【已解决】ros2 galactic 使用astra s相机运行rtabmap无法建图(可以生成单帧点云)
这边单独运行相机节点发布了rgb和depth数据,然后修改rtabmap.launch.py内部参数如下
# Arguments DeclareLaunchArgument('stereo', default_value='false', description='Use stereo input instead of RGB-D.'), DeclareLaunchArgument('localization', default_value='false', description='Launch in localization mode.'), DeclareLaunchArgument('rtabmapviz', default_value='true', description='Launch RTAB-Map UI (optional).'), DeclareLaunchArgument('rviz', default_value='false', description='Launch RVIZ (optional).'), DeclareLaunchArgument('use_sim_time', default_value='false', description='Use simulation (Gazebo) clock if true'), # Config files DeclareLaunchArgument('cfg', default_value='', description='To change RTAB-Map\'s parameters, set the path of config file (*.ini) generated by the standalone app.'), DeclareLaunchArgument('gui_cfg', default_value='~/.ros/rtabmap_gui.ini', description='Configuration path of rtabmapviz.'), DeclareLaunchArgument('rviz_cfg', default_value=config_rviz, description='Configuration path of rviz2.'), DeclareLaunchArgument('frame_id', default_value='camera_link', description='Fixed frame id of the robot (base frame), you may set "base_link" or "base_footprint" if they are published. For camera-only config, this could be "camera_link".'), DeclareLaunchArgument('odom_frame_id', default_value='', description='If set, TF is used to get odometry instead of the topic.'), DeclareLaunchArgument('map_frame_id', default_value='map', description='Output map frame id (TF).'), DeclareLaunchArgument('publish_tf_map', default_value='true', description='Publish TF between map and odomerty.'), DeclareLaunchArgument('namespace', default_value='rtabmap', description=''), DeclareLaunchArgument('database_path', default_value='~/.ros/rtabmap.db', description='Where is the map saved/loaded.'), DeclareLaunchArgument('queue_size', default_value='20', description=''), DeclareLaunchArgument('qos', default_value='2', description='General QoS used for sensor input data: 0=system default, 1=Reliable, 2=Best Effort.'), DeclareLaunchArgument('wait_for_transform', default_value='0.2', description=''), DeclareLaunchArgument('rtabmap_args', default_value='', description='Backward compatibility, use "args" instead.'), DeclareLaunchArgument('launch_prefix', default_value='', description='For debugging purpose, it fills prefix tag of the nodes, e.g., "xterm -e gdb -ex run --args"'), DeclareLaunchArgument('output', default_value='screen', description='Control node output (screen or log).'), DeclareLaunchArgument('ground_truth_frame_id', default_value='', description='e.g., "world"'), DeclareLaunchArgument('ground_truth_base_frame_id', default_value='', description='e.g., "tracker", a fake frame matching the frame "frame_id" (but on different TF tree)'), DeclareLaunchArgument('approx_sync', default_value='true', description='If timestamps of the input topics should be synchronized using approximate or exact time policy.'), # RGB-D related topics DeclareLaunchArgument('rgb_topic', default_value='/camera/color/image_raw', description=''), DeclareLaunchArgument('depth_topic', default_value='/camera/depth/image_raw', description=''), DeclareLaunchArgument('camera_info_topic', default_value='/camera/depth/camera_info',description=''), # Stereo related topics DeclareLaunchArgument('stereo_namespace', default_value='/stereo_camera', description=''), DeclareLaunchArgument('left_image_topic', default_value=[LaunchConfiguration('stereo_namespace'), '/left/image_rect_color'], description=''), DeclareLaunchArgument('right_image_topic', default_value=[LaunchConfiguration('stereo_namespace'), '/right/image_rect'], description='Use grayscale image for efficiency'), DeclareLaunchArgument('left_camera_info_topic', default_value=[LaunchConfiguration('stereo_namespace'), '/left/camera_info'], description=''), DeclareLaunchArgument('right_camera_info_topic', default_value=[LaunchConfiguration('stereo_namespace'), '/right/camera_info'], description=''), # Use Pre-sync RGBDImage format DeclareLaunchArgument('rgbd_sync', default_value='false', description='Pre-sync rgb_topic, depth_topic, camera_info_topic.'), DeclareLaunchArgument('approx_rgbd_sync', default_value='true', description='false=exact synchronization.'), DeclareLaunchArgument('subscribe_rgbd', default_value=LaunchConfiguration('rgbd_sync'), description='Already synchronized RGB-D related topic, e.g., with rtabmap_ros/rgbd_sync nodelet.'), DeclareLaunchArgument('rgbd_topic', default_value='rgbd_image', description=''), DeclareLaunchArgument('depth_scale', default_value='1.0', description=''), # Image topic compression DeclareLaunchArgument('compressed', default_value='false', description='If you want to subscribe to compressed image