    rosrun报错,ModuleNotFoundError: No module named 'pydot'
    rosrun ros
    1.0k
    • fuzzF
      fuzz
      我在跑小乌龟程序的时候,学习网上教程想看看节点,输入了rosrun rqt_graph rqt_graph,之后就报错了,具体代码如下,请大佬们给萌新指导一下。
      PluginManager._discover() force discovery of plugins
      RospkgPluginProvider._find_plugins() crawling for plugins of type 'qt_gui'
      Could not import "pyside" bindings of qt_gui_cpp library - so C++ plugins will not be available:
      File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_gui_cpp/cpp_binding_helper.py", line 39, in <module>
      from . import libqt_gui_cpp_shiboken
      ImportError: cannot import name 'libqt_gui_cpp_shiboken'
      RospkgPluginProvider._find_plugins() crawling for plugins of type 'rqt_gui'
      QtBindingHelper using pyside
      PerspectiveManager.switch_perspective() switching to perspective "@rqt_graph__RosGraph"
      MainWindow.restore_settings()
      PluginManager.restore_settings_without_plugins()
      MainWindow.restore_state()
      PluginManager.load_plugin(rqt_graph/RosGraph, 0)
      MainWindow.save_setup()
      RosPyPluginProvider._init_node() initialize ROS node "rqt_gui_py_node_2480"
      RosPluginProvider.load(rqt_graph/RosGraph) exception raised in builtin.import(rqt_graph.ros_graph, [RosGraph]):
      File "/opt/ros/melodic/lib/python2.7/dist-packages/rqt_gui/ros_plugin_provider.py", line 80, in load
      attributes['module_name'], fromlist=[attributes['class_from_class_type']], level=0)
      File "/home/fzz/.local/lib/python3.6/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 142, in _import
      return original_import(name, *args, **kwargs)
      File "/opt/ros/melodic/lib/python2.7/dist-packages/rqt_graph/ros_graph.py", line 45, in <module>
      from qt_dotgraph.dot_to_qt import DotToQtGenerator
      File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_dotgraph/dot_to_qt.py", line 35, in <module>
      import pydot
      PluginManager._load_plugin_restore()
      PluginManager._load_plugin() could not load plugin "rqt_graph/RosGraph":
      File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_gui/plugin_handler.py", line 102, in load
      self._load()
      File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_gui/plugin_handler_direct.py", line 55, in _load
      self._plugin = self._plugin_provider.load(self._instance_id.plugin_id, self._context)
      File "/opt/ros/melodic/lib/python2.7/dist-packages/qt_gui/composite_plugin_provider.py", line 72, in load
      instance = plugin_provider.load(plugin_id, plugin_context)
      File "/opt/ros/melodic/lib/python2.7/dist-packages/rqt_gui_py/ros_py_plugin_provider.py", line 61, in load
      return super(RosPyPluginProvider, self).load(plugin_id, plugin_context)
      File "/opt/ros/melodic/lib/python2.7/dist-packages/rqt_gui/ros_plugin_provider.py", line 90, in load
      raise e
      import pydot
      谢谢!
      小鱼小 2 条回复 最后回复 回复 引用 0
        小鱼 技术大佬 @fuzz
        @fuzz 别在这个板块发哈,先找找对应板块,找不到在综合问题下发
        fuzzF 1 条回复 最后回复 回复 引用 0
        • 小鱼小 小鱼 从 中的 社区&开源 移动了该主题
        • fuzzF
          fuzz @小鱼
          @小鱼 好的,抱歉,我重新发一下。
            小鱼 技术大佬 @fuzz
            @fuzz 我已经移过去了😀
            • fuzzF
              fuzz @小鱼
              @小鱼 好的,谢谢您。
                小鱼 技术大佬 @fuzz
                @fuzz 😁 还有格式,可以用代码块包裹下,markdown语法在写文档会经常用到,强烈建议使用哦
                • fuzzF
                  fuzz @小鱼
                  @小鱼 好的,我去了解一下那个软件,抱歉现在还不太懂所以格式不对,给您添麻烦了。
                    小鱼 技术大佬 @fuzz
                    @fuzz 在 rosrun报错,ModuleNotFoundError: No module named 'pydot' 中说:
                    从库的引用上看,估计是又找到了python3上面了,环境应该是有些混乱。
