    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    649.8k
    • S
      sunhao2202 年度VIP @jerry_88965294
      @jerry_88965294 我这也是这个问题,后面都是这样的报错,建图一直跳
        小鱼 技术大佬 @sunhao2202
        @sunhao2202 您好,使用的是哪个版本的固件,网络质量如何
          小鱼 技术大佬 @sunhao2202
          @sunhao2202 在 [FishBot教程] 9.0.6. 雷达驱动及建图测试 中说:
          [ydlidar_node-2] [YDLIDAR ERROR]: -1 No error
          [ydlidar_node-2] [ERROR] [1735903928.417755598] [ydlidar_node]: Failed to get scan
          [ydlidar_node-2] [2025-01-03 11:32:08][error] Timeout count: 1
          [ydlidar_node-2] [2025-01-03 11:32:08][error] Check Sum 0x121C != 0x0233
          [ydlidar_node-2] [2025-01-03 11:32:34][error] Check Sum 0xB856 != 0x868F
          [ydlidar_node-2] [2025-01-03 11:32:34][error] Check Sum 0xBF44 != 0xD5E3
          [ydlidar_node-2] [2025-01-03 11:32:35][error] Check Sum 0x53E4 != 0x51BD
          [ydlidar_node-2] [2025-01-03 11:32:36][error] Check Sum 0xD974 != 0x87D3
          [ydlidar_node-2] [2025-01-03 11:32:50][error] Check Sum 0x1E40 != 0x0FDE
          [ydlidar_node-2] [YDLIDAR ERROR]: -1 Operation timed out
          [ydlidar_node-2] [ERROR] [1735903972.437430773] [ydlidar_node]: Failed to get scan
          [ydlidar_node-2] [2025-01-03 11:32:52][error] Timeout count: 1
          [ydlidar_node-2] [ERROR] [1735903973.437858047] [ydlidar_node]: Failed to get scan
          [ydlidar_node-2] [2025-01-03 11:32:53][error] Timeout count: 2
          [ydlidar_node-2] [2025-01-03 11:32:53][error] Check Sum 0x1A71 != 0x15AB
          [ydlidar_node-2] [INFO] [1735903974.800384796] [rclcpp]: signal_handler(signum=2)
          [ERROR] [tcp_server-1]: process has died [pid 59, exit code -2, cmd '/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server --ros-args --params-file /tmp/launch_params_s0dvbmtk --params-file /tmp/launch_params_4auj8l85'].
          [tcp_server-1] Traceback (most recent call last):
          [tcp_server-1] File "/workspace/install/ros_serail2wifi/lib/ros_serail2wifi/tcp_server", line 33, in <module>
          [tcp_server-1] sys.exit(load_entry_point('ros-serail2wifi==0.0.0', 'console_scripts', 'tcp_server')())
          [tcp_server-1] File "/workspace/install/ros_serail2wifi/lib/python3.10/site-packages/ros_serail2wifi/tcpserver.py", line 76, in main
          [tcp_server-1] node.run()
          驱动正常后再尝试建图
          S Y 2 条回复 最后回复 回复 引用 0
          • S
            sunhao2202 年度VIP @小鱼
            @小鱼 烧录最新固件,我再试试
            • Y
              yongyong @小鱼
              • Y
                yongyong @1216898523
                  小鱼 技术大佬 @yongyong
                  @yongyong 把代理删掉
                    大佬,启动建图的时候打不开rviz是怎么回事:
                    [cartographer_node-3] [INFO] [1736613946.687195477] [cartographer logger]: I0111 16:45:46.000000 63 map_builder_bridge.cpp:136] Added trajectory with ID '0'.
                    [ERROR] [rviz2-5]: process has died [pid 67, exit code -6, cmd '/opt/ros/humble/lib/rviz2/rviz2 -d /workspace/launch/config/map.rviz --ros-args -r __node:=rviz2 --params-file /tmp/launch_params_xs5a5ggo'].
                    [tcp_server-1] [INFO] [1736613946.745584663] [tcp_socket_server_node]: TCP端口:8888,已映射到串口设备:/tmp/tty_laser
                    1 小鱼小 2 条回复 最后回复 回复 引用 0
                      1270164455 @1270164455
                      @1270164455 de278539-390b-4953-92f4-832db3ea2f48-图片.png efcaaf13-b490-4dd1-acc8-3cb3732a7f4a-图片.png
                        @1270164455 单独可以打开
                          小鱼 技术大佬 @1270164455
                          @1270164455 我觉得是你的网络或者配置问题
                          • H
                            hxt22222
                            这是什么问题
                              小鱼 技术大佬 @hxt22222
                              @hxt22222 1是否正常,看一下视频教程
                              • 4
                                490439406
                                为何会出现checksum的问题呢?鱼佬
                                  小鱼 技术大佬 @490439406
                                  @490439406 一般情况下是网络原因造成的,可以尝试更换网络测试
                                  G 1 条回复 最后回复 回复 引用 0
                                  • G
                                    greg333 @小鱼
                                    @小鱼 小鱼老师,有两个问题求教:
                                    1.过程是我从桌面把机器人放到地面上,然后用键盘控制节点走了一小段,结果它整个建图都飘了,是因为历史记录的原因吗?那我应该怎样清除这些错乱数据呢?
                                    f8241d8b-0b39-412e-b6fa-2aec802369b4-Screenshot from 2025-02-18 17-22-55.png /home/greg/Pictures/Screenshots/Screenshot from 2025-02-18 17-22-55.png
                                    2.我在运行“驱动测试”、“建图测试”时都一直报一个check sum的error,且在运行建图测试时一直报下面的错误
                                    c2d505a4-ed27-4360-9c1a-9f8a9a81360e-Screenshot from 2025-02-18 17-23-33.png /home/greg/Pictures/Screenshots/Screenshot from 2025-02-18 17-23-33.png
                                    求解!
                                    • G
                                      greg333 @小鱼
                                      @小鱼 还有一个问题,我的雷达频率很小,只有1-5hz,是哪个流程可能有问题吗?1b9193b3-9a39-49f7-8309-860a0d5c0ffe-Screenshot from 2025-02-18 17-33-20.png /home/greg/Pictures/Screenshots/Screenshot from 2025-02-18 17-33-20.png
                                        小鱼 技术大佬 @greg333
                                        @greg333 ctrl+c 重新运行看看
                                        • G
                                          greg333 @小鱼
                                          @小鱼 小鱼老师,重新运行了好几次都是这样。好像确认是网络的问题了:我家是一根有线网络,连接到2.4g的网关这边;然后还有一个5gwifi,通过网线连接到网关。
                                          我两个网络都试过了,建图都飘的不行,我现在打算重新买个纯的2.4g路由器,通过网线连接网关,然后连接这个新的wifi试试。。
                                            小鱼 技术大佬 @greg333
                                            @greg333 ok
