    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    802.7k
    • 12818578961
      1281857896 @1281857896
      @1281857896 基本没改啥,主要use_sim_time全都变成了false,然后把地图的膨胀半径减小,小车底盘的半径减小
      • 12818578961
        1281857896 @小鱼
        @小鱼 amcl:
        ros__parameters:
        use_sim_time: false
        alpha1: 0.2
        alpha2: 0.2
        alpha3: 0.2
        alpha4: 0.2
        alpha5: 0.2
        beam_skip_distance: 0.5
        beam_skip_threshold: 0.3
        do_beamskip: false
        global_frame_id: "map"
        lambda_short: 0.1
        laser_max_range: 100.0
        laser_min_range: -1.0
        max_beams: 60
        max_particles: 2000
        min_particles: 500
        odom_frame_id: "odom"
        pf_err: 0.05
        pf_z: 0.99
        recovery_alpha_fast: 0.0
        recovery_alpha_slow: 0.0
        resample_interval: 1
        save_pose_rate: 0.5
        sigma_hit: 0.2
        tf_broadcast: true
        transform_tolerance: 1.0
        update_min_a: 0.2
        update_min_d: 0.25
        z_hit: 0.5
        z_max: 0.05
        z_rand: 0.5
        z_short: 0.05
        scan_topic: scan
        bt_navigator:
        ros__parameters:
        use_sim_time: false
        global_frame: map
        robot_base_frame: base_footprint
        odom_topic: /odom
        bt_loop_duration: 10
        default_server_timeout: 20
        plugin_lib_names:
        - nav2_spin_action_bt_node
        - nav2_wait_action_bt_node
        - nav2_assisted_teleop_action_bt_node
        - nav2_back_up_action_bt_node
        - nav2_recovery_node_bt_node
        - nav2_single_trigger_bt_node
        - nav2_goal_updated_controller_bt_node
        - nav2_wait_cancel_bt_node
        - nav2_spin_cancel_bt_node
        - nav2_back_up_cancel_bt_node
        - nav2_assisted_teleop_cancel_bt_node
        - nav2_is_battery_charging_condition_bt_node
        bt_navigator_navigate_through_poses_rclcpp_node:
        ros__parameters:
        use_sim_time: false
        bt_navigator_navigate_to_pose_rclcpp_node:
        ros__parameters:
        use_sim_time: false
        controller_server:
        ros__parameters:
        use_sim_time: false
        controller_frequency: 20.0
        min_y_velocity_threshold: 0.5
        failure_tolerance: 0.3
        # Progress checker parameters
        progress_checker:
          required_movement_radius: 0.5
          movement_time_allowance: 10.0
        # Goal checker parameters
        #precise_goal_checker:
        #  xy_goal_tolerance: 0.25
        #  yaw_goal_tolerance: 0.25
        #  stateful: True
        general_goal_checker:
          stateful: True
        # DWB parameters
        FollowPath:
          min_vel_x: 0.0
          min_vel_y: 0.0
          max_vel_x: 0.26
          max_vel_y: 0.0
          max_vel_theta: 1.0
          min_speed_xy: 0.0
          max_speed_xy: 0.26
          min_speed_theta: 0.0
          acc_lim_x: 2.5
          acc_lim_y: 0.0
          acc_lim_theta: 3.2
          decel_lim_x: -2.5
          decel_lim_y: 0.0
          decel_lim_theta: -3.2
          vx_samples: 20
          vy_samples: 5
          vtheta_samples: 20
          sim_time: 1.7
          linear_granularity: 0.05
          angular_granularity: 0.025
          transform_tolerance: 0.2
          trans_stopped_velocity: 0.25
          stateful: True
          BaseObstacle.scale: 0.02
          PathAlign.scale: 32.0
          GoalAlign.scale: 24.0
          PathDist.scale: 32.0
          GoalDist.scale: 24.0
          RotateToGoal.scale: 32.0
        local_costmap:
        local_costmap:
        ros__parameters:
        update_frequency: 5.0
        publish_frequency: 2.0
        global_frame: odom
        use_sim_time: false
        rolling_window: true
        width: 3
        height: 3
        resolution: 0.05
        robot_radius: 0.08
        inflation_layer:
        cost_scaling_factor: 3.0
        inflation_radius: 0.15
        voxel_layer:
        enabled: True
        publish_voxel_map: True
        origin_z: 0.0
        z_resolution: 0.05
        z_voxels: 16
        max_obstacle_height: 2.0
        mark_threshold: 0
        observation_sources: scan
        scan:
        topic: /scan
        clearing: True
        marking: True
        data_type: "LaserScan"
        raytrace_max_range: 3.0
        raytrace_min_range: 0.0
        obstacle_max_range: 2.5
        obstacle_min_range: 0.0
        static_layer:
        global_costmap:
        global_costmap:
        ros__parameters:
        update_frequency: 1.0
        publish_frequency: 1.0
        global_frame: map
        use_sim_time: false
        robot_radius: 0.08
        resolution: 0.05
        track_unknown_space: true
        obstacle_layer:
        enabled: True
        scan:
        topic: /scan
        clearing: True
        marking: True
        static_layer:
        inflation_layer:
        inflation_radius: 0.05
        map_server:
        ros__parameters:
