    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    649.6k
      小鱼 技术大佬 @1281857896
      @1281857896 nav2的配置也贴一下
      12818578961 1 条回复 最后回复 回复 引用 0
      • 12818578961
        1281857896 @小鱼
        小鱼小 12818578961 2 条回复 最后回复 回复 引用 0
          小鱼 技术大佬 @1281857896
          @1281857896 求求了,不要截图不要截图,手机上一点都看不清,还不好复制粘贴
          • 12818578961
            1281857896 @1281857896
            @1281857896 基本没改啥,主要use_sim_time全都变成了false,然后把地图的膨胀半径减小,小车底盘的半径减小
            • 12818578961
              1281857896 @小鱼
              @小鱼 amcl:
              ros__parameters:
              use_sim_time: false
              alpha1: 0.2
              alpha2: 0.2
              alpha3: 0.2
              alpha4: 0.2
              alpha5: 0.2
              beam_skip_distance: 0.5
              beam_skip_threshold: 0.3
              do_beamskip: false
              global_frame_id: "map"
              lambda_short: 0.1
              laser_max_range: 100.0
              laser_min_range: -1.0
              max_beams: 60
              max_particles: 2000
              min_particles: 500
              odom_frame_id: "odom"
              pf_err: 0.05
              pf_z: 0.99
              recovery_alpha_fast: 0.0
              recovery_alpha_slow: 0.0
              resample_interval: 1
              robot_model_type: "nav2_amcl::DifferentialMotionModel"
              save_pose_rate: 0.5
              sigma_hit: 0.2
              tf_broadcast: true
              transform_tolerance: 1.0
              update_min_a: 0.2
              update_min_d: 0.25
              z_hit: 0.5
              z_max: 0.05
              z_rand: 0.5
              z_short: 0.05
              scan_topic: scan
              bt_navigator:
              ros__parameters:
              use_sim_time: false
              global_frame: map
              robot_base_frame: base_footprint
              odom_topic: /odom
              bt_loop_duration: 10
              default_server_timeout: 20
              plugin_lib_names:
              - nav2_smooth_path_action_bt_node
              - nav2_spin_action_bt_node
              - nav2_wait_action_bt_node
              - nav2_assisted_teleop_action_bt_node
              - nav2_back_up_action_bt_node
              - nav2_drive_on_heading_bt_node
              - nav2_globally_updated_goal_condition_bt_node
              - nav2_is_path_valid_condition_bt_node
              - nav2_truncate_path_local_action_bt_node
              - nav2_recovery_node_bt_node
              - nav2_path_expiring_timer_condition
              - nav2_single_trigger_bt_node
              - nav2_goal_updated_controller_bt_node
              - nav2_controller_cancel_bt_node
              - nav2_path_longer_on_approach_bt_node
              - nav2_wait_cancel_bt_node
              - nav2_spin_cancel_bt_node
              - nav2_back_up_cancel_bt_node
              - nav2_assisted_teleop_cancel_bt_node
              - nav2_drive_on_heading_cancel_bt_node
              - nav2_is_battery_charging_condition_bt_node
              bt_navigator_navigate_through_poses_rclcpp_node:
              ros__parameters:
              use_sim_time: false
              bt_navigator_navigate_to_pose_rclcpp_node:
              ros__parameters:
              use_sim_time: false
              controller_server:
              ros__parameters:
              use_sim_time: false
              controller_frequency: 20.0
              min_x_velocity_threshold: 0.001
              min_y_velocity_threshold: 0.5
              min_theta_velocity_threshold: 0.001
              failure_tolerance: 0.3
              progress_checker_plugin: "progress_checker"
              goal_checker_plugins: ["general_goal_checker"] # "precise_goal_checker"
              controller_plugins: ["FollowPath"]
              # Progress checker parameters
              progress_checker:
                plugin: "nav2_controller::SimpleProgressChecker"
                required_movement_radius: 0.5
                movement_time_allowance: 10.0
              # Goal checker parameters
              #precise_goal_checker:
              #  plugin: "nav2_controller::SimpleGoalChecker"
              #  xy_goal_tolerance: 0.25
              #  yaw_goal_tolerance: 0.25
              #  stateful: True
              general_goal_checker:
                stateful: True
              # DWB parameters
              FollowPath:
                plugin: "dwb_core::DWBLocalPlanner"
