    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    802.7k
    • J
      jowee
      系统 24.04,非虚拟机
      ROS2版本:jazzy
      控制板版本:1.7.2.alpha
      雷达驱动板版本:1.3.0.alpha
      1. 首先进行WIFI转串口测试,结果正常
      2. 再进行驱动雷达测试时,可以看到Now lidar is scanning打印,但等待大约30s后,会有如下错误打印:
      [INFO] [launch]: All log files can be found below /root/.ros/log/2025-04-10-10-46-19-476772-dab2dd4bbcec-166
      [INFO] [tcp_server-1]: process started with pid [167]
      [tcp_server-1] [INFO] [1744281979.611517270] [tcp_socket_server_node]: TCP端口:8888,已映射到串口设备:/tmp/tty_laser
      [tcp_server-1] [INFO] [1744281979.611779826] [tcp_socket_server_node]: 等待接受连接..
      [tcp_server-1] [INFO] [1744281980.013731005] [tcp_socket_server_node]: 来自('192.168.5.20', 54650)的连接已建立
      [INFO] [ydlidar_node-2]: process started with pid [190]
      [ydlidar_node-2] [INFO] [1744281982.581994205] [ydlidar_node]: [YDLIDAR INFO] Current ROS Driver Version: 1.0.1
      [ydlidar_node-2]
      [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK initializing
      [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK has been initialized
      [ydlidar_node-2] [2025-04-10 10:46:22][info] SDK Version: 1.2.9
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Connect elapsed time 0 ms
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar successfully connected [/tmp/tty_laser:115200]
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar running correctly! The health status good
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Current Lidar Model Code 12
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Check status, Elapsed time 0 ms
      [ydlidar_node-2] [2025-04-10 10:46:22][info] Lidar init success, Elapsed time [0]ms
      [ydlidar_node-2] [2025-04-10 10:46:23][info] Start to getting intensity flag
      [ydlidar_node-2] [2025-04-10 10:46:23][info] Auto set intensity 1
      [ydlidar_node-2] [2025-04-10 10:46:23][info] [YDLIDAR] End to getting intensity flag
      [ydlidar_node-2] [2025-04-10 10:46:23][info] [YDLIDAR] Create thread 0x77F78640
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Successed to start scan mode, Elapsed time 1694 ms
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Module device info
      [ydlidar_node-2] Firmware version: 3.8
      [ydlidar_node-2] Hardware version: 2
      [ydlidar_node-2] Models: F2
      [ydlidar_node-2] Serial: 2023021300030017
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Scan Frequency: 5.00Hz
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Fixed Size: 720
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Sample Rate: 3.00K
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Single Fixed Size: 490
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Successed to check the lidar, Elapsed time 658 ms
      [ydlidar_node-2] [2025-04-10 10:46:24][info] Now lidar is scanning...
      [ydlidar_node-2] [2025-04-10 10:46:55][error] Check Sum 0xA6FC != 0x6812
      [ydlidar_node-2] [2025-04-10 10:46:56][error] Check Sum 0x9AF6 != 0x5BCC
      [ydlidar_node-2] [2025-04-10 10:46:59][error] Check Sum 0x38F6 != 0x6BB1
      /startup.sh: line 5:   166 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
      再重新进行WIFI转串口测试和驱动雷达会变成这个样子:
      #? 2
      [INFO] [launch]: All log files can be found below /root/.ros/log/2025-04-10-10-49-24-734249-dab2dd4bbcec-218
      [INFO] [tcp_server-1]: process started with pid [219]
      [tcp_server-1] terminate called after throwing an instance of 'std::bad_alloc'
      [tcp_server-1]   what():  std::bad_alloc
      [ERROR] [tcp_server-1]: process has died [pid 219, exit code -6, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_tzo92wua --params-file /tmp/launch_params_zqa0rwef'].
      /startup.sh: line 5:   218 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
      大佬们帮忙看看是什么问题
        小鱼 技术大佬 @jowee
        @jowee 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
        这一步是自动发生的吗
        J 1 条回复 最后回复 回复 引用 0
        • J
          jowee @小鱼
          最后由 jowee 编辑
          @小鱼 重新测试了一下,有下面几个现象,麻烦帮忙分析一下
          1. 进入 2)驱动雷达 测试,不做其他操作是OK的,放个几分钟也没问题。
          2. 进入 2)驱动雷达 测试后,在另一个终端输入 ros2 topic hz /scan,会导致docker终端自动出现下面的打印:
          [ydlidar_node-2] [2025-04-11 09:41:32][info] Sample Rate: 3.00K
          [ydlidar_node-2] [2025-04-11 09:41:32][info] Successed to check the lidar, Elapsed time 641 ms
          [ydlidar_node-2] [2025-04-11 09:41:32][info] Now lidar is scanning...
          /startup.sh: line 5:    86 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
          1. 进入 2)驱动雷达 测试后,在另一个终端输入 ros2 topic echo /scan --once,可以正常看到数据:
          zw@zw-UM790:~$ ros2 topic echo /scan --once
          header:
            stamp:
              sec: 1744364933
              nanosec: 633379000
            frame_id: laser_frame
          angle_max: 3.1415927410125732
          angle_increment: 0.012770702131092548
          time_increment: 0.00033116465783677995
          scan_time: 0.16293300688266754
          range_min: 0.05000000074505806
          range_max: 64.0
          ranges:
          - 0.0
          - 0.3619999885559082
          中间数据省略
          - 2.7100000381469727
          intensities:
          - 0.0
          - 255.0
          - 116.0
          中间数据省略
          - 6.0
          但docker终端过个几秒会自动出现下面的打印:
          [ydlidar_node-2] [2025-04-11 09:48:00][info] Single Fixed Size: 490
          [ydlidar_node-2] [2025-04-11 09:48:00][info] Sample Rate: 3.00K
          [ydlidar_node-2] [2025-04-11 09:48:00][info] Successed to check the lidar, Elapsed time 639 ms
          [ydlidar_node-2] [2025-04-11 09:48:00][info] Now lidar is scanning...