        use_sim_time: false
        # Overridden in launch by the "map" launch configuration or provided default value.
        # To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
        yaml_filename: ""
        map_saver:
        ros__parameters:
        use_sim_time: false
        save_map_timeout: 5.0
        free_thresh_default: 0.25
        occupied_thresh_default: 0.65
        planner_server:
        ros__parameters:
        use_sim_time: false
        GridBased:
        tolerance: 0.5
        use_astar: false
        allow_unknown: true
        smoother_server:
        ros__parameters:
        use_sim_time: false
        simple_smoother:
        tolerance: 1.0e-10
        max_its: 1000
        do_refinement: True
        behavior_server:
        ros__parameters:
        cycle_frequency: 10.0
        behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
        spin:
        plugin: "nav2_behaviors/Spin"
        backup:
        drive_on_heading:
        wait:
        plugin: "nav2_behaviors/Wait"
        assisted_teleop:
        plugin: "nav2_behaviors/AssistedTeleop"
        global_frame: odom
        transform_tolerance: 0.1
        use_sim_time: false
        simulate_ahead_time: 2.0
        max_rotational_vel: 1.0
        min_rotational_vel: 0.4
        rotational_acc_lim: 3.2
        robot_state_publisher:
        ros__parameters:
        use_sim_time: false
        waypoint_follower:
        ros__parameters:
        use_sim_time: false
        loop_rate: 20
        stop_on_failure: false
        wait_at_waypoint:
        enabled: True
        waypoint_pause_duration: 200
        velocity_smoother:
        ros__parameters:
        use_sim_time: false
        smoothing_frequency: 20.0
        scale_velocities: False
        feedback: "OPEN_LOOP"
        max_velocity: [0.26, 0.0, 1.0]
        min_velocity: [-0.26, 0.0, -1.0]
        max_accel: [2.5, 0.0, 3.2]
        max_decel: [-2.5, 0.0, -3.2]
        odom_topic: "odom"
        odom_duration: 0.1
        deadband_velocity: [0.0, 0.0, 0.0]
        velocity_timeout: 1.0
        • 12818578961
          1281857896 @小鱼
          @小鱼 不好意思,这个没考虑到
            小鱼 技术大佬 @1281857896
            @1281857896 这个参数是哪里来的
            • 12818578961
              1281857896 @小鱼
              @小鱼 第17章建图与导航实践 fishbot导航实现 fishbot导航实现那块安装了nav2功能包,然后从功能包里复制出来的参数就这么多,我刚打开功能包确实是这些参数
              复制的时候用的下面这个命令
              cp /opt/ros/$ROS_DISTRO/share/nav2_bringup/params/nav2_params.yaml src/fishbot_navigation2/config
                小鱼 技术大佬 @1281857896
                @1281857896 你从快速上手教程里拷贝试试,或者直接用快速上手教程里的导航配置跑跑,看看能不能跑起来
                  小鱼 技术大佬 @小鱼
                  @小鱼 有些参数不一样
                    小鱼 技术大佬 @小鱼
                    amcl:
                      ros__parameters:
                        use_sim_time: False
                        alpha1: 0.2
                        alpha2: 0.2
                        alpha3: 0.2
                        alpha4: 0.2
                        alpha5: 0.2
                        do_beamskip: false
                        lambda_short: 0.1
                        max_beams: 60
                        max_particles: 2000
                        min_particles: 500
                        pf_err: 0.05
                        pf_z: 0.99
                        robot_model_type: "differential"
                        save_pose_rate: 0.5
                        sigma_hit: 0.2
                        tf_broadcast: true
                        update_min_a: 0.2
                        update_min_d: 0.25
                        z_hit: 0.5
                        z_max: 0.05
                        z_rand: 0.5
                        z_short: 0.05
                    amcl_map_client:
                      ros__parameters:
                        use_sim_time: False
                    amcl_rclcpp_node:
                      ros__parameters:
                        use_sim_time: False
                    bt_navigator:
                      ros__parameters:
                        use_sim_time: False
                        global_frame: map
                        robot_base_frame: base_link
                        odom_topic: /odom
                        default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
                        plugin_lib_names:
                    bt_navigator_rclcpp_node:
                      ros__parameters:
                        use_sim_time: False
                    controller_server:
                      ros__parameters:
                        use_sim_time: False
                        controller_frequency: 10.0
                        # DWB parameters
                        FollowPath:
                          min_vel_x: 0.0
                          min_vel_y: 0.0
                          max_vel_x: 0.22
                          max_vel_y: 0.0
                          max_vel_theta: 0.8
                          min_speed_xy: 0.0
                          max_speed_xy: 0.44
                          acc_lim_x: 2.5
                          acc_lim_y: 0.0
                          acc_lim_theta: 0.2
                          decel_lim_x: -0.5
                          decel_lim_y: 0.0
                          decel_lim_theta: -0.5
                          vx_samples: 20
                          vy_samples: 0
                          vtheta_samples: 40
                          sim_time: 1.5
                          xy_goal_tolerance: 0.05
                          stateful: True
                      ros__parameters:
                        use_sim_time: False
                    local_costmap:
                      local_costmap:
                        ros__parameters:
                          global_frame: odom
                          use_sim_time: False
                          width: 3
                          height: 3
                          resolution: 0.05
                          robot_radius: 0.1
                          plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
                          inflation_layer:
