    第九章无法启动模型
    ros2 gazebo
    5
    13
    1.3k
      ros2 launch fishbot_description gazebo.launch.py
      file 'gazebo.launch.py' was not found in the share directory of package 'fishbot_description' which is at '/home/zj/fishbot_ws/src/install/fishbot_description/share/fishbot_description'
      小鱼小 1 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @15014960082
        @15014960082 你有在第八章的时候将launch文件夹install吗?
          15014960082 @15014960082
          @15014960082 加过了,还重新创建和从来过
            @15014960082 放一下你的setup.py看看
              15014960082 @小鱼
                    15014960082 @小鱼
                    from setuptools import setup
                    from glob import glob
                    import os
                    setup(
                        name=package_name,
                        version='0.0.0',
                        packages=[package_name],
                        data_files=[
                            ('share/ament_index/resource_index/packages',
                                ['resource/' + package_name]),
                            ('share/' + package_name, ['package.xml']),
                             (os.path.join('share', package_name, 'launch'), glob('launch/display_rviz2.launch.py')),
                            (os.path.join('share', package_name, 'urdf'), glob('urdf/fishbot_base.urdf')),
                            (os.path.join('share', package_name, 'launch'), glob('launch/gazebo.launch.py'))
                        install_requires=['setuptools'],
                        zip_safe=True,
                        maintainer='zj',
                        maintainer_email='zj@todo.todo',
                        description='TODO: Package description',
                        license='TODO: License declaration',
                        tests_require=['pytest'],
                        entry_points={
                            'console_scripts': [
                            "rotate_wheel= fishbot_description.rotate_wheel:main"
                    ![下面是启片动后的](2022-04-30 22-47-56 的屏幕截图.png )
                      @15014960082 这不是找到了吗😁
                        15014960082 @小鱼
                        @小鱼 解决。感谢大佬带飞,主要还是我自己细节没处理好😊
                        阿政在路上阿 1 条回复 最后回复 回复 引用 0
                        • 阿政在路上阿
                          阿政在路上 @15014960082
                          • 小鱼小 小鱼 从 中的 动手学ROS2 移动了该主题
                          • 天涯未远天
                            链路小明
                            请问具体是怎么解决的呢?遇到了相同的问题
                              wushengxin
                              9.2章节
                              想要启动Gazebo及其插件
                              输入指令:gazebo --verbose -s libgazebo_ros_factory.so
                              前面几行正确
                              Gazebo multi-robot simulator, version 11.11.0
                              Copyright (C) 2012 Open Source Robotics Foundation.
                              Released under the Apache 2 License.
                              http://gazebosim.org
                              [Msg] Waiting for master.
                              [Msg] Connected to gazebo master @ http://127.0.0.1:11345
                              [Msg] Publicized address: 192.168.0.110
                              [Msg] Loading world file [/usr/share/gazebo-11/worlds/empty.world]
                              下面开始报错:
                              [INFO] [1729773472.917806661] [gazebo_ros_node]: ROS was initialized without arguments.
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.cache"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.clash"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.config"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.dotnet"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.fishros"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.gazebo"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.gnupg"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.ignition"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.local"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.mozilla"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.pip"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.pki"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.ros"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.rviz2"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.sdformat"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.ssh"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.thunderbird"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/.vscode"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Desktop"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Documents"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Downloads"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Music"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Pictures"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Public"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Python-3.10.5"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Share"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Templates"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/Videos"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/build"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/colcon_test_ws"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/examples"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/fishbot_ws"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/fishros2"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/install"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/log"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/sharedStorage"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/snap"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/towm_ws"</b></font>
                              <font color="#CC0000"><b>[Err] [InsertModelWidget.cc:403] Missing model.config for model "/home/wushengxin/turtle_ws"</b></font>
                              context mismatch in svga_surface_destroy
                              </pre>
                              求小鱼解答@小鱼
