    一键安装ros后,roscore报错
    一键安装报错 ros
    5
    19
    10.7k
    • fuzzF
      fuzz
      我之前装过一次ros,但由于一些自己的失误(好像是和python有关的代码)导致roscore报错了,然后我把ros卸载了重新一键安装,但依旧报错,请教各位大神帮我看看应该如何解决。附上报错代码
      roscore
      File "/opt/ros/melodic/bin/roscore", line 37, in <module>
      from roslaunch.nodeprocess import DEFAULT_TIMEOUT_SIGINT, DEFAULT_TIMEOUT_SIGTERM
      File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/init.py", line 52, in <module>
      from . import param_dump as roslaunch_param_dump
      File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/param_dump.py", line 40, in <module>
      import roslaunch.config
      File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/config.py", line 45, in <module>
      import rospkg.distro
      File "/home/fzz/.local/lib/python2.7/site-packages/rospkg/distro.py", line 44, in <module>
      import yaml
      File "/usr/lib/python3/dist-packages/yaml/init.py", line 284
      class YAMLObject(metaclass=YAMLObjectMetaclass):
      SyntaxError: invalid syntax
      Error in sys.excepthook:
      File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63, in apport_excepthook
      from apport.fileutils import likely_packaged, get_recent_crashes
      File "/usr/lib/python3/dist-packages/apport/init.py", line 5, in <module>
      from apport.report import Report
      File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in <module>
      import apport.fileutils
      File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in <module>
      from apport.packaging_impl import impl as packaging
      File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 24, in <module>
      import apt
      File "/usr/lib/python3/dist-packages/apt/init.py", line 23, in <module>
      import apt_pkg
      ImportError: No module named apt_pkg
      Original exception was:
      import yaml
      • 小鱼小 小鱼 从 中的 社区&开源 移动了该主题
        小鱼 技术大佬 @fuzz
        @fuzz 多少的系统呀?默认的python版本是3吗
        fuzzF 1 条回复 最后回复 回复 引用 0
        • fuzzF
          fuzz @小鱼
          @小鱼 您好,我是u18.04,ros melodic,之前貌似是默认2,然后我根据网上教学一通瞎操作想搞成3,但是可能没有成功,所以之后roscore一直报错,我卸载后按照您的一键安装后依旧这样报错。
            小鱼 技术大佬 @fuzz
            @fuzz 主要原因是默认的python版本造成的,需要改回python3
            • fuzzF
              fuzz @小鱼
              @小鱼 您好,可以向您请教一下要如何操作吗,我现在刚开始接触ros还不太懂,谢谢!
                小鱼 技术大佬 @fuzz
                @fuzz 看你怎么改的默认的了,一般是改软链接,你要根据你改过去的方式反向操作下。
                • fuzzF
                  fuzz @小鱼
                  @小鱼您好,谢谢您的意见,我按您说的尝试一下,感谢!
                    小鱼 技术大佬 @fuzz
                    @fuzz 好嘞,代码块可以用markdown包裹一下,安装相关问题在一键安装模块下提问即可。
                    • fuzzF
                      fuzz @小鱼
                      @小鱼 您好,我按照以下方法成功修改了默认python版本
                      Linux Python 版本切换方法
                      切换python版本
                      update-alternatives --display python
                      如果出现以下错误:
                      update-alternatives: 错误: 无 python 的候选项,那么按下面的流程操作。
                      #查看多个python版本
                      #ls /usr/bin/python
                      python2.7 python3.6
                      #添加Python2可选项,优先级为2
                      sudo update-alternatives --install /usr/bin/python python /usr/bin/python2.7 2
                      #添加Python3可选项,优先级为1
                      sudo update-alternatives --install /usr/bin/python python /usr/bin/python3.6 1
                      #配置
                      sudo update-alternatives --config python
                      #yongyu 删除配置
                      sudo update-alternatives --remove python /usr/bin/python2.7
                      来源:https://www.csdn.net/tags/NtzaAgysNDA5NjQtYmxvZwO0O0OO0O0O.html
                      感谢您的指导,谢谢!
                        小鱼 技术大佬 @fuzz
                        @fuzz 客气,修改完再试试是否可以正常使用ROS
                        • fuzzF
                          fuzz @小鱼
                          @小鱼 已经可以成功运行小乌龟了👍 👍
                            小鱼 技术大佬 @fuzz
                            @fuzz 👌
                            • G
                              gaoxu515
                              @小鱼 @fuzz 按照帖子的内容修改了,又出现了下面的错误,请问大佬们怎么解决啊?谢谢~ (我的环境和fuzz的一样)
                              File "/opt/ros/melodic/lib/python2.7/dist-packages/roslaunch/init.py", line 39, in <module>
                              import rospkg
                              ModuleNotFoundError: No module named 'rospkg'
                              G 1 条回复 最后回复 回复 引用 0
                              • G
                                gaoxu515 @gaoxu515
                                解决了
                                pip3 install rospkg
                                14128467031 1 条回复 最后回复 回复 引用 0
                                • 14128467031
                                  O🐯
                                  我装的python3可是也出现了这个问题
                                  • 14128467031
                                    O🐯 @gaoxu515
                                    @gaoxu515 为什么这个我输入后报错
                                    • 14128467031
                                      O🐯
                                      File "/usr/bin/roscore", line 37, in <module>
                                      File "/usr/lib/python3/dist-packages/roslaunch/init.py", line 62, in <module>
                                      from .scriptapi import ROSLaunch
                                      File "/usr/lib/python3/dist-packages/roslaunch/scriptapi.py", line 42, in <module>
                                      import roslaunch.parent
                                      File "/usr/lib/python3/dist-packages/roslaunch/parent.py", line 54, in <module>
                                      import roslaunch.server
                                      File "/usr/lib/python3/dist-packages/roslaunch/server.py", line 80, in <module>
                                      from rosgraph_msgs.msg import Log
                                      ImportError: cannot import name 'Log' from 'rosgraph_msgs.msg' (/opt/ros/rolling/lib/python3.10/site-packages/rosgraph_msgs/msg/init.py)
                                      14128467031 W 2 条回复 最后回复 回复 引用 0
                                      • 14128467031
                                        O🐯 @1412846703
                                        @1412846703 ros2不需要输入rosroce来跑小乌龟,直接输入ros2 run turtlesim turtlesim_node
                                        之后再开个命令行输入ros2 run turtlesim turtle_teleop_key就可以了。
                                        详见 https://zhuanlan.zhihu.com/p/481084074#:~:text=启动小乌龟仿真器: ros2 run turtlesim turtlesim_node 启动后可以看到一个仿真器:,另外需要打开一个终端,在里面运行键盘控制的节点,命令如下: ros2 run turtlesim turtle_teleop_key 正如打印信息所述,可以通过键盘上的方向箭头移动小乌龟,可以通过G|B|V|C|D|E|R|T这些按键进行旋转到一个绝对的方向,F取消旋转,Q退出。
                                          wesafe @1412846703
                                          @1412846703 解决了吗,我也是这个问题
