    [FishBot教程] 9.0.6. 雷达驱动及建图测试
    fishbot 建图
    66
    223
    722.6k
    • 12818578961
      1281857896 @小鱼
      @小鱼 等会尝试一下,好家伙,串话题了,刚才不是在那个问题吗
        小鱼 技术大佬 @1281857896
        @1281857896 odom到base_footprint部分代码应该有吧,里面有时间相关的操作。
        可以把左边的+1.0上去看看
        • 12818578961
          1281857896 @小鱼
          @小鱼 好的.......
            小鱼 技术大佬 @1281857896
            @1281857896 nav2的配置也贴一下
            • 12818578961
              1281857896 @小鱼
                小鱼 技术大佬 @1281857896
                @1281857896 求求了,不要截图不要截图,手机上一点都看不清,还不好复制粘贴
                • 12818578961
                  1281857896 @1281857896
                  @1281857896 基本没改啥,主要use_sim_time全都变成了false,然后把地图的膨胀半径减小,小车底盘的半径减小
                  • 12818578961
                    1281857896 @小鱼
                    @小鱼 amcl:
                    ros__parameters:
                    use_sim_time: false
                    alpha1: 0.2
                    alpha2: 0.2
                    alpha3: 0.2
                    alpha4: 0.2
                    alpha5: 0.2
                    beam_skip_distance: 0.5
                    beam_skip_threshold: 0.3
                    do_beamskip: false
                    global_frame_id: "map"
                    lambda_short: 0.1
                    laser_max_range: 100.0
                    laser_min_range: -1.0
                    max_beams: 60
                    max_particles: 2000
                    min_particles: 500
                    odom_frame_id: "odom"
                    pf_err: 0.05
                    pf_z: 0.99
                    recovery_alpha_fast: 0.0
                    recovery_alpha_slow: 0.0
                    resample_interval: 1
                    save_pose_rate: 0.5
                    sigma_hit: 0.2
                    tf_broadcast: true
                    transform_tolerance: 1.0
                    update_min_a: 0.2
                    update_min_d: 0.25
                    z_hit: 0.5
                    z_max: 0.05
                    z_rand: 0.5
                    z_short: 0.05
                    scan_topic: scan
                    bt_navigator:
                    ros__parameters:
                    use_sim_time: false
                    global_frame: map
                    robot_base_frame: base_footprint
                    odom_topic: /odom
                    bt_loop_duration: 10
                    default_server_timeout: 20
                    plugin_lib_names:
                    - nav2_spin_action_bt_node
                    - nav2_wait_action_bt_node
                    - nav2_assisted_teleop_action_bt_node
                    - nav2_back_up_action_bt_node
                    - nav2_recovery_node_bt_node
                    - nav2_single_trigger_bt_node
                    - nav2_goal_updated_controller_bt_node
                    - nav2_wait_cancel_bt_node
                    - nav2_spin_cancel_bt_node
                    - nav2_back_up_cancel_bt_node
                    - nav2_assisted_teleop_cancel_bt_node
                    - nav2_is_battery_charging_condition_bt_node
                    bt_navigator_navigate_through_poses_rclcpp_node:
                    ros__parameters:
                    use_sim_time: false
                    bt_navigator_navigate_to_pose_rclcpp_node:
                    ros__parameters:
                    use_sim_time: false
                    controller_server:
                    ros__parameters:
                    use_sim_time: false
                    controller_frequency: 20.0
                    min_y_velocity_threshold: 0.5
                    failure_tolerance: 0.3
                    # Progress checker parameters
                    progress_checker:
                      required_movement_radius: 0.5
                      movement_time_allowance: 10.0
                    # Goal checker parameters
                    #precise_goal_checker:
                    #  xy_goal_tolerance: 0.25
                    #  yaw_goal_tolerance: 0.25
                    #  stateful: True
                    general_goal_checker:
                      stateful: True
                    # DWB parameters
                    FollowPath:
                      min_vel_x: 0.0
                      min_vel_y: 0.0
                      max_vel_x: 0.26
                      max_vel_y: 0.0
                      max_vel_theta: 1.0
                      min_speed_xy: 0.0
                      max_speed_xy: 0.26
                      min_speed_theta: 0.0
                      acc_lim_x: 2.5
                      acc_lim_y: 0.0
                      acc_lim_theta: 3.2
                      decel_lim_x: -2.5
                      decel_lim_y: 0.0
                      decel_lim_theta: -3.2
                      vx_samples: 20
                      vy_samples: 5
                      vtheta_samples: 20
                      sim_time: 1.7
                      linear_granularity: 0.05
                      angular_granularity: 0.025
                      transform_tolerance: 0.2
                      trans_stopped_velocity: 0.25
                      stateful: True
                      BaseObstacle.scale: 0.02
                      PathAlign.scale: 32.0
                      GoalAlign.scale: 24.0
                      PathDist.scale: 32.0
                      GoalDist.scale: 24.0
                      RotateToGoal.scale: 32.0
                    local_costmap:
                    local_costmap:
                    ros__parameters:
                    update_frequency: 5.0
                    publish_frequency: 2.0
                    global_frame: odom
                    use_sim_time: false
                    rolling_window: true
                    width: 3
                    height: 3
                    resolution: 0.05
                    robot_radius: 0.08
                    inflation_layer:
                    cost_scaling_factor: 3.0
                    inflation_radius: 0.15
                    voxel_layer:
                    enabled: True
                    publish_voxel_map: True
                    origin_z: 0.0
                    z_resolution: 0.05
                    z_voxels: 16
                    max_obstacle_height: 2.0
                    mark_threshold: 0
                    observation_sources: scan
                    scan:
                    topic: /scan
                    clearing: True
                    marking: True
                    data_type: "LaserScan"
                    raytrace_max_range: 3.0
                    raytrace_min_range: 0.0
                    obstacle_max_range: 2.5
                    obstacle_min_range: 0.0
                    static_layer:
                    global_costmap:
                    global_costmap:
                    ros__parameters:
                    update_frequency: 1.0
                    publish_frequency: 1.0
                    global_frame: map
                    use_sim_time: false
                    robot_radius: 0.08
                    resolution: 0.05
                    track_unknown_space: true
                    obstacle_layer:
                    enabled: True
                    scan:
                    topic: /scan
                    clearing: True
                    marking: True
                    static_layer:
                    inflation_layer:
                    inflation_radius: 0.05
                    map_server:
                    ros__parameters:
                    use_sim_time: false
                    # Overridden in launch by the "map" launch configuration or provided default value.
                    # To use in yaml, remove the default "map" value in the tb3_simulation_launch.py file & provide full path to map below.
                    yaml_filename: ""
                    map_saver:
                    ros__parameters:
                    use_sim_time: false
                    save_map_timeout: 5.0
                    free_thresh_default: 0.25
                    occupied_thresh_default: 0.65
                    planner_server:
                    ros__parameters:
                    use_sim_time: false
                    GridBased:
                    tolerance: 0.5
                    use_astar: false
                    allow_unknown: true
                    smoother_server:
                    ros__parameters:
                    use_sim_time: false
                    simple_smoother:
                    tolerance: 1.0e-10
                    max_its: 1000
                    do_refinement: True
                    behavior_server:
                    ros__parameters:
                    cycle_frequency: 10.0
                    behavior_plugins: ["spin", "backup", "drive_on_heading", "assisted_teleop", "wait"]
                    spin:
                    plugin: "nav2_behaviors/Spin"
                    backup:
                    drive_on_heading:
                    wait:
                    plugin: "nav2_behaviors/Wait"
                    assisted_teleop:
                    plugin: "nav2_behaviors/AssistedTeleop"
                    global_frame: odom
                    transform_tolerance: 0.1
                    use_sim_time: false
                    simulate_ahead_time: 2.0
                    max_rotational_vel: 1.0
                    min_rotational_vel: 0.4
                    rotational_acc_lim: 3.2
                    robot_state_publisher:
                    ros__parameters:
                    use_sim_time: false
                    waypoint_follower:
                    ros__parameters:
                    use_sim_time: false
                    loop_rate: 20
                    stop_on_failure: false
                    wait_at_waypoint:
                    enabled: True
                    waypoint_pause_duration: 200
                    velocity_smoother:
                    ros__parameters:
                    use_sim_time: false
                    smoothing_frequency: 20.0
                    scale_velocities: False
                    feedback: "OPEN_LOOP"
                    max_velocity: [0.26, 0.0, 1.0]
                    min_velocity: [-0.26, 0.0, -1.0]
                    max_accel: [2.5, 0.0, 3.2]
                    max_decel: [-2.5, 0.0, -3.2]
                    odom_topic: "odom"
                    odom_duration: 0.1
                    deadband_velocity: [0.0, 0.0, 0.0]
                    velocity_timeout: 1.0
                    • 12818578961
                      1281857896 @小鱼
                      @小鱼 不好意思,这个没考虑到
                        小鱼 技术大佬 @1281857896
                        @1281857896 这个参数是哪里来的
                        • 12818578961
                          1281857896 @小鱼
                          @小鱼 第17章建图与导航实践 fishbot导航实现 fishbot导航实现那块安装了nav2功能包,然后从功能包里复制出来的参数就这么多,我刚打开功能包确实是这些参数
