    一键安装+Docker 安装ros melodic失败
    ros 一键安装
    10.0k
      小鱼 技术大佬 @Dawn丶
      @Dawn丶 和我猜想的一样,这个我更新了下代码,你再试一次看看会不会不一样
      Dawn丶D 1 条回复 最后回复 回复 引用 0
      • Dawn丶D
        Dawn丶 @小鱼
        @小鱼 重新尝试“一键安装”吗?
          小鱼 技术大佬 @Dawn丶
          @Dawn丶 是的
          • Dawn丶D
            Dawn丶 @小鱼
            @小鱼 好像依旧是同样的错误,我把完整日志贴上来给您看看。
            qlm@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
            --2022-07-04 04:20:17-- http://fishros.com/install
            --2022-07-04 04:20:18-- http://fishros.com/install/
            Saving to: ‘fishros’
            fishros 100%[===================>] 543 --.-KB/s in 0s
            2022-07-04 04:20:18 (55.7 MB/s) - ‘fishros’ saved [543/543]
            [sudo] password for qlm:
            Reading package lists... Done
            Building dependency tree
            gsettings-desktop-schemas : Breaks: mutter (< 3.31.4) but 3.28.4+git20200505-0ubuntu18.04.2 is to be installed
            --2022-07-04 04:20:23-- http://fishros.com/install/install1s/tools/base.py
            Length: 41481 (41K) [application/octet-stream]
            /tmp/fishinstall/to 100%[===================>] 40.51K --.-KB/s in 0.05s
            2022-07-04 04:20:23 (787 KB/s) - ‘/tmp/fishinstall/tools/base.py’ saved [41481/41481]
            [-]Result:success
            基础检查通过...
            ---众多工具,等君来用---
            [6]:一键安装:nodejs
            [7]:一键安装:VsCode开发工具
            [8]:一键安装:Docker
            [10]:一键安装:微信(可以在Linux上使用的微信)
            [77]:测试模式:运行自定义工具测试
            请输入[]内的数字以选择:11
            --2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
            Length: 11266 (11K) [application/octet-stream]
            Saving to: ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’
            /tmp/fishinstall/to 100%[===================>] 11.00K --.-KB/s in 0.008s
            2022-07-04 04:20:30 (1.31 MB/s) - ‘/tmp/fishinstall/tools/tool_install_ros_with_docker.py’ saved [11266/11266]
            --2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
            Length: 1264 (1.2K) [application/octet-stream]
            Saving to: ‘/tmp/fishinstall/tools/tool_install_vscode.py’
            /tmp/fishinstall/to 100%[===================>] 1.23K --.-KB/s in 0s
            2022-07-04 04:20:30 (131 MB/s) - ‘/tmp/fishinstall/tools/tool_install_vscode.py’ saved [1264/1264]
            --2022-07-04 04:20:30-- http://fishros.com/install/install1s/tools/tool_install_docker.py
            Length: 2455 (2.4K) [application/octet-stream]
            Saving to: ‘/tmp/fishinstall/tools/tool_install_docker.py’
            /tmp/fishinstall/to 100%[===================>] 2.40K --.-KB/s in 0s
            2022-07-04 04:20:31 (182 MB/s) - ‘/tmp/fishinstall/tools/tool_install_docker.py’ saved [2455/2455]
            [1]:noetic
            [2]:humble
            [3]:foxy
            [4]:galactic
            [5]:melodic
            [6]:rolling
            [7]:kinetic
            [8]:eloquent
            [9]:dashing
            [10]:crystal
            [11]:bouncy
            [12]:ardent
            [13]:lunar
            [14]:indigo
            请输入[]内的数字以选择:5
            开始根据系统架构,为你下载对应版本的docker~
            [-]Result:success ist --upgradable' to see them.se
            [-]Result:success e and 1362 not upgraded.8).
