    ros2 colcon moveit
    29.0k
    • 25191058502
      2519105850 @小鱼
      非常感谢您!!
      那就是我按照报错在这个功能包在线索引网站上搜相关包,然后安装在moveit2目录下就可以了吧
      另外我也想确认下想要实现您写的这篇公众号通过键盘控制机械臂的运动是用Ubuntu20.04 /ros2 foxy吗
      公众号推送链接: 链接文本
        小鱼 技术大佬 @2519105850
        @2519105850 是的,采用的是ubuntu20.04-ros:foxy实现。
        • 25191058502
          2519105850 @小鱼
          @小鱼 好的,非常感谢!🙂
          • 小鱼小 小鱼 将这个主题标记为已解决,在
          • 25191058502
            2519105850 @小鱼
            @小鱼 您好,在头一次运行colcon报错提示缺少cpp_common
            CMake Warning (dev) at CMakeLists.txt:2 (project):
            Policy CMP0048 is not set: project() command manages VERSION variables.
            Run "cmake --help-policy CMP0048" for policy details. Use the cmake_policy
            command to set the policy and suppress this warning.
            The following variable(s) would be set to empty:
            CMAKE_PROJECT_VERSION
            CMAKE_PROJECT_VERSION_MAJOR
            CMAKE_PROJECT_VERSION_MINOR
            CMAKE_PROJECT_VERSION_PATCH
            CMake Error at /home/zhong/moveit2/install/message_runtime/share/message_runtime/cmake/message_runtimeConfig.cmake:197 (find_package):
            Could not find a package configuration file provided by "cpp_common" with
            any of the following names:
            cpp_commonConfig.cmake
            cpp_common-config.cmake
            Add the installation prefix of "cpp_common" to CMAKE_PREFIX_PATH or set
            "cpp_common_DIR" to a directory containing one of the above files. If
            "cpp_common" provides a separate development package or SDK, be sure it has
            been installed.
            /home/zhong/moveit2/install/std_msgs/share/std_msgs/cmake/std_msgsConfig.cmake:197 (find_package)
            /home/zhong/moveit2/install/catkin/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
            CMakeLists.txt:3 (find_package)
            Failed <<< test_msgs [0.54s, exited with code 1]
            Summary: 35 packages finished [8.20s]
            1 package failed: test_msgs
            1 package had stderr output: test_msgs
            6 packages not processed
            我在https://github.com/chronoxor/CppCommon上下载这个包到moveit2这个文件夹里,然后又报这个错误😩
            --allow-overriding ament_cmake ament_cmake_auto ament_cmake_core ament_cmake_gmock ament_cmake_gtest ament_cmake_pytest ament_cmake_ros ament_cmake_test rclcpp rclcpp_action rclcpp_components rclcpp_lifecycle std_msgs test_msgs
            Starting >>> ament_package
            Starting >>> catkin
            Starting >>> domain_coordinator
            Starting >>> cppcommon
            --- stderr: cppcommon
            CMake Error: The source "/home/zhong/moveit2/CppCommon/CMakeLists.txt" does not match the source "/home/zhong/moveit2/CppCommon-master/CMakeLists.txt" used to generate cache. Re-run cmake with a different source directory.
            Failed <<< cppcommon [0.64s, exited with code 1]
            Aborted <<< catkin [0.70s]
            Aborted <<< domain_coordinator [1.32s]
            Aborted <<< ament_package [1.40s]
            Summary: 0 packages finished [2.08s]
            1 package failed: cppcommon
            3 packages aborted: ament_package catkin domain_coordinator
            1 package had stderr output: cppcommon
            39 packages not processed
            运行colcon后直接就中断结束了,这个该怎样处理呢?
              小鱼 技术大佬 @2519105850
              @2519105850 兄弟你先改下格式
              • 25191058502
                2519105850 @小鱼
                @小鱼 好的,不好意思添麻烦了,下面这个格式是较正确的吗?
                运行colcon命令报错提示缺少cpp_common
                been installed.
                我在https://github.com/chronoxor/CppCommon上 下载cpp_common这个包到moveit2这个文件夹里,然后报了下面这个错误:
                Starting >>> catkin
                运行colcon命令后直接就中断结束了,请问这个该怎样解决呢?
                  小鱼 技术大佬 @2519105850
                  @2519105850 通过检索发现,cpp_common是ros的核心包 https://github.com/ros/roscpp_core 里的。
                  而你是ROS2,应该是不需要这个包的,请你再次确认代码版本,系统版本,ROS版本。
                  moveit2的教程可以看看我之前写的,都是没有这个步骤和问题的。
                  Moveit2探索指南-源码编译测试
                  • 25191058502
                    2519105850 @小鱼
                    @小鱼 那就说明我多半版本安装错误?
                      小鱼 技术大佬 @2519105850
                      @2519105850 是的,你应该是代码版本不对,我刚再次检查了下我的环境,cpp_common只在ros1中有,你的代码如果是ros2的,按理不应该出现。
                      • 25191058502
                        2519105850 @小鱼
                        @小鱼 好的,非常感谢!!!
                        • 25191058502
                          2519105850 @小鱼
                          @小鱼 确实是我版本号的问题,真是太厉害了!
