32/src/main.cpp.o
                      Building .pio/build/featheresp32/bootloader.bin
                      Generating partitions .pio/build/featheresp32/partitions.bin
                      esptool.py v4.2.1
                      Creating esp32 image...
                      Merged 1 ELF section
                      Successfully created esp32 image.
                      src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                       #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                      compilation terminated.
                      Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                      Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                      Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                      Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                      Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                      *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                      =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                       *  The terminal process "platformio 'run'" terminated with exit code: 1.
                       *  Terminal will be reused by tasks, press any key to close it.
                        小鱼 技术大佬 @842145248
                        • 8421452488
                          likesingjumprap @小鱼
                          最后由 842145248 编辑
                              return requester(
                            小鱼 技术大佬 @842145248
                            rm -rf build install log
                            ros2 serivice list
                            • 8421452488
                              likesingjumprap @小鱼
                              /oled_control
                                  return requester(
                                小鱼 技术大佬 @842145248
                                不要加这个
                                • 8421452488
                                  likesingjumprap @小鱼
                                  • 8421452488
                                    likesingjumprap @842145248
                                      小鱼 技术大佬 @842145248
                                      @842145248 我在我这里测试了一下,没有问题:
                                      测试指令:
                                      cd ~
                                      ros2 serivice list
                                      8421452488 2 条回复 最后回复 回复 引用 0
                                      • 8421452488
                                        likesingjumprap @小鱼
                                        • 8421452488
                                            小鱼 技术大佬 @842145248
