    ros2使用colcon编译时,总是报错提示缺少一个包,安装完一个后还有另一个
    ros2 colcon moveit
    28.5k
    • 25191058502
      2519105850
      在执行下列命令时
      colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
      出现以下报错
      CMake Error at /home/zhong/moveit2/install/message_generation/share/message_generation/cmake/message_generationConfig.cmake:197 (find_package):
      Could not find a package configuration file provided by "genpy" with any of
      the following names:
      genpyConfig.cmake
      genpy-config.cmake
      Add the installation prefix of "genpy" to CMAKE_PREFIX_PATH or set
      "genpy_DIR" to a directory containing one of the above files. If "genpy"
      installed.
      /home/zhong/moveit2/install/catkin/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
      CMakeLists.txt:4 (find_package)
      Failed <<< std_msgs [1.85s, exited with code 1]
      Summary: 32 packages finished [27.7s]
      1 package failed: std_msgs
      1 package had stderr output: std_msgs
      7 packages not processed
      在git上下载包genpy后,又显示缺少包
      CMake Error at /home/zhong/moveit2/install/std_msgs/share/std_msgs/cmake/std_msgsConfig.cmake:197 (find_package):
      Could not find a package configuration file provided by "message_runtime"
      with any of the following names:
      message_runtimeConfig.cmake
      message_runtime-config.cmake
      Add the installation prefix of "message_runtime" to CMAKE_PREFIX_PATH or
      set "message_runtime_DIR" to a directory containing one of the above files.
      If "message_runtime" provides a separate development package or SDK, be
      sure it has been installed.
      CMakeLists.txt:3 (find_package)
      Failed <<< test_msgs [1.97s, exited with code 1]
      Summary: 34 packages finished [55.3s]
      1 package failed: test_msgs
      1 package had stderr output: test_msgs
      6 packages not processed
      下了一个包后,显示缺少另一个包
      CMake Warning (dev) at CMakeLists.txt:2 (project):
      Policy CMP0048 is not set: project() command manages VERSION variables.
      Run "cmake --help-policy CMP0048" for policy details. Use the cmake_policy
      command to set the policy and suppress this warning.
      The following variable(s) would be set to empty:
      CMAKE_PROJECT_VERSION
      CMAKE_PROJECT_VERSION_MAJOR
      CMAKE_PROJECT_VERSION_MINOR
      CMAKE_PROJECT_VERSION_PATCH
      This warning is for project developers. Use -Wno-dev to suppress it.
      CMake Error at /home/zhong/moveit2/install/message_runtime/share/message_runtime/cmake/message_runtimeConfig.cmake:197 (find_package):
      Could not find a package configuration file provided by "cpp_common" with
      cpp_commonConfig.cmake
      cpp_common-config.cmake
      Add the installation prefix of "cpp_common" to CMAKE_PREFIX_PATH or set
      "cpp_common_DIR" to a directory containing one of the above files. If
      "cpp_common" provides a separate development package or SDK, be sure it has
      been installed.
      Failed <<< test_msgs [2.14s, exited with code 1]
      Summary: 35 packages finished [30.6s]
      这次下载cppcommon后显示 cmake版本低
      第一次运行colcon时,显示[0/ 24 complete]就中断了,随着下了一些包就变成了[34/41 complete]时中断
      原文链接:链接文本
        小鱼 技术大佬 @2519105850
        @2519105850 很不幸,经过检索,你所使用的这些包应该都是没有二进制发布的,建议通过源码下载安装。
        比如下面这个cpp_common,就是没有发布foxy版本。
        具体的包都可以到这个网站查询:
        @小鱼 在 ROS/ROS2功能包在线索引网站 中说:
        推荐语:可以在线搜索ROS2/ROS功能发行情况及依赖信息的网站
        地址:https://index.ros.org/
        25191058502 1 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @2519105850
          @2519105850 先跑一下rosdep install就好了!
          @小鱼 在 Moveit2探索指南-源码编译测试 中说:
          2.3 安装依赖
          安装依赖时使用了小鱼自己做的rosdepc,如果大家rosdep不好用,也可以尝试尝试小鱼的rosdepc.
          rosdepc install -r --from-paths . --ignore-src --rosdistro $ROS_DISTRO -y
          另外请注意格式哈
          1. 不要截图,要复制粘贴,一定要代码块包裹
            用代码块包裹是为了更加美观,不会一个代码很长一段,不易阅读
          25191058502 小鱼小 2 条回复 最后回复 回复 引用 0
          • 25191058502
            2519105850 @小鱼
            @小鱼 rosdep install 没成功啊,后面是要跟包名吗
            zhong@ubuntu:~$ rosdep install
            Usage: rosdepc [options] <command> <args>
            Commands:
            rosdepc check <stacks-and-packages>...
            check if the dependencies of package(s) have been met.
            rosdepc install <stacks-and-packages>...
            download and install the dependencies of a given package or packages.
            rosdepc db
            generate the dependency database and print it to the console.
            rosdepc init
            initialize rosdepc sources in /etc/ros/rosdep. May require sudo.
            rosdepc keys <stacks-and-packages>...
            list the rosdepc keys that the packages depend on.
            rosdepc resolve <rosdeps>
            resolve <rosdeps> to system dependencies
            rosdepc update
            update the local rosdep database based on the rosdep sources.
            rosdepc what-needs <rosdeps>...
            print a list of packages that declare a rosdep on (at least
            one of) <rosdeps>
            rosdepc where-defined <rosdeps>...
            print a list of yaml files that declare a rosdep on (at least
            one of) <rosdeps>
            rosdepc fix-permissions
            Recursively change the permissions of the user's ros home directory.
