    ros2 colcon moveit
    26.9k
    • 25191058502
      2519105850 @小鱼
      @小鱼 您好,在头一次运行colcon报错提示缺少cpp_common
      CMake Warning (dev) at CMakeLists.txt:2 (project):
      Policy CMP0048 is not set: project() command manages VERSION variables.
      Run "cmake --help-policy CMP0048" for policy details. Use the cmake_policy
      command to set the policy and suppress this warning.
      The following variable(s) would be set to empty:
      CMAKE_PROJECT_VERSION
      CMAKE_PROJECT_VERSION_MAJOR
      CMAKE_PROJECT_VERSION_MINOR
      CMAKE_PROJECT_VERSION_PATCH
      CMake Error at /home/zhong/moveit2/install/message_runtime/share/message_runtime/cmake/message_runtimeConfig.cmake:197 (find_package):
      Could not find a package configuration file provided by "cpp_common" with
      any of the following names:
      cpp_commonConfig.cmake
      cpp_common-config.cmake
      Add the installation prefix of "cpp_common" to CMAKE_PREFIX_PATH or set
      "cpp_common_DIR" to a directory containing one of the above files. If
      "cpp_common" provides a separate development package or SDK, be sure it has
      been installed.
      /home/zhong/moveit2/install/std_msgs/share/std_msgs/cmake/std_msgsConfig.cmake:197 (find_package)
      /home/zhong/moveit2/install/catkin/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
      CMakeLists.txt:3 (find_package)
      Failed <<< test_msgs [0.54s, exited with code 1]
      Summary: 35 packages finished [8.20s]
      1 package failed: test_msgs
      1 package had stderr output: test_msgs
      6 packages not processed
      我在https://github.com/chronoxor/CppCommon上下载这个包到moveit2这个文件夹里,然后又报这个错误😩
      --allow-overriding ament_cmake ament_cmake_auto ament_cmake_core ament_cmake_gmock ament_cmake_gtest ament_cmake_pytest ament_cmake_ros ament_cmake_test rclcpp rclcpp_action rclcpp_components rclcpp_lifecycle std_msgs test_msgs
      Starting >>> ament_package
      Starting >>> catkin
      Starting >>> domain_coordinator
      Starting >>> cppcommon
      --- stderr: cppcommon
      CMake Error: The source "/home/zhong/moveit2/CppCommon/CMakeLists.txt" does not match the source "/home/zhong/moveit2/CppCommon-master/CMakeLists.txt" used to generate cache. Re-run cmake with a different source directory.
      Failed <<< cppcommon [0.64s, exited with code 1]
      Aborted <<< catkin [0.70s]
      Aborted <<< domain_coordinator [1.32s]
      Aborted <<< ament_package [1.40s]
      Summary: 0 packages finished [2.08s]
      1 package failed: cppcommon
      3 packages aborted: ament_package catkin domain_coordinator
      1 package had stderr output: cppcommon
      39 packages not processed
      运行colcon后直接就中断结束了,这个该怎样处理呢?
        小鱼 技术大佬 @2519105850
        @2519105850 兄弟你先改下格式
        • 25191058502
          2519105850 @小鱼
          @小鱼 好的,不好意思添麻烦了,下面这个格式是较正确的吗?
          运行colcon命令报错提示缺少cpp_common
          been installed.
          我在https://github.com/chronoxor/CppCommon上 下载cpp_common这个包到moveit2这个文件夹里,然后报了下面这个错误:
          Starting >>> catkin
          运行colcon命令后直接就中断结束了,请问这个该怎样解决呢?
            小鱼 技术大佬 @2519105850
            @2519105850 通过检索发现,cpp_common是ros的核心包 https://github.com/ros/roscpp_core 里的。
            而你是ROS2,应该是不需要这个包的,请你再次确认代码版本,系统版本,ROS版本。
            moveit2的教程可以看看我之前写的,都是没有这个步骤和问题的。
            Moveit2探索指南-源码编译测试
            • 25191058502
              2519105850 @小鱼
              @小鱼 那就说明我多半版本安装错误?
                小鱼 技术大佬 @2519105850
                @2519105850 是的,你应该是代码版本不对,我刚再次检查了下我的环境,cpp_common只在ros1中有,你的代码如果是ros2的,按理不应该出现。
                • 25191058502
                  2519105850 @小鱼
                  @小鱼 好的,非常感谢!!!
                  • 25191058502
                    2519105850 @小鱼
                    @小鱼 确实是我版本号的问题,真是太厉害了!
                    我运行colon命令,然后提示只要下两个包,下第二个的时候报错了
                    报错内容
                    CMake Error at CMakeLists.txt:19 (find_package):
                      By not providing "Findmoveit_visual_tools.cmake" in CMAKE_MODULE_PATH this
                      "moveit_visual_tools", but CMake did not find one.
                      "moveit_visual_tools" with any of the following names:
                        moveit_visual_toolsConfig.cmake
                        moveit_visual_tools-config.cmake
                      Add the installation prefix of "moveit_visual_tools" to CMAKE_PREFIX_PATH
                      or set "moveit_visual_tools_DIR" to a directory containing one of the above
                      files.  If "moveit_visual_tools" provides a separate development package or
                    Failed   <<< moveit2_tutorials [16.1s, exited with code 1]
                    Summary: 1 package finished [1min 24s]
                      1 package failed: moveit2_tutorials
                      1 package had stderr output: moveit2_tutorials
                    是因为我用二进制安装moveit2没成功吗?