                debug_trajectory_details: True
                min_vel_x: 0.0
                min_vel_y: 0.0
                max_vel_x: 0.26
                max_vel_y: 0.0
                max_vel_theta: 1.0
                min_speed_xy: 0.0
                max_speed_xy: 0.26
                min_speed_theta: 0.0
                # Add high threshold velocity for turtlebot 3 issue.
                # https://github.com/ROBOTIS-GIT/turtlebot3_simulations/issues/75
                acc_lim_x: 2.5
                acc_lim_y: 0.0
                acc_lim_theta: 3.2
                decel_lim_x: -2.5
                decel_lim_y: 0.0
                decel_lim_theta: -3.2
                vx_samples: 20
                vy_samples: 5
                vtheta_samples: 20
                sim_time: 1.7
                linear_granularity: 0.05
                angular_granularity: 0.025
                transform_tolerance: 0.2
                trans_stopped_velocity: 0.25
                short_circuit_trajectory_evaluation: True
                stateful: True
                critics: ["RotateToGoal", "Oscillation", "BaseObstacle", "GoalAlign", "PathAlign", "PathDist", "GoalDist"]
                BaseObstacle.scale: 0.02
                PathAlign.scale: 32.0
                PathAlign.forward_point_distance: 0.1
                GoalAlign.scale: 24.0
                GoalAlign.forward_point_distance: 0.1
                PathDist.scale: 32.0
                GoalDist.scale: 24.0
                RotateToGoal.scale: 32.0
                RotateToGoal.slowing_factor: 5.0
                RotateToGoal.lookahead_time: -1.0
              local_costmap:
              local_costmap:
              ros__parameters:
              update_frequency: 5.0
              publish_frequency: 2.0
              global_frame: odom
              use_sim_time: false
              rolling_window: true
              width: 3
              height: 3
              resolution: 0.05
              robot_radius: 0.08
              plugins: ["voxel_layer", "inflation_layer"]
              inflation_layer:
              cost_scaling_factor: 3.0
              inflation_radius: 0.15
              voxel_layer:
              plugin: "nav2_costmap_2d::VoxelLayer"
              enabled: True
              publish_voxel_map: True
              origin_z: 0.0
              z_resolution: 0.05
              z_voxels: 16
              max_obstacle_height: 2.0
              mark_threshold: 0
              observation_sources: scan
              scan:
              topic: /scan
              clearing: True
              marking: True
              data_type: "LaserScan"
              raytrace_max_range: 3.0
              raytrace_min_range: 0.0
              obstacle_max_range: 2.5
              obstacle_min_range: 0.0
              static_layer:
              global_costmap:
              global_costmap:
              ros__parameters:
              update_frequency: 1.0
              publish_frequency: 1.0
              global_frame: map
              use_sim_time: false
              robot_radius: 0.08
              resolution: 0.05
              track_unknown_space: true
              obstacle_layer:
              enabled: True
              scan:
              topic: /scan
              clearing: True
              marking: True
              static_layer:
              inflation_layer:
              inflation_radius: 0.05
              map_server:
              ros__parameters:
              use_sim_time: false
              # Overridden in launch by the "map" launch configuration or provided default value.
              # To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
              yaml_filename: ""
              map_saver:
              ros__parameters:
              use_sim_time: false
              save_map_timeout: 5.0
              free_thresh_default: 0.25
              occupied_thresh_default: 0.65
              planner_server:
              ros__parameters:
              expected_planner_frequency: 20.0
              use_sim_time: false
              planner_plugins: ["GridBased"]
              GridBased:
              plugin: "nav2_navfn_planner/NavfnPlanner"
              tolerance: 0.5
              use_astar: false
              allow_unknown: true
              smoother_server:
              ros__parameters:
              use_sim_time: false
              smoother_plugins: ["simple_smoother"]
              simple_smoother:
              plugin: "nav2_smoother::SimpleSmoother"
              tolerance: 1.0e-10
              max_its: 1000
              do_refinement: True
              behavior_server:
              ros__parameters:
              costmap_topic: local_costmap/costmap_raw
              footprint_topic: local_costmap/published_footprint
              cycle_frequency: 10.0
              behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
              spin:
              plugin: "nav2_behaviors/Spin"
              backup:
              plugin: "nav2_behaviors/BackUp"
              drive_on_heading:
              plugin: "nav2_behaviors/DriveOnHeading"
              wait:
              plugin: "nav2_behaviors/Wait"
              assisted_teleop:
              plugin: "nav2_behaviors/AssistedTeleop"
              global_frame: odom
              transform_tolerance: 0.1
              use_sim_time: false
              simulate_ahead_time: 2.0
              max_rotational_vel: 1.0
              min_rotational_vel: 0.4
              rotational_acc_lim: 3.2
              robot_state_publisher:
              ros__parameters:
              use_sim_time: false
              waypoint_follower:
              ros__parameters:
              use_sim_time: false
              loop_rate: 20
              stop_on_failure: false
