    小鱼的一键安装系列
    工具软件
    一键安装 使用指南
    63
    134
    970.7k
      小鱼 技术大佬 @1310622682
      @1310622682 重启电脑
        wenda316
        失败了。。请到社区或群聊反馈:['', 'sudo: docker:找不到命令\n']
        • 23619986862
          远
          忘记安装docker时候使用的名称怎么办
            小鱼 技术大佬 @2361998686
            @2361998686 docker ps -a 看一下
            • 10430283921
              无心
              四次换源后都失败了,请及时联系小鱼获取解决方案并处理!
              小鱼小 2 条回复 最后回复 回复 引用 0
                小鱼 技术大佬 @1043028392
                @1043028392 请单独开个新的帖子讨论该问题
                  小鱼 技术大佬 @1043028392
                  • 8925421088
                    莱昂纳税人
                    AttributeError: 'NoneType' object has no attribute 'keys'
                    bash: /opt/ros/melodic/setup.bash: 没有那个文件或目录
                      小鱼 技术大佬 @892542108
                      @892542108 请单独开个新的帖子讨论该问题
                        linzeshi
                          linzeshi
                          系统版本:ubuntu16
                          ROS:kinetic
                          安装途径:鱼香ros一键安装
                          问题描述:在配置rosdep之后,无论是rosdepc update还是rosdep update都失败。
                          --------rosdep update---------
                          casun@casun:~$ rosdep update
                          reading in sources list data from /etc/ros/rosdep/sources.list.d
                          Hit https://gitee.com/ohhuo/rosdistro/raw/master/rosdep/osx-homebrew.yaml
                          Hit https://gitee.com/ohhuo/rosdistro/raw/master/rosdep/base.yaml
                          Hit https://gitee.com/ohhuo/rosdistro/raw/master/rosdep/python.yaml
                          Hit https://gitee.com/ohhuo/rosdistro/raw/master/rosdep/ruby.yaml
                          Hit https://gitee.com/ohhuo/rosdistro/raw/master/releases/fuerte.yaml
                          Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index-v4.yaml
                          Skip end-of-life distro "ardent"
                          Skip end-of-life distro "bouncy"
                          Skip end-of-life distro "crystal"
                          Skip end-of-life distro "dashing"
                          Skip end-of-life distro "eloquent"
                          Add distro "foxy"
                          Add distro "galactic"
                          Skip end-of-life distro "groovy"
                          Add distro "humble"
                          Skip end-of-life distro "hydro"
                          Skip end-of-life distro "indigo"
                          Skip end-of-life distro "jade"
                          Skip end-of-life distro "kinetic"
                          Skip end-of-life distro "lunar"
                          Add distro "melodic"
                          ERROR: error loading sources list:
                          	<urlopen error <urlopen error timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/melodic/distribution.yaml)>
                          --------rosdepc update--------
                          casun@casun:~$ rosdepc update
                          欢迎使用国内版rosdep之rosdepc
                          我是作者小鱼,更多ROS学习资源请关注公众号鱼香ROS
                          小鱼rosdepc开始为您服务---------------
                          ERROR: unable to process source [https://gitee.com/ohhuo/rosdistro/raw/master/releases/fuerte.yaml]:
                          	Failed to download target platform data for gbpdistro:
                          Query rosdistro index https://gitee.com/ohhuo/rosdistro/raw/master/index-v4.yaml
                          Add distro "foxy"
                          Add distro "humble"
                          ERROR: Rosdep experienced an error: Expected file type is 'distribution'
                          Please go to the rosdepc page [1] and file a bug report with the stack trace below.
                          [1] : http://www.ros.org/wiki/rosdepc
                          发生错误了,请关注微信公众号:鱼香ROS,找小鱼反馈哦
                          rosdepc version: 0.21.0
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 146, in rosdep_main
                              exit_code = _rosdep_main(args)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 446, in _rosdep_main
                              return _no_args_handler(command, parser, options, args)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 455, in _no_args_handler
                              return command_handlers[command](options)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/main.py", line 677, in command_update
                              ros_distro=options.ros_distro)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/sources_list.py", line 516, in update_sources_list
                              rosdep_data = get_gbprepo_as_rosdep_data(dist_name)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/gbpdistro_support.py", line 149, in get_gbprepo_as_rosdep_data
                              distro_file = get_release_file(gbpdistro)
                            File "/usr/local/lib/python2.7/dist-packages/roscdep2/rosdistrohelper.py", line 77, in get_release_file
                              dist_file = rosdistro.get_distribution_file(get_index(), distro)
                            File "/usr/lib/python2.7/dist-packages/rosdistro/__init__.py", line 120, in get_distribution_file
                              return create_distribution_file(dist_name, data)
                            File "/usr/lib/python2.7/dist-packages/rosdistro/distribution_file.py", line 134, in create_distribution_file
                              dist_file = DistributionFile(dist_name, d)
                            File "/usr/lib/python2.7/dist-packages/rosdistro/distribution_file.py", line 45, in __init__
                              assert 'type' in data, "Expected file type is '%s'" % DistributionFile._type
                          AssertionError: Expected file type is 'distribution'
                            小鱼 技术大佬 @linzeshi
                            @linzeshi 请单独发一个帖子
                            • 28101629912
                              我清醒着一再续杯
                              请这样是安装成功了吗?我之前尝试装过ros-melodic,在初始化和配置环境变量的时候出了问题。在配置环境变量的时候也是有这个“no such file or directory”的提示,然后我卸载了原来安装的ros。
                              • 毛哥成山轮胎机油保养毛 毛哥成山轮胎机油保养 在 中 引用了 这个主题
                              • 19247227981
                                1924722798
                                最后由 1924722798 编辑
                                [ERROR] [1668773178.263392316]: [registerPublisher] Failed to contact master at [localhost:11311]. Retrying...
                                在安装完ros1之后,想要测试一下,用了一下小海龟的代码出现了这个
                                  小鱼 技术大佬 @1924722798
                                  @1924722798 没有启动roscore
                                  19247227981 1 条回复 最后回复 回复 引用 0
                                  • 19247227981
                                    1924722798 @小鱼
                                    @小鱼 嗷嗷,昨天用roscore了,没有弹窗,今天可以了,蟹蟹😊
                                    • 17719070971
                                      你和梦想我都要
                                      pi@ubuntu:~$ myros
                                      /home/pi/.fishros/bin/myros: line 1: xhost: command not found
                                      请输入指令控制myros: 重启(r) 进入(e) 启动(s) 关闭(c) 删除(d) 测试(t):
                                      s
                                      Error response from daemon: error gathering device information while adding custom device "/dev/dri/renderD128": no such file or directory
                                      Error: failed to start containers: myros
                                      pi@ubuntu:~$
                                      安装的是ros Melodic版本,出现了这个问题。求大佬解决
                                      • 21036547072
                                        2103654707
                                        我在做现实的ros小车导航,因为雷达建图不好用,我想把现有的完整图导rviz里,我已经将图片和图片附带的文件复制到map和nav文件夹下的maps了,nav下的launch文件夹下的launch文件中,内容<node name="map_server" pkg="map_server" type="map_server" args="$(find ucar_nav)/maps/mapname.yaml" output="screen">加粗字体也改好了,输入roslaunch ucar_nav ucar_navigation.launch,然后报错,该怎么办16bde6d8-9197-49b4-aff5-dd2a1f9d0458-image.png
                                          小鱼 技术大佬 @2103654707
                                          @2103654707 请单独发帖,这个是一键安装
                                            小鱼 技术大佬 @1771907097
                                            @1771907097 请单独发帖,不要盖楼了,太高了