            [-]Result:success
            [-]Result:success CE deb) docker@docker.com
            Run CMD Task:[sudo add-apt-repository "deb [arch=amd64] https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu $(lsb_release -cs) stable" -y]
            Hit:1 http://mirrors.aliyun.com/ubuntu focal InRelease
            Hit:2 https://mirrors.ustc.edu.cn/docker-ce/linux/ubuntu bionic InRelease
            Hit:3 http://mirrors.aliyun.com/ubuntu focal-security InRelease
            Hit:4 http://mirrors.aliyun.com/ubuntu focal-updates InRelease
            Hit:5 http://mirrors.aliyun.com/ubuntu focal-proposed InRelease
            Hit:6 http://mirrors.aliyun.com/ubuntu focal-backports InRelease
            Hit:7 http://mirrors.aliyun.com/ubuntu bionic InRelease
            Hit:8 http://packages.microsoft.com/repos/code stable InRelease
            下载完成,接下来升级apt索引~
            开始安装最新版本docker CE~
            [-]Result:success cation container enginer engine
            Run CMD Task:[sudo apt install docker-ce -y]
            [-]Result:code:100 r (< 3.31.4) but 3.28.4+git20200505-0ubuntu18.04.2 is to be installed
            Run CMD Task:[sudo aptitude install docker-ce -y]
            [-]Result:code:1
            Run CMD Task:[sudo groupadd docker]
            [-]Result:code:9
            Run CMD Task:[users]
            [-]Result:success
            Run CMD Task:[sudo gpasswd -a qlm docker]
            [-]Result:success
            安装完成,接下来你可以尝试使用docker --version指令测试是有正常回显~
            Run CMD Task:[sudo docker pull fishros2/ros:melodic-desktop-full ]
            ================================4.生成容器======================================
            请为你的melodic容器取个名字吧!
            melodic4
            收到名字melodic4
            [-]Result:success
            Run CMD Task:[sudo docker run -dit --name=melodic4 -v /home/qlm:/home/qlm -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/qlm fishros2/ros:melodic-desktop-full]
            Run CMD Task:[docker exec -it melodic4 /bin/bash -c "echo -e '
            source /opt/ros/melodic/setup.bash' >> ~/.bashrc" ]
            sh: 1: docker: not found
            Run CMD Task:[xhost +local:]
            ================================5.生成命令======================================
            [-]Result:success
            Run CMD Task:[sudo chmod 777 /home/qlm/.fishros/bin/melodic4]
            ================================6.生成使用工具======================================
            为方便后续使用容器,请选择使用方式,若不知道怎么选,推荐套餐1,若不需要则可以选退出:
            [1]:套餐1:VsCode+插件(本地使用推荐)
            [2]:套餐2:SSH-Service(远程使用推荐)
            请输入[]内的数字以选择:1
            套餐1包含Vscode及其容器插件,开始安装。。
            欢迎使用一键安装Vscode,本工具由作者小鱼提供
            开始根据系统架构,为你下载对应版本的vscode~
            Run CMD Task:[sudo wget http://vscode.cdn.azure.cn/stable/5554b12acf27056905806867f251c859323ff7e9/code_1.64.0-1643863948_amd64.deb -O /tmp/vscode.deb]
            --2022-07-04 04:22:01-- http://vscode.cdn.azure.cn/stable/5554b12acf27056905806867f251c859323ff7e9/code_1.64.0-1643863948_amd64.deb
            Resolving vscode.cdn.azure.cn (vscode.cdn.azure.cn)... 39.91.128.35
            Connecting to vscode.cdn.azure.cn (vscode.cdn.azure.cn)|39.91.128.35|:80... connected.
            Length: 79990376 (76M) [application/octet-stream]
            Saving to: ‘/tmp/vscode.deb’
            /tmp/vscode.deb 100%[==============================================================================================>] 76.28M 2.38MB/s in 34s
            2022-07-04 04:22:35 (2.26 MB/s) - ‘/tmp/vscode.deb’ saved [79990376/79990376]
            下载完成,接下来为你安装Vscode~
            Run CMD Task:[sudo dpkg -i /tmp/vscode.deb]
            [-]Result:success (1.9-2) .....tu3.18.04.2) ....)
            Run CMD Task:[rm -rf /tmp/vscode.deb]
            [-]Result:success
            安装完成~
            Installing extensions...
            Extension 'ms-vscode-remote.remote-containers' v0.238.3 is already installed. Use '--force' option to update to latest version or provide '@<version>' to install a specific version, for example: 'ms-vscode-remote.remote-containers@1.2.3'.
