    ros2 colcon moveit
    33.3k
    • 25191058502
      2519105850 @小鱼
      @小鱼 那就说明我多半版本安装错误?
        小鱼 技术大佬 @2519105850
        @2519105850 是的,你应该是代码版本不对,我刚再次检查了下我的环境,cpp_common只在ros1中有,你的代码如果是ros2的,按理不应该出现。
        • 25191058502
          2519105850 @小鱼
          @小鱼 好的,非常感谢!!!
          • 25191058502
            2519105850 @小鱼
            @小鱼 确实是我版本号的问题,真是太厉害了!
            我运行colon命令,然后提示只要下两个包,下第二个的时候报错了
            报错内容
            CMake Error at CMakeLists.txt:19 (find_package):
              By not providing "Findmoveit_visual_tools.cmake" in CMAKE_MODULE_PATH this
              "moveit_visual_tools", but CMake did not find one.
              "moveit_visual_tools" with any of the following names:
                moveit_visual_toolsConfig.cmake
                moveit_visual_tools-config.cmake
              Add the installation prefix of "moveit_visual_tools" to CMAKE_PREFIX_PATH
              or set "moveit_visual_tools_DIR" to a directory containing one of the above
              files.  If "moveit_visual_tools" provides a separate development package or
            Failed   <<< moveit2_tutorials [16.1s, exited with code 1]
            Summary: 1 package finished [1min 24s]
              1 package failed: moveit2_tutorials
              1 package had stderr output: moveit2_tutorials
            是因为我用二进制安装moveit2没成功吗?
            运行的这个代码
            sudo apt install ros-foxy-moveit
            sudo apt install ros-foxy-joint-state-controller
            这是结果(没报错吧)
            zhong@ubuntu:~$ sudo apt install ros-foxy-moveit
            [sudo] zhong 的密码:
            正在分析软件包的依赖关系树
            ros-foxy-moveit 已经是最新版 (2.2.3-1focal.20220209.173642)。
            zhong@ubuntu:~$ sudo apt install ros-foxy-joint-state-controller
            正在分析软件包的依赖关系树
            ros-foxy-joint-state-controller 已经是最新版 (0.7.0-1focal.20220223.161450)。
            然后我就在 https://moveit.ros.org/install-moveit2/source/ 上按照步骤运行
            运行到下面这一步时报错了,但是我接着运行后面一步没有管它
            zhong@ubuntu:~/ws_moveit2/src$ vcs import < moveit2/moveit2.repos
            Command 'vcs' not found, but there are 15 similar ones.
            当运行下面这个命令时,
            colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release
            报了这个错误
            --- stderr: moveit_planners_ompl
            c++: fatal error: 已杀死 signal terminated program cc1plus
            compilation terminated.
            make[2]: *** [ompl_interface/CMakeFiles/moveit_ompl_interface.dir/build.make:284:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/src/detail/constrained_sampler.cpp.o] 错误 1
            make[1]: *** [CMakeFiles/Makefile2:187:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/all] 错误 2
            Failed   <<< moveit_planners_ompl [6min 9s, exited with code 2]
            Aborted  <<< moveit_ros_move_group [5min 26s]
            Summary: 14 packages finished [8min 33s]
              1 package aborted: moveit_ros_move_group
              10 packages not processed
              小鱼 技术大佬 @2519105850
              你去看一下我的教程,你这个连vcs都没装怎么用
              • 25191058502
                2519105850 @小鱼
                to system dependencies:
                之前就只有成功那句
                另外运行这句指令时,报了这个错误
                  小鱼 技术大佬 @2519105850
                  moveit_visual_tools
                  rosdep这个没关系,手动下载一下到src下
                  • 25191058502
                    2519105850 @小鱼
                    @小鱼 感觉又和之前那样
                    然后提示缺少catkin
                    --- stderr: graph_msgs
                        catkinConfig.cmake
                        catkin-config.cmake
                      installed.
                      小鱼 技术大佬 @2519105850
                      @2519105850 应该是的,你的代码到底哪来的
                      • 25191058502
                        2519105850 @小鱼
                        @小鱼 我开始使用的是Ubuntu18.04,然后换了20.04,就按照公众号的这篇文章
                        https://mp.weixin.qq.com/s/yfMKYtRpRF6xF2PjtGSFzg
                        (应该是一步步执行的)
                        会不会是下载ros2的时候一些包没下上,一些需要的包没配置?我同时下了rosfoxy , noetic,前面由于我打开终端选择的是noetic然后跟着文章执行的时候colcon报了缺少各种包的错;后面我就把moveit2的那个包全删了,打开终端时选择foxy,运行到colcon时显示
                        [1/2 complete] (我以为这就要成功了,结果显示没 那个tool😥 )
                          小鱼 技术大佬 @2519105850
                          @2519105850 你可能下载的某个包并没有切换分支,还在ros上,比如你这个graph_msgs
                          • 25191058502
                            2519105850 @小鱼
                            @小鱼 我选择了foxy这个后那个终端就没有关了,一直接着后面操作的
                            我再把这个moveit2包删了,运行一步关闭一个终端选择一次foxy,但愿不报错,报错能解决也行🤕
                            • 25191058502
                              2519105850 @小鱼
                              @小鱼 您好,我使用
                              sudo apt-get purge ros-*
                              sudo apt-get autoremove
                              卸载foxy 和 neotic
                              为什么打开终端还有提示让我选择呢,是我没卸载干净吗
                              安装foxy感觉也没成功
                                小鱼 技术大佬 @2519105850
                                卸载foxy 和 neotic
                                卸载干净了,配置没有清除罢了,你先用一键安装继续装,一键安装会帮你配置好的
                                @小鱼 在 小鱼的一键安装系列 中说:
                                一键安装指令
                                • 25191058502
                                  2519105850 @小鱼
                                  @小鱼 我从安装foxy开始从头来了一遍,到这个colcon命令这里还是过不去
                                  zhong@ubuntu:~/moveit2/src$ colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
                                  Finished <<< rviz_visual_tools [1.43s]
                                  Starting >>> moveit_visual_tools
                                  --- stderr: moveit_visual_tools
                                  CMake Error at CMakeLists.txt:5 (find_package):
                                      catkinConfig.cmake
                                      catkin-config.cmake
                                    installed.
                                  Failed   <<< moveit_visual_tools [1.10s, exited with code 1]
                                  Summary: 1 package finished [3.01s]
                                    1 package failed: moveit_visual_tools
                                    1 package had stderr output: moveit_visual_tools
                                    1 package not processed
                                    小鱼 技术大佬 @2519105850
                                    @2519105850 建议你再等等吧,moveit2太不完善了,我后面会出一期教程讲的。
                                    • 25191058502
                                      2519105850 @小鱼
                                      @小鱼 好的,感谢感谢