                          我运行colon命令,然后提示只要下两个包,下第二个的时候报错了
                          报错内容
                          CMake Error at CMakeLists.txt:19 (find_package):
                            By not providing "Findmoveit_visual_tools.cmake" in CMAKE_MODULE_PATH this
                            "moveit_visual_tools", but CMake did not find one.
                            "moveit_visual_tools" with any of the following names:
                              moveit_visual_toolsConfig.cmake
                              moveit_visual_tools-config.cmake
                            Add the installation prefix of "moveit_visual_tools" to CMAKE_PREFIX_PATH
                            or set "moveit_visual_tools_DIR" to a directory containing one of the above
                            files.  If "moveit_visual_tools" provides a separate development package or
                          Failed   <<< moveit2_tutorials [16.1s, exited with code 1]
                          Summary: 1 package finished [1min 24s]
                            1 package failed: moveit2_tutorials
                            1 package had stderr output: moveit2_tutorials
                          是因为我用二进制安装moveit2没成功吗?
                          运行的这个代码
                          sudo apt install ros-foxy-moveit
                          sudo apt install ros-foxy-joint-state-controller
                          这是结果(没报错吧)
                          zhong@ubuntu:~$ sudo apt install ros-foxy-moveit
                          [sudo] zhong 的密码:
                          正在分析软件包的依赖关系树
                          ros-foxy-moveit 已经是最新版 (2.2.3-1focal.20220209.173642)。
                          zhong@ubuntu:~$ sudo apt install ros-foxy-joint-state-controller
                          正在分析软件包的依赖关系树
                          ros-foxy-joint-state-controller 已经是最新版 (0.7.0-1focal.20220223.161450)。
                          然后我就在 https://moveit.ros.org/install-moveit2/source/ 上按照步骤运行
                          运行到下面这一步时报错了,但是我接着运行后面一步没有管它
                          zhong@ubuntu:~/ws_moveit2/src$ vcs import < moveit2/moveit2.repos
                          Command 'vcs' not found, but there are 15 similar ones.
                          当运行下面这个命令时,
                          colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release
                          报了这个错误
                          --- stderr: moveit_planners_ompl
                          c++: fatal error: 已杀死 signal terminated program cc1plus
                          compilation terminated.
                          make[2]: *** [ompl_interface/CMakeFiles/moveit_ompl_interface.dir/build.make:284:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/src/detail/constrained_sampler.cpp.o] 错误 1
                          make[1]: *** [CMakeFiles/Makefile2:187:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/all] 错误 2
                          Failed   <<< moveit_planners_ompl [6min 9s, exited with code 2]
                          Aborted  <<< moveit_ros_move_group [5min 26s]
                          Summary: 14 packages finished [8min 33s]
                            1 package aborted: moveit_ros_move_group
                            10 packages not processed
                            小鱼 技术大佬 @2519105850
                            你去看一下我的教程,你这个连vcs都没装怎么用
                            • 25191058502
                              2519105850 @小鱼
                              to system dependencies:
                              之前就只有成功那句
                              另外运行这句指令时,报了这个错误
                                小鱼 技术大佬 @2519105850
                                moveit_visual_tools
                                rosdep这个没关系,手动下载一下到src下
                                • 25191058502
                                  2519105850 @小鱼
                                  @小鱼 感觉又和之前那样
                                  然后提示缺少catkin
                                  --- stderr: graph_msgs
                                      catkinConfig.cmake
                                      catkin-config.cmake
                                    installed.
                                    小鱼 技术大佬 @2519105850
                                    @2519105850 应该是的,你的代码到底哪来的
                                    • 25191058502
                                      2519105850 @小鱼
                                      @小鱼 我开始使用的是Ubuntu18.04,然后换了20.04,就按照公众号的这篇文章
                                      https://mp.weixin.qq.com/s/yfMKYtRpRF6xF2PjtGSFzg
                                      (应该是一步步执行的)
                                      会不会是下载ros2的时候一些包没下上,一些需要的包没配置?我同时下了rosfoxy , noetic,前面由于我打开终端选择的是noetic然后跟着文章执行的时候colcon报了缺少各种包的错;后面我就把moveit2的那个包全删了,打开终端时选择foxy,运行到colcon时显示
                                      [1/2 complete] (我以为这就要成功了,结果显示没 那个tool😥 )
                                        小鱼 技术大佬 @2519105850
                                        @2519105850 你可能下载的某个包并没有切换分支,还在ros上,比如你这个graph_msgs
                                        • 25191058502
                                          2519105850 @小鱼
                                          @小鱼 我选择了foxy这个后那个终端就没有关了,一直接着后面操作的
                                          我再把这个moveit2包删了,运行一步关闭一个终端选择一次foxy,但愿不报错,报错能解决也行🤕
                                          • 25191058502
                                            2519105850 @小鱼
                                            @小鱼 您好,我使用
                                            sudo apt-get purge ros-*
                                            sudo apt-get autoremove
                                            卸载foxy 和 neotic
                                            为什么打开终端还有提示让我选择呢,是我没卸载干净吗
                                            安装foxy感觉也没成功
