    『求助』
    硬件系统
    ros ros硬件 ros2
    1.0k
    • 25675246442
      er
      vscode 安装PlatformIO插件打开open一直显示loading,这个怎么解决![替代文字](Screenshot from 2023-05-12 16-10-42.png )
        小鱼 技术大佬 @2567524644
        @2567524644
        25675246442 1 条回复 最后回复 回复 引用 0
        • 25675246442
          er @小鱼
          @小鱼 系统版本ubuntu22.04LTS,ROS2-humble版本,安装了PlatformIO插件,点击open,一直显示loading,报了如下错误:
          Error: Error: Could not create PIO Core Virtual Environment. Please report to https://github.com/platformio/platformio-core-installer/issues -> Installer version: 1.1.2 Platform: Linux-5.19.0-41-generic-x86_64-with-glibc2.35
          Python version: 3.10.6 (main, Mar 10 2023, 10:55:28) [GCC 11.3.0]
          Python path: /usr/bin/python3
          Creating a virtual environment at /home/pzh/.platformio/penv
          /usr/bin/python3 at /home/pzh/.vscode/extensions/platformio.platformio-ide-3.0.0-linux-x64/node_modules/platformio-node-helpers/dist/index.js:1:5362
          at ChildProcess.o (/home/pzh/.vscode/extensions/platformio.platformio-ide-3.0.0-linux-x64/node_modules/platformio-node-helpers/dist/index.js:1:4660)
          at ChildProcess...
            小鱼 技术大佬 @2567524644
            @2567524644 换个网络环境试试
            • 25675246442
              er @小鱼
              @小鱼 谢谢,解决了