                          复制的时候用的下面这个命令
                          cp /opt/ros/$ROS_DISTRO/share/nav2_bringup/params/nav2_params.yaml src/fishbot_navigation2/config
                            小鱼 技术大佬 @1281857896
                            @1281857896 你从快速上手教程里拷贝试试,或者直接用快速上手教程里的导航配置跑跑,看看能不能跑起来
                              小鱼 技术大佬 @小鱼
                              @小鱼 有些参数不一样
                                小鱼 技术大佬 @小鱼
                                amcl:
                                  ros__parameters:
                                    use_sim_time: False
                                    alpha1: 0.2
                                    alpha2: 0.2
                                    alpha3: 0.2
                                    alpha4: 0.2
                                    alpha5: 0.2
                                    do_beamskip: false
                                    lambda_short: 0.1
                                    max_beams: 60
                                    max_particles: 2000
                                    min_particles: 500
                                    pf_err: 0.05
                                    pf_z: 0.99
                                    robot_model_type: "differential"
                                    save_pose_rate: 0.5
                                    sigma_hit: 0.2
                                    tf_broadcast: true
                                    update_min_a: 0.2
                                    update_min_d: 0.25
                                    z_hit: 0.5
                                    z_max: 0.05
                                    z_rand: 0.5
                                    z_short: 0.05
                                amcl_map_client:
                                  ros__parameters:
                                    use_sim_time: False
                                amcl_rclcpp_node:
                                  ros__parameters:
                                    use_sim_time: False
                                bt_navigator:
                                  ros__parameters:
                                    use_sim_time: False
                                    global_frame: map
                                    robot_base_frame: base_link
                                    odom_topic: /odom
                                    default_bt_xml_filename: "navigate_w_replanning_and_recovery.xml"
                                    plugin_lib_names:
                                bt_navigator_rclcpp_node:
                                  ros__parameters:
                                    use_sim_time: False
                                controller_server:
                                  ros__parameters:
                                    use_sim_time: False
                                    controller_frequency: 10.0
                                    # DWB parameters
                                    FollowPath:
                                      min_vel_x: 0.0
                                      min_vel_y: 0.0
                                      max_vel_x: 0.22
                                      max_vel_y: 0.0
                                      max_vel_theta: 0.8
                                      min_speed_xy: 0.0
                                      max_speed_xy: 0.44
                                      acc_lim_x: 2.5
                                      acc_lim_y: 0.0
                                      acc_lim_theta: 0.2
                                      decel_lim_x: -0.5
                                      decel_lim_y: 0.0
                                      decel_lim_theta: -0.5
                                      vx_samples: 20
                                      vy_samples: 0
                                      vtheta_samples: 40
                                      sim_time: 1.5
                                      xy_goal_tolerance: 0.05
                                      stateful: True
                                  ros__parameters:
                                    use_sim_time: False
                                local_costmap:
                                  local_costmap:
                                    ros__parameters:
                                      global_frame: odom
                                      use_sim_time: False
                                      width: 3
                                      height: 3
                                      resolution: 0.05
                                      robot_radius: 0.1
                                      plugins: ["obstacle_layer", "voxel_layer", "inflation_layer"]
                                      inflation_layer:
                                        inflation_radius: 0.2
                                      obstacle_layer:
                                        enabled: True
                                        scan:
                                          topic: /scan
                                          clearing: True
                                          marking: True
                                      voxel_layer:
                                        enabled: True
                                        origin_z: 0.0
                                        z_resolution: 0.05
