    求助,使用官方代码和套件导航部分出错
    机器人学
    nav2 ros2 导航
    29.3k
      小鱼 技术大佬 @1683127550
      @1683127550 没有车的情况可以采用仿真形式:https://fishros.com/d2lros2/#/humble/chapt9/get_started/1.机器人仿真介绍
      • 16831275501
        ppqppl @小鱼
        @小鱼 有开源代码集吗,类似于github开源库那种
          小鱼 技术大佬 @1683127550
          @1683127550 fishbot的主分支可以直接仿真使用:https://github.com/fishros/fishbot
          • 16831275501
            ppqppl @小鱼
            最后由 1683127550 编辑
            @小鱼 现在这个导航还是不行
            [fishbot_bringup-3] [INFO] [1684297618.592733226] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.642721159] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.697918550] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.744630143] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.792818679] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.846763764] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.892678126] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.948881983] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297618.994080727] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.042907219] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.092701254] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.142849847] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.195839205] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.244609172] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.293874121] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.342679295] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.393012918] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.448678313] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.492884034] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.542696973] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.592824863] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.642683509] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.693095345] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.742750157] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.792857044] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            [fishbot_bringup-3] [INFO] [1684297619.844838337] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
            数据还是一直这样,其他部分都是好的,只有小车自动导航这里不行,移动小车数据不变,然后另一个中断返回值是这样的:
              小鱼 技术大佬 @1683127550
              @1683127550 这个数据不太正常,检查小车线有没有松,能不能键盘控制移动
              16831275501 2 条回复 最后回复 回复 引用 0
              • 16831275501
                ppqppl @小鱼
                最后由 1683127550 编辑
                • 16831275501
                  ppqppl @小鱼
                  最后由 1683127550 编辑
                  @小鱼 雷达和里程计测试通过,所有线都没有松动,现在数据是这样的d059d951-a9dc-4824-a642-cb7406316546-image.png
                  用键盘控制小车,第一张图中数据发生改变
                  但是小车自动导航的还是不行
                  这里我点了 2D Pose Estimate 还是没有反应
                    小鱼 技术大佬 @1683127550
                    @1683127550 rqt tf tree 看下
                    • 16831275501
                      ppqppl @小鱼
                      最后由 1683127550 编辑
                      我重新下载了一下源码编译了一下,现在和刚才错误显示不一样了
                      这个是 rqt-tf-tree
                      我这边给出小车的初始坐标和方向之后,显示这些,好像是有我点击的点的信息,但是小车那边还是没反应
                      在这个基础上我重启了一下雷达,然后显示这样:
                      • 16831275501
                        ppqppl @小鱼
                        @小鱼 我搞定了,多谢,我看了一下 rqt-tf-tree,改了一点东西就好了
                        小鱼小 4 2 条回复 最后回复 回复 引用 0
                          小鱼 技术大佬 @1683127550
                          @1683127550 能具体说下是什么问题吗?我了解下,折腾了好久了
                          • 16831275501
                            ppqppl @小鱼
                            @小鱼 应该就是ros2和miscroRos通信出问题了,我这边重新编译了好多次通信节点和导航节点,才解决,之前我测试的时候,用小车不行,但是你给的那个仿真的可以
                            • 16831275501
                              ppqppl @小鱼
                              @小鱼 我这还有一些问题就是我在导航的时候,如果场景中出现了新的障碍物,雷达检测到,然后标红,但是障碍物移开之后,雷达再次检测在地图中并没有消失,是什么原因?
                                小鱼 技术大佬 @1683127550
                                @1683127550 这个应该是局部代价地图没更新的原因,看看拿掉后机器人有正确扫到没有
                                • 16831275501
                                  ppqppl @小鱼
                                  @小鱼 障碍物拿掉机器人扫描的地图还是显示有这个物品
                                  • 16831275501
                                    ppqppl @小鱼
                                    @小鱼 这个地图存在新出现的障碍物的问题还是没有解决
                                    • 4
                                      东篱青蛙 @1683127550
                                      @1683127550 你好!请教一下大佬,我也碰到了这个问题,把fishros下面的功能包都重新编译了还是不行,是还需要修改什么地方吗?谢谢!
                                        小鱼 技术大佬 @415808688
                                        @415808688 发个新帖看看