              waypoint_task_executor_plugin: "wait_at_waypoint"
              wait_at_waypoint:
              plugin: "nav2_waypoint_follower::WaitAtWaypoint"
              enabled: True
              waypoint_pause_duration: 200
              velocity_smoother:
              ros__parameters:
              use_sim_time: false
              smoothing_frequency: 20.0
              scale_velocities: False
              feedback: "OPEN_LOOP"
              max_velocity: [0.26, 0.0, 1.0]
              min_velocity: [-0.26, 0.0, -1.0]
              max_accel: [2.5, 0.0, 3.2]
              max_decel: [-2.5, 0.0, -3.2]
              odom_topic: "odom"
              odom_duration: 0.1
              deadband_velocity: [0.0, 0.0, 0.0]
              velocity_timeout: 1.0
              • 12818578961
                1281857896 @小鱼
                @小鱼 不好意思,这个没考虑到
                  小鱼 技术大佬 @1281857896
                  @1281857896 这个参数是哪里来的
                  • 12818578961
                    1281857896 @小鱼
                    @小鱼 第17章建图与导航实践 fishbot导航实现 fishbot导航实现那块安装了nav2功能包,然后从功能包里复制出来的参数就这么多,我刚打开功能包确实是这些参数
                    复制的时候用的下面这个命令
                    cp /opt/ros/$ROS_DISTRO/share/nav2_bringup/params/nav2_params.yaml src/fishbot_navigation2/config
                      小鱼 技术大佬 @1281857896
                      @1281857896 你从快速上手教程里拷贝试试,或者直接用快速上手教程里的导航配置跑跑,看看能不能跑起来
                        小鱼 技术大佬 @小鱼
                        @小鱼 有些参数不一样
                          小鱼 技术大佬 @小鱼
                          amcl:
                            ros__parameters:
                              use_sim_time: False
                              alpha1: 0.2
                              alpha2: 0.2
                              alpha3: 0.2
                              alpha4: 0.2
                              alpha5: 0.2
                              do_beamskip: false
                              lambda_short: 0.1
                              max_beams: 60
                              max_particles: 2000
                              min_particles: 500
                              pf_err: 0.05
                              pf_z: 0.99
                              robot_model_type: "differential"
                              save_pose_rate: 0.5
                              sigma_hit: 0.2
                              tf_broadcast: true
                              update_min_a: 0.2
                              update_min_d: 0.25
                              z_hit: 0.5
                              z_max: 0.05
                              z_rand: 0.5
                              z_short: 0.05
                          amcl_map_client:
                            ros__parameters:
                              use_sim_time: False
                          amcl_rclcpp_node:
                            ros__parameters:
                              use_sim_time: False
                          bt_navigator:
                            ros__parameters:
                              use_sim_time: False
                              global_frame: map
                              robot_base_frame: base_link
                              odom_topic: /odom
                              default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
                              plugin_lib_names:
                          bt_navigator_rclcpp_node:
                            ros__parameters:
                              use_sim_time: False
                          controller_server:
                            ros__parameters:
                              use_sim_time: False
                              controller_frequency: 10.0
                              # DWB parameters
                              FollowPath:
                                min_vel_x: 0.0
                                min_vel_y: 0.0
                                max_vel_x: 0.22
                                max_vel_y: 0.0
                                max_vel_theta: 0.8
                                min_speed_xy: 0.0
                                max_speed_xy: 0.44
                                acc_lim_x: 2.5
                                acc_lim_y: 0.0
                                acc_lim_theta: 0.2
                                decel_lim_x: -0.5
                                decel_lim_y: 0.0
                                decel_lim_theta: -0.5
                                vx_samples: 20
                                vy_samples: 0
                                vtheta_samples: 40
                                sim_time: 1.5
                                xy_goal_tolerance: 0.05
                                stateful: True
                          controller_server_rclcpp_node:
                            ros__parameters:
                              use_sim_time: False
                          local_costmap:
                            local_costmap:
                              ros__parameters:
                                global_frame: odom
                                use_sim_time: False
                                width: 3
                                height: 3
                                resolution: 0.05
                                robot_radius: 0.1
                                plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
                                inflation_layer:
                                  inflation_radius: 0.2
                                obstacle_layer:
                                  enabled: True
                                  scan:
                                    topic: /scan
                                    clearing: True
                                    marking: True
                                voxel_layer:
                                  enabled: True