            后续可在任意终端输入melodic4来启动/停止/测试/删除容器
            你的主目录已经和容器的对应目录做了映射
            qlm@ubuntu:~$ melodic4
            请输入指令控制melodic4: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
            t
            /home/qlm/.fishros/bin/melodic4: line 10: docker: command not found
              小鱼 技术大佬 @Dawn丶
              @Dawn丶 是我没写好,感谢反馈,你急不急,我现在在外面,要晚些才能回去,肯定给你解决掉,需要你等一等哈。
              • Dawn丶D
                Dawn丶 @小鱼
                @小鱼 没事,您先忙,我现在都非常感谢您可以这么耐心地回复帮助我👍 。我自己去网上再找找解决方法(虽然大概率是不能顺利解决的😥 )
                  小鱼 技术大佬 @Dawn丶
                  @Dawn丶 修复了下,有时间再试试~
                  • Dawn丶D
                    Dawn丶 @小鱼
                    Dawn丶D 2 条回复 最后回复 回复 引用 0
                    • Dawn丶D
                      Dawn丶 @Dawn丶
                      @Dawn丶 我自己去装个vscode吧,这个应该问题不大
                      • Dawn丶D
                        Dawn丶 @Dawn丶
                        @Dawn丶
                        贴个解决方法:
                        把配置文件的root权限去掉就好了
                        cd ~/.config
                        sudo rm -rf ./Code/
                        15167169341 1 条回复 最后回复 回复 引用 0
                        • sonxzeS
                          sonxze
                          dd@ubuntu:~$ wget http://fishros.com/install -O fishros && . fishros
                          --2022-08-24 15:16:17-- http://fishros.com/install
                          --2022-08-24 15:16:17-- http://fishros.com/install/
                          再次使用存在的到 fishros.com:80 的连接。
                          已发出 HTTP 请求,正在等待回应... 200 OK
                          正在保存至: “fishros”
                          2022-08-24 15:16:17 (38.5 MB/s) - 已保存 “fishros” [582/582])
                          [sudo] dd 的密码:
                          正在分析软件包的依赖关系树
                          python3-distro 已经是最新版 (1.0.1-2)。
                          下列软件包是自动安装的并且现在不需要了:
                          apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin
                          dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
                          kde-window-manager kpackagetool5 kwayland-data kwin-common kwin-data
                          kwin-x11 libdebian-installer4 libkdecorations2-5v5
                          libkdecorations2private5v5 libkf5activities5 libkf5declarative-data
                          libkf5declarative5 libkf5globalaccelprivate5 libkf5idletime5
                          libkf5kcmutils-data libkf5kcmutils5 libkf5package-data libkf5package5
                          libkf5plasma5 libkf5quickaddons5 libkf5waylandclient5 libkf5waylandserver5
                          libkscreenlocker5 libkwin4-effect-builtins1 libkwineffects11
                          libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5multimedia5
                          libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5
                          libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober
                          python3-dbus.mainloop.pyqt5 python3-icu python3-pam python3-pyqt5
                          python3-pyqt5.qtsvg python3-pyqt5.qtwebkit
                          qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia rdate
                          --2022-08-24 15:16:22-- http://fishros.com/install/install1s/tools/base.py
                          长度: 41972 (41K) [application/octet-stream]
                          /tmp/fishinstall/to 100%[===================>] 40.99K --.-KB/s 用时 0.1s
                          2022-08-24 15:16:22 (417 KB/s) - 已保存 “/tmp/fishinstall/tools/base.py” [41972/41972])
                          [-]Result:success
                          基础检查通过...
                          ---众多工具,等君来用---
                          [6]:一键安装:nodejs
                          [7]:一键安装:VsCode开发工具
                          [8]:一键安装:Docker
                          [77]:测试模式:运行自定义工具测试
                          请输入[]内的数字以选择:11
                          --2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_ros_with_docker.py
                          长度: 11449 (11K) [application/octet-stream]
                          /tmp/fishinstall/to 100%[===================>] 11.18K --.-KB/s 用时 0s
                          2022-08-24 15:16:30 (89.7 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_ros_with_docker.py” [11449/11449])
                          --2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_vscode.py
                          长度: 1264 (1.2K) [application/octet-stream]
                          /tmp/fishinstall/to 100%[===================>] 1.23K --.-KB/s 用时 0s
                          2022-08-24 15:16:30 (85.8 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_vscode.py” [1264/1264])
                          --2022-08-24 15:16:30-- http://fishros.com/install/install1s/tools/tool_install_docker.py
                          长度: 2455 (2.4K) [application/octet-stream]
                          2022-08-24 15:16:30 (182 MB/s) - 已保存 “/tmp/fishinstall/tools/tool_install_docker.py” [2455/2455])
                          [1]:noetic
                          [2]:humble
                          [3]:foxy
                          [4]:galactic
                          [5]:melodic
                          [6]:rolling
                          [7]:kinetic
                          [8]:eloquent
                          [9]:dashing
                          [10]:crystal
                          [11]:bouncy
                          [12]:ardent
                          [13]:lunar
                          [14]:indigo
                          请输入[]内的数字以选择:5
                          Run CMD Task:[docker version]
                          [-]Result:success 12112)
                          melodic: Pulling from library/ros
                          d2f2687beb6d: Pull complete
                          c87c7d887e7b: Pull complete
                          c51fe758bc12: Pull complete
                          9646eaa84fc5: Pull complete
                          0e4ce991e1d0: Pull complete
                          a101d7b97c75: Pull complete
                          c716f26c3c2a: Pull complete
                          f0b66bed859b: Pull complete
                          ee909ec215bc: Pull complete
                          884a1a0922cf: Pull complete
                          Digest: sha256:7e36d090a5707554654279da0686cdb6fffe94dfee2240ea7f883420d19e1fdb
                          Status: Downloaded newer image for ros:melodic
                          docker.io/library/ros:melodic
                          Status: Image is up to date for ros:melodic
                          请为你的melodic容器取个名字吧!
