    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    722.3k
    • 12818578961
      1281857896 @小鱼
      @小鱼 amcl:
      ros__parameters:
      use_sim_time: false
      alpha1: 0.2
      alpha2: 0.2
      alpha3: 0.2
      alpha4: 0.2
      alpha5: 0.2
      beam_skip_distance: 0.5
      beam_skip_threshold: 0.3
      do_beamskip: false
      global_frame_id: "map"
      lambda_short: 0.1
      laser_max_range: 100.0
      laser_min_range: -1.0
      max_beams: 60
      max_particles: 2000
      min_particles: 500
      odom_frame_id: "odom"
      pf_err: 0.05
      pf_z: 0.99
      recovery_alpha_fast: 0.0
      recovery_alpha_slow: 0.0
      resample_interval: 1
      save_pose_rate: 0.5
      sigma_hit: 0.2
      tf_broadcast: true
      transform_tolerance: 1.0
      update_min_a: 0.2
      update_min_d: 0.25
      z_hit: 0.5
      z_max: 0.05
      z_rand: 0.5
      z_short: 0.05
      scan_topic: scan
      bt_navigator:
      ros__parameters:
      use_sim_time: false
      global_frame: map
      robot_base_frame: base_footprint
      odom_topic: /odom
      bt_loop_duration: 10
      default_server_timeout: 20
      plugin_lib_names:
      - nav2_spin_action_bt_node
      - nav2_wait_action_bt_node
      - nav2_assisted_teleop_action_bt_node
      - nav2_back_up_action_bt_node
      - nav2_recovery_node_bt_node
      - nav2_single_trigger_bt_node
      - nav2_goal_updated_controller_bt_node
      - nav2_wait_cancel_bt_node
      - nav2_spin_cancel_bt_node
      - nav2_back_up_cancel_bt_node
      - nav2_assisted_teleop_cancel_bt_node
      - nav2_is_battery_charging_condition_bt_node
      bt_navigator_navigate_through_poses_rclcpp_node:
      ros__parameters:
      use_sim_time: false
      bt_navigator_navigate_to_pose_rclcpp_node:
      ros__parameters:
      use_sim_time: false
      controller_server:
      ros__parameters:
      use_sim_time: false
      controller_frequency: 20.0
      min_y_velocity_threshold: 0.5
      failure_tolerance: 0.3
      # Progress checker parameters
      progress_checker:
        required_movement_radius: 0.5
        movement_time_allowance: 10.0
      # Goal checker parameters
      #precise_goal_checker:
      #  xy_goal_tolerance: 0.25
      #  yaw_goal_tolerance: 0.25
      #  stateful: True
      general_goal_checker:
        stateful: True
      # DWB parameters
      FollowPath:
        min_vel_x: 0.0
        min_vel_y: 0.0
        max_vel_x: 0.26
        max_vel_y: 0.0
        max_vel_theta: 1.0
        min_speed_xy: 0.0
        max_speed_xy: 0.26
        min_speed_theta: 0.0
        acc_lim_x: 2.5
        acc_lim_y: 0.0
        acc_lim_theta: 3.2
        decel_lim_x: -2.5
        decel_lim_y: 0.0
        decel_lim_theta: -3.2
        vx_samples: 20
        vy_samples: 5
        vtheta_samples: 20
        sim_time: 1.7
        linear_granularity: 0.05
        angular_granularity: 0.025
        transform_tolerance: 0.2
        trans_stopped_velocity: 0.25
        stateful: True
        BaseObstacle.scale: 0.02
        PathAlign.scale: 32.0
        GoalAlign.scale: 24.0
        PathDist.scale: 32.0
        GoalDist.scale: 24.0
        RotateToGoal.scale: 32.0
      local_costmap:
      local_costmap:
      ros__parameters:
      update_frequency: 5.0
      publish_frequency: 2.0
      global_frame: odom
      use_sim_time: false
      rolling_window: true
      width: 3
      height: 3
      resolution: 0.05
      robot_radius: 0.08
      inflation_layer:
      cost_scaling_factor: 3.0
      inflation_radius: 0.15
      voxel_layer:
      enabled: True
      publish_voxel_map: True
      origin_z: 0.0
      z_resolution: 0.05
      z_voxels: 16
      max_obstacle_height: 2.0
      mark_threshold: 0
      observation_sources: scan
      scan:
      topic: /scan
      clearing: True
      marking: True
      data_type: "LaserScan"
      raytrace_max_range: 3.0
      raytrace_min_range: 0.0
      obstacle_max_range: 2.5
      obstacle_min_range: 0.0
      static_layer:
      global_costmap:
      global_costmap:
      ros__parameters:
      update_frequency: 1.0
      publish_frequency: 1.0
      global_frame: map
      use_sim_time: false
      robot_radius: 0.08
      resolution: 0.05
      track_unknown_space: true
      obstacle_layer:
      enabled: True
      scan:
      topic: /scan
      clearing: True
      marking: True
      static_layer:
      inflation_layer:
      inflation_radius: 0.05
      map_server:
      ros__parameters:
      use_sim_time: false
      # Overridden in launch by the "map" launch configuration or provided default value.
      # To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
      yaml_filename: ""
      map_saver:
      ros__parameters:
      use_sim_time: false
      save_map_timeout: 5.0
      free_thresh_default: 0.25
      occupied_thresh_default: 0.65
      planner_server:
      ros__parameters:
      use_sim_time: false
      GridBased:
      tolerance: 0.5
      use_astar: false
      allow_unknown: true
      smoother_server:
      ros__parameters:
      use_sim_time: false
      simple_smoother:
      tolerance: 1.0e-10
      max_its: 1000
      do_refinement: True
      behavior_server:
      ros__parameters:
      cycle_frequency: 10.0
      behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
      spin:
      plugin: "nav2_behaviors/Spin"
      backup:
      drive_on_heading:
      wait:
      plugin: "nav2_behaviors/Wait"
      assisted_teleop:
      plugin: "nav2_behaviors/AssistedTeleop"
      global_frame: odom
      transform_tolerance: 0.1
      use_sim_time: false
      simulate_ahead_time: 2.0
      max_rotational_vel: 1.0
      min_rotational_vel: 0.4
      rotational_acc_lim: 3.2
      robot_state_publisher:
      ros__parameters:
      use_sim_time: false
      waypoint_follower:
      ros__parameters:
      use_sim_time: false
      loop_rate: 20
      stop_on_failure: false
      wait_at_waypoint:
      enabled: True
      waypoint_pause_duration: 200
      velocity_smoother:
      ros__parameters:
      use_sim_time: false
      smoothing_frequency: 20.0
      scale_velocities: False
      feedback: "OPEN_LOOP"
      max_velocity: [0.26, 0.0, 1.0]
      min_velocity: [-0.26, 0.0, -1.0]
      max_accel: [2.5, 0.0, 3.2]
      max_decel: [-2.5, 0.0, -3.2]
      odom_topic: "odom"
      odom_duration: 0.1
      deadband_velocity: [0.0, 0.0, 0.0]
      velocity_timeout: 1.0
      • 12818578961
        1281857896 @小鱼
        @小鱼 不好意思,这个没考虑到
          小鱼 技术大佬 @1281857896
          @1281857896 这个参数是哪里来的
          • 12818578961
            1281857896 @小鱼
            @小鱼 第17章建图与导航实践 fishbot导航实现 fishbot导航实现那块安装了nav2功能包,然后从功能包里复制出来的参数就这么多,我刚打开功能包确实是这些参数
            复制的时候用的下面这个命令
            cp /opt/ros/$ROS_DISTRO/share/nav2_bringup/params/nav2_params.yaml src/fishbot_navigation2/config
              小鱼 技术大佬 @1281857896
              @1281857896 你从快速上手教程里拷贝试试,或者直接用快速上手教程里的导航配置跑跑,看看能不能跑起来
                小鱼 技术大佬 @小鱼
                @小鱼 有些参数不一样
                  小鱼 技术大佬 @小鱼
                  amcl:
                    ros__parameters:
                      use_sim_time: False
                      alpha1: 0.2
                      alpha2: 0.2
                      alpha3: 0.2
                      alpha4: 0.2
                      alpha5: 0.2
                      do_beamskip: false
                      lambda_short: 0.1
                      max_beams: 60
                      max_particles: 2000
                      min_particles: 500
                      pf_err: 0.05
                      pf_z: 0.99
                      robot_model_type: "differential"
                      save_pose_rate: 0.5
                      sigma_hit: 0.2
                      tf_broadcast: true
                      update_min_a: 0.2
                      update_min_d: 0.25
                      z_hit: 0.5
                      z_max: 0.05
                      z_rand: 0.5
                      z_short: 0.05
                  amcl_map_client:
                    ros__parameters:
                      use_sim_time: False
                  amcl_rclcpp_node:
                    ros__parameters:
                      use_sim_time: False
                  bt_navigator:
                    ros__parameters:
                      use_sim_time: False
                      global_frame: map
                      robot_base_frame: base_link
                      odom_topic: /odom
                      default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
                      plugin_lib_names:
                  bt_navigator_rclcpp_node:
                    ros__parameters:
                      use_sim_time: False
                  controller_server:
                    ros__parameters:
                      use_sim_time: False
                      controller_frequency: 10.0
                      # DWB parameters
                      FollowPath:
                        min_vel_x: 0.0
                        min_vel_y: 0.0
                        max_vel_x: 0.22
                        max_vel_y: 0.0
                        max_vel_theta: 0.8
                        min_speed_xy: 0.0
                        max_speed_xy: 0.44
                        acc_lim_x: 2.5
                        acc_lim_y: 0.0
                        acc_lim_theta: 0.2
                        decel_lim_x: -0.5
                        decel_lim_y: 0.0
                        decel_lim_theta: -0.5
                        vx_samples: 20
                        vy_samples: 0
                        vtheta_samples: 40
                        sim_time: 1.5
                        xy_goal_tolerance: 0.05
                        stateful: True
                    ros__parameters:
                      use_sim_time: False
                  local_costmap:
                    local_costmap:
                      ros__parameters:
                        global_frame: odom
                        use_sim_time: False
                        width: 3
                        height: 3
                        resolution: 0.05
                        robot_radius: 0.1
                        plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
                        inflation_layer:
                          inflation_radius: 0.2
                        obstacle_layer:
                          enabled: True
                          scan:
                            topic: /scan
                            clearing: True
