    Ubuntu电脑端编译工作空间
    ubuntu22.04 colcon build
    1.9k
    • 10587044451
      1058704445
      sudo apt install python3-colcon-ros这个命令应该是在工作空间的根目录下执行的,但是我是直接在pc端执行了,执行结果也没有错,也可以安装成功,但工作空间的根目录下执行colcon build命令时就出现了以下错误。在工作空间的根目录下重新执行sudo apt install python3-colcon-ros命令(执行该命令没有出错),然后colcon build命令时也还是出现以下的错误:
      -- Found ament_cmake: 1.3.5 (/opt/ros/humble/share/ament_cmake/cmake)
      CMake Error at CMakeLists.txt:20 (find_package):
      By not providing "Findnav2_bringup.cmake" in CMAKE_MODULE_PATH this project
      has asked CMake to find a package configuration file provided by
      "nav2_bringup", but CMake did not find one.
      Could not find a package configuration file provided by "nav2_bringup" with
      any of the following names:
      nav2_bringupConfig.cmake
      nav2_bringup-config.cmake
      Add the installation prefix of "nav2_bringup" to CMAKE_PREFIX_PATH or set
      "nav2_bringup_DIR" to a directory containing one of the above files. If
      "nav2_bringup" provides a separate development package or SDK, be sure it
      has been installed.
      -- Configuring incomplete, errors occurred!
      See also "/home/ldf/dev_ws/build/originbot_navigation/CMakeFiles/CMakeOutput.log".
      Failed <<< originbot_navigation [0.29s, exited with code 1]
        小鱼 技术大佬 @1058704445
        @1058704445 这个错误是没安装nav2_bringup造成的
        10587044451 1 条回复 最后回复 回复 引用 0
        • 10587044451
          1058704445 @小鱼
          @小鱼 直接apt install nav2_bringup吗?还是怎么安装?
          杜守钰杜 1 条回复 最后回复 回复 引用 0
          • 杜守钰杜
            杜守钰 @1058704445
            @1058704445
            1. sudo apt-get install ros-你的ros版本-nav2-bringup,
              比如 sudo apt-get install ros-humble-nav2-bringup
            2. 从源码安装,可以参考 http://d2lros2foxy.fishros.com/?error=redirect_uri_mismatch&error_description=The+redirect_uri+MUST+match+the+registered+callback+URL+for+this+application.&error_uri=https%3A%2F%2Fdocs.github.com%2Fapps%2Fmanaging-oauth-apps%2Ftroubleshooting-authorization-request-errors%2F%23redirect-uri-mismatch#/humble/chapt11/get_started/1.Nav2导航框架介绍
            • 10587044451
              1058704445 @杜守钰
              @杜守钰 在 Ubuntu电脑端编译工作空间 中说:
              @1058704445
              已解决,谢谢
              • 10587044451 1058704445 将这个主题标记为已解决,在
