    ros2使用colcon编译时,总是报错提示缺少一个包,安装完一个后还有另一个
    ros2 colcon moveit
    29.0k
    • 25191058502
      2519105850 @小鱼
      @小鱼 确实是我版本号的问题,真是太厉害了!
      我运行colon命令,然后提示只要下两个包,下第二个的时候报错了
      colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
      报错内容
      CMake Error at CMakeLists.txt:19 (find_package):
        By not providing "Findmoveit_visual_tools.cmake" in CMAKE_MODULE_PATH this
        project has asked CMake to find a package configuration file provided by
        "moveit_visual_tools", but CMake did not find one.
        "moveit_visual_tools" with any of the following names:
          moveit_visual_toolsConfig.cmake
          moveit_visual_tools-config.cmake
        Add the installation prefix of "moveit_visual_tools" to CMAKE_PREFIX_PATH
        or set "moveit_visual_tools_DIR" to a directory containing one of the above
        files.  If "moveit_visual_tools" provides a separate development package or
        SDK, be sure it has been installed.
      Failed   <<< moveit2_tutorials [16.1s, exited with code 1]
      Summary: 1 package finished [1min 24s]
        1 package failed: moveit2_tutorials
        1 package had stderr output: moveit2_tutorials
      是因为我用二进制安装moveit2没成功吗?
      运行的这个代码
      sudo apt install ros-foxy-moveit
      sudo apt install ros-foxy-joint-state-controller
      这是结果(没报错吧)
      zhong@ubuntu:~$ sudo apt install ros-foxy-moveit
      [sudo] zhong 的密码:
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      ros-foxy-moveit 已经是最新版 (2.2.3-1focal.20220209.173642)。
      升级了 0 个软件包,新安装了 0 个软件包,要卸载 0 个软件包,有 0 个软件包未被升级。
      zhong@ubuntu:~$ sudo apt install ros-foxy-joint-state-controller
      正在读取软件包列表... 完成
      正在分析软件包的依赖关系树
      正在读取状态信息... 完成
      ros-foxy-joint-state-controller 已经是最新版 (0.7.0-1focal.20220223.161450)。
      然后我就在 https://moveit.ros.org/install-moveit2/source/ 上按照步骤运行
      运行到下面这一步时报错了,但是我接着运行后面一步没有管它
      zhong@ubuntu:~/ws_moveit2/src$ vcs import < moveit2/moveit2.repos
      Command 'vcs' not found, but there are 15 similar ones.
      当运行下面这个命令时,
      colcon build --event-handlers desktop_notification- status- --cmake-args -DCMAKE_BUILD_TYPE=Release
      报了这个错误
      --- stderr: moveit_planners_ompl
      c++: fatal error: 已杀死 signal terminated program cc1plus
      compilation terminated.
      make[2]: *** [ompl_interface/CMakeFiles/moveit_ompl_interface.dir/build.make:284:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/src/detail/constrained_sampler.cpp.o] 错误 1
      make[1]: *** [CMakeFiles/Makefile2:187:ompl_interface/CMakeFiles/moveit_ompl_interface.dir/all] 错误 2
      make: *** [Makefile:141:all] 错误 2
      Failed   <<< moveit_planners_ompl [6min 9s, exited with code 2]
      Aborted  <<< moveit_ros_move_group [5min 26s]
      Summary: 14 packages finished [8min 33s]
        1 package failed: moveit_planners_ompl
        1 package aborted: moveit_ros_move_group
        1 package had stderr output: moveit_planners_ompl
        10 packages not processed
        小鱼 技术大佬 @2519105850
        @2519105850 在 ros2使用colcon编译时,总是报错提示缺少一个包,安装完一个后还有另一个 中说:
        你去看一下我的教程,你这个连vcs都没装怎么用
        25191058502 1 条回复 最后回复 回复 引用 0
        • 25191058502
          2519105850 @小鱼
          @小鱼 我现在发现好像是我rosdepc这一步错了导致 colcon错误
          rosdepc install -r --from-paths . --ignore-src --rosdistro $ROS_DISTRO -y
          运行这一步时报了 moveit_visual_tools 相关的错误(之前几次没显示这个错误)
          ERROR: the following packages/stacks could not have their rosdepc keys resolved
          to system dependencies:
          moveit2_tutorials: Cannot locate rosdep definition for [moveit_visual_tools]
          Continuing to install resolvable dependencies...