                            marking: True
                        voxel_layer:
                          enabled: True
                          origin_z: 0.0
                          z_resolution: 0.05
                          z_voxels: 16
                          mark_threshold: 0
                          observation_sources: pointcloud
                          pointcloud:
                            topic: /intel_realsense_r200_depth/points
                            clearing: True
                            marking: True
                            data_type: "PointCloud2"
                        static_layer:
                    local_costmap_client:
                      ros__parameters:
                        use_sim_time: False
                    local_costmap_rclcpp_node:
                      ros__parameters:
                        use_sim_time: False
                  global_costmap:
                    global_costmap:
                      ros__parameters:
                        global_frame: map
                        use_sim_time: False
                        robot_radius: 0.1
                        resolution: 0.05
                        obstacle_layer:
                          enabled: True
                          scan:
                            topic: /scan
                            clearing: True
                            marking: True
                        voxel_layer:
                          enabled: True
                          origin_z: 0.0
                          z_resolution: 0.05
                          z_voxels: 16
                          mark_threshold: 0
                          pointcloud:
                            clearing: True
                            marking: True
                        static_layer:
                        inflation_layer:
                          cost_scaling_factor: 1.0
                          inflation_radius: 0.55
                    global_costmap_client:
                      ros__parameters:
                        use_sim_time: False
                    global_costmap_rclcpp_node:
                      ros__parameters:
                        use_sim_time: False
                  map_server:
                    ros__parameters:
                      use_sim_time: False
                  map_saver:
                    ros__parameters:
                      use_sim_time: False
                      save_map_timeout: 5000
                  planner_server:
                    ros__parameters:
                      use_sim_time: False
                      GridBased:
                        tolerance: 0.5
                        use_astar: false
                        allow_unknown: true
                  planner_server_rclcpp_node:
                    ros__parameters:
                      use_sim_time: False
                  recoveries_server:
                    ros__parameters:
                      recovery_plugins: ["spin", "backup", "wait"]
                      spin:
                        plugin: "nav2_recoveries/Spin"
                      backup:
                        plugin: "nav2_recoveries/BackUp"
                      wait:
                        plugin: "nav2_recoveries/Wait"
                      global_frame: odom
                      transform_timeout: 0.1
                      use_sim_time: False
                    ros__parameters:
                      use_sim_time: False
                  • 12818578961
                    1281857896 @小鱼
                    @小鱼 鱼哥,用最新的底板固件加上快速上手里面的fishbot.yaml可以很好实现导航,用那个fishbot_nav2.yaml就会加载不出地图,跑不了,应该是有缺东西
                    • 7754058937
                      775405893
                      第三步,话题里面有scan,但出现警告是怎么回事😲
                        小鱼 技术大佬 @1281857896
                        @1281857896 对比下文件区别,可能哪里不对劲的
                          小鱼 技术大佬 @775405893
                          @775405893 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                          运行雷达的日志和上下文提供下
                          7754058937 1 条回复 最后回复 回复 引用 0
                          • 7754058937
                            775405893 @小鱼
                              小鱼 技术大佬 @775405893
                              @775405893 系统信息提供下:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                                小鱼 技术大佬 @775405893
                                @775405893 雷达驱动意外挂了,重新运行下试试
                                • 7754058937
                                  775405893 @小鱼
                                  @小鱼 ubuntu 24 ,ros2是jazzy版,虚拟机桥接,雷达连的电脑热点。重启了一下还是这个问题,雷达地址能ping通。
                                    小鱼 技术大佬 @775405893
                                    @775405893 估计是版本问题,docker里面是22.04的,最好主机也用22.04,教程也是22.04的,还会有坑等着你。你那里有书吗,书上有源码驱动雷达的方法,只能用这个了,或者你需要等一段时间(半个月左右),我抽空时间来适配下24.04系统。
                                    • 7754058937
                                      775405893 @小鱼
                                      @小鱼 好的谢谢,有书,我现在去翻一下😉
                                        小鱼 技术大佬 @775405893
                                        @775405893 第九章,你找找
                                        • 4
                                          466413819
                                          在ARM64架构下,ubuntu humble虚拟机
                                          zhao@zhao-virtual-machine:~$ xhost + && sudo docker run -it --rm -v /dev:/dev -v /dev/shm:/dev/shm --privileged -v /tmp/.X11-unix:/tmp/.X11-unix --device /dev/snd -e DISPLAY=unix$DISPLAY -p 8889:8888 fishros2/fishbot_laser
                                          exec /bin/bash: exec format error
                                          请问小鱼有没有解决办法,有没有类似 miroros agent 的离线解决方案?
                                            小鱼 技术大佬 @466413819
                                            @466413819 arm架构下不支持这个镜像,需要按照
                                            拓展1:FishBot配套雷达驱动教程(源码版)
                                            拓展3:FishBot 树莓派配置建图导航