topics'), DeclareLaunchArgument('rgb_image_transport', default_value='compressed', description='Common types: compressed, theora (see "rosrun image_transport list_transports")'), DeclareLaunchArgument('depth_image_transport', default_value='compressedDepth', description='Depth compatible types: compressedDepth (see "rosrun image_transport list_transports")'), # LiDAR DeclareLaunchArgument('subscribe_scan', default_value='false', description=''), DeclareLaunchArgument('scan_topic', default_value='/scan', description=''), DeclareLaunchArgument('subscribe_scan_cloud', default_value='false', description=''), DeclareLaunchArgument('scan_cloud_topic', default_value='/scan_cloud', description=''), DeclareLaunchArgument('scan_normal_k', default_value='0', description=''), # Odometry DeclareLaunchArgument('visual_odometry', default_value='true', description='Launch rtabmap visual odometry node.'), DeclareLaunchArgument('icp_odometry', default_value='false', description='Launch rtabmap icp odometry node.'), DeclareLaunchArgument('odom_topic', default_value='odom', description='Odometry topic name.'), DeclareLaunchArgument('vo_frame_id', default_value=LaunchConfiguration('odom_topic'), description='Visual/Icp odometry frame ID for TF.'), DeclareLaunchArgument('publish_tf_odom', default_value='true', description=''), DeclareLaunchArgument('odom_tf_angular_variance', default_value='0.01', description='If TF is used to get odometry, this is the default angular variance'), DeclareLaunchArgument('odom_tf_linear_variance', default_value='0.001', description='If TF is used to get odometry, this is the default linear variance'), DeclareLaunchArgument('odom_args', default_value='', description='More arguments for odometry (overwrite same parameters in rtabmap_args).'), DeclareLaunchArgument('odom_sensor_sync', default_value='false', description=''), DeclareLaunchArgument('odom_guess_frame_id', default_value='', description=''), DeclareLaunchArgument('odom_guess_min_translation', default_value='0.0', description=''), DeclareLaunchArgument('odom_guess_min_rotation', default_value='0.0', description=''),
运行的时候rtabmapiz控制台会报错
util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid
不建图 只显示单帧数据
初学小菜鸟求解终端里面看起来视觉里程计也不太正常
[rgbd_odometry-1] [INFO] [1663398187.567110256] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.010347s [rgbd_odometry-1] [INFO] [1663398187.576459463] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008404s [rgbd_odometry-1] [INFO] [1663398187.659465616] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012715s [rgbd_odometry-1] [INFO] [1663398187.668895425] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008550s [rgbd_odometry-1] [INFO] [1663398187.677696538] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007952s [rgbd_odometry-1] [INFO] [1663398187.761097371] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.011698s [rgbd_odometry-1] [INFO] [1663398187.770419207] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008257s [rgbd_odometry-1] [INFO] [1663398187.779528887] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008267s [rgbd_odometry-1] [INFO] [1663398187.859531168] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012646s [rgbd_odometry-1] [INFO] [1663398187.868233829] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007911s [rgbd_odometry-1] [INFO] [1663398187.877549215] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008469s [rgbd_odometry-1] [INFO] [1663398187.954169813] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.014044s [rgbd_odometry-1] [INFO] [1663398187.966101802] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.010370s [rgbd_odometry-1] [INFO] [1663398187.975220213] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008089s [rgbd_odometry-1] [INFO] [1663398188.061192398] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013515s [rgbd_odometry-1] [INFO] [1663398188.070477343] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008116s [rgbd_odometry-1] [INFO] [1663398188.154086911] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013209s [rgbd_odometry-1] [INFO] [1663398188.163276074] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008290s [rgbd_odometry-1] [INFO] [1663398188.171984495] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008008s [rgbd_odometry-1] [INFO] [1663398188.256393842] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012317s [rgbd_odometry-1] [INFO] [1663398188.266197199] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008756s [rgbd_odometry-1] [INFO] [1663398188.275826993] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008637s [rtabmap-2] [INFO] [1663398188.298330109] [rtabmap.rtabmap]: rtabmap (886): Rate=1.00s, Limit=0.000s, Conversion=0.0011s, RTAB-Map=0.0394s, Maps update=0.0011s