    ros2 colcon moveit
    31.4k
    • 25191058502
      2519105850 @小鱼
      @小鱼 好的,非常感谢!🙂
      • 小鱼小 小鱼 将这个主题标记为已解决,在
      • 25191058502
        2519105850 @小鱼
        @小鱼 您好,在头一次运行colcon报错提示缺少cpp_common
        CMake Warning (dev) at CMakeLists.txt:2 (project):
        Policy CMP0048 is not set: project() command manages VERSION variables.
        Run "cmake --help-policy CMP0048" for policy details. Use the cmake_policy
        command to set the policy and suppress this warning.
        The following variable(s) would be set to empty:
        CMAKE_PROJECT_VERSION
        CMAKE_PROJECT_VERSION_MAJOR
        CMAKE_PROJECT_VERSION_MINOR
        CMAKE_PROJECT_VERSION_PATCH
        CMake Error at /home/zhong/moveit2/install/message_runtime/share/message_runtime/cmake/message_runtimeConfig.cmake:197 (find_package):
        Could not find a package configuration file provided by "cpp_common" with
        any of the following names:
        cpp_commonConfig.cmake
        cpp_common-config.cmake
        Add the installation prefix of "cpp_common" to CMAKE_PREFIX_PATH or set
        "cpp_common_DIR" to a directory containing one of the above files. If
        "cpp_common" provides a separate development package or SDK, be sure it has
        been installed.
        /home/zhong/moveit2/install/std_msgs/share/std_msgs/cmake/std_msgsConfig.cmake:197 (find_package)
        /home/zhong/moveit2/install/catkin/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
        CMakeLists.txt:3 (find_package)
        Failed <<< test_msgs [0.54s, exited with code 1]
        Summary: 35 packages finished [8.20s]
        1 package failed: test_msgs
        1 package had stderr output: test_msgs
        6 packages not processed
        我在https://github.com/chronoxor/CppCommon上下载这个包到moveit2这个文件夹里,然后又报这个错误😩
        --allow-overriding ament_cmake ament_cmake_auto ament_cmake_core ament_cmake_gmock ament_cmake_gtest ament_cmake_pytest ament_cmake_ros ament_cmake_test rclcpp rclcpp_action rclcpp_components rclcpp_lifecycle std_msgs test_msgs
        Starting >>> ament_package
        Starting >>> catkin
        Starting >>> domain_coordinator
        Starting >>> cppcommon
        --- stderr: cppcommon
        CMake Error: The source "/home/zhong/moveit2/CppCommon/CMakeLists.txt" does not match the source "/home/zhong/moveit2/CppCommon-master/CMakeLists.txt" used to generate cache. Re-run cmake with a different source directory.
        Failed <<< cppcommon [0.64s, exited with code 1]
        Aborted <<< catkin [0.70s]
        Aborted <<< domain_coordinator [1.32s]
        Aborted <<< ament_package [1.40s]
        Summary: 0 packages finished [2.08s]
        1 package failed: cppcommon
        3 packages aborted: ament_package catkin domain_coordinator
        1 package had stderr output: cppcommon
        39 packages not processed
        运行colcon后直接就中断结束了,这个该怎样处理呢?
          小鱼 技术大佬 @2519105850
          @2519105850 兄弟你先改下格式
          • 25191058502
            2519105850 @小鱼
            @小鱼 好的,不好意思添麻烦了,下面这个格式是较正确的吗?
            运行colcon命令报错提示缺少cpp_common
            been installed.
            我在https://github.com/chronoxor/CppCommon上 下载cpp_common这个包到moveit2这个文件夹里,然后报了下面这个错误:
            Starting >>> catkin
            运行colcon命令后直接就中断结束了,请问这个该怎样解决呢?
              小鱼 技术大佬 @2519105850
              @2519105850 通过检索发现,cpp_common是ros的核心包 https://github.com/ros/roscpp_core 里的。
              而你是ROS2,应该是不需要这个包的,请你再次确认代码版本,系统版本,ROS版本。
              moveit2的教程可以看看我之前写的,都是没有这个步骤和问题的。
              Moveit2探索指南-源码编译测试
              • 25191058502
                2519105850 @小鱼
                @小鱼 那就说明我多半版本安装错误?
                  小鱼 技术大佬 @2519105850
                  @2519105850 是的,你应该是代码版本不对,我刚再次检查了下我的环境,cpp_common只在ros1中有,你的代码如果是ros2的,按理不应该出现。
                  • 25191058502
                    2519105850 @小鱼
                    @小鱼 好的,非常感谢!!!
                    • 25191058502
                      2519105850 @小鱼
                      @小鱼 确实是我版本号的问题,真是太厉害了!
                      我运行colon命令,然后提示只要下两个包,下第二个的时候报错了
                      报错内容
                      CMake Error at CMakeLists.txt:19 (find_package):
                        By not providing "Findmoveit_visual_tools.cmake" in CMAKE_MODULE_PATH this
                        "moveit_visual_tools", but CMake did not find one.
                        "moveit_visual_tools" with any of the following names:
                          moveit_visual_toolsConfig.cmake
                          moveit_visual_tools-config.cmake
                        Add the installation prefix of "moveit_visual_tools" to CMAKE_PREFIX_PATH
                        or set "moveit_visual_tools_DIR" to a directory containing one of the above
                        files.  If "moveit_visual_tools" provides a separate development package or
                      Failed   <<< moveit2_tutorials [16.1s, exited with code 1]
                      Summary: 1 package finished [1min 24s]
                        1 package failed: moveit2_tutorials
                        1 package had stderr output: moveit2_tutorials
                      是因为我用二进制安装moveit2没成功吗?
