    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    723.0k
      小鱼 技术大佬 @591259845
      @591259845 什么系统平台软件
      5 1 条回复 最后回复 回复 引用 0
      • 5
        591259845 @小鱼
        @小鱼 JI就是正常的win11+wsl2+Ubuntu22.04+ROS2 humble,但是我WSL2用的是新版本推荐的镜像网络不是桥接网络,我有时间试下还是用桥接网络行不行。
        • 5
          591259845 @591259845
          @591259845
          @591259845 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
          用回桥接网络就好了。。。。
          • 5
            591259845
            请问下小鱼,为什么启动雷达驱动的时候经常会报这种错?是不是docker挂了?
            sszb@sszb-2:/mnt/c/Users/qianr$ xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 registry.cn-hangzhou.aliyuncs.com/fishros/fishbot_laser
            [sudo] password for sszb:
            docker: Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint bold_tu (af0f4c653e527e9407e785a9649362e8553ab0d0245a2b885bafaa9af2efb849): Bind for 0.0.0.0:8889 failed: port is already allocated
              小鱼 技术大佬 @591259845
              @591259845 https://cn.bing.com/search?q=site%3Afishros.org.cn or 0.0.0.0%3A8889 failed%3A port is already allocated
                wangkang1551
                ubuntu 22.04 雷达驱动话题没显示,但是测试建图会有图,建图没法保存,上面的issue也看到了类似问题。需要怎么解决
                  2177527864 @mixllred
                  @mixllred 我也是这个情况,transform不稳定一直跳动
                  • J
                    jowee
                    系统 24.04,非虚拟机
                    ROS2版本:jazzy
                    控制板版本:1.7.2.alpha
                    雷达驱动板版本:1.3.0.alpha
                    1. 首先进行WIFI转串口测试,结果正常
                    2. 再进行驱动雷达测试时,可以看到Now lidar is scanning打印,但等待大约30s后,会有如下错误打印:
                    [INFO] [launch]: All log files can be found below /root/.ros/log/2025-04-10-10-46-19-476772-dab2dd4bbcec-166
                    [INFO] [tcp_server-1]: process started with pid [167]
                    [tcp_server-1] [INFO] [1744281979.611517270] [tcp_socket_server_node]: TCP端口:8888,已映射到串口设备:/tmp/tty_laser
                    [tcp_server-1] [INFO] [1744281979.611779826] [tcp_socket_server_node]: 等待接受连接..
                    [tcp_server-1] [INFO] [1744281980.013731005] [tcp_socket_server_node]: 来自('192.168.5.20', 54650)的连接已建立
                    [INFO] [ydlidar_node-2]: process started with pid [190]
                    [ydlidar_node-2] [INFO] [1744281982.581994205] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
                    [ydlidar_node-2]
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK initializing
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK has been initialized
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK Version: 1.2.9
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Connect elapsed time 0 ms
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar successfully connected [/tmp/tty_laser:115200]
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar running correctly! The health status good
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Current Lidar Model Code 12
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Check status, Elapsed time 0 ms
                    [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar init success, Elapsed time [0]ms
                    [ydlidar_node-2] [2025-04-10 10:46:23][info] Start to getting intensity flag
                    [ydlidar_node-2] [2025-04-10 10:46:23][info] Auto set intensity 1
                    [ydlidar_node-2] [2025-04-10 10:46:23][info] [YDLIDAR] End to getting intensity flag
                    [ydlidar_node-2] [2025-04-10 10:46:23][info] [YDLIDAR] Create thread 0x77F78640
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Successed to start scan mode, Elapsed time 1694 ms
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Module device info
                    [ydlidar_node-2] Firmware version: 3.8
                    [ydlidar_node-2] Hardware version: 2
                    [ydlidar_node-2] Models: F2
                    [ydlidar_node-2] Serial: 2023021300030017
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Scan Frequency: 5.00Hz
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Fixed Size: 720
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Sample Rate: 3.00K
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Single Fixed Size: 490
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Successed to check the lidar, Elapsed time 658 ms
                    [ydlidar_node-2] [2025-04-10 10:46:24][info] Now lidar is scanning...
                    [ydlidar_node-2] [2025-04-10 10:46:55][error] Check Sum 0xA6FC != 0x6812
                    [ydlidar_node-2] [2025-04-10 10:46:56][error] Check Sum 0x9AF6 != 0x5BCC
                    [ydlidar_node-2] [2025-04-10 10:46:59][error] Check Sum 0x38F6 != 0x6BB1
                    /startup.sh: line 5:   166 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
                    再重新进行WIFI转串口测试和驱动雷达会变成这个样子:
                    #? 2
                    [INFO] [launch]: All log files can be found below /root/.ros/log/2025-04-10-10-49-24-734249-dab2dd4bbcec-218
                    [INFO] [tcp_server-1]: process started with pid [219]
                    [tcp_server-1] terminate called after throwing an instance of 'std::bad_alloc'
                    [tcp_server-1]   what():  std::bad_alloc
                    [ERROR] [tcp_server-1]: process has died [pid 219, exit code -6, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_tzo92wua --params-file /tmp/launch_params_zqa0rwef'].
