    使用map_server发布保存的地图rviz无法收到
    Nav2
    nav2 map
    10
    14
    2.7k
      lockxx2021
      使用cartographer建图使用map_server保存后,使用map_server加载,
      显示一切正常
      [INFO] [1676349360.531463185] [map_server]:
      	map_server lifecycle node launched.
      	Waiting on external lifecycle transitions to activate
      	See https://design.ros2.org/articles/node_lifecycle.html for more information.
      [INFO] [1676349360.531553193] [map_server]: Creating
      [INFO] [1676349364.388825500] [map_server]: Configuring
      [INFO] [map_io]: Loading yaml file: ./fishbot_map.yaml
      [DEBUG] [map_io]: resolution: 0.05
      [DEBUG] [map_io]: origin[0]: -3.3
      [DEBUG] [map_io]: origin[1]: -2.96
      [DEBUG] [map_io]: origin[2]: 0
      [DEBUG] [map_io]: free_thresh: 0.25
      [DEBUG] [map_io]: occupied_thresh: 0.65
      [DEBUG] [map_io]: mode: trinary
      [DEBUG] [map_io]: negate: 0
      [INFO] [map_io]: Loading image_file: ./fishbot_map.pgm
      [DEBUG] [map_io]: Read map ./fishbot_map.pgm: 133 X 118 map @ 0.05 m/cell
      [INFO] [1676349369.553119216] [map_server]: Activating
      [INFO] [1676349369.553240332] [map_server]: Creating bond (map_server) to lifecycle manager.
      但在rviz中显示no map recevied
      输入ros2 topic info /map -v
      显示
      Publisher count: 1
      Node name: map_server
      Node namespace: /
      Topic type: nav_msgs/msg/OccupancyGrid
      Endpoint type: PUBLISHER
      GID: 01.0f.6e.93.81.6d.f9.3e.01.00.00.00.00.00.1f.03.00.00.00.00.00.00.00.00
      QoS profile:
        Reliability: RELIABLE
        History (Depth): UNKNOWN
        Durability: TRANSIENT_LOCAL
        Lifespan: Infinite
        Deadline: Infinite
        Liveliness: AUTOMATIC
      Subscription count: 1
      Node name: rviz
      Node namespace: /
      Endpoint type: SUBSCRIPTION
      GID: 01.0f.6e.93.8c.6d.9f.ae.01.00.00.00.00.00.2f.04.00.00.00.00.00.00.00.00
      QoS profile:
        Lifespan: Infinite
        Deadline: Infinite
      使用ros2 topic echomap显示
      header:
        stamp:
          sec: 1676349936
          nanosec: 235408782
        frame_id: map
      info:
        map_load_time:
          sec: 1676349936
          nanosec: 235407546
        resolution: 0.05000000074505806
        width: 133
        height: 118
        origin:
          position:
            x: -3.3
            y: -2.96
            z: 0.0
          orientation:
            x: 0.0
            y: 0.0
            z: 0.0
            w: 1.0
      data:
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      - 0
      环境为ubuntu22.04.1 ros-humble
      • L lockxx2021 将这个主题转为问答主题,在
        lockxx2021 @小鱼
        @小鱼 问题解决了,多次重启之后莫名其妙地好了😕
          小鱼 技术大佬 @lockxx2021
          @lockxx2021 应该是qos问题造成的
          参考如下帖子
          @追逐我的明天 在 配置激活map_server报错,Transitioning failed 中说:
          问题:配置map_server时报错
          L 2 条回复 最后回复 回复 引用 0
            lockxx2021 @小鱼
            @小鱼 我通过ros2 topic info /map -v显示出的qos是相同的...重启后也仍然不行
              lockxx2021 @小鱼
              • 小鱼小 小鱼 将这个主题标记为已解决,在
              • vico1999V
                vico1999
                和我的环境一样,也是出了相同的问题,我重启了多次,rviz依然无法显示载入地图
                  小鱼 技术大佬 @vico1999
                  @vico1999 可以先启动一个rviz2,添加map,修改好qos,接着再启动cartographer,
                  • vico1999V
                    vico1999
                    和我的一样,rviz不能显示地图
                    19592553341 1 条回复 最后回复 回复 引用 0
                    • 19592553341
                      无奈的青春 @vico1999
                      @vico1999 把map的qos设置成这样试试。Reliability Policy设置成Reliable,Durability Policy设置成Transient Local,改完我这边能显示栅格地图了。
                      1544536831 5107211675 9 W 4 条回复 最后回复 回复 引用 3
                      • 1544536831
                        Bear @1959255334
                        @1959255334 在 使用map_server发布保存的地图rviz无法收到 中说:
                        eliability Policy
                        正解,遇到了相同问题,谢谢
                        • 5107211675
                          十一。 @1959255334
                          @1959255334 正解,感谢感谢
                          • 9
                            Spider-Man @1959255334
                            @1959255334 先启动ros2 run nav2_map_server map_server --ros-args --param yaml_filename:=map/fishbot_map.yaml
                            再打开rviz2,把设置都改好后,再手动激活和配置节点
                            ros2 lifecycle set /map_server configure
                            ros2 lifecycle set /map_server activate
                            • 15378036621
                              查无此神
                              成功了,十分感谢
                              • tzhT
                                tzh
                                遇到了同样的问题,修改为如下配置后可正常显示:
                                  Wzy_ai_ros1999 @1959255334
                                  @1959255334 正解