                      运行的这个代码
                      sudo apt install ros-foxy-moveit
                      sudo apt install ros-foxy-joint-state-controller
                      这是结果(没报错吧)
                      zhong@ubuntu:~$ sudo apt install ros-foxy-moveit
                      [sudo] zhong 的密码:
                      正在分析软件包的依赖关系树
                      ros-foxy-moveit 已经是最新版 (2.2.3-1focal.20220209.173642)。
                      zhong@ubuntu:~$ sudo apt install ros-foxy-joint-state-controller
                      正在分析软件包的依赖关系树
                      ros-foxy-joint-state-controller 已经是最新版 (0.7.0-1focal.20220223.161450)。
                      然后我就在 https://moveit.ros.org/install-moveit2/source/ 上按照步骤运行
                      运行到下面这一步时报错了,但是我接着运行后面一步没有管它
                      zhong@ubuntu:~/ws_moveit2/src$ vcs import < moveit2/moveit2.repos
                      Command 'vcs' not found, but there are 15 similar ones.
                      当运行下面这个命令时,
                      colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release
                      报了这个错误
                      --- stderr: moveit_planners_ompl
                      c++: fatal error: 已杀死 signal terminated program cc1plus
                      compilation terminated.
                      make[2]: *** [ompl_interface/CMakeFiles/moveit_ompl_interface.dir/build.make:284:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/src/detail/constrained_sampler.cpp.o] 错误 1
                      make[1]: *** [CMakeFiles/Makefile2:187:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/all] 错误 2
                      Failed   <<< moveit_planners_ompl [6min 9s, exited with code 2]
                      Aborted  <<< moveit_ros_move_group [5min 26s]
                      Summary: 14 packages finished [8min 33s]
                        1 package aborted: moveit_ros_move_group
                        10 packages not processed
                        小鱼 技术大佬 @2519105850
                        你去看一下我的教程,你这个连vcs都没装怎么用
                        • 25191058502
                          2519105850 @小鱼
                          to system dependencies:
                          之前就只有成功那句
                          另外运行这句指令时,报了这个错误
                            小鱼 技术大佬 @2519105850
                            moveit_visual_tools
                            rosdep这个没关系,手动下载一下到src下
                            • 25191058502
                              2519105850 @小鱼
                              @小鱼 感觉又和之前那样
                              然后提示缺少catkin
                              --- stderr: graph_msgs
                                  catkinConfig.cmake
                                  catkin-config.cmake
                                installed.
                                小鱼 技术大佬 @2519105850
                                @2519105850 应该是的,你的代码到底哪来的
                                • 25191058502
                                  2519105850 @小鱼
                                  @小鱼 我开始使用的是Ubuntu18.04,然后换了20.04,就按照公众号的这篇文章
                                  https://mp.weixin.qq.com/s/yfMKYtRpRF6xF2PjtGSFzg
                                  (应该是一步步执行的)
                                  会不会是下载ros2的时候一些包没下上,一些需要的包没配置?我同时下了rosfoxy , noetic,前面由于我打开终端选择的是noetic然后跟着文章执行的时候colcon报了缺少各种包的错;后面我就把moveit2的那个包全删了,打开终端时选择foxy,运行到colcon时显示
                                  [1/2 complete] (我以为这就要成功了,结果显示没 那个tool😥 )
                                    小鱼 技术大佬 @2519105850
                                    @2519105850 你可能下载的某个包并没有切换分支,还在ros上,比如你这个graph_msgs
                                    • 25191058502
                                      2519105850 @小鱼
                                      @小鱼 我选择了foxy这个后那个终端就没有关了,一直接着后面操作的
                                      我再把这个moveit2包删了,运行一步关闭一个终端选择一次foxy,但愿不报错,报错能解决也行🤕
                                      • 25191058502
                                        2519105850 @小鱼
                                        @小鱼 您好,我使用
                                        sudo apt-get purge ros-*
                                        sudo apt-get autoremove
                                        卸载foxy 和 neotic
                                        为什么打开终端还有提示让我选择呢,是我没卸载干净吗
                                        安装foxy感觉也没成功
                                          小鱼 技术大佬 @2519105850
                                          卸载foxy 和 neotic
                                          卸载干净了,配置没有清除罢了,你先用一键安装继续装,一键安装会帮你配置好的
                                          @小鱼 在 小鱼的一键安装系列 中说:
                                          一键安装指令
                                          • 25191058502
                                            2519105850 @小鱼
                                            @小鱼 我从安装foxy开始从头来了一遍,到这个colcon命令这里还是过不去
                                            zhong@ubuntu:~/moveit2/src$ colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
                                            Finished <<< rviz_visual_tools [1.43s]
                                            Starting >>> moveit_visual_tools
                                            --- stderr: moveit_visual_tools
                                            CMake Error at CMakeLists.txt:5 (find_package):
                                                catkinConfig.cmake
                                                catkin-config.cmake
                                              installed.
                                            Failed   <<< moveit_visual_tools [1.10s, exited with code 1]
                                            Summary: 1 package finished [3.01s]
                                              1 package failed: moveit_visual_tools
                                              1 package had stderr output: moveit_visual_tools
                                              1 package not processed
