    求助,使用官方代码和套件导航部分出错
    机器人学
    nav2 ros2 导航
    29.3k
    • 16831275501
      ppqppl @小鱼
      @小鱼 cal_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1684060918.591872482] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1684060919.091844695] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1684060919.591846208] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1684060920.091869820] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      [component_container_isolated-1] [INFO] [1684060920.591862633] [local_costmap.local_costmap]: Timed out waiting for transform from base_link to odom to become available, tf error: Invalid frame ID "odom" passed to canTransform argument target_frame - frame does not exist
      中断一直输出这一个
        小鱼 技术大佬 @1683127550
        @1683127550 看一下fishbot_bringup 终端输出,这个节点负责发布 odom 到 base_link 的变换
        • 16831275501
          ppqppl @小鱼
          @小鱼 [fishbot_bringup-3] [INFO] [1684061786.308399678] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.362661967] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.408034740] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.457737273] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.507190908] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.556860840] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.606942969] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.656883799] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.707086627] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.756955658] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          [fishbot_bringup-3] [INFO] [1684061786.807189986] [fishbot_bringup]: recv odom->base_footprint tf :(0.000000,0.000000)
          是这样的
            小鱼 技术大佬 @1683127550
            @1683127550 动一下小车,看一下数据是否有变化,全部都是 0 有点不正常
            • 16831275501
              ppqppl @小鱼
              最后由 1683127550 编辑
              @小鱼 就是我用键盘节点控制车吗,我明天试试,今天上课没啥时间,我想问一下,如果没有车能运行那个自动导航的launch吗,还是有别的部分能代替,做没有车的情况下的自动导航?
                小鱼 技术大佬 @1683127550
                @1683127550 没有车的情况可以采用仿真形式:https://fishros.com/d2lros2/#/humble/chapt9/get_started/1.机器人仿真介绍
                • 16831275501
                  ppqppl @小鱼
                  @小鱼 有开源代码集吗,类似于github开源库那种
                    小鱼 技术大佬 @1683127550
                    @1683127550 fishbot的主分支可以直接仿真使用:https://github.com/fishros/fishbot
                    • 16831275501
                      ppqppl @小鱼
                      最后由 1683127550 编辑
                      @小鱼 现在这个导航还是不行
                      [fishbot_bringup-3] [INFO] [1684297618.592733226] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.642721159] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.697918550] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.744630143] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.792818679] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.846763764] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.892678126] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.948881983] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297618.994080727] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.042907219] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.092701254] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.142849847] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.195839205] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.244609172] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.293874121] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.342679295] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.393012918] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.448678313] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.492884034] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.542696973] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.592824863] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.642683509] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.693095345] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.742750157] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.792857044] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      [fishbot_bringup-3] [INFO] [1684297619.844838337] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
                      数据还是一直这样,其他部分都是好的,只有小车自动导航这里不行,移动小车数据不变,然后另一个中断返回值是这样的:
                        小鱼 技术大佬 @1683127550
                        @1683127550 这个数据不太正常,检查小车线有没有松,能不能键盘控制移动
                        16831275501 2 条回复 最后回复 回复 引用 0
                        • 16831275501
                          ppqppl @小鱼
                          最后由 1683127550 编辑
                          • 16831275501
                            ppqppl @小鱼
                            最后由 1683127550 编辑
                            @小鱼 雷达和里程计测试通过,所有线都没有松动,现在数据是这样的d059d951-a9dc-4824-a642-cb7406316546-image.png
                            用键盘控制小车,第一张图中数据发生改变
                            但是小车自动导航的还是不行
                            这里我点了 2D Pose Estimate 还是没有反应
                              小鱼 技术大佬 @1683127550
                              @1683127550 rqt tf tree 看下
                              • 16831275501
                                ppqppl @小鱼
                                最后由 1683127550 编辑
                                我重新下载了一下源码编译了一下,现在和刚才错误显示不一样了
                                这个是 rqt-tf-tree
                                我这边给出小车的初始坐标和方向之后,显示这些,好像是有我点击的点的信息,但是小车那边还是没反应
                                在这个基础上我重启了一下雷达,然后显示这样:
                                • 16831275501
                                  ppqppl @小鱼
                                  @小鱼 我搞定了,多谢,我看了一下 rqt-tf-tree,改了一点东西就好了
                                  小鱼小 4 2 条回复 最后回复 回复 引用 0
                                    小鱼 技术大佬 @1683127550
                                    @1683127550 能具体说下是什么问题吗?我了解下,折腾了好久了
                                    • 16831275501
                                      ppqppl @小鱼
                                      @小鱼 应该就是ros2和miscroRos通信出问题了,我这边重新编译了好多次通信节点和导航节点,才解决,之前我测试的时候,用小车不行,但是你给的那个仿真的可以
                                      • 16831275501
                                        ppqppl @小鱼
                                        @小鱼 我这还有一些问题就是我在导航的时候,如果场景中出现了新的障碍物,雷达检测到,然后标红,但是障碍物移开之后,雷达再次检测在地图中并没有消失,是什么原因?
                                          小鱼 技术大佬 @1683127550
                                          @1683127550 这个应该是局部代价地图没更新的原因,看看拿掉后机器人有正确扫到没有
                                          • 16831275501
                                            ppqppl @小鱼
                                            @小鱼 障碍物拿掉机器人扫描的地图还是显示有这个物品