          #All required rosdeps installed successfully
          之前就只有成功那句
          另外运行这句指令时,报了这个错误
          git reset 59cf8c49bb309e2bb7f06e295f87efa36f8bb506 --hard
          fatal: 不能解析对象 '59cf8c49bb309e2bb7f06e295f87efa36f8bb506'。
            小鱼 技术大佬 @2519105850
            moveit_visual_tools
            rosdep这个没关系,手动下载一下到src下
            git clone https://github.com/ros-planning/moveit_visual_tools.git -b foxy
            • 25191058502
              2519105850 @小鱼
              @小鱼 感觉又和之前那样
              src目录下了moveit_visual_tools包后,再运行下面这个代码
              提示我graph这个包没有,在 https://github.com/PickNikRobotics/graph_msgs.git 上下载包到src目录下再运行 colcon命令
              然后提示缺少catkin
              --- stderr: graph_msgs
              CMake Error at CMakeLists.txt:7 (find_package):
                By not providing "Findcatkin.cmake" in CMAKE_MODULE_PATH this project has
                asked CMake to find a package configuration file provided by "catkin", but
                Could not find a package configuration file provided by "catkin" with any
                  catkinConfig.cmake
                  catkin-config.cmake
                Add the installation prefix of "catkin" to CMAKE_PREFIX_PATH or set
                "catkin_DIR" to a directory containing one of the above files.  If "catkin"
                installed.
              我在 https://index.ros.org/ 搜索 cakin 也没找到foxy下的包,catkin也是ros1的包吧?
                小鱼 技术大佬 @2519105850
                @2519105850 应该是的,你的代码到底哪来的
                • 25191058502
                  2519105850 @小鱼
                  @小鱼 我开始使用的是Ubuntu18.04,然后换了20.04,就按照公众号的这篇文章
                  https://mp.weixin.qq.com/s/yfMKYtRpRF6xF2PjtGSFzg
                  (应该是一步步执行的)
                  会不会是下载ros2的时候一些包没下上,一些需要的包没配置?我同时下了rosfoxy , noetic,前面由于我打开终端选择的是noetic然后跟着文章执行的时候colcon报了缺少各种包的错;后面我就把moveit2的那个包全删了,打开终端时选择foxy,运行到colcon时显示
                  [1/2 complete] (我以为这就要成功了,结果显示没 那个tool😥 )
                    小鱼 技术大佬 @2519105850
                    @2519105850 你可能下载的某个包并没有切换分支,还在ros上,比如你这个graph_msgs
                    25191058502 2 条回复 最后回复 回复 引用 0
                    • 25191058502
                      2519105850 @小鱼
                      @小鱼 我选择了foxy这个后那个终端就没有关了,一直接着后面操作的
                      我再把这个moveit2包删了,运行一步关闭一个终端选择一次foxy,但愿不报错,报错能解决也行🤕
                      • 25191058502
                        2519105850 @小鱼
                        @小鱼 您好,我使用
                        sudo apt-get purge ros-*
                        sudo apt-get autoremove
                        卸载foxy 和 neotic
                        为什么打开终端还有提示让我选择呢,是我没卸载干净吗
                        安装foxy感觉也没成功
                          小鱼 技术大佬 @2519105850
                          卸载foxy 和 neotic
                          卸载干净了,配置没有清除罢了,你先用一键安装继续装,一键安装会帮你配置好的
                          @小鱼 在 小鱼的一键安装系列 中说:
                          一键安装指令
                          • 25191058502
                            2519105850 @小鱼
                            @小鱼 我从安装foxy开始从头来了一遍,到这个colcon命令这里还是过不去
                            zhong@ubuntu:~/moveit2/src$ colcon build --cmake-args -DCMAKE_BUILD_TYPE=Release
                            Starting >>> rviz_visual_tools
                            Finished <<< rviz_visual_tools [1.43s]
                            Starting >>> moveit_visual_tools
                            --- stderr: moveit_visual_tools
                            CMake Error at CMakeLists.txt:5 (find_package):
                                catkinConfig.cmake
                                catkin-config.cmake
                              installed.
                            Failed   <<< moveit_visual_tools [1.10s, exited with code 1]
                            Summary: 1 package finished [3.01s]
                              1 package failed: moveit_visual_tools
                              1 package had stderr output: moveit_visual_tools
                              1 package not processed
                              小鱼 技术大佬 @2519105850
                              @2519105850 建议你再等等吧,moveit2太不完善了,我后面会出一期教程讲的。
                              • 25191058502
                                2519105850 @小鱼
                                @小鱼 好的,感谢感谢