                            inflation_radius: 0.2
                          obstacle_layer:
                            enabled: True
                            scan:
                              topic: /scan
                              clearing: True
                              marking: True
                          voxel_layer:
                            enabled: True
                            origin_z: 0.0
                            z_resolution: 0.05
                            z_voxels: 16
                            mark_threshold: 0
                            observation_sources: pointcloud
                            pointcloud:
                              topic: /intel_realsense_r200_depth/points
                              clearing: True
                              marking: True
                              data_type: "PointCloud2"
                          static_layer:
                      local_costmap_client:
                        ros__parameters:
                          use_sim_time: False
                      local_costmap_rclcpp_node:
                        ros__parameters:
                          use_sim_time: False
                    global_costmap:
                      global_costmap:
                        ros__parameters:
                          global_frame: map
                          use_sim_time: False
                          robot_radius: 0.1
                          resolution: 0.05
                          obstacle_layer:
                            enabled: True
                            scan:
                              topic: /scan
                              clearing: True
                              marking: True
                          voxel_layer:
                            enabled: True
                            origin_z: 0.0
                            z_resolution: 0.05
                            z_voxels: 16
                            mark_threshold: 0
                            pointcloud:
                              clearing: True
                              marking: True
                          static_layer:
                          inflation_layer:
                            cost_scaling_factor: 1.0
                            inflation_radius: 0.55
                      global_costmap_client:
                        ros__parameters:
                          use_sim_time: False
                      global_costmap_rclcpp_node:
                        ros__parameters:
                          use_sim_time: False
                    map_server:
                      ros__parameters:
                        use_sim_time: False
                    map_saver:
                      ros__parameters:
                        use_sim_time: False
                        save_map_timeout: 5000
                    planner_server:
                      ros__parameters:
                        use_sim_time: False
                        GridBased:
                          tolerance: 0.5
                          use_astar: false
                          allow_unknown: true
                    planner_server_rclcpp_node:
                      ros__parameters:
                        use_sim_time: False
                    recoveries_server:
                      ros__parameters:
                        recovery_plugins: ["spin", "backup", "wait"]
                        spin:
                          plugin: "nav2_recoveries/Spin"
                        backup:
                          plugin: "nav2_recoveries/BackUp"
                        wait:
                          plugin: "nav2_recoveries/Wait"
                        global_frame: odom
                        transform_timeout: 0.1
                        use_sim_time: False
                      ros__parameters:
                        use_sim_time: False
                    • 12818578961
                      1281857896 @小鱼
                      @小鱼 鱼哥,用最新的底板固件加上快速上手里面的fishbot.yaml可以很好实现导航,用那个fishbot_nav2.yaml就会加载不出地图,跑不了,应该是有缺东西
                      • 7754058937
                        775405893
                        第三步,话题里面有scan,但出现警告是怎么回事😲
                          小鱼 技术大佬 @1281857896
                          @1281857896 对比下文件区别,可能哪里不对劲的
                            小鱼 技术大佬 @775405893
                            @775405893 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                            运行雷达的日志和上下文提供下
                            7754058937 1 条回复 最后回复 回复 引用 0
                            • 7754058937
                              775405893 @小鱼
                                小鱼 技术大佬 @775405893
                                @775405893 系统信息提供下:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                                  小鱼 技术大佬 @775405893
                                  @775405893 雷达驱动意外挂了,重新运行下试试
                                  • 7754058937
                                    775405893 @小鱼
                                    @小鱼 ubuntu 24 ,ros2是jazzy版,虚拟机桥接,雷达连的电脑热点。重启了一下还是这个问题,雷达地址能ping通。
                                      小鱼 技术大佬 @775405893
                                      @775405893 估计是版本问题,docker里面是22.04的,最好主机也用22.04,教程也是22.04的,还会有坑等着你。你那里有书吗,书上有源码驱动雷达的方法,只能用这个了,或者你需要等一段时间(半个月左右),我抽空时间来适配下24.04系统。
                                      • 7754058937
                                        775405893 @小鱼
                                        @小鱼 好的谢谢,有书,我现在去翻一下😉
                                          小鱼 技术大佬 @775405893
                                          @775405893 第九章,你找找
                                          • 4
                                            466413819
                                            在ARM64架构下,ubuntu humble虚拟机
                                            zhao@zhao-virtual-machine:~$ xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 fishros2/fishbot_laser
                                            exec /bin/bash: exec format error
                                            请问小鱼有没有解决办法,有没有类似 miroros agent 的离线解决方案?
