    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    60.5k
    • 19916236831
      1991623683
      有一个问题,用git 克隆代码,编译出现错误:15795905-ed0a-427c-8303-868a76c3aa1b-图片.png ,请问是什么问题
        小鱼 技术大佬 @1991623683
        @1991623683 有重新编译过吗,删掉libmicroros
        • 8421452488
          likesingjumprap
          该贴中的方法都试过了还是不行,有兄弟们解决了的吗,
          platformio.ini,因为报错,根据提示也加了很多依赖,还是不行
          lib_deps =
          	https://gitee.com/ohhuo/micro_ros_platformio.git
          	adafruit/Adafruit SSD1306@^2.5.7
          	; adafruit/Adafruit GFX Library@^1.11.8
          	; adafruit/Adafruit BusIO@^1.14.4
          	; ; fabiobatsilva/ArduinoFake@^0.4.0
            小鱼 技术大佬 @842145248
            @842145248 你的报错是什么
            8421452488 1 条回复 最后回复 回复 引用 0
            • 8421452488
              likesingjumprap @小鱼
              @小鱼 刚刚重新编译了下,好慢,麻烦大佬帮我看看
              Building micro-ROS library
              Found 36 compatible libraries
              Scanning dependencies...
              Dependency Graph
              |-- Adafruit SSD1306 @ 2.5.7
              Building in release mode
              Compiling .pio/build/featheresp32/src/main.cpp.o
              Building .pio/build/featheresp32/bootloader.bin
              Generating partitions .pio/build/featheresp32/partitions.bin
              esptool.py v4.2.1
              Creating esp32 image...
              Merged 1 ELF section
              Successfully created esp32 image.
              Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
              Compiling .pio/build/featheresp32/lib1a4/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
              Compiling .pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o
              In file included from .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.cpp:53:
              .pio/libdeps/featheresp32/Adafruit SSD1306/Adafruit_SSD1306.h:42:10: fatal error: Adafruit_GFX.h: No such file or directory
              * Looking for Adafruit_GFX.h dependency? Check our library registry!
              * CLI  > platformio lib search "header:Adafruit_GFX.h"
              * Web  > https://registry.platformio.org/search?q=header:Adafruit_GFX.h
               #include <Adafruit_GFX.h>
              compilation terminated.
              Compiling .pio/build/featheresp32/FrameworkArduino/Esp.cpp.o
              Compiling .pio/build/featheresp32/FrameworkArduino/FirmwareMSC.cpp.o
              *** [.pio/build/featheresp32/lib2c3/Adafruit SSD1306/Adafruit_SSD1306.cpp.o] Error 1
              ======================================== [FAILED] Took 658.83 seconds ========================================
               *  The terminal process "platformio 'run'" terminated with exit code: 1.
               *  Terminal will be reused by tasks, press any key to close it.
                小鱼 技术大佬 @842145248
                @842145248 再贴一下完整的代码
                • 8421452488
                  likesingjumprap @小鱼
                  platformio.ini
                  [env:featheresp32]
                  platform = espressif32
                  board = featheresp32
                  framework = arduino
                  lib_deps =
                  CMakeLists.txt
                  project(fishbot_interfaces)
                  endif()
                  # find dependencies
                  if(BUILD_TESTING)
                  endif()
                    "srv/OledControl.srv"
                  ament_package()
                  package.xml
                  <?xml version="1.0"?>
                  <package format="3">
                    <name>fishbot_interfaces</name>
                    <version>0.0.0</version>
                    <maintainer email="root@todo.todo">root</maintainer>
                    <build_depend>rosidl_default_generators</build_depend>
                    <exec_depend>rosidl_default_runtime</exec_depend>
                    <export>
                    </export>
                  </package>
                  extra_package包
                  extra_packages/fishbot_interfaces/
                  ├── CMakeLists.txt
                  ├── include
                  │   └── fishbot_interfaces
                  ├── package.xml
                  ├── src
                  └── srv
                      └── OledControl.srv
                    小鱼 技术大佬 @842145248
                    @842145248 是 src/main.cpp ,你的错误在 main函数里不是自定义功能包造成的
                    • 8421452488
                      likesingjumprap @847718956
                      @小鱼 感谢大佬的的回复,我补充完整了main.cpp后可以编译了,我按照教程还没到编写main.cpp,我以为不用先写main.cpp😂 ,编译看看是否有错
                      但是命令行调用服务时出现了类似这种导包问题:重新运行代码时出现:UnsupportedTypeSupport: Could not import 'rosidl_typesupport_c' for package 'village_interfaces', CMakelist.txt 和 packages.xml,看着好像都没问题,麻烦大佬再帮我看看
                      $ source install/setup.bash  && ros2 service call  /oled_control fishbot_interfaces/srv/OledControl "{px: 0, py: 0, data: 'nihao'}"
                          return requester(
                      main.cpp
                      #include <Arduino.h>
                      #include <rcl/rcl.h>
                      #include <rclc/rclc.h>
                      #include <rclc/executor.h>
                      #include "Wire.h"
                      #include <Adafruit_SSD1306.h>
                      #include <fishbot_interfaces/srv/oled_control.h>
                      rclc_executor_t executor;
                      rclc_support_t support;
                      rcl_allocator_t allocator;
                      rcl_node_t node;
                      rcl_service_t service;
                      fishbot_interfaces__srv__OledControl_Request req;
                      fishbot_interfaces__srv__OledControl_Response res;
                      Adafruit_SSD1306 display;
                      void service_cb(const void *req, void *res)
                        fishbot_interfaces__srv__OledControl_Request *req_in = (fishbot_interfaces__srv__OledControl_Request *)req;
                        fishbot_interfaces__srv__OledControl_Response *res_in = (fishbot_interfaces__srv__OledControl_Response *)res;
                        display.clearDisplay();
                        display.setCursor(req_in->px, req_in->py);
                        display.println(req_in->data.data);
                        display.display();
                        res_in->result = 0;
                      void setup()
                        // put your setup code here, to run once:
                        Serial.begin(115200);
                        delay(2000);
                        rclc_node_init_default(&node, "example14_interfaces", "", &support);
