    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    60.5k
      小鱼 技术大佬 @1991623683
      @1991623683 有重新编译过吗,删掉libmicroros
      • 8421452488
        likesingjumprap
        该贴中的方法都试过了还是不行,有兄弟们解决了的吗,
        platformio.ini,因为报错,根据提示也加了很多依赖,还是不行
        lib_deps =
        	https://gitee.com/ohhuo/micro_ros_platformio.git
        	adafruit/Adafruit SSD1306@^2.5.7
        	; adafruit/Adafruit GFX Library@^1.11.8
        	; adafruit/Adafruit BusIO@^1.14.4
        	; ; fabiobatsilva/ArduinoFake@^0.4.0
          小鱼 技术大佬 @842145248
          @842145248 你的报错是什么
          8421452488 1 条回复 最后回复 回复 引用 0
          • 8421452488
            likesingjumprap @小鱼
            @小鱼 刚刚重新编译了下,好慢,麻烦大佬帮我看看
            Building micro-ROS library
            Found 36 compatible libraries
            Scanning dependencies...
            Dependency Graph
            |-- Adafruit SSD1306 @ 2.5.7
            Building in release mode
            Compiling .pio/build/featheresp32/src/main.cpp.o
            Building .pio/build/featheresp32/bootloader.bin
            Generating partitions .pio/build/featheresp32/partitions.bin
            esptool.py v4.2.1
            Creating esp32 image...
            Merged 1 ELF section
            Successfully created esp32 image.
            Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
            Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
            Compiling .pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
            In file included from .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.cpp:53:
            .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.h:42:10: fatal error: Adafruit_GFX.h: No such file or directory
            * Looking for Adafruit_GFX.h dependency? Check our library registry!
            * CLI  > platformio lib search "header:Adafruit_GFX.h"
            * Web  > https://registry.platformio.org/search?q=header:Adafruit_GFX.h
             #include <Adafruit_GFX.h>
            compilation terminated.
            Compiling .pio/build/featheresp32/FrameworkArduino/Esp.cpp.o
            Compiling .pio/build/featheresp32/FrameworkArduino/FirmwareMSC.cpp.o
            *** [.pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o] Error 1
            ======================================== [FAILED] Took 658.83 seconds ========================================
             *  The terminal process "platformio 'run'" terminated with exit code: 1.
             *  Terminal will be reused by tasks, press any key to close it.
              小鱼 技术大佬 @842145248
              @842145248 再贴一下完整的代码
              • 8421452488
                likesingjumprap @小鱼
                platformio.ini
                [env:featheresp32]
                platform = espressif32
                board = featheresp32
                framework = arduino
                lib_deps =
                CMakeLists.txt
                project(fishbot_interfaces)
                endif()
                # find dependencies
                if(BUILD_TESTING)
                endif()
                  "srv/OledControl.srv"
                ament_package()
                package.xml
                <?xml version="1.0"?>
                <package format="3">
                  <name>fishbot_interfaces</name>
                  <version>0.0.0</version>
                  <maintainer email="root@todo.todo">root</maintainer>
                  <build_depend>rosidl_default_generators</build_depend>
                  <exec_depend>rosidl_default_runtime</exec_depend>
                  <export>
                  </export>
                </package>
                extra_package包
                extra_packages/fishbot_interfaces/
                ├── CMakeLists.txt
                ├── include
                │   └── fishbot_interfaces
                ├── package.xml
                ├── src
                └── srv
                    └── OledControl.srv
                  小鱼 技术大佬 @842145248
                  @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
                  • 8421452488
                    likesingjumprap @847718956
                    @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
                    但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
                    $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
                        return requester(
                    main.cpp
                    #include <Arduino.h>
                    #include <rcl/rcl.h>
                    #include <rclc/rclc.h>
                    #include <rclc/executor.h>
                    #include "Wire.h"
                    #include <Adafruit_SSD1306.h>
                    #include <fishbot_interfaces/srv/oled_control.h>
                    rclc_executor_t executor;
                    rclc_support_t support;
                    rcl_allocator_t allocator;
                    rcl_node_t node;
                    rcl_service_t service;
                    fishbot_interfaces__srv__OledControl_Request req;
                    fishbot_interfaces__srv__OledControl_Response res;
                    Adafruit_SSD1306 display;
                    void service_cb(const void *req, void *res)
                      fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
                      fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
                      display.clearDisplay();
                      display.setCursor(req_in->px, req_in->py);
                      display.println(req_in->data.data);
                      display.display();
                      res_in->result = 0;
                    void setup()
                      // put your setup code here, to run once:
                      Serial.begin(115200);
                      delay(2000);
                      rclc_node_init_default(&node, "example14_interfaces", "", &support);
                      rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
                      rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
                      req.data = micro_ros_string_utilities_init_with_size(100);
                      Wire.begin(18, 19);