                                  origin_z: 0.0
                                  z_resolution: 0.05
                                  z_voxels: 16
                                  mark_threshold: 0
                                  observation_sources: pointcloud
                                  pointcloud:
                                    topic: /intel_realsense_r200_depth/points
                                    clearing: True
                                    marking: True
                                    data_type: "PointCloud2"
                                static_layer:
                            local_costmap_client:
                              ros__parameters:
                                use_sim_time: False
                            local_costmap_rclcpp_node:
                              ros__parameters:
                                use_sim_time: False
                          global_costmap:
                            global_costmap:
                              ros__parameters:
                                global_frame: map
                                use_sim_time: False
                                robot_radius: 0.1
                                resolution: 0.05
                                plugins: ["static_layer", "obstacle_layer", "voxel_layer", "inflation_layer"]
                                obstacle_layer:
                                  enabled: True
                                  scan:
                                    topic: /scan
                                    clearing: True
                                    marking: True
                                voxel_layer:
                                  enabled: True
                                  origin_z: 0.0
                                  z_resolution: 0.05
                                  z_voxels: 16
                                  mark_threshold: 0
                                  pointcloud:
                                    clearing: True
                                    marking: True
                                static_layer:
                                inflation_layer:
                                  cost_scaling_factor: 1.0
                                  inflation_radius: 0.55
                            global_costmap_client:
                              ros__parameters:
                                use_sim_time: False
                            global_costmap_rclcpp_node:
                              ros__parameters:
                                use_sim_time: False
                          map_server:
                            ros__parameters:
                              use_sim_time: False
                              yaml_filename: "turtlebot3_world.yaml"
                          map_saver:
                            ros__parameters:
                              use_sim_time: False
                              save_map_timeout: 5000
                          planner_server:
                            ros__parameters:
                              use_sim_time: False
                              GridBased:
                                tolerance: 0.5
                                use_astar: false
                                allow_unknown: true
                          planner_server_rclcpp_node:
                            ros__parameters:
                              use_sim_time: False
                          recoveries_server:
                            ros__parameters:
                              recovery_plugins: ["spin", "backup", "wait"]
                              spin:
                                plugin: "nav2_recoveries/Spin"
                              backup:
                                plugin: "nav2_recoveries/BackUp"
                              wait:
                                plugin: "nav2_recoveries/Wait"
                              global_frame: odom
                              transform_timeout: 0.1
                              use_sim_time: False
                            ros__parameters:
                              use_sim_time: False
                          • 12818578961
                            1281857896 @小鱼
                            @小鱼 鱼哥,用最新的底板固件加上快速上手里面的fishbot.yaml可以很好实现导航,用那个fishbot_nav2.yaml就会加载不出地图,跑不了,应该是有缺东西
                            • 7754058937
                              775405893
                              第三步,话题里面有scan,但出现警告是怎么回事😲
                                小鱼 技术大佬 @1281857896
                                @1281857896 对比下文件区别,可能哪里不对劲的
                                  小鱼 技术大佬 @775405893
                                  @775405893 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                                  运行雷达的日志和上下文提供下
                                  7754058937 1 条回复 最后回复 回复 引用 0
                                  • 7754058937
                                    775405893 @小鱼
                                    小鱼小 2 条回复 最后回复 回复 引用 0
                                      小鱼 技术大佬 @775405893
                                      @775405893 系统信息提供下:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                                        小鱼 技术大佬 @775405893
                                        @775405893 雷达驱动意外挂了,重新运行下试试
                                        • 7754058937
                                          775405893 @小鱼
                                          @小鱼 ubuntu 24 ,ros2是jazzy版,虚拟机桥接,雷达连的电脑热点。重启了一下还是这个问题,雷达地址能ping通。
                                            小鱼 技术大佬 @775405893
                                            @775405893 估计是版本问题,docker里面是22.04的,最好主机也用22.04,教程也是22.04的,还会有坑等着你。你那里有书吗,书上有源码驱动雷达的方法,只能用这个了,或者你需要等一段时间(半个月左右),我抽空时间来适配下24.04系统。