                          m1
                          收到名字m1
                          [-]Result:success
                          Run CMD Task:[sudo docker run -dit --name=m1 -v /home/dd:/home/dd -v /tmp/.X11-unix:/tmp/.X11-unix --device=/dev/dri/renderD128 -v /dev/dri:/dev/dri --device /dev/snd -e DISPLAY=unix$DISPLAY -w /home/dd ros:melodic]
                          72f7bda0051f8d26ea485944fddb697ed5458f2408413b19613c9a7cc1a156fd
                          docker: Error response from daemon: error gathering device information while adding custom device "/dev/dri/renderD128": no such file or directory.
                          Run CMD Task:[docker exec -it m1 /bin/bash -c "echo -e '
                          Error response from daemon: Container 72f7bda0051f8d26ea485944fddb697ed5458f2408413b19613c9a7cc1a156fd is not running
                          [-]Result:success
                          Run CMD Task:[sudo mkdir -p /home/dd/.fishros/bin/]
                          [-]Result:success
                          Run CMD Task:[sudo chmod 777 /home/dd/.fishros/bin/m1]
                          请输入[]内的数字以选择:1
                          Run CMD Task:[sudo wget http://vscode.cdn.azure.cn/stable/e4503b30fc78200f846c62cf8091b76ff5547662/code_1.70.2-1660628199_arm64.deb -O /tmp/vscode.deb]
                          --2022-08-24 15:22:30-- http://vscode.cdn.azure.cn/stable/e4503b30fc78200f846c62cf8091b76ff5547662/code_1.70.2-1660628199_arm64.deb
                          正在解析主机 vscode.cdn.azure.cn (vscode.cdn.azure.cn)... 120.232.246.35
                          正在连接 vscode.cdn.azure.cn (vscode.cdn.azure.cn)|120.232.246.35|:80... 已连接。
                          长度: 78183408 (75M) [application/octet-stream]
                          正在保存至: “/tmp/vscode.deb”
                          /tmp/vscode.deb 100%[===================>] 74.56M 6.20MB/s 用时 12s
                          2022-08-24 15:22:42 (6.30 MB/s) - 已保存 “/tmp/vscode.deb” [78183408/78183408])
                          下载完成,接下来为你安装Vscode~
                          [-]Result:success 发器 .....ntu1) 的触发器 ...
                          [-]Result:success
                          安装完成~
                          Option 'user-data-dir' requires a non empty value. Ignoring the option.
                          connect ETIMEDOUT 13.107.42.18:443
                          后续可在任意终端输入m1来启动/停止/测试/删除容器
                          你的主目录已经和容器的对应目录做了映射
                          dd@ubuntu:~$ m1
                          请输入指令控制m1: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
                          t
                          Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/m1/json: dial unix /var/run/docker.sock: connect: permission denied
                          密码:
                          newgrp: failed to crypt password with previous salt: 无效的参数
                            小鱼 技术大佬 @sonxze
                            @sonxze 在 一键安装+Docker 安装ros melodic失败 中说:
                            重启下电脑就好
                            • 15167169341
                              俊后生 @Dawn丶
                              @Dawn丶 在 一键安装+Docker 安装ros melodic失败 中说:
                              cd ~/.config
                              请问这在哪一步输入呢
