    《动手学Moveit2》3.安装Moveit2测试
    机械臂运动规划
    动手学moveit2 moveit2教程
    18
    49
    32.6k
    • 11989270601
      星河 @小鱼
      @小鱼 鱼哥,我的系统是ubuntu20.6,用你的一键安装,里面没有humble版本,只有rolling版本,咋回事
      • 11989270601
        星河
        在克隆moveit2_tutorials.repos的时候出现这么多错误,咋回事,鱼哥
        11989270601 1 条回复 最后回复 回复 引用 0
        • 11989270601
          星河 @1198927060
          @1198927060
          目前看到因为:https://ghproxy.com/的原因,不加这个就好了
          • 11989270601
            星河
            安装可以打开样例,但是打开官方的样例:ros2 launch moveit2_tutorials demo.launch.py rviz_tutorial:=true的时候报错:Package 'moveit2_tutorials' not found: "package 'moveit2_tutorials' not found, searching: ['/opt/ros/humble']",咋回事,鱼哥
            • 7508621397
              LZ
                  colcon build --mixin release
                  Starting >>> geometric_shapes
                  Starting >>> moveit_msgs
                  Starting >>> moveit_common
                  Starting >>> moveit_resources_panda_description
                  Starting >>> launch_param_builder
                  Starting >>> moveit_resources_fanuc_description
                  Starting >>> moveit_resources_pr2_description
                  Starting >>> moveit_resources_prbt_support
                  Starting >>> rviz_visual_tools
                  --- stderr: geometric_shapes
                  CMake Error at CMakeLists.txt:54 (find_package):
                  By not providing "Findeigen_stl_containers.cmake" in CMAKE_MODULE_PATH this
                  project has asked CMake to find a package configuration file provided by
                  "eigen_stl_containers", but CMake did not find one.
                  "eigen_stl_containers" with any of the following names:
                  eigen_stl_containersConfig.cmake
                  eigen_stl_containers-config.cmake
                  Add the installation prefix of "eigen_stl_containers" to CMAKE_PREFIX_PATH
                  or set "eigen_stl_containers_DIR" to a directory containing one of the
                  above files. If "eigen_stl_containers" provides a separate development
                  package or SDK, be sure it has been installed.
                  Failed <<< geometric_shapes [0.98s, exited with code 1]
                  Aborted <<< moveit_resources_panda_description [0.94s]
                  Aborted <<< moveit_common [0.95s]
                  Aborted <<< moveit_resources_fanuc_description [0.94s]
                  Aborted <<< moveit_resources_prbt_support [0.93s]
                  Aborted <<< moveit_resources_pr2_description [0.95s]
                  Aborted <<< moveit_msgs [1.14s]
                  Aborted <<< launch_param_builder [1.62s]
                  Aborted <<< rviz_visual_tools [2.55s]
                  Summary: 0 packages finished [3.77s]
                  1 package failed: geometric_shapes
                  8 packages aborted: launch_param_builder moveit_common moveit_msgs moveit_resources_fanuc_description moveit_resources_panda_description moveit_resources_pr2_description moveit_resources_prbt_support rviz_visual_tools
                  3 packages had stderr output: geometric_shapes moveit_msgs rviz_visual_tools
                  36 packages not processed
                  这个错误 怎么处理,一堆依赖问题,手动安装也安装不了
                    小鱼大佬,我第一步就安装不了怎么办,github一直连接不了
                    • C
                      chenxz
                      鱼哥,求教一个问题。如果只计算一个串联机械臂的逆解,MOVEIT能在ROS2的程序中通过调用函数或者接口的方式,发送目标位置并获取逆解嘛,或者还有什么其他的方法嘞。
