ORB_SLAM2编译报错,用遍了网上的方法都不行,谁给指点一下
ubuntu 22.04 系统 ros2 humble
下载代码地址:
git clone https://github.com/raulmur/ORB_SLAM2按照这个网址的方法也作了修改,用尽各种方法,编译就是不成功
CMakeCache.txt
cmake_minimum_required(VERSION 2.8) project(ORB_SLAM2) IF(NOT CMAKE_BUILD_TYPE) SET(CMAKE_BUILD_TYPE Release) ENDIF() MESSAGE("Build type: " ${CMAKE_BUILD_TYPE}) set(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wall -O3 -march=native ") set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -O3 -march=native") # Check C++11 or C++0x support include(CheckCXXCompilerFlag) CHECK_CXX_COMPILER_FLAG("-std=c++11" COMPILER_SUPPORTS_CXX11) CHECK_CXX_COMPILER_FLAG("-std=c++0x" COMPILER_SUPPORTS_CXX0X) if(COMPILER_SUPPORTS_CXX11) set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11") add_definitions(-DCOMPILEDWITHC11) message(STATUS "Using flag -std=c++11.") elseif(COMPILER_SUPPORTS_CXX0X) set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++0x") add_definitions(-DCOMPILEDWITHC0X) message(STATUS "Using flag -std=c++0x.") else() message(FATAL_ERROR "The compiler ${CMAKE_CXX_COMPILER} has no C++11 support. Please use a different C++ compiler.") endif() LIST(APPEND CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake_modules) find_package(OpenCV 4 QUIET) if(NOT OpenCV_FOUND) find_package(OpenCV 4 QUIET) if(NOT OpenCV_FOUND) message(FATAL_ERROR "OpenCV > 2.4.3 not found.") endif() endif() find_package(Eigen3 3 REQUIRED) find_package(Pangolin REQUIRED) include_directories( ${PROJECT_SOURCE_DIR} ${PROJECT_SOURCE_DIR}/include ${EIGEN3_INCLUDE_DIR} ${Pangolin_INCLUDE_DIRS} ) set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/lib) add_library(${PROJECT_NAME} SHARED src/System.cc src/Tracking.cc src/LocalMapping.cc src/LoopClosing.cc src/ORBextractor.cc src/ORBmatcher.cc src/FrameDrawer.cc src/Converter.cc src/MapPoint.cc src/KeyFrame.cc src/Map.cc src/MapDrawer.cc src/Optimizer.cc src/PnPsolver.cc src/Frame.cc src/KeyFrameDatabase.cc src/Sim3Solver.cc src/Initializer.cc src/Viewer.cc ) target_link_libraries(${PROJECT_NAME} ${OpenCV_LIBS} ${EIGEN3_LIBS} ${Pangolin_LIBRARIES} ${PROJECT_SOURCE_DIR}/Thirdparty/DBoW2/lib/libDBoW2.so ${PROJECT_SOURCE_DIR}/Thirdparty/g2o/lib/libg2o.so ) # Build examples set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/Examples/RGB-D) add_executable(rgbd_tum Examples/RGB-D/rgbd_tum.cc) target_link_libraries(rgbd_tum ${PROJECT_NAME}) set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/Examples/Stereo) add_executable(stereo_kitti Examples/Stereo/stereo_kitti.cc) target_link_libraries(stereo_kitti ${PROJECT_NAME}) add_executable(stereo_euroc Examples/Stereo/stereo_euroc.cc) target_link_libraries(stereo_euroc ${PROJECT_NAME}) set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${PROJECT_SOURCE_DIR}/Examples/Monocular) add_executable(mono_tum Examples/Monocular/mono_tum.cc) target_link_libraries(mono_tum ${PROJECT_NAME}) add_executable(mono_kitti Examples/Monocular/mono_kitti.cc) target_link_libraries(mono_kitti ${PROJECT_NAME}) add_executable(mono_euroc Examples/Monocular/mono_euroc.cc) target_link_libraries(mono_euroc ${PROJECT_NAME})
编译报错:
CMake Warning (dev) at CMakeLists.txt:96 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "stereo_kitti" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:100 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "stereo_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:100 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "stereo_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:100 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "stereo_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:107 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_tum" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:107 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_tum" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:107 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_tum" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:111 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_kitti" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:111 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_kitti" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:111 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_kitti" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:115 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:115 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it. CMake Warning (dev) at CMakeLists.txt:115 (add_executable): Policy CMP0028 is not set: Double colon in target name means ALIAS or IMPORTED target. Run "cmake --help-policy CMP0028" for policy details. Use the cmake_policy command to set the policy and suppress this warning. Target "mono_euroc" links to target "Eigen3::Eigen" but the target was not found. Perhaps a find_package() call is missing for an IMPORTED target, or an ALIAS target is missing? This warning is for project developers. Use -Wno-dev to suppress it.
@毛哥成山轮胎机油保养 大致看了一下,你这缺少Eigen3的库,装个就行
@毛哥成山轮胎机油保养 我之前用的这个链接编译成功了 orb-slam2,你可以参考一下。不过
orb-slam2
想要导航,需要修改的东西有点多,比较麻烦(我没实现) -
@Lorry Eigen3 3.4.0 Pangolin按好几个博主的方法安装了好几遍,就是编译通过不了,应该就是这里有问题,
也按照好几个博主的改了,就是不行,找不到Eigen3::Eigen
@Lorry 我试试看,谢谢
@毛哥成山轮胎机油保养 如果你安装过了,你看看你电脑有没有
/lib/cmake/eigen3
这个路径,路径里有没有Eigen3Config.cmake
的文件 -
@Lorry
按这个博主的方法安装的
https://blog.csdn.net/qq_45401419/article/details/118358687
一切都和他写的一样,但是/lib/cmake/eigen3这个路径,路径里有没有Eigen3Config.cmake文件
实在编译过不了,我先学习一下orb_slam代码,等熟悉了代码在想办法编译 -
@毛哥成山轮胎机油保养 eigen3编译完成后需要安装的
sudo make install
这样才会把编译完成的库文件安装到系统目录,cmake才会找到。
另外,eigen3添加引用时,你可以尝试将Eigen
改为eigen3/Eigen
@Lorry
ubuntu22.04 ros2 humble版应该是太新了,好多软件都不合适,毕竟这是六七年前的开源程序了 -
@毛哥成山轮胎机油保养 是的了,可以回退下版本,或者试试docker(不过又要折腾挺长时间)
@小鱼 搞了两三天了,Cmakelists.txt Makefile学了好几遍了,自己的Cmakelists.txt也改了好多次 就是不行呀,坑真深
ORB_SLAM2时间太久了,现在的软件环境很难适配,安装ORB_SLAM3容易一点.
哈哈哈,这个问题,我解决了,方法如下:
在CMakeLists.txt中,将
find_package(Eigen3 3.1.0 REQUIRED)
替换为
list(APPEND CMAKE_INCLUDE_PATH "/usr/local/include")
find_package (Eigen3 3.3 REQUIRED NO_MODULE)
