    求助,使用官方代码和套件导航部分出错
    机器人学
    nav2 ros2 导航
    29.3k
      小鱼 技术大佬 @1683127550
      @1683127550
      1.检查里程计话题是否正常
      2.检查 fishbot_bringup 是否正常(最好提供ros2 node list结果)
      终端打印一定复制粘贴,方便回答者检索和引用
      • 16831275501
        ppqppl @小鱼
        @小鱼 在 求助,使用官方代码和套件导航部分出错 中说:
        ros2 node list
          小鱼 技术大佬 @1683127550
          @1683127550 终端打印一定复制粘贴,方便回答者检索和引用!!!
          看到了bringup,你确认了里程计话题是否正常了吗
          • 16831275501
            ppqppl @小鱼
            你确认了里程计话题是否正常了吗
            里程计正常
              小鱼 技术大佬 @1683127550
              @1683127550 雷达话题呢
              16831275501 1 条回复 最后回复 回复 引用 -1
              • 16831275501
                ppqppl @小鱼
                最后由 1683127550 编辑
                @小鱼 雷达偶尔几次连接时会出现这样:
                #? 1
                Prepare to Accept connect!
                但是连接成功之后还是没用,目前雷达没问题
                  小鱼 技术大佬 @1683127550
                  @1683127550 连接成功后有全部重启吗
                  • 16831275501
                    ppqppl @小鱼
                    最后由 1683127550 编辑
                    @小鱼启动后直接连接就不行,连接后全部重启之后还是不行
                      小鱼 技术大佬 @1683127550
                      @1683127550 倒是贴一下终端日志,日志会告诉说为什么不行
                      • 16831275501
                        ppqppl @小鱼
                        @小鱼 cal_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        [component_container_isolated-1] [INFO] [1684060918.591872482] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        [component_container_isolated-1] [INFO] [1684060919.091844695] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        [component_container_isolated-1] [INFO] [1684060919.591846208] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        [component_container_isolated-1] [INFO] [1684060920.091869820] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        [component_container_isolated-1] [INFO] [1684060920.591862633] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
                        中断一直输出这一个
                          小鱼 技术大佬 @1683127550
                          @1683127550 看一下fishbot_bringup 终端输出,这个节点负责发布 odom 到 base_link 的变换
                          • 16831275501
                            ppqppl @小鱼
                            @小鱼 [fishbot_bringup-3] [INFO] [1684061786.308399678] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.362661967] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.408034740] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.457737273] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.507190908] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.556860840] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.606942969] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.656883799] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.707086627] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.756955658] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            [fishbot_bringup-3] [INFO] [1684061786.807189986] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
                            是这样的
                              小鱼 技术大佬 @1683127550
                              @1683127550 动一下小车,看一下数据是否有变化,全部都是 0 有点不正常
                              • 16831275501
                                ppqppl @小鱼
                                最后由 1683127550 编辑
                                @小鱼 就是我用键盘节点控制车吗,我明天试试,今天上课没啥时间,我想问一下,如果没有车能运行那个自动导航的launch吗,还是有别的部分能代替,做没有车的情况下的自动导航?
                                  小鱼 技术大佬 @1683127550
                                  @1683127550 没有车的情况可以采用仿真形式:https://fishros.com/d2lros2/#/humble/chapt9/get_started/1.机器人仿真介绍
                                  • 16831275501
                                    ppqppl @小鱼
                                    @小鱼 有开源代码集吗,类似于github开源库那种
                                      小鱼 技术大佬 @1683127550
                                      @1683127550 fishbot的主分支可以直接仿真使用:https://github.com/fishros/fishbot
                                      • 16831275501
                                        ppqppl @小鱼
                                        最后由 1683127550 编辑
                                        @小鱼 现在这个导航还是不行
                                        [fishbot_bringup-3] [INFO] [1684297618.592733226] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.642721159] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.697918550] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.744630143] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.792818679] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.846763764] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.892678126] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.948881983] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297618.994080727] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.042907219] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.092701254] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.142849847] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.195839205] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.244609172] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.293874121] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.342679295] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.393012918] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.448678313] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.492884034] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.542696973] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.592824863] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.642683509] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.693095345] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.742750157] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.792857044] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        [fishbot_bringup-3] [INFO] [1684297619.844838337] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                                        数据还是一直这样,其他部分都是好的,只有小车自动导航这里不行,移动小车数据不变,然后另一个中断返回值是这样的:
                                          小鱼 技术大佬 @1683127550
                                          @1683127550 这个数据不太正常,检查小车线有没有松,能不能键盘控制移动
                                          16831275501 2 条回复 最后回复 回复 引用 0
                                          • 16831275501
                                            ppqppl @小鱼
                                            最后由 1683127550 编辑
