    求助,使用官方代码和套件导航部分出错
    机器人学
    nav2 ros2 导航
    29.3k
    • 16831275501
      ppqppl @小鱼
      最后由 1683127550 编辑
      @小鱼 就是我用键盘节点控制车吗,我明天试试,今天上课没啥时间,我想问一下,如果没有车能运行那个自动导航的launch吗,还是有别的部分能代替,做没有车的情况下的自动导航?
        小鱼 技术大佬 @1683127550
        @1683127550 没有车的情况可以采用仿真形式:https://fishros.com/d2lros2/#/humble/chapt9/get_started/1.机器人仿真介绍
        • 16831275501
          ppqppl @小鱼
          @小鱼 有开源代码集吗,类似于github开源库那种
            小鱼 技术大佬 @1683127550
            @1683127550 fishbot的主分支可以直接仿真使用:https://github.com/fishros/fishbot
            • 16831275501
              ppqppl @小鱼
              最后由 1683127550 编辑
              @小鱼 现在这个导航还是不行
              [fishbot_bringup-3] [INFO] [1684297618.592733226] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.642721159] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.697918550] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.744630143] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.792818679] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.846763764] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.892678126] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.948881983] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297618.994080727] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.042907219] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.092701254] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.142849847] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.195839205] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.244609172] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.293874121] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.342679295] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.393012918] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.448678313] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.492884034] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.542696973] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.592824863] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.642683509] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.693095345] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.742750157] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.792857044] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              [fishbot_bringup-3] [INFO] [1684297619.844838337] [fishbot_bringup]: recv odom->base_footprint tf :(-0.000050,0.000000)
              数据还是一直这样,其他部分都是好的,只有小车自动导航这里不行,移动小车数据不变,然后另一个中断返回值是这样的:
                小鱼 技术大佬 @1683127550
                @1683127550 这个数据不太正常,检查小车线有没有松,能不能键盘控制移动
                16831275501 2 条回复 最后回复 回复 引用 0
                • 16831275501
                  ppqppl @小鱼
                  最后由 1683127550 编辑
                  • 16831275501
                    ppqppl @小鱼
                    最后由 1683127550 编辑
                    @小鱼 雷达和里程计测试通过,所有线都没有松动,现在数据是这样的d059d951-a9dc-4824-a642-cb7406316546-image.png
                    用键盘控制小车,第一张图中数据发生改变
                    但是小车自动导航的还是不行
                    这里我点了 2D Pose Estimate 还是没有反应
                      小鱼 技术大佬 @1683127550
                      @1683127550 rqt tf tree 看下
                      • 16831275501
                        ppqppl @小鱼
                        最后由 1683127550 编辑
                        我重新下载了一下源码编译了一下,现在和刚才错误显示不一样了
                        这个是 rqt-tf-tree
                        我这边给出小车的初始坐标和方向之后,显示这些,好像是有我点击的点的信息,但是小车那边还是没反应
                        在这个基础上我重启了一下雷达,然后显示这样:
                        • 16831275501
                          ppqppl @小鱼
                          @小鱼 我搞定了,多谢,我看了一下 rqt-tf-tree,改了一点东西就好了
                          小鱼小 4 2 条回复 最后回复 回复 引用 0
                            小鱼 技术大佬 @1683127550
                            @1683127550 能具体说下是什么问题吗?我了解下,折腾了好久了
                            • 16831275501
                              ppqppl @小鱼
                              @小鱼 应该就是ros2和miscroRos通信出问题了,我这边重新编译了好多次通信节点和导航节点,才解决,之前我测试的时候,用小车不行,但是你给的那个仿真的可以
                              • 16831275501
                                ppqppl @小鱼
                                @小鱼 我这还有一些问题就是我在导航的时候,如果场景中出现了新的障碍物,雷达检测到,然后标红,但是障碍物移开之后,雷达再次检测在地图中并没有消失,是什么原因?
                                  小鱼 技术大佬 @1683127550
                                  @1683127550 这个应该是局部代价地图没更新的原因,看看拿掉后机器人有正确扫到没有
                                  • 16831275501
                                    ppqppl @小鱼
                                    @小鱼 障碍物拿掉机器人扫描的地图还是显示有这个物品
                                    • 16831275501
                                      ppqppl @小鱼
                                      @小鱼 这个地图存在新出现的障碍物的问题还是没有解决
                                      • 4
                                        东篱青蛙 @1683127550
                                        @1683127550 你好!请教一下大佬,我也碰到了这个问题,把fishros下面的功能包都重新编译了还是不行,是还需要修改什么地方吗?谢谢!
                                          小鱼 技术大佬 @415808688
                                          @415808688 发个新帖看看