            May require sudo. Can be useful to fix permissions after calling
            "rosdepc update" with sudo accidentally.
            rosdepc: error: no packages or stacks specified
            然后我试了试rosdep install cpp_common
            报这个错误zhong@ubuntu:~$ rosdepc install cpp_common
            ERROR: rosdepc cannot find all required resources to answer your query
            Missing resource cpp_common
            会注意格式的😳
              小鱼 技术大佬 @小鱼
              @小鱼 在 ros2使用colcon编译时,总是报错提示缺少一个包,安装完一个后还有另一个 中说:
              rosdepc是这样用的。。。。
              • 25191058502
                2519105850 @小鱼
                @小鱼 我运行了这句再运行colon还是报一样的错啊
                实在不好意思,我基础太差了😩 😩
                  小鱼 技术大佬 @2519105850
                  @2519105850 提供一下你的系统信息吧,版本号,ROS版本,我给你写条安装指令。另外可以改一下上面的格式,可以二次编辑的,看着实在难受哈哈。
                  • 25191058502
                    2519105850 @小鱼
                    @小鱼 实在是太感谢了!!!
                    Ubuntu 20.04.4 LTS \n \l
                    ros2foxy ros1 noetic
                    提供完全了吗?
                      小鱼 技术大佬 @2519105850
                      @2519105850 你用的是foxy吧
                      • 25191058502
                        2519105850 @小鱼
                        对的
                          小鱼 技术大佬 @2519105850
                          具体的包都可以到这个网站查询:
                          • 25191058502
                            2519105850 @小鱼
                            非常感谢您!!
                            那就是我按照报错在这个功能包在线索引网站上搜相关包,然后安装在moveit2目录下就可以了吧
                            另外我也想确认下想要实现您写的这篇公众号通过键盘控制机械臂的运动是用Ubuntu20.04 /ros2 foxy吗
                            公众号推送链接: 链接文本
                              小鱼 技术大佬 @2519105850
                              @2519105850 是的,采用的是ubuntu20.04-ros:foxy实现。
                              25191058502 2 条回复 最后回复 回复 引用 0
                              • 25191058502
                                2519105850 @小鱼
                                @小鱼 好的,非常感谢!🙂
                                • 小鱼小 小鱼 将这个主题标记为已解决,在
                                • 25191058502
                                  2519105850 @小鱼
                                  @小鱼 您好,在头一次运行colcon报错提示缺少cpp_common
                                  been installed.
                                  Failed <<< test_msgs [0.54s, exited with code 1]
                                  Summary: 35 packages finished [8.20s]
                                  我在https://github.com/chronoxor/CppCommon上下载这个包到moveit2这个文件夹里,然后又报这个错误😩
                                  If the overridden package is used by another package in any underlay, then the overriding package in the overlay must be API and ABI compatible or undefined behavior at run time may occur.
                                  If you understand the risks and want to override a package anyways, add the following to the command line:
                                  --allow-overriding ament_cmake ament_cmake_auto ament_cmake_core ament_cmake_gmock ament_cmake_gtest ament_cmake_pytest ament_cmake_ros ament_cmake_test rclcpp rclcpp_action rclcpp_components rclcpp_lifecycle std_msgs test_msgs
                                  This may be promoted to an error in a future release of colcon-override-check.
                                  Starting >>> ament_package
                                  Starting >>> catkin
                                  Starting >>> domain_coordinator
                                  Starting >>> cppcommon
                                  --- stderr: cppcommon
                                  CMake Error: The source "/home/zhong/moveit2/CppCommon/CMakeLists.txt" does not match the source "/home/zhong/moveit2/CppCommon-master/CMakeLists.txt" used to generate cache. Re-run cmake with a different source directory.
                                  Failed <<< cppcommon [0.64s, exited with code 1]
                                  Aborted <<< catkin [0.70s]
                                  Aborted <<< domain_coordinator [1.32s]
                                  Aborted <<< ament_package [1.40s]
                                  Summary: 0 packages finished [2.08s]
                                  1 package failed: cppcommon
                                  3 packages aborted: ament_package catkin domain_coordinator
                                  1 package had stderr output: cppcommon
                                  39 packages not processed
                                  运行colcon后直接就中断结束了,这个该怎样处理呢?
                                    小鱼 技术大佬 @2519105850
                                    @2519105850 兄弟你先改下格式
                                    • 25191058502
                                      2519105850 @小鱼
                                      @小鱼 好的,不好意思添麻烦了,下面这个格式是较正确的吗?
                                      运行colcon命令报错提示缺少cpp_common
                                      been installed.
                                      我在https://github.com/chronoxor/CppCommon上 下载cpp_common这个包到moveit2这个文件夹里,然后报了下面这个错误:
                                      Starting >>> catkin
                                      运行colcon命令后直接就中断结束了,请问这个该怎样解决呢?
                                        小鱼 技术大佬 @2519105850
                                        @2519105850 通过检索发现,cpp_common是ros的核心包 https://github.com/ros/roscpp_core 里的。
                                        而你是ROS2,应该是不需要这个包的,请你再次确认代码版本,系统版本,ROS版本。
                                        moveit2的教程可以看看我之前写的,都是没有这个步骤和问题的。
                                        Moveit2探索指南-源码编译测试
                                        • 25191058502
                                          2519105850 @小鱼
                                          @小鱼 那就说明我多半版本安装错误?
                                            小鱼 技术大佬 @2519105850
                                            @2519105850 是的,你应该是代码版本不对,我刚再次检查了下我的环境,cpp_common只在ros1中有,你的代码如果是ros2的,按理不应该出现。
                                            • 25191058502
                                              2519105850 @小鱼
                                              @小鱼 好的,非常感谢!!!
