    自动化编译microROS的github仓库
    ros2 microros stm32
    889
    • ganyuanzhenG
      Elysia 技术大佬
      做了自动化编译microROS的github仓库,有需要的可以自取。
      目前是STM32F407VET6的静态库,适用于ROS2 iron版本。可在Release当中下载。
      更换芯片之类的教程,待我之后来更新!
      传送门:https://github.com/ganyuanzhen/microROSF407BinrayBuilder
      ganyuanzhenG 4727958324 3 条回复 最后回复 回复 引用 1
      • ganyuanzhenG
        Elysia 技术大佬 @ganyuanzhen
        @ganyuanzhen 使用的CMake文件如下,可自行取用
        #此文件从模板自动生成! 请勿更改!
        set(CMAKE_SYSTEM_NAME Generic)
        set(CMAKE_SYSTEM_VERSION 1)
        cmake_minimum_required(VERSION 3.27)
        # specify cross-compilers and tools
        set(CMAKE_C_COMPILER arm-none-eabi-gcc)
        set(CMAKE_CXX_COMPILER arm-none-eabi-g++)
        set(CMAKE_ASM_COMPILER  arm-none-eabi-gcc)
        set(CMAKE_AR arm-none-eabi-ar)
        set(CMAKE_OBJCOPY arm-none-eabi-objcopy)
        set(CMAKE_OBJDUMP arm-none-eabi-objdump)
        set(SIZE arm-none-eabi-size)
        set(CMAKE_TRY_COMPILE_TARGET_TYPE STATIC_LIBRARY)
        # project settings
        project(microROSF407 C CXX ASM)
        set(CMAKE_CXX_STANDARD 17)
        set(CMAKE_C_STANDARD 11)
        #Uncomment for hardware floating point
        add_compile_definitions(ARM_MATH_CM4;ARM_MATH_MATRIX_CHECK;ARM_MATH_ROUNDING)
        add_compile_options(-mfloat-abi=hard -mfpu=fpv4-sp-d16)
        add_link_options(-mfloat-abi=hard -mfpu=fpv4-sp-d16)
        #Uncomment for software floating point
        #add_compile_options(-mfloat-abi=soft)
        add_compile_options(-mcpu=cortex-m4 -mthumb -mthumb-interwork)
        add_compile_options(-ffunction-sections -fdata-sections -fno-common -fmessage-length=0)
        # uncomment to mitigate c++17 absolute addresses warnings
        #set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wno-register")
        # Enable assembler files preprocessing
        add_compile_options($<$<COMPILE_LANGUAGE:ASM>:-x$<SEMICOLON>assembler-with-cpp>)
        if ("${CMAKE_BUILD_TYPE}" STREQUAL "Release")
            message(STATUS "Maximum optimization for speed")
            add_compile_options(-Ofast)
        elseif ("${CMAKE_BUILD_TYPE}" STREQUAL "RelWithDebInfo")
            message(STATUS "Maximum optimization for speed, debug info included")
            add_compile_options(-Ofast -g)
        elseif ("${CMAKE_BUILD_TYPE}" STREQUAL "MinSizeRel")
            message(STATUS "Maximum optimization for size")
            add_compile_options(-Os)
        else ()
            message(STATUS "Minimal optimization, debug info included")
            add_compile_options(-Og -g)
        endif ()
        #Import microROS Library Start#
        add_library( libmicroros STATIC IMPORTED )
        set_target_properties( libmicroros PROPERTIES IMPORTED_LOCATION ${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/microros_static_library/libmicroros/libmicroros.a )
        list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/custom_memory_manager.c")
        list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_time.c")
        list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_allocators.c")
        # Set here the custom transport implementation
        list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_transports/dma_transport.c")
        # list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_transports/it_transport.c")
        # list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_transports/udp_transport.c")
        # list(APPEND microROS_Source "${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/extra_sources/microros_transports/usb_cdc_transport.c")
        include_directories(${PROJECT_SOURCE_DIR}/micro_ros_stm32cubemx_utils/microros_static_library/libmicroros/microros_include)
        #Import microROS Library End#
        include_directories(Core/Inc Drivers/STM32F4xx_HAL_Driver/Inc Drivers/STM32F4xx_HAL_Driver/Inc/Legacy Middlewares/Third_Party/FreeRTOS/Source/include Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2 Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F Drivers/CMSIS/Device/ST/STM32F4xx/Include Drivers/CMSIS/Include)
        add_definitions(-DDEBUG -DUSE_HAL_DRIVER -DSTM32F407xx)
        file(GLOB_RECURSE SOURCES "Core/*.*" "Middlewares/*.*" "Drivers/*.*")
        set(LINKER_SCRIPT ${CMAKE_SOURCE_DIR}/STM32F407VETX_FLASH.ld)
        add_link_options(-Wl,-gc-sections,--print-memory-usage,-Map=${PROJECT_BINARY_DIR}/${PROJECT_NAME}.map)
        add_link_options(-mcpu=cortex-m4 -mthumb -mthumb-interwork)
        add_link_options(-T ${LINKER_SCRIPT})
        add_executable(${PROJECT_NAME}.elf ${SOURCES} ${microROS_Source} ${LINKER_SCRIPT})
        target_link_libraries(${PROJECT_NAME}.elf PUBLIC libmicroros)
        set(HEX_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.hex)
        set(BIN_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.bin)
        add_custom_command(TARGET ${PROJECT_NAME}.elf POST_BUILD
                COMMAND ${CMAKE_OBJCOPY} -Oihex $<TARGET_FILE:${PROJECT_NAME}.elf> ${HEX_FILE}
                COMMAND ${CMAKE_OBJCOPY} -Obinary $<TARGET_FILE:${PROJECT_NAME}.elf> ${BIN_FILE}
                COMMENT "Building ${HEX_FILE}
        Building ${BIN_FILE}")
        • 4727958324
          何念 @ganyuanzhen
          • 4727958324
            何念 @ganyuanzhen
            @ganyuanzhen 大佬有没有foxy的版本啊 有么有上板子跑过
            • ganyuanzhenG
              Elysia 技术大佬 @472795832
              @472795832 还没上板子测试,这几天考试没去实验室。
              过几天可帮你测试一下
              4727958324 1 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @ganyuanzhen
                @ganyuanzhen 欢迎出个教程,我给你发篇推广
                • 4727958324
                  何念 @ganyuanzhen
                  @ganyuanzhen 跪求教程 我帮你验证
                  • ganyuanzhenG ganyuanzhen 在 中 引用了 这个主题