                    /startup.sh: line 5:   218 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
                    大佬们帮忙看看是什么问题
                      小鱼 技术大佬 @jowee
                      @jowee 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
                      这一步是自动发生的吗
                      J 1 条回复 最后回复 回复 引用 0
                      • J
                        jowee @小鱼
                        最后由 jowee 编辑
                        @小鱼 重新测试了一下,有下面几个现象,麻烦帮忙分析一下
                        1. 进入 2)驱动雷达 测试,不做其他操作是OK的,放个几分钟也没问题。
                        2. 进入 2)驱动雷达 测试后,在另一个终端输入 ros2 topic hz /scan,会导致docker终端自动出现下面的打印:
                        [ydlidar_node-2] [2025-04-11 09:41:32][info] Sample Rate: 3.00K
                        [ydlidar_node-2] [2025-04-11 09:41:32][info] Successed to check the lidar, Elapsed time 641 ms
                        [ydlidar_node-2] [2025-04-11 09:41:32][info] Now lidar is scanning...
                        /startup.sh: line 5:    86 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
                        1. 进入 2)驱动雷达 测试后,在另一个终端输入 ros2 topic echo /scan --once,可以正常看到数据:
                        zw@zw-UM790:~$ ros2 topic echo /scan --once
                        header:
                          stamp:
                            sec: 1744364933
                            nanosec: 633379000
                          frame_id: laser_frame
                        angle_max: 3.1415927410125732
                        angle_increment: 0.012770702131092548
                        time_increment: 0.00033116465783677995
                        scan_time: 0.16293300688266754
                        range_min: 0.05000000074505806
                        range_max: 64.0
                        ranges:
                        - 0.0
                        - 0.3619999885559082
                        中间数据省略
                        - 2.7100000381469727
                        intensities:
                        - 0.0
                        - 255.0
                        - 116.0
                        中间数据省略
                        - 6.0
                        但docker终端过个几秒会自动出现下面的打印:
                        [ydlidar_node-2] [2025-04-11 09:48:00][info] Single Fixed Size: 490
                        [ydlidar_node-2] [2025-04-11 09:48:00][info] Sample Rate: 3.00K
                        [ydlidar_node-2] [2025-04-11 09:48:00][info] Successed to check the lidar, Elapsed time 639 ms
                        [ydlidar_node-2] [2025-04-11 09:48:00][info] Now lidar is scanning...
                        /startup.sh: line 5:    86 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
                        1. 在3的基础上继续进行 2)驱动雷达 测试,在另一个终端输入 ros2 topic echo /scan --once,可以正常看到数据,docker终端有时候会自动出现下面的打印:
                        [ydlidar_node-2] [2025-04-11 09:51:58][info] Now lidar is scanning...
                        [ERROR] [ydlidar_node-2]: process has died [pid 134, exit code -9, cmd '/workspace/install/ydlidar/lib/ydlidar/ydlidar_node --ros-args -r __node:=ydlidar_node -r __ns:=/ --params-file /workspace/install/ydlidar/share/ydlidar/params/ydlidar.yaml'].
                        [ERROR] [tcp_server-1]: process has died [pid 111, exit code -9, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_u30s3nr7 --params-file /tmp/launch_params_2wv5u3xe'].
                        /startup.sh: line 5:   110 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
                        1. 在4的基础上继续进行 2)驱动雷达 测试,在另一个终端输入 ros2 topic hz /scan,docker终端有时候会自动出现下面的打印:
                        [ydlidar_node-2] [2025-04-11 09:53:03][info] Now lidar is scanning...
                        /startup.sh: line 5:   162 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
                        • J
                          jowee @jowee
                          @jowee 有时候是core dump,有时候被kill掉
                            小鱼 技术大佬 @jowee
                            @jowee 你的系统内外版本是什么,包括ROS2版本
                            • J
                              jowee @小鱼
                              @小鱼 系统 Ubuntu 24.04,非虚拟机
                              ROS2版本:jazzy
                              控制板版本:1.7.2.alpha
                              雷达驱动板版本:1.3.0.alpha
                                小鱼 技术大佬 @jowee
                                @jowee 请用ubuntu22.04
                                  yyy2409
                                  @小鱼 大佬帮我看看,我正在进行9.06章节的实验,前面的WiFi和小车ping通并上传雷达数据,雷达驱动测试,rviz2的点云数据可视化均可跑通,但是最后一点建图测试跑不通a4ca1c88-8db6-450d-bb91-7e481590be2f-image.png 具体情况是我输入3建图测试的时候没有任何报错,终端一直有输出信息,但是rviz2没有打开也没有地图加载出来,我手动打开rviz2发现有很多话题可以订阅但是一开始也没有地图,于是我根据视频手动订阅了相关话题a02225d6-4fbe-4c2e-9c12-47620b296de7-image.png 出来的地图也是非常杂乱,我想咨询一下是我哪里操作出问题了吗?
                                  我的linux系统是VMware的ubuntu20.4,ros2是humble版本
                                    szh12031
                                    ##我按步骤建图,小车已经不动了,但还是在不断扩展空间,ubuntu版本22.04,其他软件都是按教程安装。这是哪里的问题呢。
                                      小鱼 技术大佬 @szh12031
                                      @szh12031 解决了吗,网络质量如何
                                      S 2 条回复 最后回复 回复 引用 0
                                        shawn @1436893633
                                        @1436893633 解决了吗?
                                          siryelin @小鱼
                                          @小鱼 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
                                            2b540b40-aa98-4723-9b04-baeae7cfd373-image.png 两个下载雷达驱动的命令都不行是怎么回事呀
