    动手学ros2第5章进阶篇-控制OLED-自定义消息接口
    ros2 humble ros2 添加接口
    12
    52
    60.5k
      小鱼 技术大佬 @842145248
      @842145248 用示例工程的功能包试试:https://github.com/fishros/example_micoros_board
      8421452488 1 条回复 最后回复 回复 引用 0
      • 8421452488
        likesingjumprap @小鱼
        @小鱼 示例也不行
         *  Executing task: platformio run
        Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
        Library Manager: Installing git+https://gitee.com/ohhuo/micro_ros_platformio.git
        git version 2.34.1
        Cloning into '/home/nzb/.platformio/.cache/tmp/pkg-installing-mkfoxl4p'...
        remote: Enumerating objects: 5773, done.
        remote: Counting objects: 100% (5773/5773), done.
        remote: Compressing objects: 100% (2618/2618), done.
        remote: Total 5773 (delta 2905), reused 5732 (delta 2883), pack-reused 0
        Receiving objects: 100% (5773/5773), 19.12 MiB | 5.79 MiB/s, done.
        Resolving deltas: 100% (2905/2905), done.
        Library Manager: micro_ros_platformio@0.0.1+sha.085c5dd has been installed!
        Library Manager: Installing adafruit/Adafruit SSD1306 @ ^2.5.7
        Unpacking  [####################################]  100%
        Library Manager: Adafruit SSD1306@2.5.7 has been installed!
        Library Manager: Resolving dependencies...
        Library Manager: Installing Adafruit GFX Library
        Library Manager: Adafruit GFX Library@1.11.8 has been installed!
        Library Manager: Installing Adafruit BusIO
        Library Manager: Adafruit BusIO@1.14.4 has been installed!
        Verbose mode can be enabled via `-v, --verbose` option
        PACKAGES:
         - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
        /home/nzb/.platformio/penv/bin/python -m pip install pyyaml
        Requirement already satisfied: pyyaml in /home/nzb/.platformio/penv/lib/python3.10/site-packages (6.0)
        [notice] A new release of pip available: 22.3.1 -> 23.2.1
        [notice] To update, run: pip install --upgrade pip
        /home/nzb/.platformio/penv/bin/python -m pip install markupsafe==2.0.1
        Requirement already satisfied: markupsafe==2.0.1 in /home/nzb/.platformio/penv/lib/python3.10/site-packages (2.0.1)
        Configuring featheresp32 with transport serial
        micro-ROS already built
        Found 36 compatible libraries
        Scanning dependencies...
        Dependency Graph
        |-- Adafruit SSD1306 @ 2.5.7
        |-- Wire @ 2.0.0
        |-- Adafruit GFX Library @ 1.11.8
        Building in release mode
        Compiling .pio/build/featheresp32/src/main.cpp.o
        Building .pio/build/featheresp32/bootloader.bin
        Generating partitions .pio/build/featheresp32/partitions.bin
        esptool.py v4.2.1
        Creating esp32 image...
        Merged 1 ELF section
        Successfully created esp32 image.
        src/main.cpp:13:10: fatal error: fishbot_interfaces/srv/oled_control.h: No such file or directory
         #include <fishbot_interfaces/srv/oled_control.h> // 添加接口
        compilation terminated.
        Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/clock_gettime.cpp.o
        Compiling .pio/build/featheresp32/lib61f/micro_ros_platformio/platform_code/arduino/serial/micro_ros_transport.cpp.o
        Compiling .pio/build/featheresp32/lib31c/Wire/Wire.cpp.o
        Compiling .pio/build/featheresp32/lib271/SPI/SPI.cpp.o
        Compiling .pio/build/featheresp32/libaae/Adafruit BusIO/Adafruit_BusIO_Register.cpp.o
        *** [.pio/build/featheresp32/src/main.cpp.o] Error 1
        =========================================================== [FAILED] Took 16.30 seconds ===========================================================
         *  The terminal process "platformio 'run'" terminated with exit code: 1.
         *  Terminal will be reused by tasks, press any key to close it.
          小鱼 技术大佬 @842145248
          • 8421452488
            likesingjumprap @小鱼
            最后由 842145248 编辑
                return requester(
              小鱼 技术大佬 @842145248
              rm -rf build install log
              source install/setup.bash
              ros2 serivice list
              • 8421452488
                likesingjumprap @小鱼
                /oled_control
                    return requester(
                  小鱼 技术大佬 @842145248
                  不要加这个
                  • 8421452488
                    likesingjumprap @小鱼
                    • 8421452488
                      likesingjumprap @842145248
                        小鱼 技术大佬 @842145248
                        @842145248 我在我这里测试了一下,没有问题:
                        测试指令:
                        cd ~
                        ros2 serivice list
                        8421452488 2 条回复 最后回复 回复 引用 0
                        • 8421452488
                          likesingjumprap @小鱼
                          • 8421452488
                              小鱼 技术大佬 @842145248
                              • 8421452488
                                likesingjumprap @小鱼
                                嗯嗯,我再找找看,非常感谢大佬的支持
                                No LSB modules are available.
                                Distributor ID:	Ubuntu
                                Release:	22.04
                                Codename:	jammy
                                • 8421452488
                                  likesingjumprap @小鱼
                                  大佬,你电脑编完后的这个目录下的文件能截个图给我吗
                                    小鱼 技术大佬 @842145248
                                    @842145248
                                    总计 136
                                    • 8421452488
                                      likesingjumprap @小鱼
                                      total 136
                                        小鱼 技术大佬 @842145248
                                        python3 --version
                                        • 8421452488
                                          likesingjumprap @小鱼
                                          显示的python3.10
                                          刚刚我又卸载了一遍,卸载成功了,之前还剩个python3.6-minimal没卸载掉,显示的可执行文件是/usr/bin/python3.6m, 疑惑我半天,卸载的时候没用通配符,我还以为系统自带的卸载不了。
                                          终于可以正常编译了跑起来了😭 ,非常感谢大佬的支持🌷 🌷 🌷
                                            小鱼 技术大佬 @842145248
                                            @842145248 👍