                                        z_voxels: 16
                                        mark_threshold: 0
                                        observation_sources: pointcloud
                                        pointcloud:
                                          topic: /intel_realsense_r200_depth/points
                                          clearing: True
                                          marking: True
                                          data_type: "PointCloud2"
                                      static_layer:
                                  local_costmap_client:
                                    ros__parameters:
                                      use_sim_time: False
                                  local_costmap_rclcpp_node:
                                    ros__parameters:
                                      use_sim_time: False
                                global_costmap:
                                  global_costmap:
                                    ros__parameters:
                                      global_frame: map
                                      use_sim_time: False
                                      robot_radius: 0.1
                                      resolution: 0.05
                                      obstacle_layer:
                                        enabled: True
                                        scan:
                                          topic: /scan
                                          clearing: True
                                          marking: True
                                      voxel_layer:
                                        enabled: True
                                        origin_z: 0.0
                                        z_resolution: 0.05
                                        z_voxels: 16
                                        mark_threshold: 0
                                        pointcloud:
                                          clearing: True
                                          marking: True
                                      static_layer:
                                      inflation_layer:
                                        cost_scaling_factor: 1.0
                                        inflation_radius: 0.55
                                  global_costmap_client:
                                    ros__parameters:
                                      use_sim_time: False
                                  global_costmap_rclcpp_node:
                                    ros__parameters:
                                      use_sim_time: False
                                map_server:
                                  ros__parameters:
                                    use_sim_time: False
                                map_saver:
                                  ros__parameters:
                                    use_sim_time: False
                                    save_map_timeout: 5000
                                planner_server:
                                  ros__parameters:
                                    use_sim_time: False
                                    GridBased:
                                      tolerance: 0.5
                                      use_astar: false
                                      allow_unknown: true
                                planner_server_rclcpp_node:
                                  ros__parameters:
                                    use_sim_time: False
                                recoveries_server:
                                  ros__parameters:
                                    recovery_plugins: ["spin", "backup", "wait"]
                                    spin:
                                      plugin: "nav2_recoveries/Spin"
                                    backup:
                                      plugin: "nav2_recoveries/BackUp"
                                    wait:
                                      plugin: "nav2_recoveries/Wait"
                                    global_frame: odom
                                    transform_timeout: 0.1
                                    use_sim_time: False
                                  ros__parameters:
                                    use_sim_time: False
                                • 12818578961
                                  1281857896 @小鱼
                                  @小鱼 鱼哥,用最新的底板固件加上快速上手里面的fishbot.yaml可以很好实现导航,用那个fishbot_nav2.yaml就会加载不出地图,跑不了,应该是有缺东西
                                  • 7754058937
                                    775405893
                                    第三步,话题里面有scan,但出现警告是怎么回事😲
                                      小鱼 技术大佬 @1281857896
                                      @1281857896 对比下文件区别,可能哪里不对劲的
                                        小鱼 技术大佬 @775405893
                                        @775405893 https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
                                        运行雷达的日志和上下文提供下
                                        7754058937 1 条回复 最后回复 回复 引用 0
                                        • 7754058937
                                          775405893 @小鱼
                                            小鱼 技术大佬 @775405893
                                            @775405893 系统信息提供下:https://fishros.org.cn/forum/topic/151/提问前必看-不符合要求的问题拒绝回答