pub=0.0000s (local map=1, WM=91) [rgbd_odometry-1] [INFO] [1663398188.353489587] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009776s [rgbd_odometry-1] [INFO] [1663398188.365871727] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.011197s [rgbd_odometry-1] [INFO] [1663398188.456308309] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012305s [rgbd_odometry-1] [INFO] [1663398188.465904362] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008395s [rgbd_odometry-1] [INFO] [1663398188.561805348] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.010105s [rgbd_odometry-1] [INFO] [1663398188.570939979] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007963s [rgbd_odometry-1] [INFO] [1663398188.580873370] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008837s [rgbd_odometry-1] [INFO] [1663398188.656436723] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.011586s [rgbd_odometry-1] [INFO] [1663398188.665989805] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008765s [rgbd_odometry-1] [INFO] [1663398188.674980852] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008231s [rgbd_odometry-1] [INFO] [1663398188.760119437] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012440s [rgbd_odometry-1] [INFO] [1663398188.769558146] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008428s [rgbd_odometry-1] [INFO] [1663398188.856946555] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.010834s [rgbd_odometry-1] [INFO] [1663398188.866650130] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008819s [rgbd_odometry-1] [INFO] [1663398188.958472057] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.010210s [rgbd_odometry-1] [INFO] [1663398188.969012183] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009272s [rgbd_odometry-1] [INFO] [1663398188.977962460] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008188s [rgbd_odometry-1] [INFO] [1663398189.060579573] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012241s [rgbd_odometry-1] [INFO] [1663398189.070776441] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008862s [rgbd_odometry-1] [INFO] [1663398189.164213736] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012140s [rgbd_odometry-1] [INFO] [1663398189.173621654] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008350s [rgbd_odometry-1] [INFO] [1663398189.258661907] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013464s [rgbd_odometry-1] [INFO] [1663398189.267545912] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007793s [rgbd_odometry-1] [INFO] [1663398189.278019196] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009486s [rtabmap-2] [INFO] [1663398189.300369068] [rtabmap.rtabmap]: rtabmap (887): Rate=1.00s, Limit=0.000s, Conversion=0.0007s, RTAB-Map=0.0393s, Maps update=0.0014s pub=0.0000s (local map=1, WM=91) [rgbd_odometry-1] [INFO] [1663398189.360101207] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007820s [rgbd_odometry-1] [INFO] [1663398189.416060394] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013199s [rgbd_odometry-1] [INFO] [1663398189.459732742] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013063s [rgbd_odometry-1] [INFO] [1663398189.564018531] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012771s [rgbd_odometry-1] [INFO] [1663398189.574200748] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008654s [rgbd_odometry-1] [INFO] [1663398189.583941935] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008913s [rgbd_odometry-1] [INFO] [1663398189.659493997] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012491s [rgbd_odometry-1] [INFO] [1663398189.668725600] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008498s [rtabmapviz-3] [ERROR] (2022-09-17 15:03:04.973) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.154) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.349) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.454) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.561) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.671) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.772) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:05.951) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.057) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.170) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.278) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.378) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.478) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.653) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.759) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.864) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:06.969) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.071) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