                      display = Adafruit_SSD1306(128, 64, &Wire);
                      display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
                      display.setTextSize(1);
                      display.setCursor(0, 0);
                      display.setTextColor(SSD1306_WHITE);
                      display.println("hello world!");
                      display.display();
                    void loop()
                      // put your main code here, to run repeatedly:
                      delay(100);
                      小鱼 技术大佬 @842145248
                      @842145248
                      这句在哪一个目录下执行的
                      • 8421452488
                        likesingjumprap @小鱼
                        @小鱼 example14_custom_interfaces/extra_packages 目录下
                          小鱼 技术大佬 @842145248
                          @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
                          • 8421452488
                            likesingjumprap @小鱼
                            @小鱼 删除重新编译后还不行
                            CMakelists.txt
                            endif()
                            # find dependencies
                            if(BUILD_TESTING)
                            endif()
                            ament_package()
                            OledControl.srv
                            int32 px
                            int32 py
                            string data
                            int32 result
                              小鱼 技术大佬 @842145248
                              @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
                              • 8421452488
                                likesingjumprap @小鱼
                                @小鱼 示例也不行
                                 *  Executing task: platformio run
                                Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                                Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                                git version 2.34.1
                                Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                                remote: Enumerating objects: 5773, done.
                                remote: Counting objects: 100% (5773/5773), done.
                                remote: Compressing objects: 100% (2618/2618), done.
                                remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                                Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                                Resolving deltas: 100% (2905/2905), done.
                                Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                                Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                                Unpacking  [####################################]  100%
                                Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                                Library Manager: Resolving dependencies...
                                Library Manager: Installing Adafruit GFX Library
                                Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                                Library Manager: Installing Adafruit BusIO
                                Library Manager: Adafruit BusIO@1.14.4 has been installed!
                                Verbose mode can be enabled via `-v, --verbose` option
                                PACKAGES:
                                 - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                                /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                                Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                                [notice] A new release of pip available: 22.3.1 -> 23.2.1
                                [notice] To update, run: pip install --upgrade pip
                                /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                                Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                                Configuring featheresp32 with transport serial
                                micro-ROS already built
                                Dependency Graph
                                |-- Wire @ 2.0.0
                                |-- Adafruit GFX Library @ 1.11.8
                                esptool.py v4.2.1
                                src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                                 #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                                Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                                Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                                Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                                Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                                Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                                *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                                =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                                  小鱼 技术大佬 @842145248
                                  • 8421452488
                                    likesingjumprap @小鱼
                                    最后由 842145248 编辑
                                        return requester(
                                      小鱼 技术大佬 @842145248
                                      rm -rf build install log
                                      ros2 serivice list
                                      • 8421452488
                                        likesingjumprap @小鱼
                                        /oled_control
                                            return requester(
                                          小鱼 技术大佬 @842145248
                                          不要加这个
                                          • 8421452488
                                            likesingjumprap @小鱼