                        rclc_service_init_default(&service, &node, ROSIDL_GET_SRV_TYPE_SUPPORT(fishbot_interfaces, srv, OledControl), "/oled_control");
                        rclc_executor_add_service(&executor, &service, &req, &res, service_cb);
                        req.data = micro_ros_string_utilities_init_with_size(100);
                        Wire.begin(18, 19);
                        display = Adafruit_SSD1306(128, 64, &Wire);
                        display.begin(SSD1306_SWITCHCAPVCC, 0x3c);
                        display.setTextSize(1);
                        display.setCursor(0, 0);
                        display.setTextColor(SSD1306_WHITE);
                        display.println("hello world!");
                        display.display();
                      void loop()
                        // put your main code here, to run repeatedly:
                        delay(100);
                        小鱼 技术大佬 @842145248
                        @842145248
                        这句在哪一个目录下执行的
                        • 8421452488
                          likesingjumprap @小鱼
                          @小鱼 example14_custom_interfaces/extra_packages 目录下
                            小鱼 技术大佬 @842145248
                            @842145248 删除掉build和install ,重新colcon build后测试,还报错就贴一下 CMakeLists.txt 和 srv文件
                            • 8421452488
                              likesingjumprap @小鱼
                              @小鱼 删除重新编译后还不行
                              CMakelists.txt
                              endif()
                              # find dependencies
                              if(BUILD_TESTING)
                              endif()
                              ament_package()
                              OledControl.srv
                              int32 px
                              int32 py
                              string data
                              int32 result
                                小鱼 技术大佬 @842145248
                                @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
                                • 8421452488
                                  likesingjumprap @小鱼
                                  @小鱼 示例也不行
                                   *  Executing task: platformio run
                                  Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
                                  Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
                                  git version 2.34.1
                                  Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
                                  remote: Enumerating objects: 5773, done.
                                  remote: Counting objects: 100% (5773/5773), done.
                                  remote: Compressing objects: 100% (2618/2618), done.
                                  remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
                                  Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
                                  Resolving deltas: 100% (2905/2905), done.
                                  Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
                                  Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
                                  Unpacking  [####################################]  100%
                                  Library Manager: Adafruit SSD1306@2.5.7 has been installed!
                                  Library Manager: Resolving dependencies...
                                  Library Manager: Installing Adafruit GFX Library
                                  Library Manager: Adafruit GFX Library@1.11.8 has been installed!
                                  Library Manager: Installing Adafruit BusIO
                                  Library Manager: Adafruit BusIO@1.14.4 has been installed!
                                  Verbose mode can be enabled via `-v, --verbose` option
                                  PACKAGES:
                                   - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
                                  /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
                                  Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
                                  [notice] A new release of pip available: 22.3.1 -> 23.2.1
                                  [notice] To update, run: pip install --upgrade pip
                                  /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
                                  Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
                                  Configuring featheresp32 with transport serial
                                  micro-ROS already built
                                  Dependency Graph
                                  |-- Wire @ 2.0.0
                                  |-- Adafruit GFX Library @ 1.11.8
                                  esptool.py v4.2.1
                                  src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
                                   #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
                                  Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
                                  Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
                                  Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
                                  Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
                                  Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
                                  *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
                                  =========================================================== [FAILED] Took 16.30 seconds ===========================================================
                                    小鱼 技术大佬 @842145248
                                    • 8421452488
                                      likesingjumprap @小鱼
                                      最后由 842145248 编辑
                                          return requester(
                                        小鱼 技术大佬 @842145248
                                        rm -rf build install log
                                        ros2 serivice list
                                        • 8421452488
                                          likesingjumprap @小鱼
                                          /oled_control
                                              return requester(
                                            小鱼 技术大佬 @842145248
                                            不要加这个