                    运行的这个代码
                    sudo apt install ros-foxy-moveit
                    sudo apt install ros-foxy-joint-state-controller
                    这是结果(没报错吧)
                    zhong@ubuntu:~$ sudo apt install ros-foxy-moveit
                    [sudo] zhong 的密码:
                    正在分析软件包的依赖关系树
                    ros-foxy-moveit 已经是最新版 (2.2.3-1focal.20220209.173642)。
                    zhong@ubuntu:~$ sudo apt install ros-foxy-joint-state-controller
                    正在分析软件包的依赖关系树
                    ros-foxy-joint-state-controller 已经是最新版 (0.7.0-1focal.20220223.161450)。
                    然后我就在 https://moveit.ros.org/install-moveit2/source/ 上按照步骤运行
                    运行到下面这一步时报错了,但是我接着运行后面一步没有管它
                    zhong@ubuntu:~/ws_moveit2/src$ vcs import < moveit2/moveit2.repos
                    Command 'vcs' not found, but there are 15 similar ones.
                    当运行下面这个命令时,
                    colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release
                    报了这个错误
                    --- stderr: moveit_planners_ompl
                    c++: fatal error: 已杀死 signal terminated program cc1plus
                    compilation terminated.
                    make[2]: *** [ompl_interface/CMakeFiles/moveit_ompl_interface.dir/build.make:284:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/src/detail/constrained_sampler.cpp.o] 错误 1
                    make[1]: *** [CMakeFiles/Makefile2:187:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/all] 错误 2
                    Failed   <<< moveit_planners_ompl [6min 9s, exited with code 2]
                    Aborted  <<< moveit_ros_move_group [5min 26s]
                    Summary: 14 packages finished [8min 33s]
                      1 package aborted: moveit_ros_move_group
                      10 packages not processed
                      小鱼 技术大佬 @2519105850
                      你去看一下我的教程,你这个连vcs都没装怎么用
                      • 25191058502
                        2519105850 @小鱼
                        to system dependencies:
                        之前就只有成功那句
                        另外运行这句指令时,报了这个错误
                          小鱼 技术大佬 @2519105850
                          moveit_visual_tools
                          rosdep这个没关系,手动下载一下到src下
                          • 25191058502
                            2519105850 @小鱼
                            @小鱼 感觉又和之前那样
                            然后提示缺少catkin
                            --- stderr: graph_msgs
                                catkinConfig.cmake
                                catkin-config.cmake
                              installed.
                              小鱼 技术大佬 @2519105850
                              @2519105850 应该是的,你的代码到底哪来的
                              • 25191058502
                                2519105850 @小鱼
                                @小鱼 我开始使用的是Ubuntu18.04,然后换了20.04,就按照公众号的这篇文章
                                https://mp.weixin.qq.com/s/yfMKYtRpRF6xF2PjtGSFzg
                                (应该是一步步执行的)
                                会不会是下载ros2的时候一些包没下上,一些需要的包没配置?我同时下了rosfoxy , noetic,前面由于我打开终端选择的是noetic然后跟着文章执行的时候colcon报了缺少各种包的错;后面我就把moveit2的那个包全删了,打开终端时选择foxy,运行到colcon时显示
                                [1/2 complete] (我以为这就要成功了,结果显示没 那个tool😥 )
                                  小鱼 技术大佬 @2519105850
                                  @2519105850 你可能下载的某个包并没有切换分支,还在ros上,比如你这个graph_msgs
                                  • 25191058502
                                    2519105850 @小鱼
                                    @小鱼 我选择了foxy这个后那个终端就没有关了,一直接着后面操作的
                                    我再把这个moveit2包删了,运行一步关闭一个终端选择一次foxy,但愿不报错,报错能解决也行🤕
                                    • 25191058502
                                      2519105850 @小鱼
                                      @小鱼 您好,我使用
                                      sudo apt-get purge ros-*
                                      sudo apt-get autoremove
                                      卸载foxy 和 neotic
                                      为什么打开终端还有提示让我选择呢,是我没卸载干净吗
                                      安装foxy感觉也没成功
                                        小鱼 技术大佬 @2519105850
                                        卸载foxy 和 neotic
                                        卸载干净了,配置没有清除罢了,你先用一键安装继续装,一键安装会帮你配置好的
                                        @小鱼 在 小鱼的一键安装系列 中说:
                                        一键安装指令
                                        • 25191058502
                                          2519105850 @小鱼
                                          @小鱼 我从安装foxy开始从头来了一遍,到这个colcon命令这里还是过不去
                                          zhong@ubuntu:~/moveit2/src$ colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
                                          Finished <<< rviz_visual_tools [1.43s]
                                          Starting >>> moveit_visual_tools
                                          --- stderr: moveit_visual_tools
                                          CMake Error at CMakeLists.txt:5 (find_package):
                                              catkinConfig.cmake
                                              catkin-config.cmake
                                            installed.
                                          Failed   <<< moveit_visual_tools [1.10s, exited with code 1]
                                          Summary: 1 package finished [3.01s]
                                            1 package failed: moveit_visual_tools
                                            1 package had stderr output: moveit_visual_tools
                                            1 package not processed
                                            小鱼 技术大佬 @2519105850
                                            @2519105850 建议你再等等吧,moveit2太不完善了,我后面会出一期教程讲的。
