    ROS2入门篇第3章-自定义接口RCLCPP实战colcon build失败,找不到功能包
    ros2编译 ros2节点通讯 ros2humble
    6
    7
    3.8k
    • 15971956291
      1597195629
      一直按着鱼哥的教材走的,这是colcon build之后终端显示的错误,好像是找不到example_ros2_interfaces这个功能包,希望大佬帮解决一下
      gaozhihao@gaozhihao-virtual-machine:~/Desktop/d2lros2/chapt3/chapt3_ws$ colcon build --packages-up-to example_interfaces_rclcpp
      Starting >>> example_interfaces_rclcpp
      --- stderr: example_interfaces_rclcpp
      CMake Error at CMakeLists.txt:11 (find_package):
        By not providing "Findexample_ros2_interfaces.cmake" in CMAKE_MODULE_PATH
        this project has asked CMake to find a package configuration file provided
        by "example_ros2_interfaces", but CMake did not find one.
        "example_ros2_interfaces" with any of the following names:
          example_ros2_interfacesConfig.cmake
          example_ros2_interfaces-config.cmake
        Add the installation prefix of "example_ros2_interfaces" to
        CMAKE_PREFIX_PATH or set "example_ros2_interfaces_DIR" to a directory
        containing one of the above files.  If "example_ros2_interfaces" provides a
        separate development package or SDK, be sure it has been installed.
      gmake: *** [Makefile:308:cmake_check_build_system] 错误 1
      Failed   <<< example_interfaces_rclcpp [0.85s, exited with code 2]
      Summary: 0 packages finished [1.20s]
        1 package failed: example_interfaces_rclcpp
        1 package had stderr output: example_interfaces_rclcpp
      • 杜守钰杜
        杜守钰
        你能提供以下你的cmake 文件吗?
        15971956291 29378176392 2 条回复 最后回复 回复 引用 0
        • 15971956291
          1597195629 @杜守钰
          @杜守钰
          project(example_interfaces_rclcpp)
          endif()
          # find dependencies
          find_package(rclcpp REQUIRED)
          find_package(example_ros2_interfaces REQUIRED)
          if(BUILD_TESTING)
          endif()
          ament_package()
          add_executable(example_interfaces_robot_01 src/example_interfaces_robot_01.cpp)
          target_include_directories(example_interfaces_robot_01 PUBLIC
            $<BUILD_INTERFACE:${CMAKE_CURRENT_SOURCE_DIR}/include>
            $<INSTALL_INTERFACE:include>)
          target_compile_features(example_interfaces_robot_01 PUBLIC c_std_99 cxx_std_17)  # Require C99 and C++17
          ament_target_dependencies(
            "rclcpp"
          install(TARGETS example_interfaces_robot_01
          add_executable(example_interfaces_control_01 src/example_interfaces_control_01.cpp)
          target_include_directories(example_interfaces_control_01 PUBLIC
          target_compile_features(example_interfaces_control_01 PUBLIC c_std_99 cxx_std_17)  # Require C99 and C++17
            "rclcpp"
          install(TARGETS example_interfaces_control_01
            小鱼 技术大佬 @1597195629
            @1597195629 在 ROS2入门篇第3章-自定义接口RCLCPP实战colcon build失败,找不到功能包 中说:
            ament_package()
            这句话放到最后,这句话前的指令才会被ros2认可
            • 29378176392
              2937817639 @杜守钰
              @杜守钰 uu你解决了嘛 我也是同样的问题 鱼哥说的
              ament_package()
              放在cmake文件的最后我依旧有同样的报错 而且我看视频里面是在该行代码之后编写的需要添加的代码 依旧colcon build成功了TT
              10903348941 1 条回复 最后回复 回复 引用 0
              • 10903348941
                HeyMad @2937817639
                @2937817639 可以试试用SET({对应接口}_DIR /yourpath/)的方式试试,原因应该是找不到接口包的路径
                  等待修复