.175) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.356) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.459) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.577) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.762) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:07.879) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.062) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.258) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.457) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.563) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.676) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.857) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:08.959) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:09.062) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:09.165) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:09.271) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:09.417) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rtabmapviz-3] [ERROR] (2022-09-17 15:03:09.565) util3d.cpp:1153::cloudRGBFromSensorData() Camera model 0 is invalid [rgbd_odometry-1] [INFO] [1663398189.678191080] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008484s [rgbd_odometry-1] [INFO] [1663398189.758836876] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012958s [rgbd_odometry-1] [INFO] [1663398189.768478489] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008805s [rgbd_odometry-1] [INFO] [1663398189.777609651] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008430s [rgbd_odometry-1] [INFO] [1663398189.862392836] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013230s [rgbd_odometry-1] [INFO] [1663398189.872169654] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008953s [rgbd_odometry-1] [INFO] [1663398189.881003328] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.007995s [rgbd_odometry-1] [INFO] [1663398189.959873730] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.011876s [rgbd_odometry-1] [INFO] [1663398189.969237688] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008533s [rgbd_odometry-1] [INFO] [1663398189.978436890] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008343s [rgbd_odometry-1] [INFO] [1663398190.064016056] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013015s [rgbd_odometry-1] [INFO] [1663398190.073340082] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008528s [rgbd_odometry-1] [INFO] [1663398190.082695849] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008457s [rgbd_odometry-1] [INFO] [1663398190.166727006] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.012962s [rgbd_odometry-1] [INFO] [1663398190.177161550] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009585s [rgbd_odometry-1] [INFO] [1663398190.186435954] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.008062s [rgbd_odometry-1] [INFO] [1663398190.266314901] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.013465s [rgbd_odometry-1] [INFO] [1663398190.276995540] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009441s [rgbd_odometry-1] [INFO] [1663398190.287504845] [rtabmap.rgbd_odometry]: Odom: quality=0, std dev=99.995000m|99.995000rad, update time=0.009064s [rtabmap-2] [INFO] [1663398190.308047364] [rtabmap.rtabmap]: rtabmap (888): Rate=1.00s, Limit=0.000s, Conversion=0.0006s, RTAB-Map=0.0400s, Maps update=0.0008s pub=0.0000s (local map=1, WM=91)
已解决,实际上是由于相机内参标定的问题,看了代码,Astra s相机内部默认使用了理想情况下针孔相机模型进行标定,默认没有坐标偏位,且fx=fy,这里由于我也是初学者,不是很了解(其实就相当于没有标定),此部分相关源代码如下所示:
//以下为默认理想情况下相机内参计算方法,对于针孔相机模型,默认没有偏移,cx=cy=0,fx=fy,实际上这里发现投影矩阵p标定后差异较大 // No distortion info->d.resize(5, 0.0); info->distortion_model = sensor_msgs::distortion_models::PLUMB_BOB; // Simple camera matrix: square pixels (fx = fy), principal point at center info->k.fill(0.0); info->k[0] = info->k[4] = f; info->k[2] = (static_cast<double>(width) / 2) - 0.5; // Aspect ratio for the camera center on Astra (and other devices?) is 4/3 // This formula keeps the principal point the same in VGA and SXGA modes info->k[5] = (static_cast<double>(width) * (3. / 8.)) - 0.5; info->k[8] = 1.0; // No separate rectified image plane, so R = I info->r[0] = info->r[4] = info->r[8] = 1.0; // Then P=K(I|0) = (K|0) info->p.fill(0.0); info->p[0] = info->p[5] = f; // fx, fy info->p[2] = info->p[2]; // cx info->p[6] = info->p[5]; // cy info->p[10] = 1.0;
后续要先进行相机标定,使用camera-calibration标定相机后,修改参数
rtabmap的视觉里程计即可正常运行
@张宏瑞 在 ros2 galactic 使用astra s相机运行rtabmap无法建图(可以生成单帧点云) 中说:
感觉是这个错误,没有点云数据
@小鱼 是这个,后面查了下,是相机标定有问题,这里相当于判定内参错误,视觉里程计没运行,标定修改之后就正常了,感谢鱼哥
张 张宏瑞 将这个主题转为问答主题,在
张 张宏瑞 将这个主题标记为已解决,在
@张宏瑞 你好,想问下,相机标定了,还是无法建图,里程计出问题,会是什么原因。用的Astra s
大佬你好,请问我在ros1 noetic上使用astra pro运行rtapmap时初始化找不到相机是怎么回事呢:
我已经安装了astra pro的openni2驱动,而且也按照官网文档运行了sample没有问题:
希望大佬能够解惑!