          /startup.sh: line 5:    86 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
          1. 在3的基础上继续进行 2)驱动雷达 测试,在另一个终端输入 ros2 topic echo /scan --once,可以正常看到数据,docker终端有时候会自动出现下面的打印:
          [ydlidar_node-2] [2025-04-11 09:51:58][info] Now lidar is scanning...
          [ERROR] [ydlidar_node-2]: process has died [pid 134, exit code -9, cmd '/workspace/install/ydlidar/lib/ydlidar/ydlidar_node --ros-args -r __node:=ydlidar_node -r __ns:=/ --params-file /workspace/install/ydlidar/share/ydlidar/params/ydlidar.yaml'].
          [ERROR] [tcp_server-1]: process has died [pid 111, exit code -9, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_u30s3nr7 --params-file /tmp/launch_params_2wv5u3xe'].
          /startup.sh: line 5:   110 Killed                  ros2 launch /workspace/launch/laser_driver.launch.py
          1. 在4的基础上继续进行 2)驱动雷达 测试,在另一个终端输入 ros2 topic hz /scan,docker终端有时候会自动出现下面的打印:
          [ydlidar_node-2] [2025-04-11 09:53:03][info] Now lidar is scanning...
          /startup.sh: line 5:   162 Aborted                 (core dumped) ros2 launch /workspace/launch/laser_driver.launch.py
          • J
            jowee @jowee
            @jowee 有时候是core dump,有时候被kill掉
              小鱼 技术大佬 @jowee
              @jowee 你的系统内外版本是什么,包括ROS2版本
              • J
                jowee @小鱼
                @小鱼 系统 Ubuntu 24.04,非虚拟机
                ROS2版本:jazzy
                控制板版本:1.7.2.alpha
                雷达驱动板版本:1.3.0.alpha
                  小鱼 技术大佬 @jowee
                  @jowee 请用ubuntu22.04
                    yyy2409
                    @小鱼 大佬帮我看看,我正在进行9.06章节的实验,前面的WiFi和小车ping通并上传雷达数据,雷达驱动测试,rviz2的点云数据可视化均可跑通,但是最后一点建图测试跑不通a4ca1c88-8db6-450d-bb91-7e481590be2f-image.png 具体情况是我输入3建图测试的时候没有任何报错,终端一直有输出信息,但是rviz2没有打开也没有地图加载出来,我手动打开rviz2发现有很多话题可以订阅但是一开始也没有地图,于是我根据视频手动订阅了相关话题a02225d6-4fbe-4c2e-9c12-47620b296de7-image.png 出来的地图也是非常杂乱,我想咨询一下是我哪里操作出问题了吗?
                    我的linux系统是VMware的ubuntu20.4,ros2是humble版本
                      szh12031
                      ##我按步骤建图,小车已经不动了,但还是在不断扩展空间,ubuntu版本22.04,其他软件都是按教程安装。这是哪里的问题呢。
                        小鱼 技术大佬 @szh12031
                        @szh12031 解决了吗,网络质量如何
                        S 2 条回复 最后回复 回复 引用 0
                          shawn @1436893633
                          @1436893633 解决了吗?
                            siryelin @小鱼
                            @小鱼 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
                              2b540b40-aa98-4723-9b04-baeae7cfd373-image.png 两个下载雷达驱动的命令都不行是怎么回事呀
                                steepeak
                                小鱼老师,我在lazzy上运行建图测试,前面都可以正常运行,但是保存地图时报错地图映射失败
                                  szh12031 @小鱼
                                  @小鱼 没有,又试了几次,还是不行呢,小车放在桌子上不动,地图就不断的扩张了。雷达驱动程序是4个菜单的版本。
                                  3 1 条回复 最后回复 回复 引用 0
                                    szh12031 @小鱼
                                    @小鱼 网络质量是可以的,同一个WIFI下。
                                      树莓派安装Ubuntu22.04通过有线方式读雷达数据一直报绑定不上串口驱动
                                      报错如下图
                                      之后在终端打印驱动加载日志,命令 sudo dmesg | grep ttyUSB0,输出如下:
                                      [ 5.584720] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
                                      [ 8.770364] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
                                      无法连接ttyUSB0
                                      之后询问AI说是驱动冲突问题,用以下命令解决:
                                      sudo systemctl stop brltty ModemManager
                                      sudo systemctl disable brltty ModemManager
                                      sudo apt purge brltty -y
                                      sudo reboot
                                        为什么的,没有雷达图
                                        • 8
                                          除我之外
                                          964e4658-f643-4420-a729-b759eb2eddfe-image.png b9070ea3-fd5a-4ca7-8802-c8e1ca25d832-image.png @小鱼 这是怎么回事大佬,雷达能够发送,但是rviz里面没有图像,ros2 topic hz /scan
                                          这个命令也一直卡着没报错也没有其他数据。
                                          • 木木先生木
                                            木木先生
                                            最后由 木木先生 编辑
